View Full Version : Acura Integra
- is db8 b18c possible to use mugen ecu(for eg6)
- B18 vtec not working
- My DC4 Project
- honda meet nov 19!!!!!!!
- car just shut off.
- Breather Hose
- It LIVESSSS!!!
- Rear Shocks Suggestion
- DASH HARNESS HELP!!
- No Start, have spark and compression,
- help with changing an Auto tranny fluid
- b18b auto trans slipping
- Replacing accessory belts - Do I need to remove motor mount near crank pulley?
- clutch pedal sensors.....please help
- Steering wheel help
- 97 DC, Power locks & power antenna problem? Not a fuse problem...
- Hello all from Scotland UK. DB6 lowering question
- Would you like to import a JDM spec car legally?
- STOCK INTEGRA SUSPENSION ?
- No Fuel Pressure/ Fuel Pump not working with ECU
- J.R. VPAC controller
- Need help identifying this steering wheel
- New integra project
- LsVtec vtec issue
- Anybody done custom fog light add-on to their 90-93 integras?
- will a p28 obd1 auto work for b20vtec?????
- b18c1 custom turbokit DD
- Another Skunk2 IM Question!!
- 94 integra gsr...help!
- question about h22 in dc
- B18a1 oil pan work on B16a? also alternator question.
- Clutch Disc sticking on input shaft = No gears!
- why is fire coming out of my intake
- Power locks. Need help.
- 01 gsr head jobbie
- Signals and hazards blinking super fast, bad relay?
- 01 gsr type r valve springs and cams
- b20b in 98 integra, crank sensor... SEARCHED
- Car pulls to the right after alignment
- need help with my turbo setup
- ignition timing order question
- Anybody tried this wheel ?
- Corner light problem
- Check engine light, Obd2 car with obd1 ecu
- Need help-swapping a obd1 lsvtec into a obd2 non vtec
- bad catalytic converter?
- help!!!
- b18 to b20b swap help
- rubber nipple fell inside the manifold
- northern california motor rebuilds
- pistons and rods question
- 91 Integra 1st gear lag on acceleration
- RPM gauge problems..
- H22 on on my B20
- Turbo manifold for all motor setup help!?
- 94-00 red integra Photos uploads
- HEADS GAMES
- my 91 da turbo project
- 93 bumper to 91 bumper
- Very simple exhaust question PLEASE
- 95 Integra Wiring
- 2001 DB8 Progress.. My first 4 door.
- B18c1 pitting in cylinder wall
- awd da
- Integra Antenna Replacement
- 01 GSR wont start after trying to tuck wires
- Starting problem 92 integra
- Rough/bog out idle
- 95 ls no start
- What is this washer called.
- Looking into the world of GSRs
- car has spark fuel but no start
- Places to order jdm front end conversion
- JDM front seat install
- New from Southern Cali
- FOR SALE
- People with a Hondata gasket and the stock GSR intake
- which is bigger, ac or ps belt?
- B18A1 swap for H23A1
- NEED HELP! 93 DA offset rim fittings
- Project: JDM b16 swap LS
- Front bumper removed, Lens cleaning and correction needed
- No slack in clutch cable
- Turbo gsr build help plz
- Fresh b20vtec rebuild wont start
- stolen recovery help
- rivet drill bit.
- Oil on my sparkplugs
- Turbo for daily driving
- Burning smell inside car
- Lower engine cover dragging
- 1995 Acura Integra LS Help.
- anybody know what this is on back of gsr block
- B20 swap into a 92 integra gsr
- Suggestion For Exhaust
- HELP: Want to keep Powersteering in my Integra GSR with B20B Swap
- Some pics of my teggy :)
- my car stalled on the road...what do you think may be the issue?
- setup question Ingalls camber kit
- Type r rep
- Electrical problems when braking /rough idle please read and help!
- Anyone in here used the firewall plugs?
- Input Needed!!
- I would like some info on an H22 swap
- integra battery dying
- My 1992 GSR
- idle problem on b16a
- 91 DA9 Starts up for like 5 min then dies
- b20
- How to make my Integra lighter and faster?
- Dc gear into Da
- 2000 SE Integra with Type R exhaust cat question
- My lil Project integra :)
- Hit a Bump and car won't Start*
- Need some repair input advice...p1129 code thrown.
- snapped cable on gas pedal, what is it for HELP!!
- 1998- 2001 acura integra
- Is this OEM throwout bearing?
- questions about installing oil pressure gauge
- 90-94 engine mount question
- My Green Goblin
- Red96TurboLS build (oil pan to valve cover)
- need help no idea whats going on
- Where to find a headlight assembly?
- vtec cams identification help
- Swapping AC into a non-ac Car
- timing belt failure at 1yr/8000 miles..?
- from teen to clean
- is this fix able ?
