View Full Version : Acura Integra
- Spoon/itr cam setup?
- Koni Yellows adjustable before install only?
- great suspension info
- 92 Integra engine swap?
- Who sells cans of taillight tinting spray?
- Hard to put in 1st gear when cold...anyone else?
- motor mounts
- Interior Colors?
- woo haaaaaaa, no tech-topic here, just pics with my ITR lip! YAY!
- coilovers vs. lowering spring
- AGX set on highest setting...is this bad?
- Please help me with fuses so I can get home!?!?
- Sold Integra. Now what?
- B16 Intake manifold on LS?
- Black or white rims for a black Integra?
- fuse box diagram??
- Car tends to bog on cold starts PLEASE HELP!
- Symptoms of Blown Shocks?
- ABS and the ebrake...
- comptech sport springs vs. eibach pro-kit
- my quarter mile times
- ls/vtec question
- Keyless Entry Remote Needed! Anyone have a hookup?
- Where can I get an ITR Cat-Back?
- LS exhaust question
- ITR VS DC Sports VS JDM Header
- Fuel Additives?¿?¿?¿
- IF THIS WAS YOUR CAR...
- Heard of cross member support upgrade by Benen? look inside==>
- please HELP with my wheels
- g3 integ part questions
- ITR Fuel Injectors???
- Suspension Performance Comparison
- Head and longblock...
- CSUFWEED - What mods do you have on your car?
- Suspension problems....
- lateral g's
- FuelPressureRegulator??
- One more time: BRAND NEW '01 ITR cams
- short shifter rattles....
- ITR HEADER - WHEEE!!
- idle noise is drivin me nutz!!!!!
- what all is needed to do a jdmb20z swap in my 95 ls
- Having Problems making 98 ITR rear seats (bottom piece) fit in a 95 GSR
- diesel engine noise
- AC Autotechniques Gauges?
- ITR cams with stock valvetrain
- How to fix cracks in WW lip?
- What to do about suspension
- hp differance b18b jdm b20b
- where can i get a jdm b20b
- My Car
- b20b swap
- Crappy night at the Track
- is a b18b turbo kit compatible w/t b20b
- suspension noise
- brake disc width
- Got my car back - shifter vibration
- How to Install Spoiler!! HELP OUT Folks!
- Which thinner headgasket to get?
- How can I reach bolts through bushings to torque them with the car not jacked?
- Pulling dents?
- Turn signal/parking lights wiring
- Gauge problem, need help.
- Dealer service: (Scope&tune engine)
- Air/Fuel Meter Question ?
- 99 GS-R and LS exhaust
- Whats the biggets tire i can fit on a 96 gsr?
- Sheet metal JDM type r conversion.......
- comptech axle back
- Check engine light, too lean or too rich
- DA 90-93 suspension question
- AEM or ice box
- CONFUSED:::driving/fog lamp installation instructions--HELP!
- black gsr wheel ?
- Is this a sign of the master brake cylinder going out?
- suspension ok?
- Bad engine Smells~~ please help
- What is DC2 and DC4? is dc2 94-97?
- oil filter wrench?
- Problem w/ guages lighting up?
- How to prevent clutch master cylindre failure?
- Mission Accomplished: Toda FW and ACT HD-SS Installed
- Well....My Jun 3 cams broke....Pics inside
- Fuel Filter Banjo Bolt
- A/C Belt installation - how difficult is it?
- Low END!
- High Temp paint for intake / header / other engine parts
- strut bars for a ls...
- squeek....chip...shut up!!!!
- Catcon help...
- Hesitation on cold acceleration
- no one has a MT radiator in stock, all AT radiators...any problems?????
- Oil leak in intake manifold HELP
- What springs for the gsr?
- Tire choice: Kuhmo 712 vs Used FZ4's .. (read)
- is the 99 LS head the same as 94 LS head?
- Driving Lesson
- Torque is the key
- Valve Adjustment Problem
- Auto meter air/fuel guage install which wire on ecu on 92 GS-R?
- KYB AGX's
- What the...!!! Dinan Stage II
- K&N Air Filter
- Resonator Box Removal
- Question regarding upper strut tower brace for 99 GSR....
- JDM Tranny work on US car??
- Instructions for ES Motor Mount Inserts
- Throttle Body Upgrade
- 2nd Gen cross member question..... jdm 4-1's?
- HID's on GSR????
- 40HP for $G
- quick kumho question
- 5 lugs!
- wheel locks/lug nuts?
- changing front tower strut bar...differences?
- Fuel Managment question for a B18B with these mods.....
- Brakes warped.......AGAIN!
- Looking for a 98-00 integra front bumper
- Pirelli P7000
- kyokugen lug nuts??
- Fixing AEM CAI Rub??
- need help with internals of distributor
- ITR clutch on GSR?
- hybrid insight seats in a integ..wut u think??
- Help putting on lower rear tie bar..
