View Full Version : Acura Integra
- Civic exhaust on an Integra?
- How to get the most out of my engine? (was: Gsr !!!!!!! baby)
- Manual steering rack in a 94 integra
- losing coolant,need help!!!!!!
- Ticket
- 2000 gsr with toda spec b cam
- HELP! How to remove piston from connecting rod
- steering problem
- chipped ecu wtb
- Axle problem...
- Jdm front conversion
- peddles from eg 5spd conv
- OBD1 Ecu in OBD2 car..where to put ecu?
- Integra climate controll led bulbs question.
- injector cc's?
- b16 or b18 head?
- p28 chip?
- 93 integra HELP!!!!!
- How to convert cable trans to hydro?!?
- Please help broken valve guide
- smaller belt
- Check Engine light but no OBD1 plug?
- disable using a key to open your doors
- What is the panel in the bottom of the hatch floor called?
- DA is still mumbles a bit
- Using Non-abs w/ abs car
- ecu check engine light
- Oil temperature switch/ coolant temp switch
- cleaned iacv now what?
- 94 Integra LS totalled buy or dont buy
- obd-1 B18c1 motor into obd-2 integra...
- oil psi n/a da9's
- Am I missing something ? Weather stripping DB8
- How to tell what crank I have
- How much could i sell this teg for?
- DA jdm headlight help
- Question? Can H4 bulbs fit in 90-93 integra jdm one pieces?
- Oil coolers!
- rear knuckle
- 91 integra dies after interstate
- pcv on the black box and on the intake manifold?
- NEED HELP! Just bought this car!
- Gas light coming on before it is on empty
- To anyone with 98-01 with FACTORY FOG LIGHTS how do they wire?
- Help suspension!
- LS rear calipers
- jdmland.com type r head question
- Mirror replacement
- Need help is this EXHAUST a gsr.
- Need clarification on swapping B18C5 into a '98 GSR
- fog lights question ???
- Looking for Northern Cali shop to build B18C1
- Please VTEC help
- GSR head removal
- 91 integra rs ecu
- ASR Brace users!! Please chime in
- Which clutch to get? >> Autocross and Daily Driver
- Suspension Help
- Gsr tranny?
- difference between 2000 b16 tb and 96 gsr tb
- What to do for 450$ to a virgin da9.neva been touched.
- suspension n coilovers
- H&R sport springs, install question as well, anyone have pics? search sucks,
- Grinding and squeeking noise
- gsr trans or ls ?
- 95 integra ls hesistation problem
- which is the correct distributor?
- a lighter flywheel
- b18c1 5th@60mph revving @3500
- Is this a GSR integra or a LS integra
- da9 b18a build options
- anyone use a harness bar?
- Valve Envy
- power windows wont work!! WTF?!?!
- what ecu does my teg have
- 94 Integra GSR Turbo and motor work. Ignition coils keep burning out????
- will 95 integra greddy catback fit on a 92-95 civic coupe
- Clutch Question
- Coolant leak, lower hose cold, fan, etc...!
- vtec problem with my teg
- oil filter???
- Check engine light help!
- My 91integra build thread converting into gsr da
- 91 acura DA integra problems
- OBD0, OBD1 or OBD2???
- What year ???????
- Changing Pistons and then breaking rings in...P28 ECU?
- What is my Teggy worth? (*pics*)
- Is a JDM ITR Catback a direct bolt-on for a 94 DC2? (searched w/unclear results)
- obx or blox camshafts
- new suspension
- vtec no kicking in till 6,000 rpm?????help
- Question on controllers
- ECU wire question please help !!!
- Where should I get my lip from?
- at what rpm does vtec kick in?? b18c1 2000
- idle problems
- fan blower only works with 3 or 4 setting?
- wires
- 6.5 wide rims will my stock gsr tires strech if i put them on?
- Best ecu??? Obd1 or obd2
- shift knob help
- Hard to start after sitting
- 91 integra w/b16a2 vaccum line issues please help!
- Corner Light Brackets Question
- Why are 01 floormats different than 94-00?
- Want to Supercharge 95 GSR, Got some Questions
- In the Integra market.
- Cat converter help, Where to buy?
- 2000 gsr turbo heating problems
- My VSS went out on my gsr, can i use any b series sensor?
- Sidemarker Installation
- Heater blower blowing light fuse?
- 99 GSR wont start: help me diagnose
- What Transmissions Fit 94-01 acuras? B16 years?
- 96 teg Rear wiper Gromet????
- ignition problems plz help!
- Pulled mutiple ABS Codes. HELP!!
- how to help idle problelms?
- Ground control Ots rates for daily driving no track
- has anyone redrilled stock hubs for a 5x114 pattern?
