View Full Version : Acura Integra
- New guy...advice?
- Old Gas?
- restoration of my teg
- Connector Pin Out
- need radio code please help.
- HELP integra wont start
- any good tuner shops in oc area??
- 96 integra, no spark after motor swap?
- where to buy rear valance???
- Gas Capacity
- integra tranny code help
- will my car be ok
- speed sensor issues
- BLOX LCA bushing need help busted
- anyone with apexi N1
- Help Obd2 scanner is not communicating with my ECU! failed ref!
- car spuders when i am giving it gas please help thanks !
- Brake hard line question?
- a b16b question
- Need help, just getting on the road.
- will they fit
- OBD2b to OBD2a..."Help"
- swap problem
- Db1 Rsr Exhaust? and suspension
- i need a program
- bent valves
- OEM Lip
- new engine noise (vid) ---long
- HELP TACH AND SPEEDO STOPPED WORKING!!
- my friends car has been stolen. please help!!! 92 civic hatch si
- coolant temperature sensor
- Will ASR Subframe Brace fit my car?
- Integra b18a1 tranny question
- Which distribitor will work for my B18A1 from 92 ls ???
- i need a good tuner
- Throwing Code 1. - O2A - Oxygen sensor
- DC2's vs. DC4's.
- Help needed
- WASHINGTON INTEGRA PIC THREAD!!!!
- 91 integra overcharging???
- suspension question
- dc2 dash into g2 integra
- exedy clutch differences: oem vs stg 1, help asap please
- ******** How To Integra DC2 Right Hand Drive Conversion ***********
- Transmission question 94 integra b20 swap
- gsr obd1 harness help
- Brake problem
- ITR 5 LUG Conversion
- Picture help!
- clutch/tranny problem in DA
- EG wiper motor fit a DC?(searched)
- Short Shifter??
- ExMag hitting Shift Linkage on DA
- B18 Specs!!! Help!!!
- Water Reservoir tube to firewall
- Integra vs Tc?
- Rough shape....But great car
- Question's about vacuum lines/plug's
- Will LS spark plug wires fit GSR?
- newbi on honda-tech
- 91 integra S3 light Blinkin
- Throttle cable issues
- Climate Control Emergency Light
- 97 GSR w/YS1 tranny??
- 91 integra idle problems
- Are these illegal?
- Acura Integra 92' RS was hit on the side, what should I do? (Los Angeles Area)
- power window switch/motor
- Brake problem?
- please help my vtec not working??????????
- Help with my gauge cluster, 2001 GSR, ITR cluster
- 93 ls passenger window issue
- B18c5 into 96 GSR
- hytech replica header big tube or regular?
- Windshield wiper doesnt stop...please help
- B18C1 GSR Swap in a 1990 Integra RS
- i need help with my ls/vtec, i need ecu info
- can't find redline on JDM B18C1
- supercharging???
- no spark 91 integra help!!!
- b18c ITR engine cover.
- It is like my car is Choking! What is the problem!
- milano red ls spoiler
- b17a1 keep or trash
- Catalyst low efficiency CEL how do you fix it??
- First Gen Integra. 1988. New to Acuras. Need Advice!!!!
- 91 LS B18A1 cam/ignition timing
- Trading My 98 Hatch for Integra
- 91 rs bogged down and quit
- 94 integra steering lock/ignition removal
- GSR Broken Subframe
- difference in DA integra 90-91 and 92-93 motor mounts
- idle and tranny problem
- *How To:* JDM RHD DB8 ITR Window Switch into USDM LHD DB Driver Panel
- Brake kit on 15 inch wheels????
- hondata s100 get me to my goal?
- Starter sounds different
- One more Radio code request
- b16a parts
- DVP - Dark Violet Pearl Integra - How rare are they?
- Altinator belt?
- question about front lip
- obd2 motor in obd1 car and tach doesnt work and speedo jumps
- HELP!!! Doors locking when emergency brake is engaged.
- Evap Sensor Error Code... What to Do?
- wierd vacuum problem
- what rods?
- Questions regarding service recommendations
- help with reliable cam/spring/retainer setup for DD (b18a)
- rota gt3's question!
- clutch master cylinder EBAY
- Kyb gr-2 struts and skunk 2 coilovers
- Need suggestions for why my car does not start
- Engine Bay Cleaning
- Help-99 GSR keyless entry problems
- Help-99 Integra driver side door lock sticking
- b16 head to gsr block ?
- OMG! New Thermal R&D SO LOUD!
- da not accelarating how it should
- Need IACV coolant lines diagram.
- Civic hub assembly fit on integra?
