View Full Version : Acura Integra
- buddy club body kit?
- just bought a 1994 integra need help on upgrades
- Ordering brakes.
- ls compression test #s good or bad
- for teggers with H&R race spring...
- What seats fit the rear of a DC2
- My cam end seal is leaking. What to seal it with?
- h22 in da?
- need opinions or recommendations
- 90 Integra Traction Bars
- need help with auto trans?????
- turbo and vtec
- k20 in an integra
- b16 no start(died on highway again)
- A/c belt install
- What Engine Is Best
- car running really rich, extremely bad gas mileage
- are they the same
- gs-r or ls/turbo
- passwordjdm H4H Light bulbs for the JDM 1 Piece Headlights
- cant steal mine
- I have an SR20 and a 89 DA VTECH.. I need help!-
- Tranny Problems
- rattling shifter
- MY s2k Retrofit by Customlightz
- Illegal Smog?
- hks super mega flow intake
- itr 5 lug?
- HEATER PROBLEM WITH DA!
- coilovers.
- Bumper Question????
- 6 gears on 94-01 GS-R's
- 95 LS auto woes - not your ordinary idle issues.
- help!!!!
- Free Service for 95-97 Honda Vehicles
- HID in stock headlights
- axel problem
- 95 GSR stock cloth seats mint condition for trade & or $ for type r, gsr leather, or nething worth t
- Quick Question LSvtec?
- will a b17 (92-93 gsr) header fit a b18a/b (90-93) LS motor?
- i bet you cant figure this one out..
- whale penis
- need help...
- weird vibration under accel
- Look what I found in between my cylinder walls and block... RTV???
- Tool tap?
- if a cars alignment is really off would it try to pull off the dyno?
- Does anyone know if you gsr injectors can be used on a 95 accord?
- V-tec engine in G2 teg ?
- i got this letter in the mail... check it out dc4 owners
- DAs what header are you guys running?
- Quick question: DA stock exhaust size?
- best clutch
- vtec circuit failure
- whats a better header 4-1 or 421
- will 94 i/m fit a 96?
- pricing on A GSR 98
- anyone have a complete vacuum diagram for a b18a?
- 91 LS With 93 Gsr head
- Will this solve the problem???
- Quick question about maintenance light
- Removing pedals off a 89 Integra
- Vtec on GSR not working
- does any one know?
- Spec clutch
- help PLZ..gsr tranny stamp
- Headlights... Help?!
- Japan Motor Imports
- Had my pass. side seatbelt fixed 4 free!!!!!!!
- does ign coil temperature make big difference???
- will a LS oil pan work on C5? how is it worth?
- Having trouble reading JDM B18c codes, please help!
- pic request: stock alarm remotes with the cover off..
- Good thing we drive imports eh?
- ???Wheel Horse Power on Stock GSR Integra's???
- Rear Valences from streetstyler.com = How are they?
- just put in a new itr climate control and heat wont come on?
- CEL question
- spoiler
- head lights help
- SIR-G gauge cluster in amber?
- Custom Bumper sidemarkers, what do you think?
- looking for a b16a1 head
- New Tein installation and finished product with pics
- pic request: anyone have pics of their integra with a dual guage panel pod?
- o2 sensor rattling at 1.5 k rpm??
- mine
- What all engine would be a direct swap? 95 GSR
- 1990 DA throttle body gasket
- teg turned turbo/ lil wire tuck/ fusebox + battery relocation
- help with cluster
- How to install Block Guard?
- Honed or Bored?
- trouble with cam timing
- turbo manifiold question
- ___ i need to know how to take out and replace my ABS____
- Will a HID kit for an Accord fit my Integra?
- Clutch problem?
- Where to mount liscense plate????????
- How low
- interior
- help with RHD conversion
- tranny differential shim
- b20z2 into 91 teg, faster than the b20b into the Ef
- Thermal 3" on DA question...
- please help honda-tech, i know u can come thru asap
- searched...hid question??
- help .. on connecting v tec..
- help a fellow teggy owner
- rim repair
- Help with this part
- 94 Integra Radiator same as 90-93 Integras?
- injectors
- Turbonator? $59.95 supercharger????
- okay i researched but couldnt find anything!
- Any adriatic blue pearls tegs!!
- intake system on intake! an a couple questions!
- Possible to fit fat j's intake with ABS?
- McCulloch or TECHONE HID's ??? Which one is better?! HELP!
- Stock OBD0 DA Distributor plugs SQAURE??
- Need to rebuild B18A head
- 99 civic si springs fit 94+ integras?
- im hella paranoid.. should i be? help
- brake question
- UGHHH another ticket
- synchromesh
- Integra is dying
- Are these stock?
