View Full Version : Acura Integra
- TEMP Guage Question .. ...
- ** PICS OF DB1'S **
- Aftermarket lug nuts on oem wheels..
- My Integra GSR
- Two Quick ????'s
- Unable to diagnose check engine light (after obd2b to obd1 ecu conversion)
- CarFax Report
- What OBDA2a ??
- car smelling flooded and not idling right
- 91 teg fuse box qu about wire connect
- need quick info on integra
- b20 swap startup problems
- Type R front end conversion?
- Some recent pics of my GSRRRRR
- gsr intake manifold. is there a way to test it?
- Aftermarket Axles?????????HELP!!!!!
- My Cars history
- cant decide on wheels..help
- gsr head bolt torque and pattern
- b16 to integra ls swap...wiring questions????
- oily intake manifold??
- ? about super chargers and intercoolers
- HELP! Will a 98 GSR tranny bolt up with a 94-94 LS/RS/GS clutch spline and all???
- buzzing sound from under steering wheel plus maint. requ lights on!!
- HELP!!! New swap stopped starting...
- k24 swap
- Question about license?
- srt-4 vs gsr hatch
- Skunk2 full coilover vs. kyb agx's w/ skunk2 sleeves
- Blown Engine, any Business in Seattle that sell JDM Engines?
- Number 2 Cylinder Misfire? what are the causes? and fuel pump problem
- donts about nitrous
- Ignition Trouble
- I got RC 1000cc injectors and need help
- Gas Mileage with Cams and IM
- Pic request... desert silver dc on polished blades...ive seen it before
- lights won't go off
- K20 DA?
- IDLE PROBLEMS!!!!! NEED HELP
- Hitting Vtec leaking OIL???
- Help with Tranny Swap
- ___can someone post up a good how to thread here? (shaved engine related)___
- integra testpipe question
- steering wheel
- Is it worth it
- Main Oil Seal
- '95 Integra GS-R Stolen!!!
- difference between JDM and USDM LS ecus?
- Brake swap, Prelude?
- da h22a swap!
- Radiator Leak
- k24 ito 95 integra
- ***PICS OF JUST DA'S PLEASE***
- the differences in gsr years?????????
- idk what to do
- replacing wheel bearing, what else
- side marker questions
- ***Prevent Theft: Block off Plate 4 Hood Latch***
- 310cc injectors?
- TRADE??? 2000 R6
- could a civic 05 EX 2dr exhaust will fit on my 98 teg GS 2dr?
- h4h conversion to h4
- b18c1 help this is a tricky 1
- antenna problems
- APEXi exhaust
- exhaust laws in PA
- placing cruise on a 96 rs integera
- Why 8" springs in the back??
- Bumper Mounting
- Vtec Solenoid Spool Valve code after hitting pothole
- White smoke from the engine bay
- Quick Question "distributor"
- what do you use to get rusty exhaust bolts off?
- removing door panel
- DA Integra - SPOON MIRRORS
- Help! Need a B18A cable tranny transmission differential
- couple questions... suspension.. intake manifold, and ECU
- solve this one!
- Car feels alot slower with Sk2 mani, and itr cams.
- JDM Fog Light Kit...Need Help!
- Emblems for 94 Integra
- Integra car cover
- Price opinions on shaved door moldings
- anyone got ls webs or anything else up 4 sale
- h22 into dc2 motor mount problem
- complete b series turbo kit t3/t4 $1300!!!
- GSR Tranny Issues - TQ Mounts ??? Search !! HT Techs Take a Look !!
- Oil Pan Question
- what is the difference between GSR and ITR cranks?
- Those Damn Pillar Gauges...
- what should be next?
- Alarm causing me to be unable to start car?
- 1990 acura integra wont start, NEED HELP?
- Ebay strut bars ?
- Cam questions
- Boosting my gsr tommorow. little vaccum help please!
- What would you do with $6K
- help
- Exhaust Ticket = New Exhaust
- tokico struts and springs
- removed stock intake....anything else?
- 93 integra vs 2001 2.5 RS
- To keep the side molding or not to keep it
- grinding problem just showed up!!
- jdm side marker
- Factory Alarm 1998 Teg
- Service Manual
- Engine dry's out ??? WTF???
- couple stupid questions about my rebuild
- Ground Points
- car left me stranded...please read.
- first post!
- Quarter window help
- Edit this pic to diff color plz !
- DO I NEED, integra type R front and rear control arms?
- how do i keep my floor mats from moving everywhere?
- gsr head for LS fit?
- 1993 B18C5 SWAP
- New Pics of my DA Rear End
- Did i get a good deal ???