- cranks but doesnt start
- Automatic GSR?
- Testing Brake Light Switch???
- Dash/Chassis Harness Connections? 94-95 Integra
- Im New to JDM have a question about a project i wanna start
- quick question
- Stolen DA
- Very low idle?
- Quaife Differences
- What size bolts are in LS engine bays?
- Header for GSR
- installing a oem sunroof in a 91rs w/out
- 1992 integra
- tranny went out? or just shift linkage?
- Iacv for the b series
- When removing ABS....
- Machine Shops??
- Integras in Seattle/Federalway
- Ls/vtec question?
- DA INTEGRA ELECTRICAL PROBLEM
- my 95 ls in burning oil!
- 91 ls keeps blowing ignition coil?
- Spoiler ?
- Oil light comes on+jdm front converstion
- Automatic tranny flush question
- which lowering springs??
- b18c block and b16a head compression probloems
- Swapping the Acura Sign
- Acura integra Tranny no VIN#
- Break in period? ~Used clutch disc, pressure plate with new flywheel~
- integra slows down in freeway
- stock gsr fuel question.
- What ECU is better for my swap?
- Spark plug problem.
- T1R Header/Exhaust
- DA 1990 Integra Fan Knob Stuck
- How much should I sell for 1992 gs-r
- Power Steering Removal
- battery light on
- where can i get a DA squad decal at "website"
- HAHAHAHA Yah another my car wont start.
- Car wont start, i have spark and fuel
- Vibration under throttle after lowering car
- gsr/ls throttle cables
- spedo stopped working and check engine light came on ???
- New Swap, need help with hoses
- Best way to tap into my valve cover for oil catch.
- PIC REQUEST/ dc2 on neuspeed race/ side view
- Aggresive Cams
- throttle cable.
- What did you do when you bent an OEM wheel and needed to replace it?
- question, tranny oil and axle change, do you have to?
- horn wire diagram
- Running Lights?
- Tein H-Techs
- H2B KIT??
- How to clean Spoon N1
- Need help on whether to purchasing this vehicle or not.
- rod bearing torque spec?
- p28 basemap?
- leaking problem
- NEED HELP!!!!!
- Car wont start! Electrical
- LOUD KNOCK WHEN CAR STARTS UP
- 94 Ls signal lamps dont match up with bumper any help???
- PICS of my 94 gsr
- new to honda tech.
- ** HONDA PRIDE** (Post pics)
- ??? B20 VTEC VS. LS VTEC ???
- iat sensor in int coupe 1.6
- Is my head gasket blown
- is my 93 Integra GS totalled?
- kmh to mph converter. how to fit???!
- When adjusting a clutch pedal
- Power to coil
- Skunk2 Sport Shockss....
- Experts I need to identify this rare integra transmission
- wtb:transmission bolts/motor mount bolts
- supercharger or turbocharger?
- what is the coolest integra?
- B20 integras get smogged legally in california?????? wtf?
- PLEASE HELP. auto axles work with a b18b 5 speed
- what exactly will a resonator do?
- car wont start
- 90 integra ABS
- Will They Fit???
- Cant find VSS hole on 93 DA
- Ecu question
- NEED HELP!!!!
- Help. projector lense into one piece headlight?
- What is this HONDA ACCESS thing in a JDM door panel??
- S2000 antenna on a gsr
- Need tech help with 90 Integra with B20vtec abd Hondata S200...
- 98-01 fog light instructions pls!!
- Clusters Are Dead
- Smog w/ ctr parts?
- DOHC Vtec head?
- Nj Inspection
- Strut bar ?
- Proud owner
- DC2 power folding mirrors hook up
- Blinker/Taillight PROBLEM!
- Well she's done b18c itr swap
- overheating problems
- is the OBD1 GSR ecu the same as OBD2b GSR ecu?
- No spark
- 92 db1 exhaust question
- benen b-pillar to fit db?
- weird noise coming from my engine
- Oil light and Windage
- rear caliper rebuild?
- help with obd2 head in obd1 integ
- b18a b18b clutch same?
- .:Mugen DA Sideskirt pics:.
- question about skunk2 coilovers !!!!!!! PLEASE HELP
- hose??????????????????????
- mild or stainless ?
- slammed integras only!! ppl post pics of your slammed integras
- southbay
- Valve Timing
- HELP! OBD0 B18A WONT START.
- clicking noise
- B18a B18b head stamp difference
- Oil pumps
- GSR radiator questions, Searched, still have questions
- Suspension Help / opinion / suggestions please.
- Start then immediate die after getting gas
- Will 4-1 header for 94-01 Ls fit 90-93 Ls without fabrication?