- My fully rebuilt b16a teggy :)
- 1997 Integra LS
- Need Help on chosing suspension
- unknown smell
- Code 43 Problem
- stuck
- question about valvetrain for itr/ctr cams
- low fluctuating idle 91 integra b16
- Low fluctuating idle- 91 integra b16a
- DEI Alarm Add-on, remote start?
- Need help understanding this part.
- Mugen valve cwover for b20
- Clutch falls to the floor
- HELP on Illuminas with either coilovers or springs!!!
- 94 gsr has spark but no fuel???
- ABS FAIL SAFE RELAY-R? cant find it
- Can I use a ls throttle body with a gsr intake manifold
- B16 idles horrible
- EF radiator in a DA?
- Weird sound when turning off car
- how to check what code im throwing?
- 88 d16a1 5speed transmission VSS problem
- 95 integra wont crank
- OBD-0 Service Connector... NO CEL when jumping
- hello
- Is this original?
- is an aftermarket alternator worth it?
- Tein S. Tech Lowering Springs Question
- 94 GSR oil leak from the oil filter
- 97 Integra Turbo Coolant Leak Hose Resvior
- 99 GS-R Sedan RHD with JDM Type-R front and Drivetrain
- Muffler rattles, looking 4 suggestions..
- Horsepower?
- B16a 350 whp?
- GSR question need answer quick
- b18a1 oil in spark plug
- B18C1 oil pressure hole broke in 3 pieces. Need help ASAP.
- Where else can I look? DC2 GSR.
- transmission/clutch problem, need help!
- rim question. 90 da.
- Does a type-r thermostat housing fit on a gsr block?
- Pic Request-2dr jdm front wingless only plz
- Can someone help me please ?
- HELP! My Integra Wont Start!
- help with a 1990 integra
- Vibrant muffler model 1145 enough back pressure?
- HELP! LS/VTEC or new B18?
- QUESTION SHAVING TOP OF PCT CTR PISTONS FOR B18C1 BLOCK?
- brand new pads/rotors now smoking
- Colorado Springs, CO MEET?
- dc2 integra cold hard start but easy starts everyother time
- desiprate for help with ecu problem
- HOW TO: Cylinder leak test
- 1998 supercharged gsr misfire codes
- Products making my dashboard white/fade
- Tranny mount frame bracket broke! - Need to find a replacement.
- bad vtec wiring need Help
- where can i find a muffler
- How can I determine what ys1 trans?
- Trying to remove intake manifold, middle top bolt keeps turning
- Replacing bypass hose
- 92 LS no spark or fuel pump
- 2001 gsr jdm b18c
- dont know wat kind of rims i got.....
- battery keeps dying
- B18B Timing Issue
- 1992 Integra 220K miles A/C, Noise, Oil Leak, Jumpy Engine Problems
- b18b engine shaking after replacing cracked cylinder head
- 91 acura integra no defrost!
- 1995 GS-R: Oil Pressure Light Blinking
- Help! B18B flooding with Gas.
- ls vtec problams please help!!!
- Changing JDM headlight housings
- Can someone till me what throttle body this is????
- 91 integra injectors
- 1st turbo gsr build ever any setups??
- Help with my 96 gsr catalytic
- Not your average no start (with video)
- OEM Fuel Pump or Walbro
- My 91 DA integra build
- No radio or cig lighter power? Help!
- CEL help
- 96 Integra Alternator bolt
- Car is bogging
- 94 integra ls with b20b swap dies
- 1992 Integra CEL on car won't start
- B18 break in oil?
- 1994 Acura Integra LS ; Transmission Problem
- help with bucking/rubber-banding
- groaning/rumbling noise when starting from a stop
- how do you identify a LS & GSR crank?
- B18B1 Block w/ no PCV system???
- Intake Manifold sensor name?
- anyone know the best car to pull...
- Walboro Fuel pumps
- car smoking white rough idle hesitates big time and wants to die when i get on it.
- header/cat gasket custom install
- loud "knocking", pulled head, piston not level??
- Importance of BOTH Radiator Fans working?
- will this camber fit?
- trouble on integra visors, to cut or not to cut?
- OBD1 Injector Wiring Help
- PS Pump/Rack PLEASE HELP !!!
- 2000 Gsr piston ring problems
- 94-97 fogs off ebay
- 92 db1 RS window question...
- ECU??
- ABS light randomly on.
- key won't turn in ignition, wheel is not locked
- HELP! electtical issuse
- My GSR 2001 Newbie!!!
- New guy!!!
- Rear sway bar bolt sizes
- possibly a blown headgasket?.... White smoke, UGH!
- DA3 high rev problem
- 94 teg wont crank
- DA9 Paint touch up suggestions?
- Integra h22 swap help
- installing new camshafts…how do you keep the cams at tdc?
- tentioner pully
- b16a aem cold air intake fit on stock ls, please help