- spoon n1 sizes help!
- running rich after car stalled in snow storm
- **Where to go for Custom upholstering in San Jose?**
- 91 INTEGRA OBD0 B16A SWAP "S3" INDICATOR LIGHT ON
- Generic EBAY Special Wheels???
- ????Auto tranny cable adjustment????
- How safe are Integras?
- window trim
- quick question
- I want to know if this is a good custom turbo kit for my 2000 integra gs-r
- o2 question, obd2-obd1
- SEIBON 98+ Carbon Fiber Lip Kits.... OPINIONS?
- what type of oil for fully built type-R?
- any shops in Kissimmee,FL area for test pipe??
- water in my 98-01 all-read tails..
- Pressure plate
- temperature gauge goes down with hard acceleration
- Seatbelts
- Real 98+ taillights or fake 94-97 painted ones? pic inside
- replacing a clutch
- oo tegg hatch bumper will it fit in a 4 door tegg
- Torque specs on stock b18a1
- WTF am I and where do I go?
- Boost Gauge Dash Location
- iPod hardwiring dock systems
- HELP!!! ASAP!!! DC 1 piece headers --> how do i put them on?
- Anchor Bolt Part #
- Quick question Will my Clutch out of my 1999 Ls fit my 1990 Ls tranny??? ASAP
- type r spoiler on me?
- cluster needle doesnt light
- Weird wiring problem, you gotta hear it to believe it.
- Valve & header question...???
- i have a 93 b18 motor with a 93 gsr head i want to put in my 90-91 integra...plug and play?
- project try this car asshole is on the way
- Oil Pump?
- Antenna install - Searched and I can't find it anywhere.
- Fuse Box / Underneath Steering Column Nut/Bolt size
- Cutting the Third leg off spoiler..
- Castrol Super Clean on Tails
- apexi N1 exhaust
- How much is my totalled Integra worth?
- Heater not working??? HELP!!
- jdm integra climate control..
- Differences between GSR sedan / LS sedan /GSR coupe / catbacks?
- spec 2 and 3 PROS and CONS
- New Car...
- BC spec 2 set up
- Spoon n1 going from 2.5 to 2.38
- keep or sell
- using timing belt cover with Honda N1 pulley ?
- abc light is on
- ABS HELP!
- Tenzo R Big Brake kit
- Felpro Exhaust Manifold Gasket?
- what are those wires that come out of the carpet under the passeger seat for?
- 8000k HID HighBeam...
- my Teg running cool
- Stock LS bottom end, stock P72 head- if you have one chime in!
- body work
- Koyo or Fluidyne
- 93 integra Race axles
- where to get a CRV stick tranny?
- not goin in reverse
- Radiator questions
- change my oil
- Exhaust question --> 2.5 inch too big and too loud?
- tips on turoing my b17
- koni's or tokico's
- oil pan leaking
- Pistons for my GSR
- sir-g vs type-r front conversion
- Spark question on '89 Integra (should be easy)
- new wheels pulls to right
- Tranny hard getting into gear
- header/manifold
- rev limiter ?
- T/A sensor what and where?
- header ?????
- Da9brakes
- need some opinion
- Cheap clutch for my 89 teg
- tstat prob
- 89 integra seat swaps?
- Thief Proof Tegs out there ?
- Wont Start
- installing Tachometer
- I need A/C removal instruction..
- Stripped Oil Pan
- is it worth it?
- Hondata s300
- IACV swap, issues going from obd2-obd1.
- non v-tech vrs v-tech
- Engine swap help.
- Emission Testing
- Windshield Defroster Problem
- anyone else have this problem with an ebay steering wheel hub?
- Ghost Switches need a how to.
- jerky shifting
- exhaust question
- HELP! GSR IN TROUBLE!
- How to. RSX seats in DA
- 5th gear keeps poping out!?!
- 95 integra gsr power steering
- b20 pulley part number
- Stock Machined 64 mm TB worth it?
- suggestion for comfortable full coilovers for my dc
- OIL PAN HELP!!!!!!!
- 98 integra spring rates VS 99-00 civic si Spring rates
- 5lug conversion....What can be used as spare?????
- Greddy 4-2-1 header installation
- help on swap
- really need help
- Pic Request: B18A1(90-91pref) Intake Manifold
- Koni Reds with Skunk2 sleeves
- just got a thermal r&d axel back for my gs-r - did i get a good deal?
- Carb Sticker?
- putting a b18a into my dc2 is there a diffrence
- What would happen if I remove the ECU from my 95 GSR?
- Any one use the JC whitney exhaust control valve?
- Flywheel upgrade
