View Full Version : Acura Integra
- how to fix the door lock switch when the chrome scratches off? [00 gsr]
- Anyone selling a b17 tranny???
- rsx exhaust on teg
- Suspension question... I know, I know...
- 95 ls w/ gsr
- Clutch pedal stuck
- Anyone ever use one of these?
- GSR shifting problem
- HID For Dummies
- Can i put B20 head on B18c (gsr) block?
- Need help deciding on CV Axle replacements, Raxle, Fidanza, DriveShaftShop, etc...
- LS Vtec
- over mileage engine!!! help!
- Place to buy Idle screw for 87 Integra TB
- ls turbo...$?
- side defusers for 92 da9
- gauge
- oil in manual transaxle?
- smelling gas inside and especially outside my car...????
- Stock Trannies
- check this out
- Did auto to manual - For some reason, auto seems to have more "kick" when i floor it
- Nology Hot Wires...big question
- Ground controll coilovers
- I need a motor for a 1993 teg ls
- clutch problem
- Would test pipe make me run rich?
- How much do stock GS-R "blade" rims weigh?
- project da9 another one
- 5 Lug Conversion: Aftermarket or OEM?
- 5th gear grindin
- Ball joint types
- whAT CAMS FOR MY BOOSTED LS
- Where can I find CEL & ABS codes for my 92 GS-R??
- question on integra dc header and o2 sensor
- More squeaks after C pillar bar put on??
- can a mod help me out
- o2 sensor
- ecu help
- lip/ss
- pic of integra
- Shift linkage issues...someone please help
- how do I post pics of my car step by step
- crane cams?
- KYB or Tokico??
- Oil Restrictor
- CEL Code 43
- Mugen Front Lip Installation on 94-97 Integra
- Races in Santa Barbara??
- 1997 GSR Catalytic Converter on a 1999 LS ?
- itr lip/ww ss
- 95 LS belt noise and stall
- high flow cat
- B&M O-Ring
- 2.0 inch cat converter
- Fuel pump wiring
- 94-98 integra motor diagram
- new here ***pic of my teg***
- engine swap
- Strange Noise While Moving
- GOT MY GS-R!!! What next, need help
- Runnin CTR Pistons in B18B or JDM B16A pistons? Help.
- cant get tranny apart
- eprom burner
- pix of setup?
- 93 da with jdm climate control?
- Difference between LS and GSR catback
- LS motor COMPLETE, how much
- CODE 54... what to do?? HELP ppl~~
- straight pipe or high flow cat
- how much 98 and 94 integra weight. and how much hp and tor. LS vs. GSR
- Grinding 3rd Gear
- high flow cat/straight pipe
- Flashing Maintenance Required Light
- DIY ICEBOX
- Turbo Charge 95 LS Automatic Project
- LS 5th gear install, what's needed?
- Good Thread
- 99 Integra GS-R shell, fair price?
- itr cams in my gsr
- LS-vtec
- Just got my car Should i do the swap?
- Help throwin a cel
- OBD1 JDM B16a swap woes
- new here
- sputtering problem please help me out.....
- DA Engine Progression
- need info on erick's racing header
- obd-0 b16 in to obd1 teg
- 94 gsr motor for sale
- any1 one from san diego that knows how to install a stock IM in gsr
- what is this part called??
- Fresh on Hondata. Give me some pointers. Dyno Sheet inside!!
- Greddy EVO 2 For cheap!! To good to be true!!!!!
- ? for DIY painters, cost and how many gallons do I need to repaint a DA
- honda / acura lied to me - rear main seal is not leaking
- what is wrong with my tach
- question about swapping gauge cluster...
- CV Joint Replacement
- Cheeper brands of gas?
- Rear strut bolt seized
- WOOOOW!! I WHIPPED ON A TYPE R LAST NIGHT!!
- Urget Help on front suspension.
- h22 in a 91 integra
- lost to an si
- Exhaust problem
- cams
- OmniPower LCA intstalled
- I have some stuff for sale!
- Benefit of vented hood?
- Pics of 17" Black Volks TE37, have you ran 225 / 45 / 17 tires?
- Best SS Exhaust for Turbo B18B?
- 01 LS Hydro Tranny
- Checking Codes
- gauge leds
- about axles for my turbo acura
- Fuel Cutting Out.
- Question about whats best turbo???
- Are all B-series oil/water pumps interchangable?
- Comptech Ice Box or Aem Cai
- My ghetto icebox....
- can someone help with the search engine?
- 75 shots on an ls????
- What is the difference between Integra Coupe and Sedan Catback?
- Holla!!!!!
- how did you install your itr jdmshit lip?
- What happened to my DIY Auto to MANual CONversion and LS GSR SWAP THREAD?
