- differences in 96-00 integra models?
- why motor always smells like gas..
- Can someone ID this rims for me plz~
- has anyone ever head of black traxx?
- polished calipers
- electrical burning smell
- rear wheel bearing help
- Ls Hydro Tranny
- jdm front end question
- how to raise rev limit on obd2 p72
- type r lip
- compression test problem - HELP
- ls/vtec
- Automatic trans upgrades.
- exaust problems
- compression specs for a 92 LS
- How Wide are your Wheels?
- my teg have starting problem....
- cooling fan problems?!
- Has anyone here ever used B18A1 aftermarket performance cams?
- Skunk2 Shift Knob
- overevved engine and did compression test
- f/s garret t3/t4 turbo in so/cal
- Blowing ECU fuse!!!! HELP Wont start
- f/s complete swap gsr
- swap running sketchy?
- help! car won't go into any gear
- what tranny is the S80??
- GSR sedan/coupe?!..
- My '00 DB8 GSR... Freshly rebuilt engine...and right off the dyno....
- dizzy problem
- Car over heated
- Overheating issue
- Need Help with turn signals ASAP!!!!!!!!!!!
- DA electrical problems ??
- Throwing a Code.. HELP!!!!!
- Spare key won't start car?
- B20B swap???
- vehicle will not start!!
- exhaust question?
- SMOKE!!!
- Replacing an Integra A/C idler
- How hard is it to replace a spun bearing??
- Need help on 94-97 vs 98-01 connector/harness difference for headlights/turnsignal/door panel switch
- Low Idle
- best low end torque
- Noisy tires.
- GSR Big Brake Upgrade
- Is this worth it?
- broken lifter?
- Valve cover leak I think
- NooOb question on Radiator Fluid
- Pic Request 94-01 Integra EVO Carbon Fiber Hood or any VENTED C/F hood
- Acura integra GS-R horsepower
- sup there people! im new to HT.....need some help..
- 17" rims (again)
- how much nos does an ls hold???
- DA Integra JDM Cluster: Reads in KM
- CFK Sensor help
- Coolant in Cyclinders HOw and why?
- Crank Pulley Bolt
- STOLEN INTEGRA
- need a tranny
- hood chipping
- ViS CF TRUNK + rear Trunk Shocks Work??
- clutch noise
- cutting out at 7000
- MY SEARCHING SKILLS SUCK :(
- My saturday/Sunday Project!!!
- how to disconnect O2 sensor in 94 GSR?
- Installation ?!?!
- Motor Mounts quesition?
- Maintenance Req. light on.
- gsr skunk 2 manifold
- what should I set my 2 step at ?
- Ecu wires? Confused
- alignment question on a DA9
- Newbie with a problem
- Distributor bearings?
- Pistons/Comp/Fuel?!...
- GSR unstable, squirrely left to right - replaced many parts problem still there
- how fast can integra be?
- Anyone ever use the Ebay Tien knockoff hood dampers?
- Integra with immobilizer?
- Heater problem!
- hid problem
- STOLEN INTEGRA--take a look
- Steering from a s2k in a gsr???
- Lowering springs or coilovers on stock shocks?
- dented oil pan OIL STARVATION?
- Air conditioning problem
- Rubbing noise
- coolant plays the dissapearing act on me!
- clutch, burnt or just hot?
- can the suspension from a da be used on eg hatch
- what kind of coilovers for a DA?
- tokyo drift, what did you guys think
- anyone knwo where i can get this..
- pct pistons in gsr
- GSR Intermediate Pipe Same as LS?
- Wierd VTEC problem after swapping ECU
- Integra Halogen Projectors- Problem with light out put with HID's
- need help with tranny
- How much HP with this setup?????
- 17" rims
- turbonator
- faster integra
- ABS Needed???or not
- ???gsr cam caps???
- what camber kit on DA
- Motul oil and Mugen engine treatment.
- front end shaking.
- Integra Almost Got JACKED!
- Thermostat question...its closed...then opens...did search
- Is a lower arm bar the same thing as a lower tie bar???
- TPS question..
- which tranny has the...
- quick FITV question
- my integra gsr exhaust
- wtf? blown clutch? please help
- 93 GS bumper
- please help, b18 turbo wont start
- Penetrating Spray on Header Bolts, ok?
- quick A/C question
- Compression test #'s <- Help me diagnose!!
- JDM Integra SIR-G??
