- Fuel light
- Shipping engine, transmission, etc... any really GOOD ideas? *searched*
- axle
- gas driven intake
- HAy ? on B16 swap
- Another Skunk2 intake: What happens at 5800 RPM w/no secondaries?
- service shops in and around L.A.
- ?question on LS\vtec
- 17x8" Sub-zeros on 96 integra
- stage 1 cams(crower) plus header and testpipe noticable!?!?!?!?!
- Needing to find vtec solenoid plugs!
- Type R Spoiler
- WTB: p75 auto OBD1 ecu
- Fan???
- high flow cat??
- what wheels are these
- iPod hook up
- Steering Issues...Help wanted.
- Slamed DC request!!!
- FS: jdm itr steering wheel and itr seats
- PROBLEM WITH MY SUSPENSION!!
- how to install tach
- DA integra rpm issue
- 94 GSR FOR SALE
- wiring harness
- how does the integra fuel guages work?
- Where are the vents in the trunk?
- itr cams in gsr....
- Whats the bulb size for low beams? 94-01 Integra...
- Gs-R question.
- rebuild or new motor?
- 94-97 front end and 98up front end
- engines runs horribly.
- urgent question...for right now!
- Sound Like a good LSVTEC Build?
- how to remove catback?
- Need some help with my shifter.
- bad motor mounts
- vtec pinouts help
- quick question!!
- anyone have pinouts for jdm itr headlights?
- LS/VTEC question
- Spring choice
- Radiator Fans?
- CTR Pulley for B18C
- DD just became weekend worrior
- HELP- New Cam/Gear Install, Problem with Idle.
- Engine check light for catalist
- high mileage...what should i change?
- DID I FIX IT?
- Major Maintenance
- ** side skirts for da 4dr ** ??
- all ls/gs/gsr catback the same?
- V-TEC
- B16A SWAP
- quick question need help
- ?RSX seats fit a DC2??
- Setup decision made and car in the shop
- need help with my ls swap
- Two Tone Integras
- Need Advise!!!
- 1994 Rear Hatch Popper, On a 1999 Integra GSR
- How to attach a 98+ Comptech ITR front lip?
- Gas Gauge
- will bending back the stucture beam on the car cause alignment or safety problems in the future?
- What is the difference between these engines?
- vtec head
- good na intake manifold
- header ? Will it fit on a 93
- ve Tapping Up Top
- Need help:)
- greddy blue box???
- how does a fixed up gsr's vtec feel?
- 91 ls auto died at about 2800rpm won't start till you wait. wtf?
- jdm lips on usdm bumpers... doable?
- vtec help
- 92 integra gsr ---> high idle (2000rpm) when I start the engine cold
- 92 gsr
- 97 gsr bumper
- apexi ws2
- New to Modding the Teg...
- name these rims...
- Head unit troubles
- PM???
- Really noob ?. Please dont flame
- Where can I get this paint?
- looking for stock springs
- To much fuel??
- can a dc2 itr spoiler fit on da's 93 integra
- Just got my car dynoed....(95 Integra GSR-T)
- anyone using S2000 radio antenia on the dc2
- 94 gsr oil problem
- LEAK??
- filled with 4 quarts.....
- DA integra tach install (please help)
- Low idle
- LS motor in GSR body....
- b18c1 VAFC 2, car bucking problems
- Help me pick some wheels (decent choices i promise)
- advance timing...
- GSR KABOOM! not so good
- squeaky dizzy
- New cams causing idle problems.
- YOU DID NOT PASS SMOG
- NOT TECH RELATED.... Going to court tomorrow for 2nd DUI.........
- How to check if Valve Stem Seals are bad...
- CODE 8 PLZ HELP
- ls crank vs gsr crank
- 1990 integra ls - no pedal pressure - Help!
- 95 Integra LS Staring Prob?
- ecu serial number?
- Forest green DA Anyone?
- is my car ready for intake mani?
- four door weight
- Hydrolocked Engine?
- Will It Fit?
- Turboing a gsr :Any help with step by step info:
- B16a into a DC4?
- ball joints: how to..
- rare jdm DA parts.
- Brake pedal too loose??
- DIY: Integra Coil Over installation, Ground Control, KYB Struts
- Strange noise
- explicit speed performance-feed back
- Is there a difference in Steering Column shrouds
- stage 1 cams what to expect!?!?!?!?!?
- need a Good Acura factory parts online store.
- HARMONIC BALANCER (MAIN PULLIE)!!! HELP !!!
