View Full Version : Acura Integra
- Squeeking nosies in the front (suspension problem?)
- any "how to remove and install distributor" topics for a gsr?
- HIDs on DA
- Exhaust question
- is it normal to see steam coming from the hood?
- need help from the masters!
- anyone heard of bad ball joints?
- 3rd gen integra, hid lights. no retrofit is it ok?
- Advancing the TIMING
- DA relocate hood cable..anyone know about this?
- Polishing valves
- Surging idle
- sputtering during accel
- usdm 98-01 front conversion
- No idle
- car idling weird and sometimes below 700rpm causing engine to shake
- electrical problems
- will my 95 gsr header, cat, exhaust bolt right up to my 95 ls? will i gain any power?
- Wired tach problem when vtec kicks.
- HELP! Distributor/Firing Order! Searched!
- what calipers fit a DA?
- z10 3 main girdle for ls/vtec
- Engine Mounted wrong!!!!
- 1992 shut down, no prior signs of problem.
- 3rd gen GSR with a 2nd gen GSR emblem on it, pics anyone?
- type r momo steering wheel in my 95 integra
- dc forks and struts on my da
- Dropped Pheonix Yellow gsr.. Take a look!!!
- Auto Transmission Drain/Refill
- taillights won't go off
- ls block , gsr internals ?
- Integra Exhaust Parts: Manifold-->Cat
- Burning Oil, head gasket and compression test ?
- search is down, compression?
- VAFC P28 ecu wiring diagram needed?!?
- changed thermostat
- check out my new SUB $250 2.5" stainless cat back N1 exhaust system
- 4 door side skirts
- Changing Head Gasket, What else should I look at?
- Head gasket kit?
- which clutch for the teg?
- Damn Clutch!
- Tail lights
- For those runnin an ITR sway and Tie bar...
- New at this but, Turbo or NA?
- search is down.... need diagram of GSR coolant lines. ASAP
- 90 cleared tailights
- k20 vs. b18c5
- exausts differences?
- should i resurface my fly wheel when i do a tranny swap?
- problem on start up
- Cluster problem
- DC integ fogs
- bronze or gold wheels on white DA pics please
- You guys think this clutch/fw will be alright?
- golden eagle vtec conversion kit
- motor/tranny combo question
- why does the v-tec pop at 5500 on gsr
- Help me find a lost post, cleared out gauge needles
- Help! Wiper Blades went out and its raining!
- shipping weight for a b18c1
- Automatic GSR's??
- 94-95 integra gsr p72 ecu question
- LS/VTECH oil line problem
- Scam scammmm!!!!!!!!!!!
- i need help identifyin this tranny.. (pics)
- down grading
- SAN JOSE RESIDENTS BEWARE!
- Wierd problem...Starter clicking???
- how do i remove this fuel hose/line??
- integra electrical experts help please! 1157 & 9006
- can i lower my rear more than front
- Need some suggestion please!
- Will a radiator of a LS work okay in a GSR?
- Meet at UCR
- what parts from the b16 will fit the b18b?
- replacing alternator belt ?
- Coolant leak problem
- 90 acura integra b18 fuel problem`
- Civic rear ends my Integra **PICS**
- 91 front seats, what fits?
- firing order on dizzy
- lip suggestions (92 teg)
- Can u put a k series motor in an ls teg
- gsr rims for sale?
- 91 teg steering wheel in 89 CRX
- Thermal R & D muffler
- HID question
- Fog Lights
- Quiet exhaust.
- thermostat...hope i did it right
- bigger fuse question
- CTR intake cam, where does it peak?
- I need a 98+ rear bumper...
- has anyone brought a quick release steering wheel kit from ebay?
- AeroTurbine Muffler
- Rainy Day
- ITR cams in GSR head...(searched)
- NEED HELP JDM GSR INTAKE MANIFOLD DIAGRAM
- WRITE UP: Fix DA passenger wet floor permanently! Also posted on G2IC
- 92 Integra Service/Shop/Helm Manual
- Vtec engaging too late?
- takata seatbelt harness on DA or DC picssss pls
- Where does this go?
- Rear door handle swap?
- removing the axels
- o2 sensor help
- Squeeling noise, but not the belts?
- rebuliding an LS block and need some help FAQ lols
- 2001 GSR exhaust
- FS: B18 Non-Vtec JG Camshafts
- How mot to sell an DC 4dr
- Cable trans to HYDRAULIC trans?
- JDM Integra Cluster
- installing wilwood brakes
- Will 94 Del Sol SI 1.6L Rear Wheel Bearing Fit 94 Integra LS
- problems with ignition fuse short
- how to replace front wiper motor?
- Tie Rod Causes Vibration??
- Steering wheel hub, all the same?
- New springs, strut question
- Arospeed Muffler
- Swap info needed.