- how much horse power?
- car is broken
- how much is this worth?
- Integra Antenna Block off plate...
- LS/Vtec High comp..... NOS?
- TANABE CONCEPT G..help me im dying
- head bolts too tight?
- JUST BOUGHT A DA AND IT WONT FIRE hellllllp
- anyone sellin a turbo manifold for a t3/t4?
- Just want to share my Very Sad Day ;(
- how easy/hard should it be to spin compressor by fingers?
- help on how much psi i could run 95 ls/turbo
- gsr 65mm t.b.?
- how can I tell if a b18b has vtec?
- Automatic B20 Swap Help
- Need help on JDM Integra parking and fog light wiring.
- Car shaking?
- Maintainence light blinks when turning on car
- ticking when idling after motor is warm
- couple of teg questions.....cant turn of light
- 94+ integra greddy exhaust will it fit
- Got a couple problems
- Need HELP to pass smog in CA
- test pipe on RS-R ex mag
- Fuel Injection cleaner causing problems?
- What to do with 4g'z
- DOES ANYONE HAVE THESE ITR KNOCK OFF SEATS?
- crower 403 or 404? on LS
- green stuff in spark plugs
- BLACK OILY CRAP in my TB!!
- 98 front and rear conversion.
- ecu upgrade???
- "Check Engine" light on... any ideas?
- header problem
- 90 integra ls header fitment
- Suspention question?
- !!!!!!Anybody Sleeving!!!!!!
- is my apexi n1 screwed up
- New to Integra's..... Questions!!
- Optima Yellowtop?
- Interested in the twin loop 2.5" muffler
- 17 in fujime concept rims
- question about tuning after these parts
- Anyone seen the JDM rear bumper w/ fog for sale anywhere?
- i searched, seized caliper :(
- JDM Type R rear sway bar end links
- Tach signal on obd1 94 ls
- Starting problem!
- Size of LS exhaust manifold vs JDM type r
- Tips for protecting an integra..
- exhaust difference?
- What Next?
- can some one help me!!!!!!
- Comptech Tie Bar/Sway Bar Combo
- itr rotor/caliper upgrade?
- HOW DO I POST PICS NEED HELP
- WHERE ALL THE DBS AT
- Blox Performance parts
- HELP!
- how can i test the igniter and coil??
- rear squirter doesn't work.
- GSR not starting all the time
- hissing noise when i turn off my gsr
- integra issues
- '94 integra radio/electronics question
- Antenna Alternatives
- i have some cut wires (under my ignition cylinder) where do they go??
- VSD BASIS
- Timing belt kit question
- jdm headlight corner sockets?????
- B18A OIL pump fit in B18B?
- ls/vtec owners!! need ur opinion
- need help installing rear integra koni yellow adjustable shocks......
- clock light....
- Greetings
- need help loctae charcoal can
- problem with my butterfly valve
- STOCK FUEL RAIL...
- Test pipe good for GSR/vtec?
- throttlebody questions
- STOCK GSR
- help on cage (not roll bar) selection for my dc
- JDM DC2 front end conversion help!
- gsr turbo ?
- ??Need help with engine problem (94' teg)
- where to find gsr stock intake???
- Pr4 Ecu pin layout
- gauges
- Check Engine Light Came On
- Doors locking themselves while driving...
- Bad Clutch Master Cylinder?
- ABS Code Help!!!
- Question about pcv valve
- Creeking front right suspension
- WHERE CAN I FIND THESE?
- sir-g wiring diagram?
- Lowered my car, got an alignment evaluate my printout
- hign flow fuel pump?
- ECU questions
- CTR swap into DC?
- ITR throttle Body On LS
- HELP!!! Distributor Problem gone bad
- DA interior ?
- Compression abnormal!! Help!
- Dashboard Won't Light Up! HELP!
- Price for rebuild to high ???? Any engine shops in CT???
- gs-r brakes dead
- Pulling codes from a 99 integra
- DIZZY ?
- turbo-LS reliable for 50miles daily?
- Another stolen DC2 in San Diego
- Tranny bushings?!...
- flywheel question
- just found out something new
- Obd1 and obd2 heads for b18b the same?
- 95 integra
- DA GS-R production #'s
- GSR Tranny pricing
- power steering and a/c pulleys
- ecu
- catalytic converter heatshield question
- engine swap question
- ebay mods??
- cat heatshield
