View Full Version : Acura Integra
- VIPER 791XV Alarm
- skunk2 mani + str fuel rail fitment
- Looking at getting a teg
- keyed:(
- 90 LS looking for who makes a turbo manifold
- Need some help with brakes...
- Need help with turbo??
- user accounts?
- Speaker Sizes
- Security????
- Integra Dash Question
- this might sound stupid but ......
- car slow with VTEC ecu?
- what are the advantages/disadvantages of a b20 block???
- what's the better spring???
- TRANSMISSION NEEDED BADLY
- k20 engine swap
- I NEED HELP WITH SOME FACTS
- SPOOL VALVE FILTER AKA VTEC SOLENOID!!
- Random Check Engine Light
- How much to pay for a GSR?
- about to pick up 91 DA....engine help
- 1990 Integra B16A
- type r conversion
- axleback??
- A/C Removal = No Heat?
- Condensaton in head lights
- HID conversion
- Questions about KYB AGX Shocks....
- Help!!!!! I bought a stolen Integra!!!
- My friend's Wreck. Pics inside.
- Intake Manifold for boosted GS-R
- Known Trouble Areas, 93 Integra?
- ecu
- Springs
- Wheel bearing part #'s 94-01 Integra, 99-00 Civic
- Clutch Integra 90-91 same as EF8/EF9
- Any DA's on here with 4 lug ITR brakes?
- Car free revs in gear, cant figure out why, clutch ok....HELP
- Which one is the right part #
- question for all the racers?
- 95 GSR clutch "chatter" in first - need suggestions and cause
- LS VTEC swap parts list complete?
- ? about jdm H.I.D lights
- problem removing rear seats...
- exedy clutch? is this right ?
- I Need opinions after this madness....
- somethings not right..???plz hlp
- Ls tow-away
- integra help n advice
- anyone cali BAR a B16 integra yet?
- ls vtec
- what length carsound cat for this setup?
- valvetrain?
- one members thoughts of honda-tech and the mods response...read this
- 91 LS problem
- CAT CHANGE OR NOT??
- what makes more power lsvtec turbo or gsr turbo????????
- on the way to dyno
- Question About Going Turbo
- best tire size
- OEM Color on a red 94 integra RS???
- where can i find a 90-93 integra front lip?
- DISTRIBUTOR
- type r conversion
- how do you install custom speakers on cargo cover?
- is there a difference between AUTO and MANUAL starters?
- HELP!!! turn signals and emergency lights dont work
- ITR sway bars on LS - do I need any extra parts?
- Question about header and cat/test pipe setup with my rs-r exmag.
- Buddy Club Coilovers...are they good?
- New owner of 95 integra ls-->(looking for advice on upgrades)
- KS, TPS, Idle
- quick Q: VALVE COVER BOLTS
- LS ecu
- Wheel bearing compatibility?? Civic/ Integra???
- Question about aftermarket/custom exhaust
- Need some input on this about cable B16 tranny!!!
- Today's Dyno of My LS powered hatch
- Omnipower full coilovr set worth it?
- broek something on my IM!
- WHAT YEAR CIVIC OR CIVIC Si?
- ebay suspension combo question good or not ?
- Water In the Tyre Area
- Bushings
- ls header fit a b16 ?
- Powerlock Anti Theft device???
- Plastic piece around gas filler neck and driver side quarter panel
- Looking for RS parts car
- If your teg was stolen 2 times and stripped the 2nd, would you buy another?
- Got a Electrical Question
- were to buy optional side skirts *seached*
- My new Turbo... :-)
- SoCal Meet
- B20 DC2..JDM motor guaging intrest! what do you think? PICS!
- Grr Intergra year help.
- What a Load of Crap Stupid Ref Tickets*!!!!
- what kind of rims for my DA integ?
- Need help on making my exhaust sound better
- car is dying and studdering/hesitating!!!
- shop estimate...sound right?
- Parking and cold weather
- Apex WS
- what does the steering rack guide screw adjust???
- 97 bumper on 94?
- exhaust fit?
- PLEASE HELP
- Pic of Crank Pulley Bolt on a B18?
- Blower motor just crapped out..help before I freeze my a$$ off !!!!
- Idle surge?
- JDM Bumper Lights
- Acura GsR Turbo 96...question about
- noise diagnosis/motor probably going to machine shop, what to change????
- how to remove silicone sealant?
- problem wiht my teg
- y80 or s80
- what year teg's bpipes fit on a 99 ls 2door?
- I need help with this question?
- anyone have a pic of stock GSR 94-95 Intake Manifold..
- icebox fitment issues on 94-95 GSRs...ABS issue
- Buddy Club exhausts????
- CARFAX Request please
- 94-01 Dash Removal ?
- question bout tires?
