View Full Version : Acura Integra
- Specific Power Window Questions: Need Help PLEASE.
- Test pipe??
- AAH IT WONT WORK!
- another busted exedy organic clutch
- Anyone have a Precision Intercooler?
- Tire install = Scratches?
- Before my dyno
- Anyone one know what ORANGE paint or marking around block code means?
- How to tune a car?
- Does anyones car lag in the winter
- my rpm's are all f'd up after S2 manifold install
- Buying a used integra 99-00
- light weight flywheel and underdrive pulley
- What to look for when buying a GSR
- car sounds like sh!t
- carsound cat...only 1 o2 sensor?
- check engine light
- spoon plugs or ngk
- 95' front brake pad change help
- finding usdm b18c5 motor
- Measured Rear Gut Session.
- help i ran a 16.7
- FastLine Road Race Shifter
- Need Secondary O2 Sensor Wiring Diagram.
- this piston look right?
- control arm question
- engine removal
- Brake Rotor Size DA/DC
- thermostat
- LSVTEC wiring question...and god dammit, yes ive searched
- Air filters
- Does anyone have experience with Megan Racing Strut bars?
- apexi n1 exhaust
- Are these good prices?
- Does the 3rd Gen LS have a drain plug for gas tank?
- Who here wanted a Gs-R but settle on a LS
- APEXi N1 Exhaust Cat Back Prices
- best sounding exhaust
- apexi ws 2 exhaust
- pic request 98+ 4dr rear bumper
- Lowering Question
- whats the best intake filter?
- condensation...how to fix it
- Would this be a good setup for my 98 intergra LS?
- pictures of b18b hydro tranny
- Test Pipe
- how/where did you bolt up your intercooleron 94+integras?
- Adjustable springs vs coilovers for my 91 DA, need some help
- im gonna buy a a integra in year of 05 what model sould i get and how much will cost
- a/c, p/s belt
- timing belt position
- ITR FINAL DRIVE SET
- Stiff axle??? WTH??
- add on remote starter
- Skunk2 Turbo Cam Valve Spec Needed!!
- o/2 sensor wire on ecu color????
- seat?
- Anyone know where to buy a boot for your wheel?
- battery voltage below 14?
- 94 V-tec... under-reving (idoling at 750rpm)!!
- Good Deal On Apexi Ws...
- Will a B16 open differential fit in an LS? Need to know ASAP. Already searched.
- Lowest drop on a DB1??
- Speedometer Cable?
- need to find hole in trunk
- GSR throwing code 9.....and sometimes 17? weird...
- Eibach Vs Neuspeed
- Where is it?
- gsr slugs in a b18b???
- Which ECU for a GSR w/ a skunk2 or JG IM??
- Gm synchromesh is same as other brands. (link)
- help me figure out what this is!
- What mount is this? *pic inside*
- Wiring headlights on a JDM conversion NON HID
- clutch and pedal problems...
- Comptech Sway/Tie Bar combo - buying just the tie bar
- valve cover gasket + O-rings
- moisture in head lights - better process for clearing it up long term?
- Need one Gsr Blade-
- H22A into 94 TEg
- clutch problem
- need speedo cable
- LS Cutting out, Stalling
- Where to buy BREMBO blanks?
- Auto tranny question
- IAT sensor
- Questions about GSR intake and exhaust valve springs
- Whole buncha problems, Fuse keeps blowing, Tach, lights dont work. Help please!!! lotsa sundden elec
- Need help w/B18C1 valve adjustment: "slight drag" + Skunk2 Cam Gears
- Worth it??- -95 Integra Rs with jdm front end
- Radiator question... need yoru opinion quickly!!!
- Car runs a lot smoother when cold.. why?
- clutch, disk, flywheel combo... good? bad?
- I have a brand new T3/T4 Turbo kit for sale for $1,800!
- STOLEN TEGS...HELP GIVE ADVICE TO KEEP OTHER's TEGS SAFE FROM BEING JACKED..
- quick question....
- Maint Reqd light!!
- how do i pull out the side impact beam in the doors, 94integra
- DA JDM Front bumper
- Looking for Ls motors for sale??? Guys know any good sites or shops Im from Chicago
- New Exhaust
- hondata
- best parts to add to integra with jrsc
- would this exhaust setup work?
- How to make it so u can go over redline and....
- 14 sec. gsr?
- h22 injectors in my DA-b16
- Greddy Sp2 or Skunk 2?
- Crx Si seats in 1994 integra?
- gsr... wut kind of turbo?????
- Does anybody know what kind of lsd comes in a jdm ys1 tranny?
- I recieved a code from the ECU.... what's it mean?
- Stripping a 'Teg
- Heads up Winnipeg, MB
- "BLENDING PAINT" questions inside
- best clutch?
- Possible to swap in a K20A engine in my 99 GSR?
- I put regular unleaded gasoline in my GSR is it bad?
- Civic lower control arms fit integra?
