View Full Version : Acura Integra
- Paintcode for Rota Bronze C8s?
- WHAT HAPPENED TO HONDA-ACURA.NET????????????
- Will 205-50-15 Azenis fit Stock 'Ninja Star' GSR Rims?
- HondaCom?
- ls motor? anybody have one
- looking for a new mirror (passenger)
- engine swap question . . .
- Part Number Search Request
- Cam Gears
- GSR-- Swap or Re-build...
- track video
- Questions for those who have Koni Yellows
- help
- Got screwed for a header. What do I do
- well, I dynoed on the 20th...
- Electrical Disturbances!!!
- selling my sub and box...wat box to get now??
- longevity of a stock clutch?
- Oil you guys use?
- tranny issues
- ground design jdm front
- what kind of high flow cat?
- Is 1998-2000 shocks dif. from 2001?
- GSR-- Swap or Re-build....
- dc headers on ebay worth it????
- quaife or itr tranny w/ lsd
- What ENG Mods next For GSR?
- Who makes good carbon fiber hoods that have rolled edges?
- starting my bottom end......
- Using b16a3 pistons in b18c1 gsr. Pro, Cons, How to? Thought appreciated
- Trying to decide on springs.
- 215/40/17's on H&R sport 1.75" drop ?
- List your all motor setups!!!
- opinions on my potential set up
- VIS c/f hood
- My Homie and his 4dr LS
- FS: Hoosier Radial GT's mounted on Acura Legend rims
- Tire/Wheel Combo
- who fixes/corrects the camber?!?!?
- What size exhast is best????
- Port and Polish HP Gains???
- Tire Bubble...
- Please help on school work...
- Is the Dashboard Exactly the same for 94 to 2001 GSR's ?
- HELP WITH SMOG TEST IN MARYLAND
- LS w/ GSR swap
- stock 94+ GSR Wallpapers
- Please, I need some help w/My Car
- Got a LS... Which mod(s) next?
- 2nd generation integra owners or others..
- Looking for power!!
- Some Please explain Final drive?
- mounting hardware for rear speakers?
- updated pics of my car...........
- help wiring indiglos
- Interested in purchasing an Integra..need some help
- next mod??????
- how can I tell if they are real ITR shocks springs.
- Gen 3 ABS Question
- can i run a sound system with a stock head unit.
- should i do this??
- Zex on a 1996 GSR
- shift knob is stuck!!!!!!! WTF
- Looking for best price for a factory spoiler..
- Attn: DeDonDerosa
- How much do racinghart C2 & C5 rims weigh?
- WWW.NFIMPORTS.NET
- Updated Review: Comptech 6.75# Flywheel, ACT HD/SS Pressure Plate / Clutch.
- engine light after hi flow cat was installed
- Skunk 2 manifold w/ AEM CAI
- 2000 GSR w/ 35,000 miles: blown motor
- wtb :Rear brakes
- Konig Heliums or Greenlights in 16's?????
- Konig GreenLight pics?
- Tokico coil over kit..
- Best Rebuild parts...
- EVIL HITS THE DYNO
- ITR vs H&R OE springs??
- VTEC=Smoke???
- Leather
- Best rebound 'settings' for my Koni yellows with Pro-kits?.....
- how much should i mill??
- Kevlar vs Organic Clutches
- Difference between the models
- gs-r throttle body
- engine smoking
- project car
- Need Help Please
- 3" aem on a gsr
- Electrical Troubleshooting
- VTEC engagement on GS-R
- Gotta ne pics of C5 RacingHarts post um, yeahhh..
- Any of you experience tach float or think you may have a bad ignitor?
- What brand tire did Acura put on the 1994 GSR's stock??
- The Ultimate Sleeper =)
- Best setup for street-only integra
- Interesting question about GC coilovers...
- Skunk2 IM on ebay
- C-speed Integra 12-second NA video's are now available
- see a hint of oil in the coolant overflow tank, blown head gasket? or somthing worse?
- Solo Short Shifter
- 3rd brake light?
- vtec happy?!?!
- JDM b18c ???
- 96+ Greddy turbo GSR
- need help with an engine problem
- Hks Exhaust How does it sound, Good? Bad? Help
- how fast???
- Difference between 4x100 and 4x114.3?
- Ground Control coilovers
- how to check & reset the check engine light?
- Best black rims on the market
- What can I expect Folks!!?
- 98+conversion question
- How do you flush the Clutch M/C?
- Valve Cover HELP.......... :)
- How much of a difference will this affect ride height?
- Turbo LS vs Type R
- Engine timing help please!
- ATTN seifuku_b18c5!!!
- Is there a difference between the '98 & up OEM body kit front lip and the ITR front lip?
- Mounting Kit for VAFC in dash?
- Differnces between AEM CAI for GSr and Type R
- Problems with my short shifter!
- OEM Fog Lights
- Good spring replacement for Ground Controle coil overs?
- Where's the best(cheapest) place to get Apexi WS exhaust?
- Strut and tie bars
- will the 92-93 bumper fit the 90-91?