- do you think 205-55-15 good on stock gsr rims?
- Good options for not getting ur DA JDM turn signals jacked?
- Funny story.
- What function do all the heat shields provide?
- Where to Find ITR valve springs
- Alternator Question.
- Large Gaps in body on integras? (pics)
- how to clean cf hood
- help with shocks
- thermostat
- INFO APPRECIATED: Performance Shops in LA
- Some pics of my Turbo Parts..
- integra window visors for sale
- ls/vtec write up
- speed limiter
- Vtec solenoid
- Please I need help!!!
- If i was going to rebuild...
- JDM side markers on USMD front end?
- Cleaning IACV? (Used search)
- Type R OEM style on GSR?
- JDM DA6 One Piece Headlight Cornerlight and Fender Sidemarker Light, 90-93
- Need different lug nuts for Black Racing Wheels
- sound deading crap!!
- help installing springs
- 92 gsr hood swap - what will work from other DA's
- Bad mods and repairs: Why do people do them?
- Power Steering/ Engine Picture
- Finally, good pics!
- Why the hell do people waste money on stupid things?
- Valve Tap
- GSR tranny part ?
- Battery Light?
- HELP!!! CLUTCH MSTR WENT OUT!!!
- difference between automatic and manual dizzy on 91 integra
- JDM DC2 Window and Mirror Door Switches to USDM DC2?
- what does missing link do?
- GSR IACV & Skunk 2 Intake Manifold
- JDM SiR-G Front Lip?
- Bad Fucking way to start the year.......
- another question
- Clicking noise when trying to crank car
- b16a2 in 97gsr (need help quick, restoring process)
- Bolt head broke off for suspension
- Supercharge da?
- AEBS intake manifold for gsr
- Vip: Stolen Itr Front End Converted Da
- JDM DC2-R HID wiring
- up n down idle
- Axles for H22 Integra
- Should I replace my retainers or not?
- just curious, where do you guys buy your LS motors from?
- does a 94-00 integra dash fit into a DA integra chassis with MINOR modifications?
- Hydrolock Question
- vtec problem
- will a VAFC2 help out?
- Flashing key light...car wont start!
- 1991 Acura Integra
- headers ...
- Take a look at this piece
- Pictures of my new Kaixen HID's in my beater
- 90 integra turbo
- 87 Teg LS --> Fuel Problem. PGM-FI light on, and fuel pump keeps running, WONT START
- ls weight
- Tranny Issue, While in First Gear it makes a metalic noise?
- momo/hkb steering wheel hub users...question for you
- HELP ON INTEGRA SUSPENSION...
- my temperature control is not smooth.
- Opinions on B18C engine build
- numbers under engine code,what do they mean?
- Sound packing
- How do u take out my speed limter
- Need help with brakes, brakes are dragging
- Need help with Clutch Interlock Switch
- 94-94 b18b(JDM) Map sensor and TPS location *Searched*
- New intake for the teg
- Turbo or NA?
- Need new Clutch put into my GSR **San Diego**
- could the squeeking sound be my shocks ?
- Quick Swaybar Endlink Question (Pictures)
- Pictures of your dc2/4 radiator setups?
- no carpet = loud car inside??
- How long do you guys think I have?
- Edelbrock Pro Flo..or..GREDDY header
- Throttle bodies IACV FITV and HONdata!
- tranny to motor nuts and bolts...
- no fuel at all
- want to turbo my ls
- one picture.
- Confirm Location - Coolant Temperature Sensor, Temp Sending Unit and Fan Switch - on B18C1?
- help
- Changing HeadGasket on my 90 DA9
- Crank Angle sensor
- spark plug wire keeps poppin up.....NEED HELP!!!
- 94-97 lip on a 99?
- jdm b16
- How to produce max power from stock engine
- good tuning!
- WTF is wrong with people?
- POST YOUR PIC OF YOUR INTEGRAS WITH YOUR SPOON MUGEN OR VOLK WHEELS
- Car cutting off
- places in bay area that can do hid retrofit on 3rd gen integra?
- Spoon lip for usdm integra
- Camera question
- what lip is this?
- Climate Control Mode Butons Don't Work
- Update on my Car
- will a chip help?
- battery
- anyone have a picture where to refill tranny fluid
- new b series axles?
- Injen race divison Cold air intake
- single bend, or dual bend short shifter?
- GSR V-tech plug help!!!
- b18c turbo. help!
- 91 Integra LS, Oil leak around the oil filler cap
- Methods to "hide" your header?
- stock shifter direction?
- Low compression and Misfire, i want to fix this myself.
- Distributor question
- ok guys read this plz i am worry a lil
- integra window visor installation help!!
- OEM Exhaust manifold bolts and nuts?
- ls vtec convertion
- ball joint question
- GSR tranny
- 92 integra is driving me nuts. distributor rotor not turning.
