View Full Version : Acura Integra
- Rocker noise?
- Beafy axles?
- Oil light issue after rebuild
- 99 integra shutting off
- No crank no start issues
- Fuel pump not priming in 'on' position
- Douchey Neighbor EPA
- 94 integra slight power lose. please help!!
- Reusing flywheel bolts?
- Transmission Dust Seal/Cap Part #?
- Lower seat rails for leather '98 gsr seats?
- Battery light on and off?
- 90 integra db1 vibration/shakin help
- Ls vtec with Roket m24xx cams
- Engine Bay Harness - Where does it mount?
- DA 1 Piece Head Light Question..
- 1995 Ls Thermo won't open
- AC Compressor / Switch Testing Replacing
- Need a LS crank - Finally tore down engine
- Help I got a no start no crank problem
- installed new antenna mast today. what is the clear tubing hooked to antenna motor??
- Where to buy DA9 replacement parts?
- Need help with oil leak
- relay help
- GSR Vacuum Leak at Intake Air Bypass (IAB) Spring / Shaft
- O2 sensor help
- Charging help!!?
- 99 gsr turbo
- 5th Gear in YS1 Transmission
- 1999 gsr tuubo
- 1995 GsR
- i need some input on my build :)
- 96 gsr cel will not turn on!!
- 2001 gs acura integra factory alarm problem... door locks before you can open.
- type r sway bar on gen 3 integra
- Head
- 95 LS Charging system failure
- alternator or voltage regulator?!?!?
- Safe alternative to OE 3 belt crank pulley?
- h2b in a Da9
- no brake peddle
- Delete ABS system on a 92 DA
- Progress cs2 coilovers, am I tuning them correctly, they seem way too low? (photos)
- what is electic load dector ELD Does 2000 integra have it?
- PLEASE HELP b18c1 i really cant figure it out maybe you can :(
- 00' Integra RHD conversion Info!
- correct wheel offset and width
- db8 sunroof gets stuck when opening
- DC2 Dash repair for small incisions
- GSR trans code S9B question!! Need help asap
- Ukdm cluster?
- JDM ITR Srs steering wheel with no inflator
- Coilover Questions
- Need Help with rough cold start
- Buy a GS-R with a history of salvage title?
- squeak coming from car, Help please!
- EF radiator on DA?
- Can a broken starter wire cause a short?
- LS cable transmission 4th & 5th gear delete
- b18c1 idle issue please help
- Help me finish my Gsr!
- Running AC without tensioner
- Gasket issues
- Opinion: RSR ExMag
- Car won't rev more then 4000RPM!!!!!
- help plz
- question about oil leak on a gsr
- Need to find c216
- Project Black Integra - Urgent Attention
- Gsr IM and SK2 IM?
- no fuel no spark
- No brake lights
- Install avital 3300 alarm system in 97 integra
- Back to Fresh - 97 GSR
- Troubles with GSR TIming Belt
- Can I do this for wiring my gauges? Picture
- diy intercooler piping bov question
- Need Help With My GSR!!!
- exhaust system without cels possible?
- Help PLEASE strange situation
- Bogging/smurging need help ASAP!
- Energy balljoint boot set
- 83mm bore gsr... sleeve?
- 94 Integra RS Cranking/No start
- Best Cost effective things to do to GSR shell
- Need help installing EL Glow gauges on 01 integra
- GSR ECU P72 OBD 1 and OBD2
- Car stalling! Not sure!
- rollcage for integra with sunroof
- Lsv help
- Aftermarket crank Pulley
- dash harness issue
- Bumper screw sizes for JDM bumper
- Skunk 2 Springs on Koni shocks
- Can i use this resistor box? Link
- Car feeling like its bogging
- Need help with a part number.
- Jdm type r
- Someone help me explain hose size and fittings.
- Help w/ my Integra just picked up
- B18b Pr4 head valve guides
- What lower control arms work on a 1999 acura integra ls
- How do I find....
- How to get power to accessories W/ No swap
- Are A/C and Power Steering belts the same?
- 92 Acura Integra
- Too lean problem
- b18c1 dead cylinder - engine repair/rebuild advice needed
- Custom Wiring Harness ????
- Custom Exhaust HELP
- 2000gsr turbo build
- Skunk 2 pro s or pro s2 ?
- How to take off stuck lca bolt? not snapped.
- Can anyone help me with the fuel pressure on my gsr?
- GSR swap in eg hatch
- Can you ID this Header?
- B18C1 build thoughts.
- 99 Integra LS no start
- 3 gen Integra stock windshield color
- Breather box/chamber: gsr vs ls
- DB2 attempt #2
- Distributor Help
- GSR with the wrong engine?
