View Full Version : Acura Integra
- 94-95GSR (the one with 4 round headlights)
- How can you tell if you have H&R Sport or OE???
- Exhuast Question
- strut bar on 90-93 integra w/ abs
- Does anyone have a sparkplug cover for a b18b??
- How can my VTEC kick in at 5000rpm?
- Small cracks on the crank
- Skunk2 Short Shifter
- High flow cat smog legal?
- B&M fuel pressure guage leaks
- Skunk2 Exhaust
- questions about dyno
- Code 45 ownz my ass for $223 bucks
- EVAP purge question (and oil and idle question)
- Quiafe LSD
- Can a stock automatic 96 ls integra beat a 90-96 stick hatch back?
- v-afc fries ecu's?
- Can a automatic 96 ls integra beat a 89 stock crx hf?
- What is this fuse for????
- Does Honda make black center caps that will fit LS Mesh?
- anybody with carfax
- dyno on long island
- Please Help w/ Removing Inside Panel
- how much would you pay for this car:
- 94-97 vs 98+ rear bumper???
- autometer a/f gauge
- which cat??????
- Acura Parts Online Cheap?
- Got scammed by turbobboy.
- Will a 215/40/17 tire fit on 17x7 rim with 40 offset ???
- Power Door Lock Problem/Question
- help: install shocks..
- Will a 97 GSR catback exhaust fit on 01 LS???
- Need Help! 93 Integra broken into (window smashed)
- Lip mounted wheel weight on stock wheels. Can it be removed when new tires are put on?
- One-Piece headlight on 91 teg!
- my a/c isnt cold..had my freon recharged and it didnt help, what should i do next?
- comments on this suspension?
- So I ran my fender lining over today
- remote starter goes crazzzy
- One touch window switch
- What combination of bars would best compliment my setup?
- Skunk2 Coilovers VS Springs
- Integra vs s2000
- RS integra
- Will 95 civic Ex driver airbag fit on 95Teg??
- Redirecting AC Line?
- boosting b18b obd2
- aem air bypass valve
- Group Buy suggestions?
- Gas tank
- will TYPE R header + full exhaust fit a integra LS ???
- headlight slowly cracking? Just old?
- B18b engine question
- Quick Question................
- TACH SIGNAL WIRE, PLEASE HELP ME! =(
- checking engine trouble codes
- automatic motor into a manual car
- Mount Bolts
- CR-V Crank Pulley Question
- Burning smell when i shift?
- Need help finding a part number...
- looking for fuel injector
- horrible screeching sound
- dont know where to post this....
- Need Help With Emissions Testing On My Integra (exhaust/intake)
- Friend passed away on Saturday... Racing :(.
- slight rattle from 3.5K-4Krpm???
- COPS !!!
- itr shift linkage vs gsr shift linkage
- What can I use to plug up extra holes left from Type R spoiler???
- DC Sports JDM 4-1 Header Question
- this is for my CRV(b20B).. it drives normals but at slow speeds.. it stalls...??why?
- what is the ecu code for 94-95 manual ls
- b18b internal coil question
- ENGINE CONVERSION ON THE 92 TEG LS
- Looking for product demand: Wheel spacer and extended wheel studs
- Coolant leak
- NEW AVATAR THNX TO Seprioth64
- homebuilt exhaust.. should I use flex coupler? Also, which muffler for B18A1
- RE: Got Busted Racing... any help please!!!!!!!!!
- AC Problem
- i am in desperate need guys, please HELP
- need a part number and acuraautomotiveparts.org is down! help
- Brake Caliper Rebuild....
- Fast Brakes goes long....
- Got Busted Racing... any help please!!!!!!!!!
- a lil abs question for u guys
- starting up the motor
- any1 have the ABS plastic type R lip?
- ctr intake cam problem.
- help me take off my aibags please...im begging
- stripping the block
- S-AFC hack ?'s
- question about blower motor... for the AC/heat inside car
- Skunk2 Camshaft Problem
- Exhaust Ticket...But wait in FLORIDA!
- Help radiator fan and cooling fan comes on at same time
- diy: hood latch cable relocation
- BRAKES
- what you guys think about Ingall Cmaber kit??
- itr distributor
- finally got header on :)
- What tire pressure do you set your kumho 712's at?
- strange noise after cluch/flywheel install, help...
- Would throwing a turbo N1 apexi muffler on a NA car be a mistake........
- trouble starting my 91 integra
- is my 98 4dr gsr worth 12.5k?
- What should I offer?
- how to drive
- will the Ingall camber kit from a 91-93 teg fit on 94+teg??
- will this fit?
- Hondata for 1990 LS motor? (PR4 OBD0)
- j's intake + skunk 2 manifold =
- 93 integra fuses
- how reliaible and fast are turbo ls i want to see dyno # and pics
- squeaking sound when shifting?
- ITR exhuast, worth it or not?
- Two 95 GS-R's im looking at Wich 1 to buy??? plz help
- cam caps
- Anyone Try the Venom 400 Control Module??????
