View Full Version : Acura Integra
- orc or test pipe, which would you choose
- what lip is this, and where can i find it?
- DA: Anyone using these taillights
- Question regarding LS/VTEC swaps ...
- GSR stats on a LS
- tyep r ignition
- water in headlights
- !? THERMOSTAT !?
- Problem
- clunking noise
- Is this reasonable?
- Identify Buddy Club spec 3+
- Dead ODB port
- need axel help...
- Name of this piece that connects the pcv valve
- water in my heater
- poormans R
- buyin a teg
- intake syste, questions
- LS CP 10:5 compression pistons in a GSR with CTR cams?
- going wingless
- help me ID this intake manifold..
- LS motor with LS Special Edition Tranny and get a ITR 4.7 Final Drive
- integra problem
- RHD Conversion! New Project!
- got major problem
- 98 gsr leather
- Slotted and drilled rotors question!!!
- Help dc4 radio issues
- Speed limitation
- Is it possible to swap a V6 into a DA
- Help, Did a DC Dash color swap, windshield wipers dont work
- 90 Integra OBD1 B16 swap... spark and fuel, but wont run..... help!!!!!!!!!!!!!!!!!
- Troublesome ABS, please help..
- ***help***94 gsr hard to start then idles for a little then dies
- engine choice
- 1993 Integra GS Fuses
- da one piece head light ?
- 94 ls vtec swap
- Removal and installation of rack and pinion
- Integra RS Exhaust?????
- low idle
- NEED A GOOD TUNE IN MA????????
- skunk2 really the way to go for an IM
- Autozone radiators any good?
- front corner lamp
- need help with pcv valve
- turbo with stock internals
- problems with obd0 b16 in 93 integra rs???
- need to know how to remove windsheild washer resevoir
- I think i blew up the gsr help!!
- LETS START A DA PIC'TATHON
- quick question!
- whats pm?
- Im looking for an engine block!!
- Refill point on 94 -01 Integra transmission.
- sparco harness bar
- MY FRIEND'S DC STOLLEN IN EL MONTE!!!!!! PICS INSIDE!
- SSBP Seats for a sedan?
- 500hp Integra Build
- je pistons/eagle rods
- This a good deal on a db2
- My DA loses all interior power when i touch the brakes when driving lol
- Steering Wheel Column
- Fun little incident this morning (3 a.m.)
- #2 injector in not working.
- HEAD GASKET FOR B20/VTEC??
- rota jmags or axis oldskool on black gsr?
- Front upper control arm self locking nut
- Cold Air Intake on LS
- Belts Squeeking!
- heater never gets hot
- Cluster face swap question
- turn signal brackets 94-97
- fully built turbo gsr and now have oil leak.. :(
- resleeved block or ported an polished head
- 94 integra leak!! NOOOOOOo
- DB Trunk Differences
- PART NUMBER REQUEST FOR REAR DISK BRAKE BRACKET [ASAP]
- stock p28 on obd1 b18b
- Rear bumper removal.
- jdm fog lights
- How to tell between the B18a1 (90-91 obd-0) and the B18a1 (92-93 obd-1)
- A/C Condensor Removal
- B16 Trans for my stock DA????
- intermittent code 15 on 91 integra
- transmission
- 2001 GSR wont start HELP PLEAS
- Few problems....
- spark plug gap on obd0 b16
- i need help! beware im a nooob :)
- Question on ls motor
- some help on how to spend 2'g on a gsr
- SKUNK 2 SUSPENSION
- RSX seats in a DC2
- pic request: DRL relay, how to keep DRLs on all the time
- Front Bumper Problem Heeeeeelp
- What will happen if i leave my iacv sensor disconnected?
- TEG SUSPENSION QUESTION SHOCKS OR STRUTS?
- cluster bulbs from superbrightleds.com
- Car problem.. plz help!
- Differential Case cracked
- here we go again...
- Help How to tell a JDM p73ecu from a USDM p73
- ***need advice**** electrical dc2 in distress!!!
- Broke the orange fuel injector sleeve
- Puddle of water when car sat and idle from my exhaust...?
- Engine woes after the rains...99LS Integra.
- ls dizzy on b16
- starting issues
- Thermostat problem!?
- will 94 dc struts fit?
- got a 1991 integra with tranny issue . . . had a question . .
- What do I have to do to be able to post on the Marketplace?
- Kill Switch problem..
- Dyno'd my car (GSR with i/h/e)
- Ignitor Problem
- 96 b18 ls in my 95 civic.
