- the key ringer / gauges and taillights don't work
- s2000 TEG
- rage header
- Disconnecting shift linkage
- Quick pricing question?
- car wont start
- What to do first?
- Anyone know site to order Integra locks?
- JDM Front SILVER front H emblem
- Used SPEDS or new wheels?
- TDC Timing Belt Question
- new front brakes
- ecu code 67
- steering wheel shaking
- IAB ON 98 GSR
- I m looking for a Shell 95 and up
- LSD
- Fuse Box Plug Pin Diagram?
- Best *part here* for a 2000 Integra GS-R?
- DA power folding mirrors
- Right Rear Brake
- Rolling up windows without switch?
- New to Honda-Tech
- Fuel Pump
- any difference between b18c cams and b18c1?
- Auto to Manual conversion - screws up speedometer
- maintenance required light, now motor dont work and knocks?!?!
- help! is this right?
- Need Help!! Changed Dash Harness ran into some problems
- axle proble
- Temperature acting strange
- Lug nuts coming loose...
- A/C question for dc2
- steering response decreased after suspension install?!?
- JDM ITR Header: what cat? S2K?
- Any 94+ Integra owners with Powerslot Plus Big Brake kit?
- Will 98-01 rear integra bumper fit 0n 94-97
- Will my car run w/o my apexi vafc2
- Cable/Hydro miscommunication
- oil filter changing question.
- vtec hitting late?
- Which timing belt for the bigger water pump
- VTEC HELP!!!
- Buying a GSR
- horn stopped working
- fuse
- ls engine miss firing ( need help)
- side skirts for a da?
- Maintenance question?..
- Can I buy a single sidemarker?
- 16" rota
- bad lsd
- wheel lock for OEM wheel
- Door Lock Change.....
- Please dont delete, need it gone......
- changing motor mounts
- turbo charged gsr
- Wiring harness plugs and connectors
- Weird electrical problem in 91 LS
- how to take the head of a b18a1
- Can my car do better?
- cat converter
- ball joints tie rod need advice
- oil catch can?
- DA Jdm ecu noise?
- GSR...OR.....Ls/Vtec...?????
- What shocks are interchangeable with a DA??
- 91 integra gs 5 sp vibration problem....help
- ABS Code 8 1, how to fix?
- some one help gas psi up to 80
- dc4 dash swapped, turn signals and heat dont work??
- TOP SPEED!??
- itr oil cooler interchangable?
- Throttle cable or gas pedal
- Front Struts???
- Omni Coilovers.
- apexi n1 or ws2 exhaust systems
- man how tight is the oil plug suppose to be?
- 94-01 Headliner coupe sedan the same ?
- c-pillar bar
- Any way to raise the seats?
- EDM itr cluster with MPH!!??
- are da and dc lower ball joints the same??
- How to Change your oil with a lowered integra?
- H22a DA: I need some sort of a quarter-mile prediction for both NA and with a 75hp wet-shot.
- Towing with a Integra?
- B20Vtec
- b20 ignition timing....
- b16a head/b18a1 block help help help!!!
- sluggish dc2
- ls wiring problem
- New transmission and Axles, now theres vibrating?
- problems with tachometer
- itr pulley into a gsr?
- color code for gold rota GT3's???
- b18c5 piston into a b18c1?
- Hey what's up people. Im new in here. Hope ya'll cool w/ it =]
- code 43..car drives fine..wtf
- B18A/B plug wires the same?
- venom 400 performance module???
- dc2 door handle removal
- Help!!
- skunk ecu
- I need a carfax
- hondata knock sensor problem
- New to ht and just got some questions?
- HID RetroFit For DA9/DA6
- DA wiring harness question
- Clutch problem (splines stripped)
- Question about gauge cluster
- SiR-G Metal Fenders?
- help with my crappy rims
- Does this head looks okay?
- Questions about strut and sway bars
- I have a ls and have a civic si head computer and harness
- Ways to Protect Your Car
- QUESTIONS ABOUT INTEGRA DA JDM HEADLIGHTS
- dc header or generic jdm style headers?
- Ignition problems??
- Please give me some advice on painting
- who's gsr leaks oil??
- gsr fast???? poll
- gsr fast????
- ABS removal from my 94 gsr HELP!!!
- integra interior question
- ls/vtec with automatic tranny.
