- rear trailing arms
- Quick offset question???
- Pictures
- h-tech video question?
- ABS Plastics or Ebay Style Lips for 90/91 or 92/93 Integra
- VAFC1 controller for sale
- solution for securing Blox IM to factory bracket on GSR?
- SPEED LIMIT in gsrs
- tenzo seat questions
- Interior door handles.
- Head Gasket Quetion?
- H&R Race Fitment Question
- GSR or LS.....what one to buy and mod?
- any honda engine website?
- Which injectors?
- Should I do cam gears @ timing belt job
- radiator cracked
- Wanna switch out stock heat controls for a digital controller
- bent control arm
- NEED PARTS!!!!!!!!!!
- interior question
- Intermittent low idle SEARCHED plz help!
- Short Shifter Question
- Brakes I had posted FS
- Found a local guy selling a stripped 99 GSR for $800. Just missing seats and tires.
- what is the purpose of those little rubber donuts on GSR axles?
- what do you guys think of my setup??
- best octane to use when going to get a smog test
- red calipers
- 95 Integra Question on B16A SiR II swap.
- Dust Covers Necessary?
- USDM Integra OEM Fogs
- skunk cambe kit ???
- disintegrated ground strap on spark plug - plz help.
- Traction bars
- integra
- can you help me on radiator install
- No Block vin# on B18b1 block????
- grounding points?
- Anyone have a straight B20 in thier DC2?
- how do i cheak cel. light is on but its not blinking.
- H22 stroker kit???
- I need your opinion on which
- Tein Stech and Htech pics? 90-93 Teg's
- silverstar head lights
- 94 gsr......gone.
- which tranny oil and techique would be best to help me with this
- **Picture Request** SILVER 94-01 Tegs
- how do i know if my cel light is working?
- Changing CV Boots
- Paging: * SHystrdyGSRtdy *
- greddy SP2
- all motor or jrsc?
- Plugs for when removing spoiler on gsr?
- installed header....now...... drove 35 ish miles..burned 4-5 gallon of gas!!!!
- nice birthday presink
- is it suppose to smoke up?
- sway bar?
- My solution to leaking trunk/taillights
- Is this a sympton of a dead battery?
- jdm parts
- where are the abs hook ups on type r calipers
- is anyone running stock gsr intake man.... on there ls/vtec?
- engine help
- just got a front.. what do i need
- anyone have ls/vtec with gsr head and gsr im.P72
- Any input on Thermal exhuast for N/A
- 10grand no vtec.............................................. ............................
- taking off my GSR wing, need help with this item(3rd light)
- cant post in appearance...any seen cf rear?
- tokico gas shock
- new to honda tech...well sorta
- just need your opinon
- ANYONE GOT ANY STOCK GSR TIMES FOR 0-60 AND 1/4 MILE?
- Replaced Axle and its still clicking
- inlinefour quick release?
- rear lower tie bar install, already serched, have a couple questions
- Loose Throttle cable or bad sensor? you tell me
- Has anyone driven both a fairly stock GSR and a Type R?
- how hard is it to install motor mount inserts?
- shops in socal that do upolstry(sp)"
- what intake for gsr w/skunk2 intake manifold???
- S2K steering Wheel
- QUICK 98 ls headers to exhaust fit gsr headers to exhaust?
- quick need help fast searched already
- Lookin for a gsr tranny...
- tie-rod ends and their balljoints pics requested
- ls vtech or gsr engine
- few pics of my DC2
- Exhuast for a 91 Teg LS
- Newbie removing seats & carpet in 4 dr. teg for impossible to find water leak, what tools & anything
- skunk2 IM question
- gsr ecu obd1 or obd2
- Are all obd 2 alternators the same for the gsr, type - r and ls? If u know please reply!
- sprigns shocks
- 17 in wheels for sale w tires-cheap-2 months old
- where do you guys buy teg stuff?
- jdm integra fog light switch
- Brembo's and PBR Pads
- TYPE R ECU IN A GSR
- Cooling fan making noise?
- nice integra spotting
- CAM specs....need a little help....
- quick apex-i N1 question
- Engine Problem
- Wanted: Boost! Help!
- Oem wing to ITR?
- quick question 8:5:1 vs 9:3:1
- CL Seats in a DC?
- car stutters when i floor it
- Xmas List
- Anyone ever heard of NoyanUSA in VA?
- Clutch Fluid Reservoir is empty???
- Engine Rebuild.. want your opinion
- Reputable place to buy motors?
- Any one know the difference in style between 94-97 and 98 up?
- Steering pulls to the right.....
- Lower rear tie bar installation GSR? Skunk2
- I just received my 2nd Hytech Header this year
- suspension help
- LS VTEC vets. please respond, your useful knowledge is wanted, thank you
- ebay halo projectors
- LS chassis with gsr engine?
- vtec dont work
- cheap place to buy o2 sensor?
