View Full Version : Acura Integra
- skunk2 shift knob or...
- $ For the Ride From: Tax Refunds
- Im stumped (smoke from exhaust)
- damn
- SRR lca problem on DC2 !! Help !!
- Got some new parts for the teg (pics)
- need help trying to identify a set rods and pistons
- offset question
- how to spend $5000... turbo?
- Best Price on Icebox & Short Ram??
- SI wing?
- distributor question
- How to rewire your foglights independent of headlights (90-93)
- LS valve covers interchangeable?
- Acura fuel injector question saturated or peak and hold?????
- TEG ls all motor
- STR block saver???
- Civic Radiator fitment problem with Integra Hoses
- dyno'd my car today
- Please help with Parkin lights
- ITR GC's on a G2 teg?
- Compression of jap b18b (did many searches ) =(
- Tokico Illuminas or KYB AGX?
- Koni w/GC's or Tein SS??
- 4-2-1 or 4-1
- Hood?
- Aftermarket Body Part Replacements. . .
- Reverse not working???????????
- lightening my load
- Question about my GSR
- LS guys with b16 tranny.....
- bay area smog problems
- need obdI ls ecu
- vtec question?
- would anyone be interested in seeing videos of gsr vs. Itr gearing?
- Pricing on used zex dry shot kit for gsr????
- code 43 is driving me crazy ..... please help!!!!!!!!!
- how can i v-tech my whip?
- S2000 engine start button on '00 GS-R.. anyone done it???
- PS/AC removal, will the rack be ok?
- Carfax please
- Mysterious plastic/rubber smell?
- 01 GSR question
- HELP! drilled hole too big for swaybar bolt install
- Location of thermostat on DA?
- Cold morning starts.............
- HID INSTALLATION ON 2000 GSR
- will 1990 Integra engine fit in a 1993 civic?
- Which header? 4-2-1 or 4-1?
- any suggestions? (nuespeed)
- New Integra owner
- GSR Guys, whats your RPM at 80mph???
- bottle neck effect
- EBAY - OEM TYPER STYLE FRONT LIP/SPOILER. FACTS?
- Gsr idle LOW !!! Please help
- 97 gsr whats it worth?
- is there any difference in GSR sidekit than ITR?
- Help removing airbag..
- vtec question
- CRV B20 in 90 teg GS
- baking paint on valve cover
- braking sqeak.....
- Stainless or Ceramic Header?
- 92 GS-R Front Upper Strut Bar w/ ABS
- Fujitsubo RM01A or Crower Head for my 94 Integra LS?
- nitrous express kit for sale!!!!
- Tsudo header
- my Gsr feels slower after changed the timing belt
- carfax help please,
- Help on negotiating
- Interesting article in Honda Tuning this month (Stroker Kit)
- Whats the cheapest mods i can do with my car?(93 acura integra rs)
- Snapped some pics during GC install (56k....go install some springs)
- Tein S tech springs
- carfax
- Climate Control Fan lever 1, 2, Not working. (Searched)
- CTR cams and VAFC...or Springs and struts???? Need help
- 94 Integra GSR
- Acura Injectors peak and hold or saturated
- nitrous its good for the soul
- 5 lug conversion on dc2
- Chiped code based p28 computer surges at 1/4 throttle!!!
- How difficult and involved is it to...
- how to i adjust my headlights
- Type R header and GSR exhaust
- changing rear speaker
- Crank pulley stuck!!
- What year is this axles?
- Very Serius N02 question...
- N1 for my 4 door.
- Skunk2 Or ITR Intake manifold! help
- 98+ ITR lip on 94-97. How'd he do it!?
- AEM fuel pressure regulator?
- Apexi vafc vs vafc ver2
- where's the bellhousing access hole??? ASAP
- 1G Integra Gearbox
- how to use pm's
- 2000 integra ls where is the odb 2 diagnostic plug
- zex nos kit on 2nd gen gsr
- Is my car fixable?
- Where to find good clutch?
- primary resonator replacement??
- Brake Pad Shims?
- anybody use the Lokar G-bar?
- 91 integra Question!
- alignment on lowered teg
- new pistons
- Intake for '97 GSR choices galore
- Header for '97 GSR --- which to go with.
- Does auto tranny drain plug fit manual tranny?
- Carfax please
- where to install srs control module? 98 integra
- DIY Halo's/Angel Eyes
- Tires, Tires, Tires??
- Is this an ITR intake cam? Just wanna make sure it's not fake, might be working a trade
- Prewired for cruise control? (93 Integra Rs)
- wireing harness
- still a trial user?
- I need to get the stock radio out of my 99 teggy
- Check engine codes, where to find them on the net?! CANT FIND ANY!
- what kind of flywheel do you recommend?
- I found a good deal on a teggy! Whats your opinion?