- Clunking Right Side of Vehicle driving my crazy!
- Exhaust Question
- what would ya pick a h22 or a gsr for a 91 teg?
- 96 JDM?
- concerned with b18b deck height!!!
- Stock air Box w/ Alum. Piping Any good results from that
- GS-R/ITR Hybrid suspension! :P
- B&M FPR + gauge problem need help
- I cant find my Radiator Drain plug
- Autometer Tach Install on a 90 RS
- Rethreading motor mounts00
- quick question about jrsc install pricing
- front brakes grind/drag under slow speeds/soft braking.
- cv boot replacment- can't get stop stop pin to seat
- spoon/buddy club ... vtec controllers
- Some New Pics Of The Teg.(da)
- Can the Spring on The Throttle Be Adjusted (Tightened)?
- --------k20 in a 90-93 integra? -------------
- how to time the ignition at top dead center
- can some1 help me identify this b series camshaft
- Bad ground have some corrosion in batery terminal hard to start? Help..
- Do you think this will look ugly?????
- P30 pistons in b18b
- Does AEM bypass valve lower your hp or torque?
- Proximity sensor
- teg owners - armrest question
- TURN SIGNALS NOT RESPONDING.
- Rear caliper covers
- License Plate Relocator
- turbo gsr quarter mile
- gsr manifold butterflies question
- Anyone knows what CKFM sensor is? plz help
- USDM VS. CDM Alterntors???
- trouble starting ???
- quick turbo question
- TSB's on integras
- engine mechanical problems?
- not really feeling the noise im hearing.
- Testing Fuel Injectors
- Did all integras come with amber corners?
- Turbo 101
- please help
- Tranny Oil
- 3rd break light/stock gsr wing issue..
- "BRAKE" light on '01 GSR
- DA owners.... question bout Swaps
- car bogging and hesitating really bad :( SOMEONE HELP ME
- DB2 Stolen in San Diego!!!
- Choosing a head
- Vtec problem maybe????
- Tranny Swap, what tools will I need?
- 1990 Acura Integra: Water leaks coming from under both sides of dash.
- 1990 Acura Integra: Engine Smell Creepin through the Vents.
- da integra: ac/blower fan speeds 1-2 not working, 3-4 is ok
- higher comp on Ls
- Ok Guys, I've tried the search and suspension forum..........
- changing rod bolts?
- Random overheating problems....
- Jdm donut gasket?
- HIDs won't work. HELP!!!
- Integra Turbo Kit
- Del Sol Lip Kit
- GSR ECU ON B16
- LS VTEC
- the plan and the questions!
- Which would be better.....LS/VTECH....or turbo Stock Ls
- Gsr vtec crossover points
- How much is an 94 LS motor worth?
- Brake caliper markings?
- Running rich? valve clearance
- drag turbo upgrade
- b17a vs b18c intake bolt pattern
- bumpstops...which is which?
- what mm to take out 91 LS spark plug..need it right now
- cheapest/most common white paint on g3's
- ls motor 155psi compression????
- How do you know if slave or master cylinder needs to be replaced?
- Winter Storage
- DA owner new to H-T
- Did my rotors and pads last night.
- Accleration
- timing help
- ***Greddy EVO II***
- Got my teins in today!!!!!!!!!!1
- Where in the US can i buy a full JDM ITR front end conversion?
- Just another day in the life of....
- HELP... Vtec oil Pressure switch
- integra catback system, does it really matter?
- wiring up Vtec on Nonvtec tegs
- HELP!!1 need Alternator wiring diagram
- DA: 9004 to 9005 conversion..
- g2 spoiler.
- turbo kits and NA header
- Fuel Pressure question- is this normal??? HELP! :(
- Do you have Comptech IceBox on GSR???
- fog light?
- exhuast bolt on
- 96 Special Edition Wheels
- Brake light problem
- ls/vtec or ls turbo?
- Hey guys...what is this part called? Need your help specifically.
- MTF in wrong hole?
- axle replacement, set ring?
- Rear Suspension knocking noice
- hidden power of automatic?
- might join the teg band wagon
- GM 3 Bar with S-AFC
- thermostat question??
- Cant bolt in Flywheel cover - just did auto to manual
- help ......radiator problem...
- thermostat off or is it just like that
- help! car getting hot..
- 2006 civic engine 1.8l 6800 redline 140 hp vs b18b
- Help..searched already..exhuast questions
- Please Help Me Find A Lip Kit For My 98 GSR!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- need paint scheme opinions...
- hey guys im new to the DA Family!
- Cutting Valve Cover for Cam gears?
- Any DA's going to CMI in Sac this weekend?
- will a crank pully
- 96 GSR & 95 LS
- Integra RS