- cracked transmission housing, need some help
- Acura da 93 b20v swap
- HID headlight bulb stuck in socket
- Integra light problem
- Distributor Help
- just bought a db7 with b18c1 swap
- Ecu
- JDM front conversion advice
- Ebay clear headlight lense on OEM headlight assembly
- 2000 Auto integra wont start
- Windshield> AP Tech,Pilkington,PGW
- B18C ring gap specs?
- Best Integra Front Sway Bar 2016
- Need LCA advice
- 1997 Integra RS Brake Problem Light Stays On
- [IDLE] Strange stall
- Hey guys couple b18c1 questions
- b18a1 flywheel cutting into oilpan
- No Crank/No start-Daily driver please help!
- Oil everywhere, how to clean?
- What relay to use for actuator?
- Installing engine for a first timer
- 2000 RS Rear hatch (Need help/video provided)
- Did I just bend a valve?
- B18b breather box
- 1996 ITR Cluster Problem
- HELP CENTER BORE?????
- Help! Engine revs when clutch is pressed?
- 94-01 Integra Sedan Roll Cage Pictures
- Integra seats
- Question ... GSR Headers
- Heater/coolant valve worn out?
- Integra LS windshield from Type-R?
- 91 integra codes 7 and 16
- Need Help 1986 Acura Integra
- Integra front bumper corner tabs
- who makes the stiffest springs for DA/DC which are non-progressive and non coilover s
- Electrical help
- ABS Codes
- Help
- 91 teg cowl seal
- Reusing HG only torqued?? Never started
- Ls to ls vtec
- 1990 integra da b20 turbo??? help???
- LOUD idle noise coming from timing belt?
- No Start- Bringing It Back To Life
- car struggles to start
- automatic to manual 1999 Integra
- LS Vtec jumper harness & emissions
- Engine mount verification
- Missing plug in engine wiring harness
- Want to turbo my stock ls, any suggestions
- Turbo Timer Plug & Play Harness interest???
- Unsolvable Idle issue
- My first build from scratch.
- manual windows conversion to PWR
- DA Integra Racecar build
- GSR trans issue
- 98+ Integra with Cabin Filter
- B20 swap into obd0
- acura integra 95 gsr cluster not working
- 93 GS-R - Head gasket replacement and other repairs
- Wiseco Pistons with OEM Rings?
- cam information
- wire tuck under dash fuze box w/heater retained?
- GSR LSD QUESTION
- LS map on B20?
- Very weird noise coming from intake
- California BAR question is 1998 and 1999 the same?
- How to trouble shoot wiring issue, on a car that has a wire tuck?
- Another classic car won't start
- '90 Integra low rpm stumbles
- JBM B18C Swap jerking on low RPM
- Oil pump bypass sensor
- 2000 LS immobilizer headaches after replacing ig. switch
- Will B16 pistons fit in a b20 block out of a crv
- Integra brake hose part?
- green climate control lights.
- B18a1 motor swap to b20b with ls tranny
- new member needs help!
- 1994 Integra Sedan interior water leak
- Ignition output signal missing CEL 15
- Need a DA GURU- Identify this Spoiler
- Pre Turbo LS Mods?
- LSD Ring Gear Fabrication
- 2001 Integra LS Cams or wait till turbo?
- Please help.
- Cabin harness ??'s
- Integra problem - Loss of power and multiple CEL codes
- JDM LS into 96 GSR
- Integra Mainshaft.
- Mesh rims
- b18b1 - will a pr4 ecu work?
- Help identifying springs on GS-R
- Please help!! 87 Integra won't start
- A/C Drain Tube
- UNEVEN RIDE HEIGHT
- Yo finally making a build theead 00 integra
- Gen 3 SRS Unit Interchangeability
- Car smokes
- rhd j32a2 aem
- Will b16a 4-1 manifold fit on a b18c?
- D3300 - DC2 Race Car Build
- DA integra Fan issue
- does anyone make a turbo kit for a 93 Integra that I can keep the AC?
- first car for a teen ,want to do some upgrades.. suggestions!!!
- Skunk2 Alpha Series 4-2-1 Tri-Y Header
- Code 43 problem
- Fuel pump assembly ?s
- Under hood fusebox b18b1
- B18a1 transmission compatibility
- b18a1 rev issues
- Toyota calipers on integra
- GSR wiring harness swap???
- 1993 integra wont rev past 4500/5000 rpm
- Engine mount trouble
- Please ID location of transmission range switch within the engine bay
- Compensator Adjustment?
- CAMSHAFTS 91 integra
- Lsv or gsr,?
- Heater wont work
- 98 Integra Oil Filters
- Gsr will not start
- B20 swap
- 3 PIN oval plug obd2 B-series alt?
- How much will this cost me? (GSR head)
