View Full Version : Acura Integra
- I got my 98 GSR back
- Front end accident, trying to fix
- BWR Throttle Body Gasket
- Aftermarket muffle on stock exhaust?
- Suspension and Wheel Advice
- Mystery oil leak
- Aftermarket water pump?
- How to test the oil pressure warning light flashing circuit in the 1990-93 ICU?
- Acura Integra Confetti Blue's Front and Rear Seats
- Clutch Slip
- Build update
- Clogged cat
- Integra Type-R 98' Dried Coolant Blocking Engine Block Drain
- Subharness help
- Difficult ignition switch
- I need help can someone tell me what's up round wit my integ
- Black box on cabin filter behind glove box
- I bought a clapped 91 Integra from some tweakers to start my first ever project
- Engine bay screeching noise
- No start Help. Super confused
- Under hood fuse box wires help
- It was a sign...
- HELP! Multiple Misfire Codes 2000 Integra GS-R
- Got my favorite car back...
- Is there a need for an aftermarket ICU for 1990-1993 Integra
- Should i run a knock sensor?
- Super weird crank no start issue-im stumped!
- Need help with Insane Shafts and Wheel bearings
- B20B starts then dies immediately
- Differential Preload with tapered bearings
- Cluster not working, I can’t find the answer anywhere.
- JDM 97 Integra help
- How much horsepower can my engine handle
- Trunk mat being restored
- Leaking AEM Fuel rail
- New front lip is too short
- Failing fuel pump check valve?
- Head gasket keeps failing
- 87 Integra | Where is the coolant temp switch?
- Celica seats in integra??
- Need ECU help ASAP!!
- Street build 93 integra questions
- 94 manual teggy ignition switch key can’t pass position 3
- 1994 integra GSR transmission issue
- Not Charging?
- 93 LS sp for my boy
- Integra Rims
- Question on brake proportioning line
- No crank
- Clutch will not disengage
- Best CA smog legal options for most horsepower out of a b18b1
- How much boost can b20 non vetc handle?
- Help with replacing fuel feed and return lines.
- HELP! NO FUEL!!!
- Doesn't want to turn over
- No-start issue after replacing fuel tank
- h22a4 in obd1 dc4 (ls) integra?
- swapped a b18b into a b18b1 CEL P1337
- Crank No Start, No Fuel
- Cylinder head options
- Idle/ throttle problems
- What are these sensors?
- DC2 Rear Bumper Fitment (Facelift)
- How much should I pay?
- Integra Vac/Coolant hardline routing
- Integra
- 92 gsr ticking
- b18b1 Goon Toon injectors??
- Need advice. WWYD WIRING. 1990 integra
- acura integra hazards
- B series and D series Harness
- 98 GSR O2 Voltage
- Car dies at normal operating temp.
- Tach quit working, need wiring info
- [HELP] Idle Surging + Weird Throttle Response – LSVTEC DC2 (Hondata S300)
- Wire issues
- Swap not starting
- Cam Shaft Clearance
- 98-01 Rear Bumper Bottom Black Strip Question
- jdm obd2 alternator plug to obd1 chassis
- T'shooting Power Distribution Box, AC Relay Socket
- V-TEC oil pressure switch wiring
- EVO H2B Swap 94-01 integra troubles
- Electrical I hate it
- Which is better?
- Intermittent CEL Code 9
- B18B - Indent on water pump mating surface
- ARP head studs for B18B - 2 longer studs
- Bracket Name / Part Number
- No start with ignition lock cylinder
- Chips on outer side of cylinder wall
- 11:5:1 compression, turbo setup.
- Could it work?
- Radio delete cover double din template
- Rpm drops crazy low after pressing gas pedal
- Auto trans ECU pin out
- Lactic question
- Dc4 integra cv joint/axle issue
- To Anyone With A 90-91 Integra (Factory Manual)
- Fuel injectors not getting pulse
- 1991-1993 Acura Integra Servie manual
- 1990 Acura Integra Soft Brake Pedal
- need help after transmission swap
- Please help!!
- Brake Compatibility
- Valve cover??
- Downpipe hits the oil pan and wont line up
- What ecu can i use on jdm type r
- looking to rebuild my b16a2
- 1990 Acura ls and gs
- Dash wiring
- Bouncing Idle Help
- In a shitty situation.
- Interior swap
- B-series trans help
- Dash fuse box
- Help with horrible alignment
- GSR with ITR swap has a form of studder
- Need help identifying rims
- Honda b18b3 heater valve clip
- DA9 fuel pump/crank/no start
- OBD2 port not reading VIN
- Cant tell if i need to get bored
- B20B with Auto ECU??
- B18b1 gasket kit?
