- NEED HELP! CAR WONT START!!!
- '00 Clutch Master Cylinder question
- blocking front strut bar installation
- Spoon brakes???
- transmision vac line???
- Re-Using Waterpump/TB/Tensioner
- Tinting front windows in Socal
- looking to buy a DC2/DC4 integra, help me out with shopping, i've got ?'s
- I'm not sure what model integra i am looking at...
- How do you silent the rattling noise from a no CATBACK car?
- help.. bucket seat install
- chikara torque step headers
- Hid kits, Need your help on picking out which one! post your hid plug n play kit.
- Ignition problem with 99 GSR
- Overheating problem
- hey do u guys know where i can get a new carpet for a DA??
- front/rear type-r strut bar fitting
- Skunk2 intake manifold
- obd2 o2 sensor help skunk2 test pipe
- about how much does my 92 teg sell for?
- exhaust guidance please
- Air Condition
- Help please. My car dies.
- Axle & CV joint out of place...
- quick question....
- ls integra 1/4 mile
- gear ratio for turbo
- Rear LCA Shock Bolt - Exact Same for Integra and Civic?
- apexi ws susp or tein basic susp setup
- I think I'm in love!!!
- seibon rear lips?
- A mass murder scene, with a twist of lazy
- WS2 for 2k integra gsr
- Tranny fluid HELP. Grinds on 3rd gear.
- hard starting
- Need an opinion.
- Engine Code Po420
- b16a vacuum diagram
- Clicking valves on gsr
- Quick Integra Question..
- need help fast...water possibly in head...
- subframe torque specs
- ok i have some transmission questions.
- What size speakers in front and back?
- Car has trouble starting
- Turn signal lights on 01 Integra?
- carsound cat and exhaust?
- problem with holding a charge
- Integra LS turbo questions
- Anyone know what this sensor is?
- type r spolier holes
- water in the trunk
- wtb:exhaust
- Camber kit for DA?
- has anyone bought shocks off ebay lately?
- hope i dont get burned for this
- :: Is this Integra a good deal for 6k?
- Lumpy Idle...CEL...
- Honda Rear Trunk Emblem suppose to have Black background around it?
- oil leak
- NEED HELP ASAP!!!! TRANNY!!!!
- Exhaust o2 sensor
- Car does not start (acts like clutch is not engaged)
- B18A1 engine bearing codes
- somethings wrong with my suspension
- Car starts backfireing and stops acl. at 6.5k
- Muffler question
- New Clutch Needed Need Info
- lc-1 wideband question
- Idle @ 3K....i understand there's a lot of topics, i've searched. please help. *pics*
- Two questions that require help quick...
- back fire on a ls
- Timing Belt Tensioner
- Grinding on 3rd gear
- my 89 model DA crunches?
- what would be a better setup?
- how to remove OEM deck?
- 96 GSR build
- noob question
- Dyno Jet vs. Mustang Dyno
- question about ls/vtec ECU
- DIY: You want BLACK carpet and seats for $35.00???? Look no further!!!! 56k=n0zorz
- transmission problem
- need help on what i should do
- DIY resonator install question.
- Good Trade ? My 95 del sol Si vs 95 Integra LS Coupe
- GSR and LS throttle body's interchangeable?
- weird fuel issue...
- Antenna
- future upgrades??
- When installing a motor in a DA.....
- what are my options?
- Help Emergency Brake is very weak need advice
- what Ecu are you's running on a b16 . P30 or P28
- WHAT TO DO
- chipped ecu
- 94 4 door
- Are all 94-01 Airbags the same(passenger side)
- hey driving in the snow got stuck think there migth be some damage...
- stock strut removal
- sohc vtec in dc
- Mugen Aero Parts for DC2 Integra Discontinued
- Anyone purchased from "JDMCarBoy.com"???
- VAFC Question
- b16a2 into my integra
- help with cat converter size (94 gsr)
- HELP!!!! 95 GSR OBD1 B18C1 WIREING PROBLEMS! VAFC!
- selling some rims $300 909 area
- back timing belt cover
- Want to sell how much am I looking for? Please provide me your honest opinion.
- 2000 Acura integra
- best kind of paint for interior?
- Is the ECU here obd2a or obd2b?
- b20 in 2000 ls
- throwing a code 10
- Cat Convertor help! i think?
- How do i turn on fog from jdm front end headlight?
- how many killawatts is my car?
- A little to bright for fog lights??
