- Paint?!? where?/How much $?
- Thermostat
- turbo or all motor gsr
- type r front end
- 94 - 97 integra amber bumpers
- can i do this (is it possible)
- does anyone know if i can install the jdm power folding mirrors on my da without power option?
- Best place to get Driveshaft Shop Axles??????
- traction bars
- Bogging down low in first
- help with buying a teg
- Use TRANNY fluid to detail car?
- What is the oil pressure and oil temp supposed to be on 00 GSR???
- Cleaning Carpet...
- O WTF - Starting Issue
- Just checked codes. 8 and 9
- 94 thermostat
- wiring for power doors??how much $$$$?????
- Skunk2 single bend shifter or dual?
- Quiet Hi performance exhaust??
- LS Turbo kills
- Power Steering Squeak
- P0171 Too Lean (Bank 1)
- brake caliber upgrade
- iac/itv question ?
- how wide is a stock 2000 gsr throttle body...in mm???
- Quick question
- SRI thats fits in stock factory airbox...
- Timing belt change, need tips
- help solve this idle problem (searched)
- question about slipping clutch?
- faster revs?
- spedo jumping.....vtec off and on
- What is ERR-3? (please help)
- motor mount insert replacement techniques..
- Quarter mile times four door Gen3 integras?
- Road Noise
- well my axle broke while going 75...
- time to do the timing belt, just need some verification on parts..
- fog lights won't work!
- changing a thermostat
- gsr intake manifold removal
- How to tighten the Rear Lower Control Arms
- wiring diagrams
- LS/VTEC on my 95 teg
- Another Surging Problem PLEASE HELP
- wanna take power steering belt off
- Halfshaft replacement
- Alternator installation help
- OEM Optional Kit for 1St Gen Integras?
- Ls vtec bottom end
- can somebody identify this exhaust????
- Bad to drive with out a sway bar??
- S2K seats w/ headrest speakers?
- ecu questions...
- Found a small patch of body rust
- window visors
- Rear way bar and lower tie bar
- TRANNY question HELP HELP
- NEW TO THE SEEN NEED SOME TIPS PLEASE
- back fire, breaking up which ever one
- torque specs for things that hold the cams down
- How do i retard the ignition?
- Whats the fuel pressure psi supposed to be on a 00 gsr??
- v-AFC???
- Post your Rota's that are on your green teg!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Broke my rear lower shock bolt.. HELP..
- gsr Header?
- Idle Issues
- problem with DC4 not wanting to turn on after engine becomes warm?
- Checkin for codes
- ???? bout gsr intake manifold ?????
- 91 Integra doesn't start, help!
- 94-95 Accord Fog Lights
- Will a 95 LS outer tranny case fit 95 gsr tranny?
- Quiet muffla?
- leaking tranny fluid?
- 1st gen integra owners out there?
- HID for 96 Ls
- O2 Sensor Code
- Wiring My Lights
- B18B best hp gains?
- UGR or Omni coilovers?
- 15's or 16's ??
- opinion on this headlight..plz
- b20 turbo help
- Need Help Rear Trailing arm bushings.
- Both Headlights Go Out At The Same Time.
- crx mudflaps on a da?
- General Tune-up..
- Suspension questions
- wait...you mean koni yellows can adjust ride height?!
- question about side markers???
- Pic Request-Megan Exhaust on DC Integra
- Integra Colors...
- ***How-To*** Install Valve Springs & Valve Stem Seals
- 91 DA9 motor mounts
- wheel width question
- Carbon Fiber lip for sale!!!
- Thinking of buying an integra...
- blox a spec camshaft ????????????
- H22 FPR please read yO!
- i have a 91 ls that needs tranny oil what oil does it get
- Dynamat Effective?? Also - Should i repaint wheels??
- Do I need a camber kit?
- Fog light question
- ys1 lsd vs. s21 y21 lsd
- what alternator belt for b16 in 1990 Integra LS?
- Engine cutting out when raining
- Got the rounded bolt off !!!
- Spark Plug Wires?
- Rim offset for DC2????
- B16A firing Order - ls halfshaft and ECU etc./.other Questions.
- First Gen Motor Project
- Hi i'm noob to this site as well
- Help with car shake(I think I
- Which belt is farthest from the block on the crank pulley?
- where can i ..?
- Thermostat question...
- tranny making wierd noises + poping out
- good summer coolant/water mixture?
- Lowering 1.7in. need anything to correct alignment?
- Motor Mounts............
- ? about these side skirts
- 00 integra GSR Engine Specs needed
- suspension...
- STOLEN INTEGRA. SAN DIEGO 92108 PRIMER BLACK JDM FRONT
- Flip out lcd in a second gen teg
- Need help id this..
