View Full Version : Acura Integra
- Changing to a 2.5 inch collector on the stock GSR header
- upper arm assmebly slipped out of frame, need expert help =( =(
- Radiator problem?
- High Pitched Whirring Noise!
- For everyone wanting philips 6000k HIDs
- Totalled my Integra, pics inside
- Exhaust
- ITR cams w/turbo
- Does anyone have a type R throttle body on their gsr?
- Exhaust Question
- Purpose of heat shield on cat. converter?
- There goes my integra...
- quick q - are usdm itr cams same as jdm?
- Crower cams. WHY?
- itr cams
- Need help with throttle body swap
- Weird noise when turning the wheel??
- Got Pics of my CM flywheel and Exedy Clutch!
- Spark Plug Question
- Warranty Issues with AEM CAI...
- Making it lighter?
- AEM CAI: Possibly Damaged HELP!
- Where can I get a Helms manual??
- Weird clutch incident....help?!!!
- Question about integra interior
- Who makes a good carbon fiber hood for GSR's?
- Jun2s/Jun3s on Portflow inner/itr outers + titanium retainers
- Need help ID'ing these springs
- Need new tires what size should I get for my stock rims?
- Apex V-AFC Cheap
- Kakimoto R 70mm catback for Integra!!
- exhaust
- Where is Evil GSR?
- I have 98 ITR cams and S2 gears for sale!!!
- My AEM Fuel Pressure Regulator?!?!??
- Bolt on's
- ECU chip to use with Jun2 cams?
- Anyone using the ITR lower tie-bar?
- is knight engineering closing up shop???`
- which cams for N/A now, but turbo later?
- Anyone have OEM body kit?
- Vtec controller harness question
- Side view mirror install
- Stock LS/VTEC DYNO..
- Dealer Drama
- offset on wheels
- Best gsr motor oil
- How much to install and paint a body kit
- Question about my brakes
- Raising Idle, above Stock
- European Integra???????????????
- B16 Tranny in a GSR
- A few Q's before CAI install...
- where to get oem body kit
- Act Xtreme , how much over stock clutch?
- jdm itr pistons in gsr?
- Is this worthwhile?
- Tranny options...
- Correct valve spring install height?
- Suspension/Engine work done! Pics!!!
- JG Single port intake manifold VS The Skunk2 IM
- GSR factory Air-Box Question...
- ITR rim copies/equivalent??
- Type-R struts. Are these good?! Look inside please!!
- I have FOAM around mine!!!
- just did my first valve adjustment
- Annoying Noises coming out of Glove BOX when heat is turned on??
- How to make ITR manifold fit GSR?
- new low/mid rpm humming/whirring noise
- red gauges
- 90-93 intrgra's?
- 2.5" exhaust catback, axleback, muffler, cat
- Good bye all
- Suspension finally done!
- LS Intake Size?
- gs-r vs. frankenstein
- idle surge problem after flywheel installation
- JDM conversion kit...
- Neuspeed Race owners...what size wheel do you use?
- itr head on gsr block
- MUST READ: BAD ONLINE COMPANY
- recaro srd's
- Rev limit on Jun2 cams?
- ITR rear sway bar + DC rear tie bar (will it fit)?
- Skunk2 Type 2 Cams.
- what's wrong with my car?? help me
- Help w/ My term paper of NA vs. Forced Induction.
- Toda B's on a GSR, I think there is still more power potential to be unleashed
- Toda cams for te b18b?
- Coolant leak.. from top of radiator it looks like.
- What is your CAMBER set at???
- engine swap rates??
- about to make exhaust decision...please help!!!!
- straight or bent/curved intake pipe?
- Anybody have some pics of some LS wheels?
- Cybernation Integra ran 11.13
- reprogramming OBDII?
- ITR exhaust on 95 GSR
- Anyone familiar with PRM jet stream intakes?
- AHHH!!! I ripped the emblem off, but the paint came with it!!! WAHHH!!!
- Can anyone vouch for SiLock at clubsi.com?
- just installed a AEM CAI
- do i change the oil after storage??
- does anybody have any 96 wheels you wnat to sell?
- Interior questions???
- engine bogging when cold in first gear
- Nitrous Setup
- 3rd Brake light removal
- Help with Hondata tuning, and fuel tuning
- Check out this teg...
- Car got painted... link inside!!!
- question for those with an aem short ram...
- Honda leather steering wheel covers
- Since so many people have asked... here you go! <Warning>Dial-Up users may not wanna go here!
- what to do?
- cross drilled or sloted
- Coolant Change: Drain/Refill or Flush?
- Is a type-r head the same as a port polished b16a head??
- installation of OEM front underspoiler
- Need Help on Pedal Selection
- FYI: Selling Pro-Kit/AGX setup
- Check out my new muffler (5-8 hp) across the board
- Polyurethan Ball Joint Boots
- Oil Catch Can. LS PCV Valve on the Valve cover
- Installed remote oil filter.