- exhaust
- Help
- which engine is better?
- cloudy highbeams!
- GSR GAS/OIL HELP
- b18c5 jdm type r pricing question
- noob throttle body question
- rims??
- Startup
- 98 Rear bumper help!
- modifications??
- Cel Problem and still have vtec .. after swap .. Help
- Need help ASAP!
- I need your turbo opinions???
- my first teg =]
- HIDs
- j-spec Gsr
- VSS plug wire colors?
- skunk2 test pipe
- Best place to buy replacement DA hatch shocks/struts?
- Stabilus Hatch Strut
- Breather Hose
- big dilemma
- Lowering Springs for 16'' rims
- someone help!! (clutch??)
- valve stems
- *b16 swap 91 integra getting CEL 23*
- aftermarket IM to GSR intake pipe
- side molding
- Would Like some opinions on this part please.
- 99-00 SI seats in 91 teg
- 3' exhaust systems???
- Heat shield rattle in the engine bay...
- how to wire in several accesories.
- clutch problem help
- how do you reset/calibrate the TPS
- which spark plugs for b20vtec?
- Im looking for a B17
- extended lug nuts
- Interior
- new here
- Gas Light stopped working!
- How do u adjust Integra's cambers?
- need help
- Difference between pre 94-97 and 98+ Integra front bumper
- quick question (searched)
- FINALLY took the LS to the Dyno
- check engine light O2 sensor
- still overheating?!
- Replaced senser still getting CEL
- SKUNK2 CAMS? OREGON
- 88-94 ?
- need opinions on a website
- Climate control
- LS/V-Tec
- 95 GSR INTEGRA NO BRAKE LIGHTS!!!???!!!
- no spark from distributor to plugs...
- valve cover
- B18A no fire cant figure it out, please help need to get to work.....
- HELP 94 DC integra Ls NEED TO WIRE VTEC and is a p30 fine?
- need clutch to support 400tq
- ***Tranny Problem***
- my instrument lights dont work? HELP!!!
- Not the usual idle issue
- 2nd radiator to bust
- 92 gsr
- VAFC wiring help
- VERY WEIRD SOUND FROM ENGINE
- what shops do compression test's?
- tranny question HELP!
- A/C Removal
- my 50$ paint job on my teggy
- rubber grommet inside clutch/flywheel???
- H2B H22 on LS tranny 4 daily
- DC highlights high beams how to wire high beams?
- brake problem
- Trouble with my Engine
- B18C Head Problems
- type r lip kits w/o wing
- Throttle Cable to Short
- MIL and oil light flashing???
- Setting timing?
- Brake Pads
- Crank shaft pulley bolt, need help
- Question about Integra GSR
- some questions reguarding my swap
- ?obd0 or obd1?
- paint matching
- vibrant resonator
- half radiator efficiency on an integra? searched
- help with hid retro fit
- Skunk2 intake mani. and stock gsr intake hose.
- GS-R for sale
- sqeaking sound?
- Idle problems after car warms up plez help
- Need alt belt for B18 w/ JDM TypeR N1 Crank pulley????
- Ignition/cam timing: rotor not lining up at tdc?!
- b18 head torque specs (searched) want to make sure
- H22 Integra's I need your help
- Hydro finally for all DA owners!!!!
- throw out bearing
- loud knocking noise
- will they fit???
- how far can in psi's and hp on a ls turbo without changing internals
- Ignition Switch problem!!! (PLZ HELP)
- Map sensor keeps failing...
- which rims are lighter?
- 5 lug conversion?
- Type-R Rear Seats in a LS...
- broken bolt in block
- Has Anyone Used Hardrace Motor Mounts?
- My Gs-r motor mod suggestions
- Teggy wont start. HELP!!!
- overheating
- WOW this is bull....
- My ACURA is too low and these big ass 19's keep rubbing and slowing me down
- im new
- New '95 Integra
- Help me pick my 3" muffler
- Horrible hesitation/stumbling idle (almost dies at idle).
- HELP?!?!?! PLZ PLZ PLZ PLZ~~~
- LS VTEC: Everything You Need To Know.
- What is this?? should it be plug in??
- Rattling from system
- Need help! I think its bearing problem
- Thought you might want to see this
- color changing HID kit???
- Car bogs when warm.
- question regarding exhaust fitment with USDM omni testpipe
- Whats the best way to remove the shifter linkage spring pin(split pin)?????????
- oil pan bolt
