View Full Version : Acura Integra
- steering wheel shakes while driving
- Weird problem
- Transmission question
- HELP THE CAR IS LEAKING
- HELP! weird vibration
- WTB a 4Door GSR - Prefer Stock and under 100Kmi - NOVA
- Installing aftermarket fog lights
- Leather front seats
- Tps sensor
- battery light on please help
- injectors for turbo
- RADIATOR PROBLEM
- Help diagnose starter problem
- power steering
- Injector Differences
- Tranny swap
- 91 ls vtec problems
- Were to get a b16 Tranny
- VTEC not engaging like usual
- ugh. the dc is down, AGAIN
- transmission problems!!?!?!?! PLEASE HELP!!
- 94 integra smoke question
- blox or skunk 2 intake manfiold
- Questins on a po20 code
- Question for 98 Integra stock spring installation
- skunk 2 intake manifold question
- Type R catback + test pipe of some sort?
- power windows no worky...
- Car wont crank, fuel pump dont prime, fan spins when trying to start, HELP
- Need help: Replacing an alxe on a 95 GSR?
- S300 Calibrations
- throttle body spacer?
- Type R intake manifold & Skunk 2
- B-series cam gears
- intakes for type r same as gsr??
- whats the diffrence between these two fuel pumps?
- What should i do next?
- K24 into a DC2
- my 2001 GS-R project!!!!!no 56K!!!!
- taillights
- Power Steering
- 90 DA Build Up
- Clutch/Transmission problem? I seriously need some help here!
- 13's on a 95 teg?
- Took my teg to the smog shop and.... *results inside and pics* UNBELIEVABLE!
- 96 gsr motor in 90 integra
- advance timing ?
- key comes out of the ignition
- need some info **
- what cams to get?
- timing belt
- Need teg owners suggestions Please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- oem hub caps on steelies
- 94-97 ITR OEM Front Lip...
- Fitting and Paint Questions
- Difference between 15 and 16's?
- Weird problem (srs plug/steering wheel).
- A little project I've been working on. 94LS
- distance between fender and tire on a stock DA?
- GSR to a Type R
- Black bumper over exhaust
- ::::IACV????::::
- just bought a dc2 lights dont work
- TIMING BELTS
- HELP! gas soaked plugs
- Help Wet Seat
- LCR Bushing Question
- What valve spring compressor I need!?
- Problems???
- brake caliper
- 92-93 steering wheel in a 90'
- RSR Exmag...
- What needs to be done to an LS to keep up with a GSR?
- just registered
- AEM fuel rail?
- Blew Ignition Coil?
- gsr Vs eagle talon tsi
- What kind of Pistons and Rods for Turbo GSR?
- need help and advice w/ Helical lsd for my jdm Y80 tranny
- Integra LS tryin to get Type R cluster to work
- Speedo no go
- 3rd gear grind. i think i need new synchro set
- The Best Short Shifter?
- why does it sound like its got a v8 now??????
- Where do i get a light test for my DC?
- what IM and Cams do you preffer?
- 91 DA integra: Removal of front and/or rear bumper support?
- Need rear lip pics...
- Timing belt
- a/c fans control
- intake manifold layout.....HELP!!!!!!!!!
- compression ratio???
- d16zc dohc non vtec
- CEL 69???
- What pistons to get??
- front ITR LCA same as RS,GS,LS,GSR?
- getting water out of your taillights
- dc2 DC header on a DA?
- auto to manual swap
- Does anyone sell 2 piece replacement rotors with aluminum hats for GS-R's?
- pulsating idle
- correcting camber with a sledgehammer
- megan headers?anyone have them?
- putting stock suspension back in
- no Vtec
- Different lengths of A pipes.. (94-99 GSR) Vs 00+ GSR?
- Help needed fast PLEASE !!!!!!!
- When to tune an LS motor???
- is the rsr exmag muffler looped?
- 95k and the problems start
- toda flywheel
- Integra nitrous
- 2000 LS Brake Upgrades
- h22 in 92 da could it work? does swap have potiential?
- code 90 after installation of skunk 2 intake mani
- Buddy Club Racing Spec Engine Grounding Kit
- Swaping gsr cluster to jdm cluster
- is it worth doing a 5 lug conversion
- GGG good game gsr
- My new New Project H22a - > Integra DC2
- springs qusetion
- !!?? I NEED HELP ??!!
- ported and polish intake mani question
- B series lego's
- How much is hydro LS tranny worth?
- guage cluster lighting, LEDs any good?
- New Dizzy now no start! need quick answers
- Oil Pan Removal Question
- help cooling problem is my waterpump dead
- GSR Header and Type R Header Question
- Why Won't My Motor Start
- bought my 92 teg GS juz a week ago... YIPEE! unfortunately it's not running....