- 98 Integra GSR
- JDM 2.5 header set up
- Clutch Install problem...
- TPS&KNOCK SENSOR
- did tranny swap now reverse makes noise..
- How to take off integra rear bumper!!!
- My turbo project has begun *pics, 56k warning*
- Any 1G Integra people out there?
- heat shield
- Which Plugs?
- my car is cursed.
- which route to go?
- ls/vtec people!!!!
- b20 rev ability?
- what muffler to get?
- Gen3 headlight baking ?
- my seats got jacked...
- Gearing, LS vs Si vs GSR
- Oil filter
- New Transmission
- Car wont start, Please help???
- Stripped out oil pan...please help
- help meh pick an exhaust!!
- Question about the maintance light
- Ebay cat?
- b20 block on b18a head and b16 cable tranny, DA9
- [Pic Request] 4100K vs. 6000K HIDs
- ok guys i realyy need some help here. please post helpful hints!
- Cold to short intake
- Need help with idle
- Tranny problems!
- will 94 GSR rad fit a 94 LS??
- Tuning for a cat back and a Skunk2 Mani
- how much is this worth?
- anyoen with prestige 990/950 alarm please help
- side markers and turn signals
- What is the easiest way to remove an inner fender?
- Motor with no vins.. Need help and Advice!!
- my 1000th post!
- 94 up shift linkage on a DA?
- Anybody know why my map sensor check engine light keeps coming on?
- bought a 97 LS and need orange corners
- Auto B18B V.S. 5 spd B18B
- ls head
- can it be tuned?
- ls-vtec 1/4 times
- Quick fuel pump question?
- i need some help.
- Car is pulling hard left!!!
- itr or s2000 muffler?
- maintinence light blinks 9 times
- fell asleep driving - now have some damage
- Missing Header studs, need help please.
- Do you sit higher or lower in 94+ Integras with racing seats?
- using the clasiffied
- GSR..Which Tranny?
- advancing timming
- Low idle
- Installing My CAI Intake -- Searched
- stock ls head for sale
- comptech/testpipe/apexi n1 and kyb/neuspeed
- Do i still need bigger injectors with fmu and fuel pump?
- APC
- Rs-R good?
- hm... I dont think my radiator cooling fan is working
- so I got a CSF radiator, we'll see what happens, question about ATF fittings
- energy suspension bumpstops
- Opinions on Skunk2 Coilovers please?
- Brake Master Cylinder Brace
- Looking to buy 95 teg w/ plans of turbo, what internal work do i need b4 i bolt it on?
- My Brake Light Stay On....
- Rear section exhaust??
- engine temp stays cold longer than usual?
- best shock/strut for integras.. waht do u think
- ITR fuel pump same as GSR fuel pump???
- What camber kits (F&R) do you recommend?
- GSR gauge cluster?
- Exhaust clearance w/ Comptech Sway/Tie Combo ????? SRR?
- The Tiger's video!
- LS/Vtec questions....
- camber kit? shocks?
- Are Integra Xsi b16a motor mounts the same as stock usdm b18a mounts?
- Fuel Pump Cutoff switch Question
- Engine runs hot after radiator and themostat replacement
- Where is the drain bolt and filler on '94 GSR Tranny????
- just got insurance settlement...
- 2 quarts of oil every 2 weeks? help
- how to relocate hood cable latch?
- 100K miles in 3 years Vs 100K miles in 8 years.
- bang for the buck
- yay, 1.5 quarts of oil in less than 500 miles
- need some help with fuel pump
- cam removal and installation?
- Whats with the Apexi N1 catback?
- how to get 200 whp out of a street gsr???
- 1994-2001 gsr's only 3 types of iacv's?
- ALARM QUESTION.....!!!!
- o2 sensor simulator
- OEM Optional Side Skirt Install
- mixing synthetic oil
- Tranny Oil change question?
- Dash removal instructions? (94 Integra LS)
- valves
- JDM Front End Conversion!!!
- suspension trade opinions needed...
- My DA repair. . .and improvements. . .
- ITR piston and rings fit on GSR stock rods/bore?
- H&R springs fittment question
- CEL codes how to fix
- when will be able to be a full time user
- any GSR's in midwest area for sale?
- how to install a tow hook
- vtec complete head
- Burning Oil
- All fo your SMSP dreams will be fulfilled
- v-afc question. (no its not where to install or hwo did you set yours) question lol
- Clutch Pedal stiffness
- need help with coolant system
- thinkin bout 01 conversion:is it worth it? would it be theif bait??
- Tein HA Question?
- I love my car.
- how much is a good drop with donut tires on ITR
- SS Brake Line Install
- just wondering...b16-->b18
- Goofy Q: Can you center mount a baby seat in an '01 Integra sedan?
- HIDS for teggy
- Hi
- NEW engine? or Build up on Bolt-ons? this is bone stock...
- Getting GSR tranny swap and...........
- wierd metel clanging noise
- Spring Autocross ---> Time to choose my suspension!