- all red tail lights.....where to get them?
- Anybody with TEIN S-tech springs?
- 2001 GSR power door lock problems
- Question about setting Apexi Afc Neo
- difference between p28 computers?
- 98+ tails...
- city lights....aaahhhhh
- dont know if its the rigth susspension for my integra???
- 90k Service
- quick question
- Best police radar detector ?
- Good place in SoCal to have JDM DC2 front end installed?
- SEAT RAIL QUESTION, SEARCHED NO ANSWER! DA OWNERS CHIME IN!!!
- tokico illuminas and pro circuit coilovers
- stripped screws trying to remove bumper...
- 90 Integra Bouncy Idle !!! need help !!
- Weird knocking noise from engine bay....
- to all ya boosters out there!...
- NPW Water Pump?
- 805 meet
- Grounding issue or coincidence? End of my wits has been reached...
- best intake for my da???
- whats a b18c1?
- question to jdm integra cluster owners...
- ecu problems (need help)???
- Turbo GSR questions (yes I have searched and done research)
- cams and what else.....
- Restoring my wheels
- check engine light when I hit a bump???
- megan racing sleeves
- Need some mechanical help...Starter I beleive...
- Weight reduction- Whats the lightest tegs out there?
- CAn a 2000 SI cluster fit?
- ACT 4 puck
- guages
- Are ground control springs lower than eibach prokits?
- Spark plugs?
- need pic of firewall
- swap in early integra
- spark plugs for turbo?
- skunk2 shocks
- how to identify JDM engine?
- witch cai will fit my da
- best plugs for stock turbo LS?
- 2gen teg timing
- 06 Si muffler
- LS turbo??
- difference in struts - GSR vs LS
- Stage 3 clutch over a stage 2 clutch is it worth it
- eg brake line fit dc ?
- Just had alignment and now axle broke
- ecu codes.
- ecu code
- Difference between Bore and Sleeving?
- Freeze plug size?
- DC5 itr abs steering wheel fitment?
- I know this has been debated to death BUT...
- projector retrofit How-to?
- droping car soon. do you need a camber kit???
- Engine Bore
- Best Place to BUY Golden Eagle Manufacturing Cam Seal Plug?
- h22 into a DA integra
- please help me identify this part
- laying around in the trunk and i cant figure out what it is.. please help.please help me identify th
- Dyno'ed my 2000 Integra GSR sedan B18C... Terrible numbers
- Question about JDM front end
- Is there any difference in Alternators between 98 and 99 Model Year GSR's
- eibach pro damper shocks/struts
- Supercharger for DA
- HELP!!!! Please~Check Engine Light
- Skunk2 Pro intake manifold on a b18a/b engine
- goto ebay
- HELP! idling shaking ??? thermostat ?
- poor mans type r
- taillight problem...
- DC owners in Cali
- chipped ecu and ticking sound?
- zc problem
- H22a into a 94 Integra LS - Just a few questions - Need clarification
- parking brake stiffness....
- b16 tranny
- Clutch for boost!
- ecu code 65
- GSR Trans Help!!!
- Road trip from DALLAS To L.A need advice on police inspection
- engine that over reved
- big problem
- wheres the VIN on the motor?
- Newbie Here..
- another cluster problem- with a twist
- axle removal????????
- Does rasp mean a less deep tone?
- fuel injectors
- please help me :(
- How many quarts does an integra take
- Cap & Rotor: OEM or "O""E""M" or Napa or etc..
- roll cage for a DA?
- difference between comptech and oem type r lip
- WHats your shifting speed/rpm?
- head gasket set
- Can 2000 Gsr rear seats fit in a 93 integra Ls?
- corrosion inside distributor cap
- I've Tried searching but couldn't find what I was asking. car running in Limp mode.
- rednecks and windsheilds......
- Teggy Problems
- Where to buy JDM ITR Fender Liners New/Used???
- Are Jasper Green DAs rare?
- changed the water pump now it wont start???????
- throw out berring? new trans?
- wire specialist
- signs and symptons of spun bearing?
- Blox Intake Manifold????
- *still searching* but input needed please...
- Omni Power Coilvers, or GC's w/ Illumnia's
- b16 trans worth it
- idle issues/car being cold
- help on clutch install
- need new engine where to find please help
- Exhaust help! Need advice on muffler..
- What is this metal shaving from my JDM B16A y1 tranny???????
- JDM XSI trans code
- -------HELP!!--------