- Any way to tell visually if you have a cracked exhaust manifold?
- Need help cleaning my headlight...
- Just got my dyno #'s
- tranny fluid
- break in guys im pissed!!!!!!!!!!g
- motorsport coilovers
- i believe something happened to this integra. I'm not sure what
- Overrevved my engine and now my engine is messed up, but don't know what???
- Where to find 98+ Type R Lip?
- what type of tranny does the 2nd gen have? cable or hydro?
- ECU codes 17 and 3, any help please
- Will this work?
- Clearing Headlights
- what is the recommended interval for replacing the factory airbag?
- My engine loves RPMS a bit too much....
- what causes the buzzing around the brake master cylinder??
- Best Place to buy a AEM CAI that ships to Canada?
- lookin for a pic of the teg that has the skyline bodykit.
- Help with clutch...
- Two S2000 Silver colors?
- need help....
- Are Tokico Blues good shocks for the money for 94 GSR?
- G2 Teg Solo2 Race --pics
- Exhaust Manifold outlet size to cat (GS-R 94-01) ?
- my tranny only holds 1.75qt. is that ok???????????
- Should I Sell my DC2? Please Help?!?!
- my dam car dies
- g2 or g3 integra, which is most comftorable.
- VAFC Help
- Looking at a 95 GSR...
- Storing my integra for about 3wks should I disconnect the battery?
- Anyone with Spoon Exhaust?
- what do u think of the regamaster evos.
- what are the specs of a 2001 LS stock cat?
- damn it I crossed threaded a valve cover bolt
- Finally, my engine runs quiet!
- Skunk 2 Camber kit....any good? Need to buy one soon.
- brake lines
- How muck are these worth?
- Anyone from Reston, VA know where the racing hot spots are??
- Shift Point on AUTOMATIC Integra??
- Should I sell my Teg?
- valve cover
- Need Some Help on Which Wheel and my Car.
- ITR rear sway bar fitment with RSR catback question :answered:
- Weird sound when turning..
- Boooostin!!!!!!!!!!
- does any one know www.ppsonline.net
- ITR vs comptech axle back muffler flow
- kyb agx settings? what are yours?
- C-speed Integra broke again...
- hey thanks
- gsr for sale
- Please Identify the cause of this sound
- How much would an OBD1 help my manifold?
- Ferrea Valve are they any good???
- Bought an Integra what should I do?
- What to do with my brakes
- Carfax report please?
- How to remove the clock?
- Minimum parts needed to do 5 lug conversion on a teg?
- Custom Gauge Cluster with Autometer gauges for Integra
- 3" Exhaust + 1.x" drop = ?
- Loid Noise ---- Not Good
- I Need help with OEM fog light install 98+ integra.
- what spring rate for my ground control coilovers?
- Anybody have an emissions hose diagram for a OBDII B18B.......
- Just ordered Prothane Motor Mounts for my GSR...anyone else have these?
- looking for good GSR head
- Skunk2 Cams Stage 1???????
- skunk 2 cam gears
- how does the venom 400 work
- bumper cover bolts/sizes
- JDM & US brake pads
- Will ITR springs fit on a 94 gsr? How much of a drop???
- engine harness question.
- anyone have pix of the S2K antenna on a teg??
- does the front bumper of a G3 teg have holes for emblem?
- DIFF BETWEEN GSR AND ITR CAMS???
- Which Throttlebody?
- Who has a S/C Integra Gsr? Have a few questions
- Anyone know where i can find a test pipe?? Pls
- What should I get for My valve Train?
- Re: Integra Seats (Weight??)
- How much to paint Integra Type R spoiler????????
- AEM CAI to short cai?
- SMSP 2-1/2" Cat Back System Update
- What do I need to turbo this car?
- can someone vouvh for smkngsr?
- Removing lower rocker panel mouldings?
- my hybrid forum is up!
- Best Body/Paint Shop in NYC Area?
- Cermetallic or Organic clutch?
- HELP!!!!! I cant find the radiator drain bolt
- srr or hr springs
- anyone know SRR springs ( suspension)
- My stock 1/4 time
- finally finished my mods
- Whats the Best Ignition?
- good shops in SOcal
- new motor having problems need help
- konig heliums
- What grade transmission fluid goes in a GSR?
- JDM ITR wheel Vs. USDM ITR wheel
- Now What Should I Do
- Gains from carsound cat
- Which Cams to buy!?
- Need a big favor from a helms manual owner
- Jackin up, HELP!
- help me to decide pls: 195/50/15 or 205/50/15 Bridgestone Potenza S03
- Does a GSR turbo manifold fit an LS?
- How To Tell If Their Real 01 Itr Cams???
- Tech Guru's- Distributor swap?
- ITR springs/shocks combo installation tips
- Yellow Box speed re-calibrator
- when do I know when to change the thermostat and hoses for my radiator????
- just ordered KYB AGX's and Eibach Pro-kits..!!
- anyone have a catalytic converter for a 2000 ls?
- Rochester Area Car Show!
- performance radiators???
- Do I have to break in a Clutchmasters Stage 1....