- hybrid 1990-92 integra
- Testing a Thermostat Switch
- help on replacing right rear brake light!
- vibrating when accelerating, why?
- omni power w/ skunk2 stage2 cams
- What is this part called?
- would b16 lsd fit?
- JDM P73 ECU question
- Clutch noise question -- with a twist (searched)
- im new and i need a diagram!!!!
- Her she is fresh from paint!!
- b17 vs. b18c1???
- 94-97 convert to 98-01 front end??
- what ecu for 92 integra b16 swap
- would a sk2 manifold purchase for gsr be worth it with cmashaft?
- ABS light
- Teg and RSX mirrors Interchangable?
- selling my SSBP GSR
- RS is faster then any GS or LS
- where to buy plugs for dc2 wing removal?
- AC Idle Pulley Question
- Integra front mount options...
- started my car....
- So i was driving in the snow...
- is this a good price for a JDM Mugen style Twin Loop Muffler
- Rad fan not working
- Any1 interested
- WINGLESS QUESTION
- 01 integra crankshaft
- 10 IAT - intake air temperature sensor ??
- DA clusters
- NEED DIAGNOSIS..
- Any body no where i can get a wing for my Integra
- Integra GSR Weight??
- k series swap
- need to know LS rod bolt torque, and head torque w/arp bolts????????????
- honda emblem.
- how hard to replace rear main/ oil seal?
- Some Questions....
- help me decide what catalytic converter [need to ref]
- state ref question will i pass visual?
- Where can I find these?
- Vtec Solenoid ...
- dashboard
- jdm sh*t.com intake mani?
- Power steering belt off....comments
- Mainting Car from rust and wear and tear.
- car died on highway......l
- Got the Teg back from the paint shop here it is
- type-r side skirts?
- TRANNY ISSUE
- whats wrong with this tranny?
- code 43,16
- gauges for my 90 integra
- foglights???????
- bad idling
- 95-97 INTEGRAS: Emissions Warranty Extension and FREE Service Reminder
- Stock Radio Err-3 Integra LS
- short shifter question
- Temp gauge electrical problems
- #1 and #4 dead HELP!!!
- Pulling CEL off a 1990 Integra LS - How do i do it?
- Overheating problem (already searched)
- D3 or D4?
- JDM or Aftermarket?
- I love my car!
- STOLEN: INTEGRA 626 SO CAL MTSAC
- iacv coolant hose ID??????
- Hi I'm new
- headgasket problem??
- looking for "I <3 my (integra sillouette)" sticker
- Is this a ECU problem, please read!!!
- Clutch Problem Need help
- ****Immobilizer Unit- Do I Need 2 Reprogram*****
- which choice is better for my set up? help
- GSR endlinks... where did you get yours?
- weird noise @ low rpm's
- whp on a sk2 manifold? (GSR)
- Couple Questions about my GSR...maintence light, keyless entry
- broken header studs
- emissions warranty letter
- What Leather seats in a DA?
- undercarriage weather-guard
- what if i put blowoff to the automatic teg?lol
- 99 B18c1 Block --> obd1 or obd2?
- gsr leather seats....
- Anyone ever upgrade the interior lighting in a DA?
- Type r piston question????
- Want to paint my valve cover but cant find paint.
- Need Advice!!!!! Please Help!!!!
- Won't start after stall. Help...searched
- Which Piston,Camshaft,Rods Are Best for ALL Motor On a GsR?
- Hatch Light is coming on and just flashing at me?
- tie bar behind the rear seats???
- battery light on after missing a gear
- rev hard turbo kit
- Rear Motor Mount Insert, with or with out tranny in?
- buddy club seat question
- How much is this integra worth?
- Motor mount replacement
- transmission wont go into gear
- 93 ys1 gsr tranny gearing??
- LS-VTEC VS. GSR
- Removing the spring pin on the shift linkage?
- To those using a NRG hub...Quick question...
- Steering Wheel 92 and 97
- IAB's ANy help?
- help,help!!
- can i run a 75 shot on stock ls
- cat/exhaust question
- 98-01 teg rear seats in a 94-97
- which Skunk2 front and rear strut bars will fit '90 Integra's??
- arp headstuds for b18a?
- 50 shot question
- coilover and strut question
- Looking for a spare part. Heatshield around cat.
- Headers... which are best ?
- messed up alignment affect performance?
- LS To Vtec
- skunk2 stg 2 cam on stock valve train
- Camshaft caps bolts
- Racing seats for the DA
- where can i get a replacement engine for my 94 ls?
- Installing component speakers
- wheel question
- 94 integra/B20 replacement
- ecu throwing a 2 and a 22
- MSD ignition gone bad
- adjusting tokico blues