- help me diagnose a possible problem
- itr shocks on LS
- Wheel Offset
- differences between b18c1 and b16a header
- price suggestion for my teg guys
- Installed new parts. itr exhaust +comptech header
- Pressure plate question
- Wont let me post in other forums.....i cant get my old username's password back.
- H.I.D. on a DA? JDM one piece H.I.D. possible?
- LS with itr camshafts
- 2.5 or 2.25 piping
- Is something wrong or is this normal for a tranny???
- How can you tell if the car has been street raced?
- Vtec vs. I-Vtec!!!???
- kendall wy is the nitrous turbo supercharger that is the question locked
- skunk 2 cams !!
- ups man came today
- gsr sway bar?
- 98-01 silver color question
- INSTALL OEM ITR LIP?
- Are integra fans dual or single speed?
- what size tires come on a 95-96 gsr..or any stock gsr
- NITROUS TURBO SUPERCHARGER THAT IS THE QUESTION!!!!!
- Rating the Bridgestone RE 730's with the rest ( Falken Azenis,Kumho 712, MX, Yokohama AVS ES100 )
- thickness of stock headgasket B18A1
- Apexi N1 Knockoff on ebay?
- Skunk 2 cam gear alignment problem
- dohc valve covers
- how to adjust windshild washer squirter ??
- Valve cover for non v-tech
- My car eats alternators...
- best tranmission for 90-93 Integra Ls B18A1
- Anyone know patdemps?
- How to: increase stock car radio reception
- i have i/e.. what should i do next?
- radiator support removal/installation?
- where can i find red,rear JDM honda "H"
- I need a Carfax
- New To Honda-Tech
- is the 94 steering rack the same off a GSR than an LS/GS?
- temp gauge prob
- caliper piston compressed? -crappy pics-
- ITR exhaust bolt on to '94 GSR?
- 5Zigen or Tanabe
- dilema: need help taking 2 bolts that hold the key cylinder to steering rack
- HKS turbo timer instructions for Integra gsr
- O.E.M. or Mugen thermostat??????????
- B18A crksft pulley I.D.
- Brake Pads
- octane question
- fixing a tranny
- what should i get please help
- GREDDY EVO!!!
- g3 lowering springs in a g2
- CAR WONT START!! please help
- how much torque and horse have v-tec controller
- jdm dc2 lips
- 94-97 to 98-01 front bumper conversion?????
- Lighest 17in wheels?
- Winter photo's
- GSR CAT to Stock RS question
- Stock Radio Pockets/Sleeves?
- New Intake Showdown
- low cold cranking amps...battery..
- help with install of QP windows
- Anyone have any pics of the s2000 antenna on there integra
- comptech or tanabe springs? opinions.
- 17" TIRES
- Help me find a shop to do my ITR conversion!
- ABS question
- Who's Integra's are snowed in?
- Pulley?
- neele is off
- Type One headers
- sprint hart, racing hart
- ITR maniflod on GSR head. (read)
- crank pulley question.........
- Will EP3 (03 civic si) rear seats fit in my dc2?
- suspension on a JDM DC2
- Need ECU/Tuning advice, I'd like to rev to ~8400 and do some tuning...
- Driving with a >COLD< engine after a swap>>???? :X
- anyone in bay area help me out installing my cf hoodpins?
- n1 crank pulley OEM cheap? searched!
- anyones gsr burn oil like crazy but still runs strong?
- 00 civic sunvisors in a teg?
- weird light problem
- anyone hear ever had a recall on there exhaust--94-97 integra gsr?
- just got an es oval muffler with a 2,5 in outlet any one with this setup with a2.5in test ppipe???
- exhaust: increasing HP without increasing noise
- aem v2 question....
- 2.5 collector on a comtech header? DIY
- New Jersy members
- HID questions and best placesto buy...
- Factory Suspension Specifications
- Cut pipe after the header?
- anyone know where I could Weld my side molding in San Diego?
- GS factory sway bar?
- ***what do you guys think? edelbrock or type r tb?***
- low beam bulb into high beam socket?
- throttle body question
- car wont start pleasehelp
- hmm b16 tranny in a gsr?
- is 184-185 good compression for a gsr
- Grinding sound?
- Finally got a pic of my car...
- LS ECU SWAP
- Injen Intake install problem
- Fuel and O2 sensor question
- S.O.S inspection problems
- vibration while cruising between 80-100mph
- Need Help???? Diagnostic Plug???
- pulling out power steerig = frozen steering rack?
- Front Lips available for 94-97's ???
- Oil Ring Problems????
- Nardi Grinta Steering Wheel
- Quick, dumb exhaust ?
- high miles, beware?
- Valve Adjustments specs for a GSR w/ CTR cams???
- Stuck at home with Teg, what should I do to it?
- Comptech Exhaust Broke! wtf? Anyone have this problem?
- where can I order pct/b16b pistons?
- 98 integra srs control module install
- itr aem intake?
- GSR cluster?
- ford cup holders in teg???
- ice box filter
- pic request 3rd gen teg cai
- type r spoiler?
