View Full Version : Acura Integra
- need help asap lug hub remove
- need help with obd2!!!!searched
- trading my integra lmk what you think
- Searched: Rev Limit for GSR w/CTR springs and ARP bolts
- JDM 4WD INTEGRA?????
- b18b wont stay on
- Weight savings with Half sized radiator?
- Damn ACT CLUTCHES!!!!!
- What clip goes in here on my cluster
- Getting ready for a Turbo
- uhh..wierd question but need help asap.
- lsvtec block, too many miles?
- Just a quick question
- Replacing headgasket in a 92 Integra w/B18B
- interior dye???
- New Guy Here....
- ABS problem, help!
- Do all GSR's have leather interior??
- Front Lip questions.
- OEM LIP KIT
- Gsr and Ls Header the same? DA Integra
- $$$$$ CASH REWARD 2000 RED DC2 INTEGRA STOLEN- NYC/LI- 7/14 $$$$$
- First day questions.
- ls motor knocking on startup
- lowerd cars = bad for axles?
- JDM ITR valvecover wont fitt on my head!!!!
- Hood
- stock DA hood weight?
- wooble in the front???
- Post 4dr w/ Type R wing
- finally i got a K20 for my DA project
- vac lines needed?
- shaving off side moldings?
- Scraping with AGX/H&R settup. Thinking about changing. Help
- putting head on block?
- My DA: Pics
- Running Lean Question
- radiator
- After 3weeks of owning my ITR....
- Where can iI get one of these?
- engine build need advice on part matching
- coilover question.. i want to go LOW
- ::UNDERCARRIAGE PIC REQUEST::
- car won't start
- How Do u Tell If u blown a head gasket?
- do i have a bent frame?
- I NEED A QUICK ANSWER PLEASE!
- side molding
- New To The Forum
- Clutch wires??? (searched)
- Need Verification on a part #
- HELP! ENGINE CODES!
- 15" slipstreams with type-r brake conversion on dc4
- question GSR IN DA back mount
- wrecked b18b1 vtec turbo!!!!
- 17's wheel size
- Question, best RED colored plug wires comparable to NGK
- VSS problem??
- Car Loses Power when i hit the gas!!!
- Short shifter
- *****Official Stolen Car Thread******
- STR vs. Skunk 2 tb
- Overheating
- Need help for repairing the Teg
- wtf is this rattle?
- Decent Set of Spark Plugs
- difference between b18b and b20b cams
- Idling problems when hose is connected, & idling problems when it isnt! Help!
- clutch "knocking" when 1st gear engaged
- quick noobie question
- tirerack.com
- What would you do to a 96 LS coupe if......
- Is the msd 6 btm worth using?
- Help! What is this sound
- obd2 gsr motor with NO VIN NUMBER/TAG on the block :( ???? what should I do?
- ****94 WHITE GSR WITH LS-VTEC STOLEN!!!! LONG ISLAND, NY 7-13-06****
- B20 vtec turbo size question
- 1/4 Times from weekend-DC4 B20/vtec!!!!
- rattling sound at 3000 rpm
- wheel locks
- USDM P28 on a JDM B18C with a test pipe, code or no code?
- Poor mans type R Head Bolts
- y is it dangerous to pump gas while car is on?
- Paint Question
- nead help
- my modest gsr setup...but i need header advice.
- edel. vic. x mani. 2nd throttle sensors?
- ANOTHER terrible chick story
- liquid coming from exhaust?
- Has anyone has this problem
- HELP!
- Integra For parts
- b18c1 block.
- Sparco steeringwheel + quick release + adapter.
- install new steering wheel need help
- Confused: Exhaust?
- looking at a 1997 GSR, water in the trunk...??
- how much is shipping to 95070?
- Stock Fuel Pump Size.. 93 Integra GSR
- first day on honda-tech sup people
- apexi N1 question...
- Zex kit blew my engine...
- Car Died While On My First Date With A Hottie....
- CEL just came on.....already looked at the FAQ Thread
- how much are b18c1?
- Is 7.5 and 8 in. possible ?
- timing belt?
- b18c stock manifold
- CEL code kickpanel?
- need help with 97 integra please
- car not charging!!!
- Power steering problem 1990 LS
- what should I do with this integra
- Building Bottom end for turbo
- Should I buy these Cams???
- help with my b20b
- LET'S PLAY A GAME! Name these springs and retainers....
- New ITR shift boot and knob installed!
- terpentine for octane booster?
- Valve cover/catch can question...
