View Full Version : Acura Integra
- Transmision help?
- Need Help to replace wheel studs!
- I am looking for a tranny
- Integra Radiator Resevoir Hissing?
- LS Cluster Pinout Help
- need help with injector sizing & ecu tuning
- Security - laser key
- plug gapping?
- what is this and is it needed
- installing shocks ..searched
- parking brake light
- 99 Integra LS timing belt/ water pump
- sensor?
- vinyl and fabric painting help???
- creative pics of vtec controller placement....
- official B16 thread, Everything B16
- Coolant hose diagram
- Clutch question? is this a sign of it going out?
- wire up distributor obd1 from ls to si
- motor wont turn over
- Recommended oil...
- Got my first Teg... RHD?
- crank and rod ?
- My 89 LS Didn't Pass CA Smog
- ..::Need help with weird electrical cig lighter issue?
- Electrical teg Guru's
- GS-R header question
- plug wire question
- B20b with pr8 head question (I've searched)
- b18b1 header question
- Idle is fluctuating need help?!
- GONNA REPAINT MY CLOVER GREEN DB8
- Skunk2 intake manifold
- lip on the DC2
- Wheel Lock!!! contin...
- advancing timing
- Pic? Of Injen Intakes?
- Pa state inspection
- rocket motorsports
- b18a1 vs b18b1 heads
- Difference between 2 and 4 door bumpers on DA
- After about $3000 I learn, I can get a Waivor to pass Emissions.
- GSR burning/losing oil?
- window help
- windshield wipers
- Head gasket job Q's
- Intenna help/??
- pics of my teg
- What's sea foam?
- Inside integra help please....???? (Remove couple of compartment)
- Help me find a part
- need ecu pin identification
- Check engine light> electric fans not spinning
- bent rear LCA or bent trailing arms?
- What rear strut's do i use with XSI lca's? PICTURE LOOK
- squeeking from right side of car (i think)
- what do i need to hook my AC back up on my teg..?
- if i do a compression test what should each cylinder read
- how do you kno if you need a head gasket
- asR kit w/ 23mm itr sway, with omni control arms.....problem!!!
- Antenna Doesn't go Down...
- INSTALLING AEM Intake Short RAM - More complex then I though
- fidanza flywheel question
- A/C ventilation duct and filter?
- can i use 205/55/15 on ls mesh?
- Squeaky Clutch
- Whitish Blue Smoke out the exhaust????
- LSV: A real question for real tuners
- check engine light...code 43...help?
- need help asap car won't start after sea foaming
- b20 motor swap
- motor swap ?'s
- 205/40/17?
- ls integra hard to time ignition
- need help no temp
- sup new to this form
- Opinions on ls/vtec T.
- primary oxygen sensor, where does it connect to?
- brake caliper painting
- my integra is dying out!
- Help! I am throwing a codes 3(MAP Sensor) and 6(Coolant Temp)
- hey people i am new
- Greddy Turbo Timer
- help on jdm itr headlight
- question about taking off b-series head.
- Sup all im new.. teach me the ropes
- My steering wheel won't stay locked?
- Weird Whining Noise coming from passenger wheel area
- how much should i pay?
- Hey I am new to Honda Tech(((((looking for 15" Flat black slipstreams w/tires)))))))
- S2k antenna kit, where to buym and what to buy?
- What do cat converters look like inside???
- are Rays Lug Nut Locking Keys the same?
- secondary o2 sensor.
- Pics of my '99 Silver SE. Lotsa pics.
- Need help with Radiator Fan
- turn signals don't work
- How do you check the Engine codes using a jumper wire?
- honda s2000 hid projector question
- Fastest N/A DC Chassis Tegs
- Cleaned the Teg and took pics......56k warning!!!!!
- car sluggesh/wants to stall
- Full pump's done, what wires are what?
- RSX Steering wheel inside 95 integra gsr?
- new azenis
- turbo ls
- NEED HELP ASAP!!!!!! ECU FUSE KEEPS BLOWING!!!
- Turbo Setup
- To add a Crank sensor, do I have to Change the oil pump?
- Need Help Cell 9 CYP cylinder sensor?
- 97 LS stock cd player reset and locked
- help me with a muffler (98 GS)
- taking off the front wipers??
- Which type of ECU harness do I buy?
- Coolant Bleeder Valve?
- need help
- Fast idle, EGR, Intake Manifold questions
- Will a JDM Engine Swap into a USDM Integra?
- How do you purge radiator?
- what size tires should i use?
- how many bottles of Automatic Transmission Fluid?
- Running a b18a 90-91 throttle body on a b18b intake manifold
- Whats up everyone.. im new on hondatech..
- Considering a GSR Integ...but Worried?
- anyone want a car!!! for cheap
- MY DA WONT START!
- painting my car need help to pick color
- No Horn = No Cruise Control ??
