View Full Version : Acura Integra
- my transmission?
- Off brand vs brand name HEADERS
- Where To Purchase Type R Transmission?
- Which year of the gs-r is considered best?
- authentic stock type r muffler
- did a compression test...
- need help with A/F, oil temp, & water temp wiring in to 97 h22 teg
- Same as ITR chassis?
- ways to figure out if it's a b16 tranny or ls tranny?
- MPH goin stupid
- I need help with an inspection problem
- Integra LS Header
- Problem with gsr swap
- car not starting up
- Exhaust Questions
- stud snapped
- Valve lash adjustment tool
- Mix and Match
- special socket for flywheel bolts?
- header question?
- Jumping and/or Erratic Idle
- *SEARCHED* DC2 Can't find main relay
- Quick GSR Manifold wire question (which goes to IAB and IAC)
- i need the torque spec on pressure plate and clutch for a 91 ls
- pressure plate and clutch install
- B18 BLOCK
- horn wire ripped.... how to fix?
- spoiler or no? and why?
- "aftermarket" bumpers worth getting?
- DA integra how do i remove/shave the rear wiper?
- 93 Integra GSR- HELP
- buddy club spec3+ question (searched)
- what are the best stage1 cams out there?
- 5 speed swap underway...
- Timing 55 degrees help me!!!
- Are windows supposed to work after car is off?
- Stock inserts into hasport mounts?
- hi im new
- GSR WILL NOT START...RAN OUT OF IDEAS
- Keyless entry/alarm installation for DA
- Burnt up spark plugs
- bent control arm?
- Noice car.. but yarr what rims be these?
- HELP!!! CAR ISNT SHIFTING RIGHT
- aftermarket front lip question
- Grinding Noise In Clutch At Start Up
- what kinda sway bars are these?
- Front end question.
- Flatblack, i need your opinion
- A/C question
- im so confused!!!! please help
- need downpipe for turbo
- LS head gasket or GSR head gasket on a LS VTEC?
- Bumper question??
- water in the taillights
- catalytic converters will they fit??
- Skunk 2 intake manifold ls no vtec Problem after installation!
- Crower
- NEWBIE need help with strutbar
- Engine compression was not bad but hydrolocked??
- funtion/form full coilovers on a dc2 integra...anyone got em? If so tell me how they are
- strut bar install
- how do you remove the metal clamps inside an oem gsr exhaust tip?
- throttle body gasket....NOTHING!
- what lube to use on sunroof track
- Tein upper pillow mounts... great or ok
- ls brakes vs gsr brakes
- WHAT TIRE SIZE?? 195/55/15 or 205/50/15?
- Engine Noise On B18c1
- Backfiring/Stuttering With Rough Idle And Jumpy Speedo
- Should I get keep SI rims or get the 95 Fat fives
- What grease to lube window rails?
- Throttle bodies??
- apexi world sport exhaust
- Paint Question
- 3 Consecutive mornings my car wont start ??
- Which Header should i get?
- clutch alignment tool
- Anyone ever purchase a Clutch Slave Cylinder from Autozone? Reviews on Autozone?
- some help asap please
- Type R front conversion help!!!
- GSR valves
- function forms w/ no bumpstops?
- Titanium Valvetrain and clutch
- new pics
- just washed up the teg and decided to take a pic or two. hopefully picking up my lights tommorrow an
- engine knocking
- Where can i buy this kind of lip?
- vtec prelude in integra?
- How do you bypass a clutch for 01 gsr for remote start system?
- p72 ??
- Unusual Noises
- Front brake line from MC???(Non ABS system)
- Where can I buy the oem kit for a 94-97 teg?
- b18c oil squirters
- Adjustable cam gears
- +40
- COMPRESSION TEST LOW!!! & SHIFTING PROBLEM!!!
- Is there a difference between the da and dc rear calipers
- b16 header problem
- for the people that suffered low end loss with aftermarket manifold
- Integra Engine Oil Leak
- OEM
- code 65, car bogging
- Im a newbie and need some help taking something off
- GSR Wheels
- Clutch Squeaking Sound
- why can a 99 gsr 2dr beat a 96 gsr 4dr
- goddamnit!! my integra is starting to piss me off.. power window related.. plz help!
- 98 integra front end conversion
- cams and prices
- coolant leak!!! in dire need of daily driver!!
- b16a swap questions
- thinking of buying, whats it worth?
- Cat questions (searched)
- Car won't start
- Damaged Valve guide? How can I check?
- price on used OEM 98+ headlight for Integra
- do factory plug wires have yellow dots
- what are some replica type R rims out there?