- Need Help: What Kind Of Timing Belt To Use?????????
- need a few more things for ls-vtec need help
- Help with OBD1
- loud noise in my gsr.
- Help
- d16z6 in 94 integra
- crower cams
- climate control and turn signals?
- Misfiring on Cylinder One
- Front end shakes when I hit 40mph or more and I a noise???
- My two tone teg
- JDM DA headlight question...
- stolen integra
- integra prices
- Skunk 2 Lower Tie bar.
- Gauge Cluster mph/kph
- Need help with radiator
- engine book?
- Items I need to by for a Tune Up?
- GSR to ITR: NOT ENGINE swap
- no fuel?
- Stage 3 cams??
- Over heated
- Differential Bearing?
- Car racks for tegs ?
- rhd integra how to register in texas ?????
- getting a new radiator
- The COMBO of Aem tru-power pulley and the Forum under drive crank pulley ?
- dc seats in da
- Help? Any suggestions on some transmission web sites?
- Car idling problems. NEED HELP
- Ebay lightweight crank pulleys, are they any good?
- Need a pic of a stock GSR intake or stock GSR engine bay
- e CAP, What year cap do I use?
- LS/VTEC HEADER QUESTION
- throttle body sizing
- HeLP ME PLZ!!!
- People with test pipe/no cats
- GATHERS JDM RADIO
- Engine Trouble?
- cost of a/c
- 98-01 type r lip replicas?
- Engine Break in
- gauge clusters
- have a 01 gsr and wanting to know what other mods i could do to it
- B18C1 GSR, no VTEC, no CEL... new one to me i guess...
- Front license plate bolts
- quick question
- How much should I sell my GSR for?
- Mufflers
- Ebay Integra
- how do you install a charcoal canister for LS 96+
- GSR Swap
- installing usdm or jdm itr doors on SE
- off topic. in japan.
- throttle body help
- Trying to do leakdown test, is my homemade tester working properly? (leakdown results)
- Will OEM axleback bolt up to apexi mid section Thanks
- Timing belt replacement
- Need help reprogramming Keyfob...Db8 Gs-R 98...
- ls vtec - what do i use for general maintainance
- ***HELP: Window Motor / electrical / wiring...HELP***
- need help code 7 8
- b18a1
- Check this out
- cams
- check engine light
- Quick question bout a 95 teg
- 15th axle broken
- "$499" JDM Authentic Civic Type-R EK9 CTR Front Strut Bar RARE
- Which Cams Should I Get
- USDM 3rd gen integra (94-01) Cluster Information... instrument panel/gauge cluster/speedometer
- 4 door civic rwd drift car..
- i really did help (TPS) ?????????????????
- will A/C compressor turn on without freon?
- Da gas light
- My H/C Ls Vtec build
- Fuel Gauge
- whats beter nos or alcohol
- i just got my b20b need hlep plz
- tps
- DA/Del Sol suspension?
- need help asap..
- car not starting
- Differences between 90-91 teg clutch and 92-93?
- DA as a first car?
- i need some help on which computer to use.
- Which would be better?
- Will JDM B16 oilpan fit usdm GSR
- ooppss i think i put a post in the wrong place
- Block work
- Just a thankyou
- What should i get
- DA REAR SEAT REMOVAL, How to???
- Door Lock
- need help asap
- Ask help for the oem si-vtec fog again, hopefully someone can help me
- timing belt b16a2/gsr
- jdm mugen front end on red gsr
- extended lug nut question
- n/a build
- axles need help quick please
- Xenon HID kit for $216?
- "Need Help" I can't open my trunk?
- wat types of bulb goes in the 98-01 oem fog lights?
- are there such things as....
- Spoon N1 Piping?
- tachmeter
- Best way to install emblems??
- Gas Saving Article - REALLY GOOD!!
- B18a/b, B16, DC2 etc What does this mean really?
- Oil light blinking can it be my oil pump cause Vtec not to work?
- Shift Boot question...
- Pic request.
- clutch question
- Where is my fuel pump?
- Buddy club spec 3 or itr cams?
- Burning Gassss
- 3 MAP - manifold absolute pressure sensor
- cluster
- b16a2 swap
- DC Exhaust on DB7
- Integra DA July Wallpaper - showoffcafe.com - Nisei Week Car Show 8.20
- good price for window tinting?
- passenger airbag problem.
- tanny?
- P72 ECU is in limp mode how to reset can't get pass 5000 rpm on 3rd gear....
- Red Lugs on OEM rims
- Clutch vibrates when I press it
- Switches