- Just put in my USDM ITR cluster..weird problems
- Guage Cluster lights work sometimes... new bulbs?
- dc2 Idles high then idles low
- Where to get this bracket?
- im about to put my gsr head on...couple ???
- HOW MUCH OIL IN A DOHC MOTOR
- camber kit
- 99 dc2 fog lights
- Tire size???? for autoXXX
- JDM DC Header
- common distributor parts
- B18c5 swap
- car jerks when cold
- Just interrupted 2 [guys] trying to steal my GSR
- Dc2 H22 Vtec problem help!!!
- Help! my GSR wont pass smog! code7
- b20/vtec is smoking =(
- Anybody use AutoXray OBD 1&2 Scanner
- what else should i upgrade on my dc2???????
- fix scatched/nicked rims, wheres a good shop in NYC?
- Can I fit a 2000 GS-R header into a 1998 GS-R
- Stock shocks and stiffer performance springs
- RSX Radio in an DC2
- 94 GSR cams VS. 2000 GSR cams???
- JDM GSR swap in 94 ls p72 ecu. Limp mode 6700rpm. No vtec
- Ek sides on DA...where to cut?
- omni power titanium retainers....
- Help : Proplem with my engine
- power steering and gas mileage
- Installing lowering springs
- Another weird ass noise coming from my suspension
- how many quarts does my teg take?
- guage/instrument lighting help...
- Do 94-95 integra's have VIN attached to transmission?
- distributor rotor screw HELP!!!
- block balancing
- APEXI Rev / Speed Meter GP ?
- heater & a/c issue
- Installing a JDM 4.785 Final Drive in a USDM Type-R Tranny
- Hot air coming from parking brake area
- Question regarding JDM Headlights.
- Looking for low mileage Integra.
- GREDDY SP1 for 94-99 GSR fit an 01 GSR???
- Type R lip a little short, any suggestions?
- where can i get a poly type-r lip?
- How to adjust valves on my Jdm b16
- Engine Claying Info and Questions
- CAR WANTS TO DIE WHEN I HIT FULL THROTTLE
- low cold idle help
- 94 Integra gsr
- ecu swap engine light?
- Radio Codes
- idling issues
- abs modulator noise while driving
- Integra head swap
- WTB: rear 2000 integra lowering springs. need a 1.5 drop
- exhaust fitment question
- need help 93 integra fan relay
- jdm itr core support
- Clutch fork / Slave cylinder / clutch install question. PLEASE HELP!
- rpm at start up?
- Fuel after turbo
- timing issue..take a look
- car stalls at stop
- integra swaps vs. civic swaps
- type ! racing exhaust
- tire making sound???need help
- help with skunk2 throttle body
- N1 pulley= actuall gains??
- Anyone hear of a after cat tubo setup??????
- Koni Yellow Bracket
- Need Help !!!!
- Head lights!
- timing belt gear?
- Jerky steering wheel at high speeds
- changing out the master cyclinder on a 92 teg
- wipers dont work!
- sea foam engine?
- Exhaust questions
- San Diego Autobody Shops Experienced with JDM Front End Conversion
- Rota C-10
- DA RS-R Exhaust
- New Springs .. Will They Drop After Awhile
- Quick Question:Buddy Club Exhaust
- overheating?
- white smoke, struggle to start...but it runs perfect? whats the problem?
- Blox intake Mani on b18b
- WHERE 2 PUT SIDEMAKER ON DA INTEGRA
- Swapping a K20A (RSX TYPE S) into a '94 Integra
- HELP: V TEC dont work
- A question about VAFC
- pic request cyclone blue metallic on a dc or db
- Clutch Noob Question
- Need some Help for my buddy
- anyone ordered anything from this site?
- Idle running really high at first start up, engine cold.
- Quick Fog Light Wiring Question!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Integra JDM headlight wiring
- engine torque damper
- * Need headlight connector * where can i get one?
- Sqeaking noise coming from my brake or is it?????
- does anyone has play in there clutch pedal?
- Why wont my car sit on all the jackstands?
- AC question for a 93 Integra
- heater problem
- OEM OIL FILTER question!!!! DID SEARCH!!!!
- IS THERE SOMETHING WRONG?? GSR troubles
- 3rd Brake Light.. How do u wire it up if it was Cut from the Hatch?
- best valvetrain?
- Turbonetics complete turbo kit, Good or bad?
- How much is this Teg worth?
- Is it possible to have a throttle body that is too big?
- Tokico blue crx shock and struts will work on an integra fine right?
- Light bulb for 98-01 halo headlight
- LOOking for door wirring
- pretty dumb ? sorry (newbie)
- ctr rim question
- HELP auto tranny
