View Full Version : Acura Integra
- 95 integra circle track car
- LS sedan wing mounted brake light replacement?
- 1998 GSR MOONROOF/SUNROOF WIRING HELP!!
- What is this part?
- Can’t get my LS swap to start
- TICKING LSVTEC HELP!!
- Troubleshooting Fuel Pump Issues
- Beastly Street DC2 Suspension Setup
- Emperor Akihito’s Integra
- What screw size for headlight ring on JDM front?
- Lsvtech
- climate control a/c button green bulb
- Installing a gsr head on a b20
- Replacing Oil Pan Gasket...What Else?
- Integra Sedan Side Mirror Plug?
- 2000 Integra GS Engine Stopped While Running - no compression, with cam lob burn mark
- Secondary O2 sensor
- Chassis harness confusion ITR
- How To Time LSVTEC MOTOR?
- No start no crank
- Throttle problems/ ideal problem
- Fair Price for B18B1 Motor?
- New battery + alternator - battery light.
- Coolant leaking from around intake manifold
- Coolant leaking (boiling/exploding) out the back of engine, JDM B18C P72
- B18b1/p75 daily driver
- 95 ls itr strut bar not fitting
- DC1 B18C swap, No Rev gauge
- My turbo lsv build
- Help
- Car won’t start- when I turn the key I don’t hear clicking from dash no more
- Newer Integra Stereo?
- Lets see them pics of Integras with Advan TC4 and Gram light 57DR wheels
- Why all these CAT not for use in Cali and NY?
- B18b1 non vtec valve cover studs?
- Anyone recognize this security system?
- CEL code 9 - 97 GSR with Hondata S300
- Integra LS 1992 engine dies while running help
- Auto to Manual swap ecu
- Quick release steering wheel kit question
- remrahc's '94 GS-R Build Thread; or Something Like That
- Clutch Problem?
- RPM drops quickly to idle when clutch depressed
- Over heating.
- Fixed front wheel bearing using cheaper Ford bearing for CAD$17
- Whats the best way to build a b20 head for a b18b1 block.
- 94 3 dr to 4 dr.
- Sedan aero parts
- Building b18b turbo
- Questions about wheel hubs
- Rustoleum let me see how you did..
- 95 integra lsv
- I need some serious help because this is giving me a major headache.
- Projector lens swap
- Will the cooling fans for a standard 1.8L L4 work on a B16A3?
- Left Front Motor Mount on a DA Problem
- Front Door Harness Connector ID and Pinout?
- Broken flange in mid exhaust pipe.
- Where can i find this bolt??
- Clutch Pedal Push Rod Problem
- Acura 1993 won't start HELP please
- 98 integra ls abs light on
- DC2R 96 Spec Hubs = 4th Gen Prelude Hubs?
- Daily driver tire opinion \ suggestion
- my current setup ideas for what to do next 2000 gsr
- 2001 Acura Integra GSR Pickup Truck
- 2000 Integra LS going lean at idle
- engine sputters at 4000 rpm and above (b18b1 93 teggy)
- Gsr build
- Cause of 40/40 prop valve failure
- Factory power lock remote
- ‘97 DB7 Cabin filter & airbag? Yes please!
- Car bogs down after warmup, questions on compression test results
- Low compression Cylinder 4
- Things to look for on 1999 integra gsr
- Will ek9 seats fit in my 96 integra?
- Will flex z struts off a Accord fit my 90 Integra DA?
- Uneven motor
- 98 Integra LS Speedo Cal Tire Size
- 90 Integra running on 3 cylinders
- 90 Integra sounds like a VW Bug.
- Ha motorsports hondata ready p28 issues
- 5 speed swap axle length
- Dtc help plz.
- Dtc help plz.
- B20b Wiring up in 96 Integra GSR
- Catalytic converter for smog check help.
- Car bogging down on low RPMs
- B20b vtec build (help)
- Surging idle help! Integra turbo
- 2000 Ls auto to manual swap not starting
- P75a01 code 41
- Coil packs
- '97 DC2 Integra Track/Daily Build Thread
- Integra b18b1
- Integra b18b1
- Is my timing off?
- B18A1 engine wiring harness compatibilies
- Looking for vtec rocker arm pin!!
- Harmonic Balancer Flew off while driving
- Rod bearings
- 94 Integra fender to bumper clips?
- How many transmission bearings in a LS integra
- Manual swap vss
- 1998 Integra LS Tach Issue
- Need some help figuring out an issue
- Idle surge issue
- What year is this b18b1 exactly?
- 93da top hats
- TPS problem
- 91 Integra B20B swap high idle.
- Cam gear seals keeps leaking!!!
- Headlight problems
- Bigger fuel lines, on factory fuel tank?
- 2000 Acura integra 4 door swapped
- Is this 2000 Gsr worth $4000??
- Pcv valve leaking coolant 91 Integra b20b swap
- LS Turbo questions
- B18B No-Start
- Kill switch. Which wire to splice on MFR?
- 92 da9 Wire tuck on passenger side now car won’t start!!!!
- B18b1 exhaust leaking into coolant system
- Pedal assembly question...
- how much is a clean GSI Integra worth ?
