View Full Version : Acura Integra
- radiator fan question
- High Performance Clutches for a 95' LS Integra
- civic brake system into my teg
- JDM ITR final Drive Vs. USDM ITR final drive
- CV Boot Job = DriveShaft Removal??
- Do newer model gauge clusters not work on older cars???
- GSR water pump on LS?
- ITR cat back on gsr?
- for those who have done the itr suspension conversion
- Correct Tranny Fluid for a 91 Auto teg
- tanabe medallion exhaust
- beaks kit help pls ?
- firing order
- Who ports and polishes GSR manifolds
- Removing Acura Word on back of car!
- Question about painted rims...
- Question regarding removing the interior carpet from an integra.
- Are tokico blue shocks good for a 1 and a half inch droped car?
- what chip to get for 1998 integra ls
- Blown tranny, need some help [link inside]
- Anyone know where i can still get the S2000 anntena kit?
- ABS problem help please
- header bolts part #
- problem with shifting
- Question about tornactive.com
- how much for complete greddy turbo?
- does anyone have pics of rota slipstreams on the teg
- Thinking of selling my 94 Turbo LS Teg for a gsr.... some inputs please??
- Where to get body kit??
- brake fluid: when to flush or when to bleed?
- jdm dc 4 to 1 header vs. comptech 4-2-1 header
- ever heard of tsudo coilover?
- Looking for some aftermarket parts websites
- crankshaft pulley
- Anyone Living In Nyc
- Sup guys im new
- ITR rear sway on my 95 LS
- what are specs on a 1998 ls ? hp, 0-60, blah blah balh thanks!
- Wheel bearing or axle, which is the problem?
- can't find this oem part #
- PRICING FOR A TEG
- lowering springs
- AEM CAI in the snow?
- A/C line Part ##
- how cheap is cheap?
- Just learned to drive a standard...
- a 200hp 94-01 GSR Motor
- SHould I sell....
- Some one told me that gs is all power and rs is not.... True or False????
- help with header
- i need a b20 block any body got one for sale
- HELP! Flywheel Dowel Pin Removal
- 1992 Integra Computer Needed
- Lookin at another GSR...
- Fluidyne Radiator Install (pics)
- Built LS/Vtec block LS Head?
- Question on PR4 ecu.
- clean side skirts
- Best/Cheapest Place to get a New/Refurbished Starter for a GSR...
- I didn't think it would be this bad....
- Stock LS spring able to support an ITR Spring?
- Pic Request: DC2 with "halo" headlight mod..
- 92 DA Suspension Build-Up
- need help with ecu code for 97 integra
- jdm gsr injectors
- how do you get sponsored
- Suspension torque specs
- External oil cooler
- is there any difference between the CTR exhaust cam and the GSR exhaust cam?
- Differences between JDM/USDM Integra GSR?
- Pics of my 91 GS
- new fluidyne, is if ****** up??
- tom's spring
- Why is my coolant orange?
- What is your opinion on putting the 'INTEGRA' badge on an integra???
- JDM RECARO OWNERS INSTALL HELP
- dc2 w/ roll cage
- Tein S Tech on Gs-R? Comments?
- Going away for a month - storage
- Primered Integ in Nashville Tennessee at a gas station
- antenna
- My new DC4!
- dual guage pod
- Slipstreams-Need Hub Rings for 98GSR?
- Weight difference????????
- Brake Booster (searched)
- Coilover info: APEXi N1 Pro or JIC FLT-A2
- well my car almost got.....
- http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33629&item=2435341421
- STR Pulleys
- Just got my teg, couple questions
- Metal shims needed on brake pads?
- Is the 91 integra gs b18a1 engine good?
- Integra Intake
- braking problem...................help
- 94-95 gsr into 93 LS
- cold air intake piping
- Integra 97 LS - Suggestions?
- Is the b18a1 gsr engine???
- How far can I lower my car with a 17 inch wheel
- Exhaust for 95 GSR
- type r cams in gsr
- how much should i pay for....
- Need help with my integra???
- is it better....header exhaust q's
- WTB cheap oem parts?
- G2: cricking noise, lower brace ?'s
- KM to MPH????
- *rant* Wheel bearings and my Integra...
- Will 215/45/16 Azenis rub on an Integra
- Some new pictures of the "Type R" style lip for the 98+ Integra
- Rattle after Exhaust Install!!!!!
- I am so F****** excited! I finally get a gizzer!
- Adjustable perch Koni's and which springs - eibach sportline or pro-kit ?
- NITTO 1320 CHALLENGE
- any 1 got pics of DC2/4 wit neuspeed race springs wit koni yellows set on highest perch?
- LSD for a 1st gen integra
- DOES ANY ONE HAVE SKUNK 2 COILOVERS ???
- B20 Turbo?
- Condensor fan wont come on. . . relay problem?
- oil filter
- Ebay Strut Bars/Tie Bars?
- carfax please?
- Wings West ITR lip $190 shipped.