- Which injectors are you using or are recomended i am going turbo with plans of 450 whp
- Finally got an Integra!!
- where buy car paint
- will 92-95 civic eibach sportline fit in integra?
- Might get a free teg
- Did the b16a come in any auto jdm integras after 1993?
- Bulb Size
- look for a jdm style lip
- Have a 2000 GSR and NEED guidance
- DA MUGEN SIDE SKIRT QUESTION
- tdc sensor, cel code 8 help
- tranny probs
- Buying Another Integra
- which one is better SRP or CP
- cat back pics
- Integra guru's a question
- ordered some new ish
- Where to find forged internals
- How long do B18 motors last?
- b18c1 engine bog, ignition timing off?
- anyone have an lcd flip out in their g2?
- 12:1 CR build questions
- My Car
- ITR brake master cylinder into GSR: fr brake line
- can you identify this as a GSR trans? (pics)
- who can chip my p28??
- Stock 00 B18B dyno
- someone please help me and run a carfax
- i wanna give it up to my integra
- My Teggy!
- god damn theives
- my car died on the freeway
- engine code of tegs
- Own This Poser..
- damn thieves... got no life or no morals
- question about itr ecu?
- Anyone Running Air to Water Intercooler...searched
- Question for 98 LS owners
- do i need this for my Intake Manifold Gasket?
- camshaft question....
- B16 header fitting a GSR?
- exhaust sounds like crap
- 90 teg installing a jdm cluster
- Carbon Fiber in Cold
- how to mod a k&n into stock airbox
- Do you guys think that this LS b18b1 block is worth to buy?
- boosted b16
- LSVtech questions
- CEL Help
- dont be cheap change those head bolts after taking them off!!!
- Damn it. . .
- Integra spoiler?
- Question about this Integra DA from j-tuned.com...
- am i running rich?
- reliable used parts source?
- I am selling my 2000 acura integra on ebay North. CA
- exhaust question??? need suggestions
- timing cover???
- Can I use Civic Si
- temp gauge prob??
- Head is not getting any oil? any suggestions?
- wat makes a grown man cry...
- where can you buy G2 1 piece headlights?
- RED ITR Valve Cover
- wtb: helms manual
- g2 integra lip choices?
- 98 integra 1 piece headlight
- Ticking sound: POSSIBLE BENT VALVE?
- QUESTION ABOUT ECU"S
- Safe Compression Ratio
- Questions about Turbo charging gsr motor.....
- Compression Spec on an 94 LS
- GReddy SP-2
- Yay! Got my 01 GSR! Have a few questions.
- close call with timing belt!!!
- question about spoon products
- again about the ignition......
- Damn ABS light.
- Inspect my B18c1 please......
- got hks hi power...ran into a small annoying problem
- pedals
- Integra JDM Front End HID or No HID....? WOrth the extra Money?
- overheating gsr tried everything the previous info said need help!
- Integra Theft
- Useful info here.
- why is my motor burning oil?
- 91 Integra LS Headlights not working
- p72 ecu redline
- 91 Integra LS Charging Light Goes On And Off
- questions about intake manifold & throttle body for gsr
- 91 Integra LS Hesitate During Acceleration
- Anybody every heard of a JDM KYB chip???
- Adventures in motor mount replacement
- Possible IACV problem, not sure... I'm starting to think it's a clutch thing
- Got a new Chip for my p30, anybody ever heard of it?
- convert a/t to m/t
- ECU
- what type of header and manifold for 98 GSR?
- Chech out my gunmetal dc2 with advans and my buddy's EK
- different IM on LS head??
- teg problem after headgasket change
- Sprint Extreme Springs Pic Request
- Exhaust woes!!!
- Car Fax Request
- does anyone have a greddy exhaust or a RS-R exhaust on a 90-93 teg?
- San Diego help please! STOLEN: My JDM front Integra GSR 4dr Db8 STOLEN Dec 5th!
- 98+ integras...can u post ur OEM fog lights? already did search..everything was red x
- tranny or clutch problem?
- 1993 GS-R (NEED A LITTLE HELP)
- would this be too loud?
- 94-97 Teg CUSCO roll cage in '90-'93 teg, would it fit?
- Replacement for blown shocks and springs...
- Should I get this car? 1998 GSR 98K miles. Some Mods.
- where can i get the OEM optional side skirts?
- which ARP head studs are these? *PICS*
- power antenna in winter
- 86 integra will not start! getting spark, main relay good, new fuel pump....
- MEGAN RACING HEADERS
- Custom Exhaust
- Running Loose on bearings for a turbocharged b18c?
- approximately how long does it takes to tune HONDATA + BOLTS ON
- gsr no vtec?
- New Exhaust
- my tranny wont shift into 2nd, 4th, or reverse.....
- what brand exhaust sounds the best?