- Auto to manual swap, axles
- Ford Tauras cup holders are useless
- B18c1
- GS-R Timing Belt Too Loose?
- 1991 da9 turbo help crank but no start
- Everything needed for odb 1 conversion.
- Broke 10mm bolt in head (cam seal plug cap)
- No compression on b20 vtec
- Auto to 5 speed. swapping wire harness's?
- Rare JDM HONDA ORTHIA,CIVIC 96-00 CR-V 97-01 Steering Wheel
- Integra No Start - ECU???
- Clutch Noise—Sounds like air
- No fuel 98 integra
- B18 transmission manual swap
- Swap for 91 rs integra
- exhaust flange gasket question
- Which is more likely to fail 1st on 20 year old 250k mile Integra: relay or starter?
- 1998 Integra Interior/Front End Harness Questions
- 98 Integra no spark
- Need help with h22a4 rebuilding spect
- Head Swap
- Tensioner Bolt Rounded Off
- Tough getting it in all gears (integra ls)
- JDM B20 Swap
- JDM B20 Swap
- After market headlight issue....
- Best way to diagnose heater issue.
- 95 Acura Integra LS trans problem.
- Aftermarket Timing Belt Tensioners Good?
- Usdm type R inspired LS (build/ ?'s thread)
- What is this slipping in my steering?
- Fuel cut off at highway speeds?
- 94 built rhd integra issue almost like limp mode ?!!
- Installing 2000 LS Ignition Switch in 1999 GSR?
- 2020...Any good auto body shops in San Diego?
- Type r lip kit pics
- Engine inquiry: what engine should I install in my '95 LS?
- Long term fuel trim & short term fuel trim % negatively high
- High output Alternator pros and cons?
- 1999 Acura Integra Cranks but no spark or injector pulse
- '92 Integra, driver's side door latch is stuck and door won't close
- JDM Front integra cooling issue.
- B16 Swap Hesitation on Acceleration
- Wher do they Go??
- eBay thermost 19301-PAA-306 genuine? Looks legit, cheap!
- IDLE ISSUES
- Turbo Integra Sputter/Rough Idle
- Car feels awful under 4K rpm
- New to honda
- Reliable Aftermarket Integra Distributor ??
- Tachometer fails
- super cheap integra autox and trackday
- Acura integra gsr b20 AC bracket question
- Type r piston for gsr engine
- Mirrors
- My acura rsx k20a3 to k24a3 swap
- No Crank no start
- Hondata light not turning on
- Code p0172 & p0170
- Help needed, badly.. "93 RS B16A/GSR head
- Fuel pump prime question
- Civic Half Radiator Cap Leaks Coolant
- Burning alot of oil and little coolant.
- Desperate for advice ‘93 RS/B16A/GSR HEAD
- JDM s4xa
- Speed sensor help
- 90-93 Integra Proportioning Valve internal replacement parts
- 2001 Integra LS B20B swap help
- Just checking before I change my head gasket
- Hard to find/ discontinued OEM parts
- 2001 Acura Integra GSR N/A Build Suggestions?
- Interior parts?!
- 96 acura integra axle problem
- Acura integra 1994 b20b swap!
- Proportioning Valve alternative replacement 92 Integra
- B18C1: Skunk2 Tuner Stage 1 Cams with Toda Springs/Stock Retainers?
- Integra 4 door window moldings
- Running Hot?
- under dash ignition fuse keeps blowing
- Blue confetti seats
- How rare are blue confetti dc2 front and rear seats?
- Timing issue
- Stripped engine post bolt bolts
- DB7 work in progress
- My ‘99 LS auto to manual swap & track prep
- Rims and paint ruined?
- B18b1 shift linkage
- Compression Test B18C1 Low Results?
- 98 Integra LS Low Fuel Indicator Light
- 1997 gs-r thach and vtec problems
- 2020... B18c1 rebuild?
- 01 GSR windshield moulding ?
- 2000 integra gsr click no start
- Main Shaft Input Speed Sensor location
- 99 LS steering issue, not sure where to start
- What Radiator For 1999 Integra GSR?
- Disconnect Rear Brakes 96 Integra
- Do good condition GSR trans still exist to buy?
- Water/moisture inside j front headlight
- Transmission leak or rear main seal leak, or?
- INTEGRA AIRBOX FILTER
- INTEGRA AIRBOX FILTER BOLTS
- 1997 Integra GS distributor problems
- Unfortunate chain of events, now crank no start.!!!
- HELP! Diagnosing noise from 1999 Integra GSR
- 98 Integra LS Antenna vs Rear Cargo Bay Light???
- Headlights
- Turbo B18b1 Rebuild
- 1994 Integra VTIR Engine turns off after turning on
- My turbo K24/20 build
- 98+ hatch actuator, can i remove it?
- I’m looking to k swap my 1997 Acura Integra
- Being Worried About Car Getting Stolen
- Chublu's DC2
- Rear toe adjustment bolt mount
- Identify gear ratio
- Knuckle problems
- Smog legal mods for ls
- Is my pp too small?! XTD clutch kit?
- Need a name of part
- Troubleshooting: GS-R head with missing oil lubrication oil ring
- Rear parking brake cable
- Need help
- Ignition switch Civic/integra
- Oil Leak Distributor