- ECU Pin for o2 sensor PR3 JDM B16A swap I NEED TO KNOW ASAP
- HELP... 91 integra
- Just baught a 90 Teg Any recomendations?
- What could be throwing my speedo off so much?
- CEL Code 1 Oxygen Content formerly code 45 too rich - bad cat or o2?
- gsr trans question
- went to the strip now timing is advanced to like 25 degrees??
- skunk2 intake maniold for ls yeh or neh
- blox intake mani question...
- !!!!!!!!!!!!!!NEED HELP ABOUT QUESTION ON TRANNY ASAP!!!!!!!!!!!!!!!!!!!!!
- My B18b vs. h23 turbo
- gsr alarm
- 5th gear problems
- How much is a head gasket job
- need parts for a g1
- HELP! can't get the ignition timing right on my car! 91 integra w/B20B
- integra question
- About to install McCulloch HID conversion kits, questions
- B Series Cam Gear Weight
- 98 GSR RUST PROBLEM NEED HELP
- Is there a way to have moderators delete your threads?
- radiator problems?
- My Car wont idle right and kills itself???
- botling b16 head on gsr block...another question..what head bolts
- integra fender
- Chipped ECU Problem
- White smoke comes out exhaust everytime i come to stop!!!! HELP
- can someone measure the dimessions of your oem maplight
- Subfram Tearout
- AEM Question
- clutch
- Body Work Needed
- Just Got Home from the Dyno Again...
- Integra Antenna Plug
- need to if tranny is bad or clutch....please help ht member
- intermediate shaft leaking from the tranny
- Vacuum help for 97 JDM ITR in 92 GS-R
- Older 3 bolt STR cam gears good? And what about these?
- How much hp are stock cv axels rated up to?
- oil pressure question
- Over heating and hot wired dual fans.
- HELP BRAKES
- Can't get new distributor on, wtf?
- Compressor map help
- can i use the B20 crank pulley on my JDM B20 swap into 91 integ?
- crank pulley
- passwordjdm
- Air Leak near Intake.
- JDM B20B...what is this sensor on the back on the block?
- Rims + Tires 4Sale 205/50R15 $500
- Help! brake line on master cylinder
- is a CSF bronze radiator a good replacement?
- SHOT SPRINGS?
- s2k installed..what to do with seatbelts?
- oil press @ 45psi
- ls vs itr calipers
- Anyone got a spare wiring harness you wanna part out???
- My wipers wont shut off!!!
- B18C1 Issues
- WRX fogs on Integra
- EK tien coilovers fit on DC integra?
- 99 gsr quick question
- LOOKING for an INTEGRA or CIVIC for around $5,000!
- Hondata IM Gasket fitment w/ Skunk2 Manifold
- Which one?
- Rare integra accessory????
- where are the fuses for 2000 gsr taillights???
- Clock spring?
- How do i remove this black adhesive that looks like glue/ double sided tape
- For those Non-Vtecs out there
- pics of my new swap
- Speedometer not working after swap??
- Excessive whitish blue smoke at cruising speed????????????????????????
- Help with wiring sensors on JDM B20B swap in 91 integra
- What is a P30 Head?
- cutting wire of a type r cluster?
- Confused what to do?
- b&m on aem rail fit?
- 2000 gsr ECU questions
- Autometer Oil Pressure Gauge & Greddy Block Adaptor.....
- 94 LS engine..going into 00 LS
- light problem
- hmm? whats wrong with the motor?
- Remove Fingerprints From Gauge Faces
- vtec lag on 95 rebuilt b18c1
- radiator question?
- Is this car worth 10g's
- Keep on blowing a damn fuse Help!
- Towing a teg...
- Rebuilt Vs Re-manufactured engine?
- WTB: 98-01 INTEGRA REAR BUMPER
- DA9 Headlight unalignment
- car wont run. help please
- 95 Auto LS - terrible acceleration problems!!
- Help removing crank pulley bolt
- rsx(DC5) steering wheel
- GSR transmission
- Qeustion about ground clearance???????????
- Which flywheel?
- Anybody Sleeving!!!! LOOK HERE $$$$
- Tokico Blues goes best w/ what springs?
- where to find 2.5'' exhaust? 91 teg
- How to get to rear engine mount...? V-TECH
- what is the most hp you have seen out of a daily driven, street legal integra?
- obo- ob1 distributor wiring need help pics included help with the wiring
- Coolant Lines
- flywheel bearing
- lower timing belt cover
- DA Integra Starting Problem - Weird!
- front window
- EG suspension on DA??
- What's wrong with my friend's car?
- Is stock DA fuel pump good enough?
- where to buy new DA carpet?
- out with the old in with the new
- Double checking Ls\Vtec
- Convert RS(non VTEC) to Vtec
- what should i do to my head
- Type R rears...in DA
- Transmission question
- info. for so. cal people!
- OBD2 Distibutor work on OBD1 car?