- Tach Guage help on my DA
- clutch problem?
- help stock p72 bin needed
- need help
- headlights
- tradecarview
- project 96 gsr-t
- where to buy sleeved bare block?
- Radiator Fan Question
- window clips
- Problem with Fuel Relay.. please help!
- Weird sound when shifting...
- 98-01 front lip and rear valence fit on a 96' Integra?
- buddy clup spec 2 problems...bleh
- rpm gauge jumping
- For everyone that gets their whip stolen...
- 4DR GS-R stolen! headsup!
- 5 Lug Conversion Question?
- how long does it take to warm up your car?
- secondary o2 sensor important and what brand?
- 2 quick questions
- fuel filter on 1st gen Integra
- BC spec II on a DB...???
- 92 Integra GSR
- DA makes a huge pop noise whenever clutch is let out in 1st..
- Moton coilovers
- Broken Integra (yay or nay?)
- Electrical load detector, but no harness goes to it???
- Red 98 Gsr Stolen In cali Heads up!!!!!!!!!!!!!!1
- steam comes out of rad. cap...
- OBD1 B16A Wont rev past 3500RPM
- E brake light will not turn off?
- Heater is not working? Conclusion?
- how to disconnect shift linkage from trans. asap plz
- coolant leaking from behind intake manifold
- Any DA Experts?? HELP!!
- Driver side air bag delete/removal question.
- 96 GSR into Civic, Random NO START plz read
- GS can the front brakes fit on the rear?
- blown head gasket.
- 93 Integra Rs 94-97 Gsr with Ls Cable Tranny Anyone have this set-up???
- what cat will line up with 01 itr header?
- Stock tires are 190/60/14.. if i use 185/65/14.. will it be okay?
- cam gear question
- What year integras have EGR?
- check engine light..please help
- How to install replica hop sides
- Rebuild or Forget It
- where can i find a shop in canliforin for swaps??? need a b16 or b17!!!! b18
- car found: city of philadelphia
- fuel rail
- best place to order from?
- Best Wheel Choice
- Temp Gauge
- so i got these rims....
- Seatbelt Warranty... Confused?!?
- DA fuel relay
- Rack and Pinion help for my DC!
- cbale to hydro kit where can i find them????
- Will 9005 hids bulbs fit in a 9006 hids kit?
- motor to tranny promblems need help
- Exhaust
- cable transmission
- Horn Help
- Oil servicing??? HELP!!! HEAD GASKET????
- Cyp sensor
- heater blower won't turn on
- whats the best car starter?
- What else would you do?
- Special tool
- 200whp ls/vtec
- Lowering and my Preference
- JDM FOG lights on a 99?
- Need HELP - Loud Noise
- HELP CAR WONT START
- Why am I getting such poor gas mileage ?
- which oil filter????
- My B20B IM question
- various questions
- HID quetsion
- Oil on spark plugs.
- What OEM Wheel? 15" OEM - POLL
- ls vtec hp??????
- b16 into a da redline problems
- Sparco Harness Bar
- some help needed here.
- another question about 94-97 oem fogs
- window have water on them
- crank/connecting rod bearings
- what is a a good spring rate..
- Stainless Steel brake lines
- GSRUpgrade - SRI or Header?
- Type R console in LS
- ECU Codes Help!!
- What bulbs are in ash tray and lighter?
- GS-R Intake ???
- motor rebuild I have a few questions
- 94 Integra .. whats needed to put on 99 bumpers?
- Help build me a turbo for $1800
- gauge lights and tail lights out
- difference between headrest?
- Audio System errors
- What to check on swap?
- Best price for OEM carbon fiber hood?
- gsr head
- AEM Tru Pulley Diameter
- skunk2 coilover with?
- car wont start
- lightbulbs
- Quick Question
- 3rd gear grines
- what set-up is best for my integra??
- Starter is on the way out, whats a good replacement?
- Audio error?
- ECU plug wiring diagram anyone have one? 1996 GSR
- purge control solenoid question
- Turbo LS
- repairs for tailight gasket leak on a g3
- Towing with Integra or Civic
- flushing looped rack.
- Sputtering, loss of power & backfiring
- 90 integra b20b swap
- Good deal???
- Comptech Sport Intake with Ice Box for 98 GS-R
- Differences between obd-1 and obd-2 motors?
- stupid question, which is the left side of the car? passenger or driver
- just bought a 1993 four door.... parting out what i dont want
- low erratic rpm when in drive
- car doesent start after its hot
- quick header question
- clutch problem need help
- TRANMISSION