- Wanted 93 integra ls bumpers and fenders in so cal area
- Question about a straight pipe exhaust install.
- just got my apexi super ground system...question
- wut u guys think would be better
- Need opinions for my SSBP Turbo GSR.
- sO WUTS UP DO U GUYS THINK THE MEGAN RACING HEADERS ARE GOOD OR WUT
- Possible to rebuild distributor cap for B18B
- non vtec head on ls
- header installed.....small leak....becuase it doesnt sit flush with cat
- Anybody have this Ebay Strut Tower Bar? (R1-Mugen)
- IACV-clean or replace after possible freezing...
- ball joint , acura part # WITHOUT arm ??
- fuel pressure regulator ?
- Integra ZX suspension and brakes
- READ READ READ
- Can someone run a carfax or autocheck report for me?
- jdm gsr lsd tranny problem help please !!
- how manny posts
- HELP ASAP PLEASE its 920 and IM IN THE MIDDLE OF AN INSTALL
- No Help in "TECH"-- Safc-II display color.
- How do I remove d16a1 pistons/rods? (at a junkyard)
- itr gauge cluster swap in a DA
- How much would you pay for this INTEGRA?
- selling B20B integra norcal area! nice interior PICS! click link
- suspension question...
- jdm molding...
- Bad day....
- need help!!!
- 350 WHP in stock 97 GSR..is it possible?
- Suspension Problem
- gsr skunk2 intake manifold ?
- GSR rotors
- abs
- my integra
- leather teg seats
- CTR pistons in an LS block w/out mods?
- GSR throttle body = LS throttly body??
- ls stock exhaust on a gsr?
- Exhaust Part Interchangeability between b18b and b18c1
- DA steering conversion!!!??
- starting problems?
- LS with boost...or LS/Vtech or H22
- NEWBIES....wanna know what the first mod for your car should be ?
- 93 gsr to 91 ls
- '98 GSR Water Temp. Gauge not normal
- gsr b17 block with stock crank help with what rods on ctr pistons
- integra ls header
- DONT WANT ANYBODY STEALING YOUR INTEGRA ?? Read this !!!!!
- Jackson Racing Short Shifter.....
- From the Lehigh Valley area? Want your car featured in Pulse Weekly?
- ITR spring ?
- 99 GSR fuel pump wireing / need help ASAP / Map sensor color code
- Stock Integra Clutch -??Problem??
- Warm up time
- threw on some tokico blues with my neuspeed sports on the dc
- Removing my sliders from my stock gsr seats: What parts will I need to fabricate...
- Does gsr axles fit ls axles perfectly?
- header clearance on 91-93 teg
- Buddy Clud's services are bad...
- ARP bolts from a B16a - will they fit a b18b?
- questions on internals before i ass turbo.
- help on my brakes
- 91 integra LS... fuse blowing problem
- stock clutch
- b16 tranny with GSR?
- quesiton...had to replace pedal...now im stuck
- anyone knows who or how to remove a broken bolt?
- Question regards Thermostat B16/B18
- JDM conversion? IL
- valve leak on tire
- 98+ conversion install question
- How to clean CIA?
- Acuraparts247.com ITR sway bars....FYI
- whining coming from under the hood--HELP?!
- apexi vafcII settings
- Cruise control out
- newb to lowering springs!
- darn it.... pulled that nut/stud off the head,...for headers...
- rpm problems...
- 93 integra strut bar
- type r lip
- 93 integra bumper lights
- looking for specific conv headlights!
- head bolts reusable on FI vehicle?
- rattling noise.... help!
- Stolen 4dr GSR.... *sigh*
- civic springs in a teg?
- INTEGRA ONLINE MANUAL
- Good place to buy an OEM 1998 integra radiator
- GSR dyno numbers
- wrecked my teg!!!!!!!
- resurfacing flywheel
- Rollbar and omni power
- integ with a h22 swap
- Help with underdrive belt sizes
- HELP!!! GSR guru's- come play the new game show "WHATS THAT MANIFOLD!"
- Am I asking too much??
- im stumped!
- Brake pads
- Passenger side Mirror and housing
- changing real wheel bearing/hub assembly on 91 teg
- Whats a good radiator to get
- turbocharging questions
- tranny problem
- What if?
- for civic 2003
- for civc2003
- hondata ecu problem!
- Anyone ever taken their Headlights Apart?
- cel 41
- 2.5" Outlet for a GSR header?
- Crazy Rattling!
- Glove box question!
- Curious on rim look!
- Si Seats?
- clutch and flywheel set up
- Will it fit ?
- Wheel size?
- Will my car pass smog???
- Koyo or Fluidyne Question.
- y1 final drive?
- breaking in lsvtec
- 90-93 Integra stock flywheels?
- An odd engine setup... advantages?
- I Need to know if 1996 Integra LS is OBD1 or OBD2....