- integra car cover....which one and where to get
- im in the last 8 months of my lease how thorough are they gonna be when looking my car over!??!?
- Removing alternator pulley
- Size of bolt on alternator pulley
- Part # for itr throttle Bracket
- Selling a performance Car - Thoughts?
- Ordering some custom wheels what is the backspacing?
- Went to Famoso Raceway today...
- does the apexi ws bolt up to my 01 gsr?
- S-2000 steering wheel on a 97+ integra. HOW????
- gutted hatch
- Charlotte, NC Meet March 16 @ Frank Liske Park - Noon 'til 5
- 250 mi on a full tank of gas?
- 4-1 header clearance
- 94 and 95 gsr's?
- i want some 96 gsr
- Going to the track tomorow....what kinda times can i pull? (setup inside)
- For Those Who Drag Race(@ the track), I have a question about tires.
- Oil?
- bay area skunk2 itm users: looking for an ITR throttle cable bracket?
- what's a good price for a 99 GSR ECU
- Snapped a header bolt...now what?!
- Comp Ratio difference pistons for B18C1 go in to B16A?
- Anyone has a HKS Hiper Exhaust?? Do you have the same problem as me?
- Maintenance required indicator
- I need ECU harness help ASAP!!
- CD player removal
- H&R Coilovers vs. Tein SS Coilovers
- low beam conversion????
- E-town March 2: N/A 95 GSR takes out 2 V8 Mustangs and a 02 M3 powered Z3 conv.
- E-Town March 2: N/A GSR takes out 2 V8 Mustang GT's and a 02 M3 powered Z3 conv.
- tire width for tegs?
- Installers, Dynos and import shops in Portland Area?
- torque? how many pounds?
- Rear Tail light Gaskets
- cat question
- Redline
- san fran
- parts
- dyno facilities in central nj/eastern pa area?
- hp from crowler 403's?
- cams?????
- 9005 Light Conversion
- Bay Area, Looking for Non-GSR Throttle Body Rotor
- should i go with the cams on my motor??
- integra antenna problem
- Dumb question about coilovers?
- Differences between 2dr and 4dr Rear Bumper?
- CR for ctr pistons in b18c
- Wheel Size
- VAFC for sale!
- What Camber Kit is good? Comment please. thks!
- my crank pulley broke????
- B18b sensors
- Limited Edition Ground Control????????????
- need help quick.......
- a little help please
- Question about camber...
- length of doors?
- O/T: Shout out if you're going to the AutoX tomorrow at Hollywood Park!
- new pistons = bore block?
- intake=loud
- Is this right ?
- how to install eletrical oil temp and press gauges
- Use Skunk2 ECU Prog.?
- more pieces of the performance puzzle coming together
- What kind of pistons to get?
- Maxspeed Coilovers...ever heard of them?
- oo si b16a trans on a gsr ??
- Serial Number next to engine code
- Stolen Type R in NoVA
- Shipping from Canada...
- hey, im a newbie
- Please Help w/ GSR Mugen Thermostat Install
- ignition switch problem
- aem-hydrolocking
- vtec cyliniod gasket/filter keeps breaking
- Anyone using the specialty Adj Ball Joint Camber Kit?
- BLITZ POWERMETER ID
- Irratic idle - throttle position sensor - HELP!
- Stock fuel pressure for B18A1???
- Brake upgrades for an LS with 17's?
- Just installed Comptech Cat-back System
- AEM CAI for LS w/ S2 IM?
- 9005 Cool Blues blew up
- lowering to 1.25 inches. HELP!
- 2002 jdm type r engine for sale
- just got my bumper guards today! should I install?
- I want a pair of "these" lights, which aftermarket brand is almost the same?
- itr exhaust mod......
- Post your Teg License Plate
- Harcore tranny problem!
- Cop pulled me over with gf window washer lights
- Short Shifter Install, 911 !! Help!
- Stolen emblem
- BEST PRICES?
- offest on wheels
- What tires should I get for my GSR?
- my gearing is starting to feel havey, what's wrong?
- AEM CAI users..
- springs or coilovers
- Where does your gsr temp guage normally run at????
- Can this be fixed?
- Anybody need ITR intake cam?
- Anyone know if G3 shocks will fit on EG Civic?
- Pro-rating tires
- do some of you get paid or advertising?
- Other Down Sides to Having a Lowered Car?????
- JDM ITR 4-1 2 1/2" Collector Flange
- INtegra LS Idles @ 1200rpm
- OT who has window 2000
- ITR springs on GS-R
- Stiffer springs needed. reccomendations?
- best quiet yet powerfull exhaust to get for my rs??????
- Diamater of AEM CAI for LS/RS?
- guage cluster... fraud?
- She rolled over 100k last night...
- motor mounts
- When I hold the revs at 3k the motor sounds like it it making power in waves.
- 95 ls??? Need help!!!
- UPDATE - car runs rich at WOT.
- How much for changing synchros?
- B20 (prelude) crankshaft in a B-Series?
- About to install springs...what if the LCA bolts snap??
- rear lower tie bar