- stock LS quarter mile times?
- exact a-pipe length differences: RS/LS/ITR vs 94-99 GSR
- Witch exhaust choose????
- Mugen 1st gen spoiler for DC2
- accord rails in a G2
- Type R ECU in GSR Trouble
- Replacing axle
- brake lights dont work?
- how do i tell the year of my motor!
- 89 octane in the ls
- would springs from 96-up 2 door civic fit 94 2 dr teg?
- HR Sport Spring rubbing issues
- integras top speed
- Run into a bit of a dilemma....
- when does vtec kick in
- Is this direct bolt on?
- Car Wont start
- Quickteg is a scammer!!!!
- GSR head swap to an LS block
- Finally......it's finished
- WAS I SCAMMED?!
- skunk2 exaust silencer where?
- differences in LS cams?
- I have an auto LS....
- yokohama es100 or kumho ecsta 711
- rack and pinion
- just orderd itr 22mm sway now what else???
- What coils are you running?
- Does it matter what coldair intake?
- Building up a GSR what throttle body to get??
- sick spoon dc2 cluster only $ 127.50 on ebay right now
- making the light on reminder sound louder
- H22a or B18c5
- FINALLY my car is quiet(er), but CEL still on...
- AutoMeter Speedometer swap into my Integra... HELP?!
- header
- need to find cable jdm ys1 tranny
- headstud and mainstud question?
- LS and GSR axles, the same?
- Prefered oil grade?
- help with exhaust for my 94 4dr gsr
- speed limiter
- 4dr gsr exhaust help!
- 98' GSR w/ 90k miles, what do you think?
- Steering of car is awkward, any thoughts?
- Nitto 450's....correct PSI?
- Question about ls
- Overheating problem?
- winter tires
- track times? what times should i be at?
- taking off timing belt cover
- Is an OBX cat-back on a 93 gsr a good idea? Should i buy a diff brand?
- would you rock autozone rotors (20$ each)? or brembro blanks for 126$ whole set?
- aebs intake manifold
- 99gsr OEM header fit my 95gsr?
- lost flywheel splash guard - flywheel exposed, any damage?
- ok..need help from the tech guys
- Partial by-pass of power steering pump
- J's "style" intake in my dc2
- Anyone has BSQ DIY intake with K&N Filter
- Took Cat out now Check engine light is on what do i doooo?
- Car Painting
- 90-93 Integra Brakes the same?
- Front License Plate mount options?
- Where to get tan leather steering wheel wrap?
- question about the block number on B series motors!
- Im buying a integra gsr!! what year is the best one
- 2001 GSR shocks in 93 GSR
- AUTO RECYCLER/JUNKYARDS in Ttri-state area????????????????????????????????????
- Anything you regret about buying a integra?
- Quick Question for OIl
- wheel question......Yes I do still exsist
- Firewall
- Do bad bushings creek/squeek?? someone help
- Oil leak - help if you dare!
- ls to gsr swap questions
- excedy 3 puck clutch in my 95 gsr
- Who has the best deal on VAFC's?
- h&r sport and camber kit?
- JDM Dc 4-1 header test pipe
- exhaust sedan = coupe??
- Anyone Have Apex Power intake ?
- Post-Accident Engine Startup: Issues
- Just got a header install, Oil Problems
- podium performance. hondata.
- Leakdown test results of my 97 GSR
- Honorary member of the EVIL DOHC family goes 14.4 @ 93 mph
- bolt paddern on a gsr
- Help, car just died on me...what could be the prob?
- Why cant I send PM's and Post in certain topics?
- Anyone got a 94+ integra tan interior pic?
- whining, screeching sound when applying gas while step on clutch half way
- HOLY CRAP! That was time consuming!
- spoon Integra-R P73 Piston Set
- Help with some information
- starter whining when key is inserted into 2nd position
- JDM lights
- hmm... h&r race springs on stock shocks...
- i got a new car i have sum questions
- GSR Internals Question
- a/c?
- Post your times with your B20
- Rev limit dropped to 6500???
- greddy evo exhaust?
- GSR tranny ... rebuild or replace
- compression test results low?
- itr cams pics please... searched and i got NOTHING
- Header question?
- 2nd stripped wheel stud in a month! Something's amiss.
- Unhooked and plugged IACV holes-nothing happened.
- Nitrous Oxide For Integra
- If you were building a allmotor B18c.....
- Spark ?
- heater probs..quick it's going to be cold out tonight...
- radiator cap
- need help, need wiring diagram for Apex Rev speed meter for a 2000 acura integra gsr?
- Where can i find a itr comptech icebox?
- greddy sp troubles.........
- crower cams in b17?
- short shifter
- Car stumbles during acceleration at 3K??? Help/Advice please
- 00 GSR - Swapping in a 97 B18C5 - Need HELP!!!
- 97 ITR lip
- Car Flood. What are possible water inlets to engine
- Quick Fender Removal Question