- i need help on this
- DA GSR Driveshafts
- weird issue with fuel pressure?
- wet carpet and back seat?!?!?!?!?
- 97 ls integra SE redline problem (video included)
- 95 GSR Bogging or lagging at 2k to 3k Help!
- half shafts???
- 93 integra wont crank
- help wit my teg!?
- Knock Sensor Location
- Climate question / problem...
- just exhaust finished on my da
- ls engine cutout at redline
- What exhaust are you using on your DB7?
- YS1, cable, how to tell if it is a GSR??
- 94 integra ls stock kyb suspension setup
- Injector Wire Problem
- da integra turns over but does not start
- car smells
- intake manifold.
- is b18c1 and b16 valve cover gasket is it the same?
- removing inside sunroof panel??
- Where thermostat on b20b
- things to expect after getting a new exhaust installed?
- How to tell what head is on my motor
- update from previous post "white smoke outta exhaust"
- GSR Motor. 87 89 93 fuel... questions
- Help!!!
- How to Identify Engine
- Few probs with 91 integra 1.8 dohc
- Axle fit my 91 integra?
- gsr smokes when getting on it.
- Raspy Noise at 3k- 1996 GSR
- need part # for hood weather strip
- Tint glue removal
- keep breaking axle
- Vibration in 2nd gear
- Check out my sparkplugs???
- help: 97 integra CD player installation
- burning oil and grinding gears... questions
- GSR cluster in a GS?
- '95 LS special edition, Distributor problem(im pretty sure)
- Clutch.net or Exedy Clutch kit
- Need help with sensors.
- 94 integra with knock sensor code..
- Help with headers and cat dilema
- New clutch and lightweight flywheel HARD SHIFTINg?
- Over heating/pressure in the coolant system
- 16s or 17s??
- watsup with my vtec and my warming up the ca issue
- 92/93 YS1 and 94-01 Y80/S80 - 5th Gears Exchangable?
- how to install horn with quick release
- Low fuel light comes on too late
- ES tuning muffler
- Heater/AC sometimes doens't work???
- how do you adjust the way bulbs point in jdm front headlights
- Brakes getting extremely hot... scraping noise heard
- skunk2 intake manifold?
- Gsr swap failed smog w/3k miles on rebuild
- HELP! Motor mount need advice!!@
- itr rear seats fit integra 90-93?
- oem brake upgrades?
- 92-93 exhaust on my 91 DA
- My 1991 Acura Integra
- Deal or not
- need help with idle problem!!
- Integra Burnt! HELP
- ls/vtec planning stages
- 98 GSR JDM B18C1 Swap
- ignition switch
- Please help car wont start.
- Size and threadpitch of rotor screws?
- 97 Integra Head and Other Problems
- windshield banner?
- need help fast 94 teg sputter
- HELP! header wrap how to ?
- low rpm sputter
- Removing Electric Integra Antenna
- please help: O2 sen. or fule system?
- asr sub frame brace question
- plastic oring stuck in manifold
- Turn Check Engline Light off?
- b17a1 question
- climate control
- PIC bushing kit problems - LCA
- Automatic Turbo Integra
- question about Honda tech
- GSR Tranny VS LS Tranny
- OBD0-OBD1 issue
- engine stutter...
- are all fenders the same for integra coupe?
- Need help identifying a pair of side skirts
- what dc2 gauge cluster is this?
- Reving issue
- Relays, are they the same from 94-97 to 98-01
- 2000 integra bumper?
- no 5th gear or r
- Narrowband Setup Question
- Annoying Gulping noise coming from stock intake
- stock gsr bottom end rebuild
- bad radio signal
- Hydrolocked?? Gsr-turbo...Wont start. Need help, advice
- Overheating only during stop-and-go traffic AND long freeway drives
- 98 teg running lean
- CEL turns off without manual reset? WTF
- Clutch??..
- P72 Tran - Worst Case Scenario
- white da b20
- what do you guys think about this quick release?
- k20a into dc2 chassis
- Throwout bearing
- Shifter Trouble
- Gsr wire tuck help!!!
- looking for dress up bolts!?!?
- power window problem
- OBD1 motor in 2001 Integra Type-R
- B17 bore/boost question
- Steering busted..anyone tell me what to do!
- good offset for db getting rims (Daimond Racing)
- single stroker in a DA9
- Lovely Code 43....any advice is grateful
- integra bumper help
- DA GSR Transmission... Hydraulic?
- 91 LS integra acceleration stutter
- 95 GSR makes odd "vibrating" sound around 2k-8k rpm
- clunking sound and jerking steering wheel 97 gsr
- Subframe help.
- time to replace head gasket?
- gears are grinding WTFFFF