- Skunk2 Intake Manifold!!
- Who from NYC is goin to the Meet on 3/16?
- what exhaust is tuned for the integra??
- Air leak?
- new guy here.. wats up (help please)
- jacobs i.c.e. pak ignition system
- dyno tuning
- where to go to get a chip soldered into your ecu??
- Stock Bumpers and headlights
- need some insight
- OEM keyless entry for my '00 GSR??
- IDRC IN PHOENIX THIS WEEKEND!
- Will a 99GSR stock header fit a 94GSR?
- Gab shocks??
- Size of Window Washer Fluid Resivoir
- Shaky after 60mph
- Need some help
- Need help with my teg....must have more power!
- hayme or n1 muffler??
- Anyone w/ a Stock GS-R and a G-Tech Pro?
- Suspension?
- Does anyone have this setup
- ECU pins
- skunk2 manifold install. what's needed????
- will these tires slow me down?
- check this news coverage...
- OT: Trading in Integra for new car..
- can u get 190whp off of 1.8L?
- slower on light 17's?
- What price to pay for GC Adapters to put on Koni Yellows? and Do i need them?
- does gsr cat fir on ls?
- Car shaking when starting
- Tokico Illumans and eibach sportlines anyone?
- Newbie.. Bought a Tegra... Came to the Darkside :)
- LS header fit GSR?
- Koni Yellows, what does it come with? and how do you assemble it?
- ANYONE RUNNING A DFI SYSTEM IN THERE INTEGRA?
- ok got my new 1/4 time
- cut outs...
- BEST HEADER...
- Need answers quickly
- dynoed the POS today, comments?
- jet chip? venom400?
- Diameter of Comptech headers and exhaust?
- What should be my next mod?
- 94-95 gsr ecu
- what r good shocks for 93 teg?????????
- Anyone know the outlet DIA
- GSR head
- fuel filter 1989 - how to remove?
- Which styling do you prefer: 98-01 Integra or 2002 RSX???
- Is the Apex WS as quiet as everyone says?
- has anyone order from JCwhitney.com?
- 92 GS Swap Question (need real teg techies)
- Weight of a 94-01 Teg Hood????
- FYI 1st coolant change: Just DRAIN and REFILL
- Which front strut tower brace is the best?
- QUICK HELP!! do i have the wrong ECU or what? tell me what could be wrong!!!!
- Fuel light
- My New SHOES! now where to go?
- Engine question
- Tire Pressure
- hesitation during acceleration
- Track Day @ GingerMan Raceway
- What Program is best for this setup on a p28 ECU?
- Did I mess up my tranny
- Road noise, and now a clunk..CV?
- Prop from ArchAngel...
- question about brakes???
- New Cat Offering
- Import car SHOOTOUT
- Loud Squeaking?
- gsr brain
- Charging System
- GReddy air filters?
- maxspeed coilovers?
- Will My Apexi VAFC or other electronic controllers memory be reset??
- anybody have 95 gsr dist part #?
- Apexi GT spec header
- Car for sale- lots of parts!
- Integra Radio
- Insurance question on your GSR's......
- Group Buy on 70mm Kakimoto R exhaust.
- Skunk 2 mani
- If you have the Skunk Intake manifold....
- I need help!!! Is this a gsr motor?????? LEt me know.
- FYI: Buy now at your dealer!
- Anyone Like Their GSR - Cloth Seats, Any Pics Available..?
- badly in need of a car fax report please!!
- SS Works 11.8" 4-pot brake kit...whaddaya think?
- headlights diff on front ends?
- turbo GSR or supercharged GSR need opinions
- OEM Body Kit
- Got skunk 2 ecu with no rev limiter how do I add one?
- FREE stuff
- Engines for sail + deals
- Don't worry about this, unless you live in NM and your initials are JB
- Problem with front corner bulbs?????
- finally installed my AEM CAI..!!
- fs jr supercharger for ls,gs,rs
- 5zigen Heidfeild wheel?
- So Acura gives me an RS-X Loaner
- Anyone going to the 12 hrs of sebring need a place to crash/party???
- fs: greddy header
- Ladies and Gents, I present Maggie and Friend
- Neuspeed rear tower owners *help*
- Iceman or aem
- 2.5" too much for stock GSR?
- Car running Rich
- :Interesting Question about front lights:
- Wanted, sunroof switch......
- Hot S2K antenna tip...
- are jdm and usdm honda pistons rings the same?
- Any problems with Field VTEC/SFC on OBDI ecu?
- more suspension questions...
- I need some pics of 93 Integra ls's...
- Integra Axles; max horsepower.
- how to fix passenger coupe seat in my 94+ integra
- debate: JDM gsr.. skunk2/chipped pr3? or JDM/usdm gsr ecu obd to obd1 conversion?
- What would you buy for $21,000
- Any info on whats required for factory fog install?
- few questions about 00 gsr.....yes i searched