- painting my car poll
- I stole you guys' lip :P
- Interior repaint?
- Crankshaft Knife
- 93 DB2 ITR swap
- starter fluid
- cover around wipers
- 1997 RHD Acura Integra GS-R
- OEM Acura Kit
- Going to smog my car soon! Need some advice!
- code 29????? help?
- Antenna question
- Finding somewhere to BAR a car in SoCal.?
- 4th gen prelude seats in da?
- should i sell my gsr
- windshield wiper nozzles
- 5th Gear Grinding
- 95 integra ls for sale!!!
- Fastbrakes?
- How does this exhaust setup sound?
- quick lsvtec question
- speedometer
- How Can u increase torque on a b series??
- 95 gsr not turnin over
- gsr block ls crank?
- ECU or Chip help please
- RPM fluctuation?
- 1.5 or 1.7 drop
- Need Help on which Header to buy?!!!!!!!!!!!!!!!!!
- DA integra parts: where do i get these??
- DA or DC4.. which would you choose?
- Shift Lite
- power locks from one car to another
- Somewhat new 95 Teg GSR owner
- Chipping ECU
- Current engine turbo'd or??
- H&R sport or race springs??
- WTB: 1 Fat Five Rim for a 95 GSR
- Looking at GSR rims
- Blew piston ring in b18b1 with boost I have a question.
- OBDII for 95 GSR?
- Obd2-Obd1 conversion idle problems
- Torque, preload?
- Changing out my timing belt...what else should i change
- tranny bolt help
- fireing order
- B18B1?
- COOLING PROBLEMS AND IDLE PROBLEMS SINCE SKUNK2 IM INSTALL and CEL 43
- Skunk2 IM w/ Skunk2 TB on gsr question
- changing my timing belt.. got a question.
- Buying a new car.. opinions...post em' all
- Intake questions..
- posting pic's lesson for a noob.
- Knockoff skirts anyone??
- JDM S2K seat swap with DC2 seat parts
- Mr. Smiths Laguna DC2
- question about ls vtec
- itr rear sway bar on a 97 gsr?
- GOOD half size DUAL core radiator for b18c that wont break the bank ???
- steelies?
- exuast system that looks stock
- JDM front fog light + city light question
- Adjusting Clutch on Cable Tranny
- CEL came on when RPM's > 5000??
- Back up lights don't work what now?
- where to get wires for this switch *pic*
- lookin to turbo...need help
- rotten smell?????
- Question about Angel Eye headlights
- Should I buy this Integra?
- Distributor is not getting spark.???
- ECU chip help!
- DA Integra:Seat Rails, Engine Mounts, Front X-member?
- buying a chipped P28... HELP?!
- B-series Tranny's?
- 94-97 teg rear valences.
- VTEC sound changes due to air intake?
- where can i get this?
- Maint Requ Light
- NEW TO HONDA TECH!
- ls vtec setups
- EF engine mounts in DA?
- GSR water pump or b16 waterpump?
- I need help idle problem?
- Shift Linkage question.
- possiblity
- Rear trailing arms?
- Transmission Bearing Kits?
- Oil Leaking
- happened to me...
- Feedback about my set up
- My suspension progress...
- timming belt
- Del Sol radiator question for b series motor
- Itr header on a 90 DA.
- Where can i buy gears for my 91 manual transmission?
- fuel filter is leaking, help?
- my sterring problem
- Need new Catyltic Converter input por favor
- Oil coming out between, head and block on right side after head gasket change help!
- How to tell the difference between a JDM B16 92-93 XSi Swap and all other JDM B16's???
- Here is mine
- Are integra wipers slow?
- Integra LS or GSR
- Clutch Pedal wont come back up
- carwash
- testing
- Car wont idle below 3000... Help me!
- Chipped p72 solid cel........Help!
- MOTOR SHOP, DENVER
- 1999 INTEGRA FRAME RAIL
- Worth doing a b18c(type r) engine swap?
- Need help to turn off the light for the "Maintanence needed"
- Need advice on removing blower motor!
- obd2B to obd1 Schematic?
- Anyone with a rattling Integra?
- Thermostat fluctuates..wtf!
- Rear defrost doesnt work anymore!
- "bumping" noise on clutch release under low speed & rpm
- Coolant in the cylinders?!?
- Car killing batteries?
- how to: everything
- gsr/b16 cams
- Car wont start...
- GSR tranny problems
- Is this true, Found it on Wikipedia.com. pretty cool
- First Teg and I have some Noob Q's
- Buying an Integra
- What Lip is this and where can I get one
- dropzone items
