View Full Version : Acura Integra
- Integra SiR-G major power loss after dyno run
- Tow hooks
- Can I cut this vtec solenoid wire?
- intake manifoldsssssssssssssssss
- rear installation for coilovers
- My first integra
- Redneck Lost a Race to me and put a hit out on my motor. RIP my ls.
- B16 tranny make a big difference over LS tranny ?
- Car's Temp gauge...running really cold!
- rpm likes to jump
- gsr or ls fuel pump
- Is there a difference between a CTR Tranny and an ITR tranny?
- HotT or NotT
- MY LS VTEC TURBO
- removing muffler?
- where to find ls IAT sensor
- Exaust
- transmission oil leak
- will JDM DC 4-1 header fit my jdm mugen?
- iacv location need help fast!
- Keep The Teggy Or Get A Civic
- swap labor concern
- Gearing question??
- Car let me down, need help!
- Info. on a gsr tranny?
- B18B w/B16A Tranny!
- Which Honda emblem for DA Integra?
- new to the site but not to hondas
- passenger window doesnt want to roll up
- 95 gsr coolant leak by oil pan
- Transmission and exhaust ?s
- Do the Non-HID and HID JDM headlights use the same projector lense?
- daily driver
- Part #?
- 94-99 vs. 00-01 GSR
- Code 14?
- idle up and down
- CALLING ALL OWNERS OF SKUNK2 PRO-S 1 Piece Coilovers
- WHICH CAR TO GO WITH?
- Shop to do a tranny conversion?
- GSR oil pan gasket same as LS/ GS?
- Idle/misfire/backfire problem???
- h22a swapped g2 teggy for 4 gs... any advice and help would be appreciated
- help catch these theives! CA (san diego)
- New shop opened in Tempe
- Weird Idle
- Does this look like true OEM metal front end?
- need help putting on coilovers!
- axle question
- Type R Cluster Going Into a GSR Problems
- difference between oil filters?
- Shooting flames
- 96 gsr has a rattle at 3k rpm and up
- Just replaced alternator and Car doesn't start *** HELP
- exhaust bolt question
- Idle problems
- Side Markers Specs (DA9)
- Megan racing GOOD or WACK
- What do i need for an auto-to-standard swap? Please help!!
- B18c, High idle (feels like pedal is stuck), ignition timing goes to 0 under WOT then goes to 16 but
- ref tickets?? please help
- coilover help
- db8 stolen
- smog results
- what side skirts are these?
- riped motor mount
- nos on high compression
- All Motor dc2
- need help with part numbers
- ABS problem, code 42
- Can a ls auto tranny fit on a gsr motor?
- really wierd, w/ o2 wont start... w/out o2 will start...
- DC5's for sale in the US?
- how much would this setup go for?
- GSR MOTOR PROBLEM!
- motor swapping
- Has anyone installed LED's in their gauge cluster?
- integra rear seats.
- car catching on fire.
- dash fuse box cover
- will this fit my gsr?
- 2nd Car
- what is this??
- question?
- power steering res. relocation. - engine bay wire tuck/shaving
- LS vtec
- ls/vtec wiring question
- breather box on b20/vtec
- 96-2000 Civic seats into 1990 Integra?
- window visor
- Fatboy in Recaros?
- itr head on gsr bottom end
- Weird Idle, video's included
- 95 Integra for sale
- My side mirror was stolen lastnight.
- Got a problem with my idle!
- jdm 6 headlight bumper
- I just got myself a gift!! =]
- help... del sol seats in a DA
- Hmmm... Stalling when cold
- Is the intake manifold brace needed?? b18a1
- Need quick help, changing tranny fluid.
- lsd!!!
- What's my gains from doing the B20Z swap in my LS???
- 07 Si vs integ LS-V
- help on suspension .
- SO I HAVE THESE SEATS AND........
- Decisions...Decisions
- Turbo guys: what are you using for engine managment??
- motor is seized up...wtf do i do
- 92-93 Integra Lip - What fits and what doesn't?
- HELP BLACK SMOKE
- my integra is acting like a vw: electrical issue
- Fuel Injectors and Ignition Controller?
- oil filter
- i need help with my auto to manual conversion
- ok so this is pretty ricer of me buuut...
- Head Gasket help???
- AIR BAG REPLACEMENT
- water pump, oil pump going bad?
- spark plugs black! running rich? what to do?
- So my girlfriend got me a gift today!