- airbag
- crank pulley
- breather/catchcan question
- check engine (maint req'd) light on
- integra stereo
- hi im new !
- Advice: Wiring JDM 1-piece headlights
- Voltage/Temperature problem
- dc2 95 si vtec lip
- very simple questions about oem lca
- No power lots of fuel smell please help
- Pep Boys/Autozone - clutch master cylinder & slave cylinder
- SHOCKS AND SPRINGS
- HELP 98 GS-R Converted 2 An AUTO 4 The ONLY acceptable reason....can sombody help PLEASE!
- JDM headlight question
- need a part number...
- APEXi VAFC on a b17a1
- will 99-00 civic si side skirts fit a 94 db8?
- track?
- type r ecu into a gsr?
- vtec pressure valve?
- clutch question
- IS this line for my A/C????
- Before installing Drag turbo
- 91 integra question
- where can i purchase 98 + frontend & rear bumper
- Another Stolen Integra!
- TW 1993 integra
- help car have problems
- Need help with my 2001 GS-R!
- TEIN S TECH SPRINGS W/ TOKICO BLUES
- transmission is whining
- Bent valves?
- looking for good 4dr integra add on lips.
- 94 front fender lining question.
- Anyone from Houston?
- parts from b18b to b18a??
- who would win?
- VTEC engagement and disengagement question!?
- gsr help!
- chip p28
- a/c and speed?
- Stock 96 LS air intake...how does it even work?
- type R strut bar on ls sedan?
- 1995 acura Integra Ls Looking for a full exhaust greeding system
- will a OBD2 JDM VTEC solenoid work on a USDM OBD2 Motor & ECU?
- fluid leak
- Installing AEM short ram
- 92 & 93 GSR Question
- b18 timing question
- Honda window visor
- itr ecu obd1
- Transmission Upper Output Leak
- Pic Request: Autopower 4 Point Roll bar with proper 4 point harness setup in DA Integra
- how to hollow out cat...and results from it
- Password JDM License plate re-locater.
- T1R street SPL
- HOW DO YOU WIRED UP JDM DC2 HEADLIGHTS???????
- need help with vent visors
- best CAI?
- My car is extremely slow after i changed my iavc.
- electric super charger
- oil temp and oil pressure gauge issue
- Wheel offsets.
- help b17 head gasket!!
- hear silence when crank the engine...need help...
- is there truth to this madness? is this guy right?
- Top 10 Stolen Cars of 2005 - Integra Makes the List, SIX Times!!!!!
- My radio in integra?
- axle
- 2 min pulley job
- harness question
- Part out or Sell as whole?? 99 ls
- picture request (dc2 jdm front w/ mugen MR5 wheels)
- Clutch Engagement/Dilemma
- Which "H" badge fits the rear hatch of a DC2?
- Some1 in california Please Help!!!!!!!!
- Suede or leather aftermarket steering wheel?
- 01 GSR Dash Help
- INTAKE VALVES
- JDM b18c w/ ls ecu for smog?
- Oil related issues and a question about running crazy rich!
- hey need help..on Swapping and engine
- new to imports what is the best year integra to get
- Transmission refill on manual
- Lowered car
- Help Please! Car Misfires
- i need help with wiring
- d16a integra owners...quick question on valve seals...
- problems...need some help
- starter solenoid
- HELP ASAP radiator mount issues big time
- Does 94+ integras come with Solid Core Spark Plug Wires?
- running a p28 on a gsr
- Question about removing trans.
- H22 , Type R Or B18b
- Intake Manifold Question.need help!
- What color white was the 1998 integra?
- jdm itr rear sway bar
- Ls Vtec ECU qustion
- Black Leather GSR seats for sale?? $450
- Transmission Troubles.
- front license plate
- CEL
- loud noise out of intake pipe
- Car for sale 98 integra ls with a B18C swap
- Will this bracket work
- type r intake manifold
- need some help
- driver side air vent sunroof control
- Radio unlock code help?!?!?
- I have had it! Stupid heat... please help me!!
- Tranny situation..
- Fender Gap
- EK/DC2 Mugen Calipers, any differ from standard B16/B18 caliper?
- change valves
- Aluminum Radiators
- Ecu Question
- putting 96+ b18b1 in a 94-95
- what's the difference?
- B17 spark
- CAN THEY FIT?
- which obd1 pin do I use for a/r guage narrowband?
- obd1 p72 ecu pinout
