View Full Version : Acura Integra
- pruchasing used ITR rear sway, what else needed....
- how much would factory GSR strut bar be worth?
- a/f meter is f#"/! up car bug like hell
- Where can I find the best deal on a comptech exhaust?
- radiator question...
- hey what do you gusy think of the asking price on this 4 door gsr?? is it good or bad?
- Integra is throwing Code 37
- Radiator problem
- ADVANCING TIMING
- I cant find ANY!!!
- Duration of Cam Install
- Free Car Payment
- ITR rear sway bar
- Non-adjustable shocks
- Apexi WS vs. Tanable Hyper Medallion
- any opinions on the Comptech SS axel back?
- Seat Belt Jam!
- what I used to protech my clear corners.
- Where can i buy a test pipe to fit with my downpipe and thermal exhaust?
- got in accident and have a question about the lights
- Random Stutter! Feels like hitting a brick wall. Help!
- Polished my Head
- 2000 RPM Redline!?! Please help me!
- what order should I buy these??
- My car goes under the knife tomorrow
- anyone has a pix jdm da6(g2 integra) front lip spoiler.....
- itr clutch in a gsr?
- DOHC Decals
- Shifter Question? NEED HELP QUICK!
- neat setup
- ecu
- car won't start
- wat tools will i need?
- type r rear swaybar parts
- Tire Pressure
- ecu
- to all ls owners!!!!!!!!!!!!!!!!!!1
- OEM Badges
- right tail light out
- AEM FPR help!!
- OEM gsr wheels
- Apexi VAFC
- Skunk2 (RSR invidia) exhaust experience?
- Broken Axle
- Wheel Offset??
- B20 Block and the LS
- HELP ME PLEASE!!!!
- CODE 4 ON 1993 INTEGRA OBD1 PR4 ECU B18A1
- 94-01 Integra Carbon Fiber Hood
- weights?
- did '86-87 (d16A1) or 88-89 (d16A3) integra have larger rods?
- hi boost
- Filter Box Cover?
- JG Edlebrock Header
- Anyone buy from these people?
- D2S or D2R for GSR?
- integra type r header on a LS
- how to fix corroded rims?
- Does anyone use Redline synthetic Tranny fluid?
- Power Windows, Sunroof, SLOW
- OEM Fog lights
- Damn Valves! Help!!
- Suspension Set-Up
- 2002 Asian Model Expo, and a huge domestic hot rod show pics just posted
- Code 73 being thrown by the ECU....doesn't sound good!
- How many integras in San Diego
- Fluidyne radiator. Fits 94-00 USDM, will it fit the JDM radiator support?
- (Integra) Brembo OEs rusting!
- CAI and Midrange Power - Quick Facts
- Ground controls with what shock?
- jdm header?
- Pic of my integra
- which tranny to go with b18c1?
- help! 9000+ rpms on stock motor!
- DC Exhaust
- Reclinable vs. Non reclinable
- Type R cams!
- Pictures of Kakimoto Racing N1 Axle Back Installed!!!
- any good shops in the bay area?
- vinyl repair?
- do 94- 01 tegs have daytime headlights?
- Konig Helium
- Greddy turbo install help!! fuel rail wont bolt down with injectors!!
- broken pcv valve..
- Good performance shops?
- LS/SE or GSR??
- Integra's of Houston
- Anyone in know any reputable shops in MD that install LSD's
- need help with alternator removal: getting the driveaxel out?
- Need ITR Rear swat bar with BSQ kit install instructions
- Spoon DC-2 Gauges on a DA...?
- Water where my spare was
- Body Kits or Lip's?
- Would this be a good idea
- check engine light?
- please help me!!
- OT: Looks like I totalled it his morning...
- Rear Bumper OEM under bosy spoiler????
- which size cat bolts?
- Can a little leak on radiator cause for Idle to be funny?
- Which one to CHOOSE!
- 1990 integra ls engine
- Best I/H/E combo?
- can someone explain engine timing??????
- Dyno in NJ? Prices?
- How to take out headlights for G2?
- picking a tire
- 2 Step Ignition Box?
- wiring diagram
- Idle is erractic, SOMETIMES. Help!
- reseting ecu
- Code 17(VSS) and VTEC question
- Dyno in Bay Area
- cat on 2001 gsr
- What happens if..?
- Tokcio blues w/Eibach Springs = too stiff for Integra gsr???
- help!
- How can I get some low end
- Such thing as 16" 4x100 steelies?
- Cable clutch adjustment?
- Stock Intake hose
- 1/4 Mile Stock GSR
- MY WRECK!
- whats the difference between LS and GS
- need help from someone with a '00 gsr...
- Finally ran my car, I'm happy :)
- Can someone explain why you can only use the original cam caps from the head?