- Hardcore Motor Vibrating
- Coolant overflowing, 92 integra half rad?
- stripped a subframe nut
- CARBON FIBER LIP ANYONE?!?
- ecu on 89
- Dc2 exhaust fit an eg ?
- anyone tuning crome in VA?
- Trailing amr bolt walked out
- belt tensioner
- Si-Vtec Fog Help!!!
- d16a1 help please???
- Cruise Control Removal???
- camshaft
- Wiring help
- Need Desperate Help H.T
- cooling problem
- what is this
- Hey, new here and looking for someone...
- Azenis/sizing
- Pulling an engine?
- Clutch installation price???
- K-Sport coilovers
- Wich NGK plugs?
- 89 integra
- 17" Miglia wheels/tires f/s 98% tred
- 4 lug itr wheels
- Two O2 sensors in 99 GSR CAT? Options avaialble?
- manually opening IAB
- My new WS2 is TOO quiet!!
- 1994 Integra sunroof/moonroof different from 95-01?
- clutch break in?
- 92 Integra driving side and pass. side harness help
- Voltage and Ground Systems
- set timing
- wtb- 94-01 shell and ek9 shell
- Adding tranny fluid (i've tried searching)
- Steering squeaks...Any fixes?
- Filter's almost dead on the GSR...What should I get (air filter)/or new intake?
- How To Diagnose This issues. Tie-Rods perhaps? No Clue
- Chipped power steering pully.......
- Chipped ecu?
- Trim
- obd2 -> obd1 problem
- headers?
- Idleing problems after taking car out of storage.
- 1990 integra
- gsr and ls exhaust
- Interchangeable parts from a 95 GSr sedan from a coupe?
- What yall think of the 95 GSR sedan vs. coupe model...???
- amber side corners on DA yes or no (pics please)
- Drop Springs that fit multiple applications....
- shifting noise and low idle on DA
- Anyone has image of Yakima roof rack on Integra?
- what camber kit on DA
- fuel ?
- Spec clutch?
- how much weight can you take off interior wise
- Need some info on rims and tires!!!!!!!!!!!!!
- Clutch problems
- Headgaskets?
- SUSPENSION NEED HELP VERY BAD!!!
- is an ls motor an interference motor
- friend wants to sell me some exhaust parts.. what do you think?
- 2 Piece Cold Air Intake?
- One headlight is dimmer than the other..checked voltage/ground, SAME problem!
- Trouble Taking GSR Flywheel off
- anyone heard of XTD clutches?
- VIN translation
- runnin lights not workin
- Crank pully bent? crank bent?
- neuspeed front strut
- dc4 front lip
- Royal Purple Max Gear?
- I hate those dam construction trucks and 18 wheelers!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Fuel rail bolt question?
- anybody got pics of the spoon dc2..the yellow and baby blue 1???
- What the hell dose this sensor do?
- what shipping company does HMO use?
- Ls trottle body Fit on a gsr??
- Fuse Box Cover came off?
- spoiler for DA?
- clutch upgrade
- 00 Center console need help ASAP
- Liquid in spark plugs 2 and 4?
- Is a second gen b16 obd1 or obd2?
- seering wheel removal?
- Koyo Radiator on Ebay
- Where to find bumper plugs?
- Can't Get Caliper Bracket Bolt Off
- FS: Tein Bonnet Dampers for dc2/4 integras
- bad gas mileage
- Grinding noise from tranny when clutch not engaged????
- wierd rattling sound in front end
- master cylinder help!!!!!
- 94 gsr windows fogs up
- ITR headlights into a DA
- Rattle clacking noise help!?
- So who has replaced their distrubutor (dizzy) before?
- xs power cams? better than skunk 2?
- Front End Damage...
- Exhaust system help
- Replacing Radiator on 98 Integra LS
- went for dim sum...FUCKING THIEVES!
- side marker installation on DA
- Work Meister do they fit dc2 ?
- ENGINE LIGHT ON!!!!! RESET!?!??!?!?!?!?!?!?
- what motor to choose for DA
- pillow mounts squeeking?
- Losing Oil !!?? HELP!!!
- ***How can i Turnoff/disarm stock alarm? All integers Help
- Overheating problem.
- STATUS RACING SEATS
- Newbie question about spoon sports radiator hoses
- Installing a fuel-air gauge
- is there a way to check if the master cylinder is still good while it is off the car?
- HT Integra Modifications, your personal favorites (any mods)
- input on engine build for dc4
- ecu help. (searched)
- Help with rear speakers in 4 DOOR!!
- what rim is this?
- geeser