- Recalibrating gauges
- need help fast
- Eagle rods or stock?
- 99 Gsr wheels powder coated black or painted gunmetal.. Pics??
- Tranny going bad
- S-AFC mounting
- Rear Seat Removal Regrets?
- hail damage - need new hood - questions
- What year console is this???
- h22 or ls/vtec
- timing belt
- how to install a/c belt?!?!
- 60 foot times w/ stock suspension
- what is the best headers for 96 gsr?
- anyone got a link to purchase a aftermarket OEM integra hood?
- Integra with jdm itr conversion , radiator, fan fitment
- Compression Test
- 200whp
- Directional OEM integra wheels?
- radiator fan..push or pull?
- car super bouncy after energy suspension install
- hesitation ?
- A NOTE OF WARNING: SO CAL
- Car dranks, but wont start! HELP!
- Any thoughts on the best (aftermarket) LS cams for STOCK valvetrain?
- That A/C line that gets a hole rubed in it from CAI's...which ones will fit?
- what size is my stock exhause pipe on 94 db7?
- Help identifying clutch disk - T30H04?
- Quick Header install question!
- rubber board under radiator question
- No turning signals on a front bumper, but need them!!
- are my Gun-metal GSR wheels from the factory???
- 92 LS... OBD0 or OBD1?
- distributor ticking
- rs*r exhaust for 2nd gen integra?
- neuspeed race uneven drop? right/left sides
- oil cooler sandwich adapter
- 15.3 @ 92....
- Would anyone in here be interested in honda-tech.com plate frames?
- ECU Questions
- ATTN: Auto-Manual swap owners
- CAI install...
- Headers ?
- Short Shifter???
- Electrical Problems with new car!
- JUN Headers
- Check Engine Light w/ Test Pipe for OBD2?
- Whats the difference between rs, ls, and gs
- would itr valve springs and retainers be a good combo with skunk2 stage 1 cams?
- Could I get a stock ITR muffler to bolt on to mine?
- Post your JRSC GSR 1/4 mile times!!!!!!!!!!
- Integra Transmission Swap
- will 99 si pro - kit springs fit a 99 gsr
- buzzing noise at really high rpm (around 7.8krpm)
- u guys think k&n is the best filter to use from experiance?
- '92 Interior floods!
- Koni yellows come with bumpstops..>?
- DIY Grounding Kit Question... (yes i searched!)
- j's intake on gsr...does it work??
- Clicking noise from engine bay help please!!
- skunk2 stage 1 cams or ctr/itr cams?
- ported manifold and larger throttle body!!
- 92 teg b16a vtec question
- Does Greddy SP exhaust 60mm = 2.25 or 2.5 inches??
- 94 LS turbo Project Help
- For those for 3rd gear syncro problems
- Carfax help
- Problems with OEM fogs...
- Apex'i Dunk, lot's of Pics....
- window coming loose
- Getting a turbo next week, I need to know what to look for...
- clutch questions . . . .
- got my check today...
- EVAP solenoid
- obd1
- ls vtec questions????
- drag turbo kit for my 91 LS teg?
- H&R OE Spring? How much gap between the wheels and fender?
- Engine VIN
- Stuck idle?
- domelight bulbs are 3022???
- 1/4 96 gsr?
- Camber Kit
- Will a 1998 Integra Type R ECU OBD2 Fit 96 GSR?
- EXHAUST
- Clutch and Header rec ommendations.....
- Anyone know Len's # at Baranco??
- Can you change OBD2 to OBD2 for gsr?
- DA and DC2 integra sway bar questions....
- gasket questions
- I Need Help with MSD-Boost Timing Retard!
- squeaky clutch
- Help Help oil line for turbo
- ls vtech
- Installed comptech icebox w/ stock intake arm and aem filter..
- engine bay and up prob
- Help loud grinding noise!
- Apex'i N1 vs Apex'i Dunk...
- WTB either CRX, EG Hatch, or an early 90's Integra. Please help.
- Alignment Questions Alignment Tommorrow!
- 94 GSR, stock rims, these springs, enough of a drop?
- Quick q for ls owners with aem cai.......
- HELP: ignition timing
- usdm b16a pistons!?
- type r cams?
- GSR Gear ratios/mph...does this seem right?
- will the swirly gsr tires fit on a size 15 x 6.5 wheel???
- HKS Hiper
- VTEC head removal step by step?
- Update on Cross Threaded Bolt
- Strut compatibility???
- Rota C8 Question
- how much nitrous to use?
- stock rs auto 1/4 time?
- spoon N-1 or apexi N-1
- Selling my spare 94 LS
- question about insulating wrap
- Aiming Headlights after HID install
- oulThrowing code 67 ... Catalyst problem
- My car got broken into...
- what would you think about a b16?
- Torque Spec. Starter 95 GSR
- Anyone run smaller LS cams? Crane #12 vs Crower 62402?
- How much for OBD2 - OBD1
- EXAUST QUESTION
- Just got a clutch installed
- Need suggestions about rims.
- All are OB2->OBD1 harnesses made equal ?