- high flow cat and other exhuast ?s
- Rims to get?
- Code 45 after cams, what to do with FPR??
- what rear strut tower bar are you using?
- question about nos on ls/vtec
- CTR Pistons on a B18B1??
- ot: search funtion not working
- difference between the years...
- Neuspeed 4 point strut bar vs ITR strut bar
- Prelude Rims on an Integra?
- ***** Tranny probs differentiel HELP *****
- what flywheel for ls/vtec???-block or tranny???
- LS Integra
- Anyone know anything about welding?
- painting the 98 gsr swirlie rims
- Oil filter reviews, not buy the Prelude ppl.....
- Authorized Mugen Strut Bar and Sway Bar Special!!!
- Whats an LS block worth?
- Door Locks
- ITR Flywheel?
- I think my "Arm Spring" broke on my tranny
- alternator?
- Crankshaft question?
- Hyundai
- somebody jacked my air filter...
- where is the oil pressure sending unit on my 94 integra rs??
- 2 part question....ITR part fitment on LS............
- ATTENTION 01 GSR OWNERS
- advance timing?
- will a these fit my LS?
- turbo
- Those w/ LS (B18b) Engines, what do you dyno at?
- Fender help after camber adjustment
- Authorized Mugen Sport Pedal and Shift Knob Special
- How much to get a Jap spec Gsr to the US???
- Anyone know where I can get my stock wheels powdercoated in NJ?
- 97 GSR Turbo ForSale - Good Buy?
- Just got my GSR factory strut bar. Any tips on install?
- OEM Honda "H" Emblem
- P28??
- Re: Valve cover
- Help with Rims
- TOTALED TEG NIGHTMARE CONTINUES
- S2K Antenna Kit
- Can you change pistons with crank in block?
- what kind of rod bearing can i use with aftermarket rods on ls block?
- Midnight Help!! Cig Lighter, Radio power down!! =)
- Type-R tranny vs. GS-R
- What clutches are people using for 200 whp?
- FS: Tein SS for 99-00 Civic SI
- Where's the ECU located?!!??!
- quarter mile time at palmdale
- any of you gsr owners want 13s or 12s?
- Any downsides of installing new struts for the front only?
- clear corners & euro clear...what is difference?
- What Sparkplugs do you run?
- exhaust fits?
- Wanna see some pics of wingless sedans
- what exhaust ??
- Clutch Alightment tOOl hELP!
- Strange sound
- Handata Stage 2 and VAFC - A Conflict?
- how to set instrument panel to 0?
- What Coil Overs should I get?
- 17x7 rims or 17x7.5 rims?
- how hard is it to install a rear camber kit?
- K&N filters - 'RU-3130' or 'RU-2820'
- Break Rotors
- Any good links for online auto salvage?
- gsr & r JRSC....
- Quick Question
- My wheels are dirty, what to use???
- Why did my VTEC stop working?
- Exhaust rattling or something?
- type r font lip for 94-97's
- Engine Swap!!!!!
- Price for 00 or 01 GSR
- Price on boring?
- lude injectors in gsr?
- clear corners.. prevention from theft??
- Awww crap... still rattling
- jdm b20 on the way
- Check out what just came inthe mail.......
- OEM parts and accessories?
- LS build up
- where to get jdm header package
- Just spent a huge amount of money: Please make me feel better about my purchase!
- What the highest RPM a stock GSR valvetrain can handle with ITR cams ?
- Best tire sizes for wheels on GS-R?
- Hey Check This Ebay Auction out!!
- how many gallons of gas does your gsr drink?
- What exactly is a B-pipe?
- Kosei K1 15"x7" 38mm offset
- S2000 start button >> don't push the red button !!!
- civic springs into an integra
- Help on Comptech Icebox!
- open exhaust
- weapon-r adjustable fuel pressure reg.?????????????????
- Anyone have pics of a 90-93teg with carpet removed?
- complete exhaust
- skunk2 im for b18c1 the same as b18b1?
- Brake question
- Is there a special key to install stock cam gears?
- Question on wheel offset for Rota Slipstreams on GS-R w/ Type R suspension?
- tunning stock cam for a gsr
- CARB legal question
- oil pan gasket!?
- ITR rear sway bar squeaks?
- centerforce. . . . clutchmasters ???
- Maint Reqd light, cant turn off!
- Tokico 5 way / Ground Control Install Help??
- need an opinion apexi n1 or kakimoto r?
- 120k tune up
- best mod for you buck!
- what do you guys think of EBC "sport grooved rotors"?
- Eek! Rad. Fan!
- catalytic converter????????? help!
- Poor gas mileage in an LS?
- Weak engine
- best suspension upgrade for my teg
- how do u launch
- Weird sounds ..
- how many mi do your turbo motors last?