- b18a price
- spark plug sleeve.
- stupid things always happen to me.
- Coolant Draining Really Fast/Overheating. Whats going on??
- Koni Yellow Dampening Setting
- question about new exhaust setup
- crower cams
- Strange blower motor question
- 1992 integra
- integra header b18 to b16?
- Yet another VTEC related question
- Backfire! NEED HELP!
- 97 Ls Tranny Flywheel Hub Ring Seperation???
- b20 swap dont start... help plz
- lookin for pchop pics
- gauge cluster not lighting up
- rocker arm adjusting ?s
- Help ! messed up ignition timing b20b
- wont idle when its cold
- Secondaries not kicking in PLEASE HELP!!
- How much do you think I can let my 95 LS go for?
- lowering a 1988 integra rs 4dr
- Problems with remote
- ITR or DC sport header
- ctr piston.....will it fit without problems? HELP!!!
- engine removal write-up
- how to remove integra 2001 side skirts
- shift bushing install..tranny fluid?
- atmospheric pressure sensor- help fix plzz
- Ignitor Interchangeability..??
- H.I.D. and fm radio........
- Can't Maintain Smog Speed 15 MHP & 25 MPH
- 94 worth it?
- itr dc5 exhaust on dc2
- 93 Integra engine swap?
- Interior grounds
- want to trade 17inch motegi wheels for 15's
- i can make left turns out touching the wheel
- WTB B series Cable Trans
- please help o2 sensor cel wiring!
- Advice on choosing Seat
- Headers Fitting Test pipe
- underhood fuse box diagram for 95 gsr/searced
- What springs are good?
- Just won this for a buck from ebay
- intake for ls/vtec
- help buying a GSR...
- 94 integra ignition
- timing belt the same for b18a1 and b1?
- Do HX wheels fit on integra/si's?
- help choosing exhaust
- What is this JDM Integra Worth?
- found out how much transmissions cost
- trouble starting...
- positive camber on right front tire
- what can i do about this?
- has anyone.......
- Help! noise from bad timing belt tensioner or water pump bearing???
- b20..high compression pistons??
- wut kind of side skirts????
- Automatic Tranny: Hard shifts out of park between Reverse and D
- Main girdle
- Da wont stay running
- Type r back wing?
- help insatlling head
- SKUNK2 upper control arms
- JDM B18C distributor - Which Cap????? Help!!!
- MSD 6al info ?
- Will speed sensor from a 94+ Integra Ls fit in a 92' Integra YS1
- fully welded exhaust. how do i remove it!?!
- Auto tranny question?
- on itlma question
- 91 integra throttle position sensor broken how do i fix
- tein/skunk2?
- type r /skunk2?
- Good deal on mats on Ebay
- Engine Removal
- Anyone have a DIY write up on a rear motor mount????
- DC HEADER CRACK..help!
- just got a photo shoot tonight!! dc2
- Found this on EBay
- LS VTEC TURBO CAMS
- OEM 98+ Raybrig Fogs vs. EK Fogs
- ebay rebuild kit
- 98-01 oem fog lights
- is this normal for new motor???
- Power Steering and A/c installation
- B18C oil leak
- engine vibrating
- B-Series Parts
- Im Lost Sumthings wrong!
- Got into a car accident Nov 5th, insurance is considering my car totaled. =(
- Bouncy Idle
- no heat after new water pump
- DC2 Integras... 15s or 16s???
- valve cover
- so. cal. machine shop for b20 vtec or trusted member.
- Engine bay clean up
- Recaro Srd problem
- stolen gsr!!!(eklavi is a thief)
- quick question?
- yellow head lamps
- Exhust Question
- Weapon R header any good???
- b20/vtec , need some info , i searched!
- havin some trouble findin a muffler
- First Time
- Sidemarker s
- 94 Integra Transmission Problems
- can i put a jdm itr intake mani and throttle body on my gs-r? will it fit?
- 95 gsr IAC diagram
- hard time turning over???
- code 43
- b18a1 timing belt install
- opinion
- PCV help
- Quick Q? --Rust...
- Steering Wheel Options
- integra tires
- how much boost can a type-r motor handle????????
- Problem with car indicators
- TEIN LOWERING SPRING 90-93 INTEGRA
- My Acura has a ticking sound by my Cam Sprokets!
- Blower motor problem!!! No HEAT!!
- Building my head. b18
- Adjustable balljoint ?
- cams
- dc2 with upper mount ?