- DA integra K24 swap Innovative mounts fitment issue
- CANNOT CONTROL MY IDLE
- Input shaft bearing
- No throttle response, car died while driving and now only runs at idle in gear.
- Speedometer cable
- Jdm hid problem
- H2b wiring for non-vtec obd0 integra
- Mystery Hose
- What is the name for this hose?
- Dc5 integra (k20a3) | Rough cold Start
- 94-01 Integra B series Auto transmission
- LsV smoking after rebuild
- Smaller belt size for Alternator
- 1990 acura integra (idling)
- Crank but no start
- Key Fob replacement Question
- Honda Integra DB8 Help
- Supertech valves amd valve seals
- I need as much help as possible
- how much amp does the alternator need to have?
- GSR Idling Issue
- MAF sensor
- B18B1 timing rattle noise
- Keyless entry help!
- First build... advice?
- I KEEP popping ball joints.
- ebay wiring harness good?
- B16 piston in b18
- Front indicators wiring help!
- Prelude Steering rack on integra?
- 2000 Integra GSR weirdness
- Problem with IDLE.. HELP?!!!
- B16 oem pistons or forged
- Where’s this supposed to go?
- S2K Cluster Harness Conversion By Wireworx
- First build need 2 know what to buy
- Shifter Problems?
- Alternator for b18b2 not fitting.
- 1995 GSR leaking from top of breather chamber
- Main relay wires melted
- POWER STEERING HELP
- Sheepy Race A/C P/S compatible top mount turbo manifold
- clutch is losing pressure 1996 acura intgra gsr
- B18b head on b16a2 block... NEED HELP
- Impossible to set valve lash on b18b1 p75 head
- 2000 Integra Gsr intake
- NEED HELP B SERIES DIFF LOCKED i think
- Cutaway or layer model for B18C1 head
- H22a4 alternator on a b18b?
- Fitting 15x8 +40 to clear rear trailing arm
- B18C1 wiring
- Removing fuel tank + safe jack stand points
- Would B series mounts work on a h22a4 engine?
- Looking help with a parts list for working a/c and heating
- Sporting the problem with my integra being hard.
- 'Overheating' issue with a 93' DB1 Integra B18A1
- 95 integra ecu shutting off and on.
- 98 B18B1 Timing Belt Jumped Time
- h2b mounts for 94 integra in AU
- Norcal Shops
- Edelbrock intake B20b question
- Any advice on buying vtec cylinder heads online?
- My 98 integra does not crank or anything but starts up when i push start it
- possible blown head gasket??
- 1999 acura integra running on 2 cylinders
- H2b engine bay fitment for 94 integra
- Code 54 help
- Power loss issue 1990 B18A
- Auto to manual swap won’t crank
- Bunged B18B valve cover
- Surging causing integra to loose electrical power!!
- Australian Integra not starting
- How to fix/replace coolant temp sensor on integra
- How to fix radiator wiring on an integra
- Vss code but speedo works help plz
- How much power can a stock b20b head handle?
- Auto 91’ DA9 Gearbox slipping out
- 97' Acura Integra
- 35 PSI boost!
- My build idea for my 96 teggy feel free to give criticism or advice id appreciate it
- How to disconnect abs from Acura integra
- B20b JDM spec swap please help ! Won't start
- How to adjust radiator mounts/placement
- GSR Transmission bolt missing. HELP!!
- How to remove stripped hex nut off clutch
- How to remove crank pulley bolt
- B18b obd1 high idle
- How to remove engine block
- How to remove driver side axle shaft
- Gsr Swap (96) Into ls Integra(96)
- A/C Line Question
- Bad MPG
- How to remove stripped nut off intake manifold
- Honda performance shop
- Long Brake Pedal
- DA integra Pcv/Intake Manifold
- LS/VTEC SWAP Timing Belt Cover with manual tensioner Write-up
- Engine Overheat Troubleshooting
- Troubleshooting engine hesitation/poor acceleration 1991 “Integra LS” B18A1
- 1999 Acura Integra Knocking From Wheel Well
- Crank no start, good spark, good fuel
- B18B1 Fuel Issues!! Help!
- Need help figuring out electrical issue
- Acura integra LS
- Help...Reverse light only works if I hold shifter back hard
- Keep blowing battery fuse trying to reconnect alternator ground
- Alternator Rebuild Kit Recommendations??
- Tapping Upper Coolant Neck for Water Temp Sensor vs. Using Adapter for Hose Inline
- Temp guage reading artificially high
- Acura Integra Type R Badge Restoration
- 2000 : Integra GSR : High idle issue
- Hi there! I need some cams advice. Thanks
- 98-01 hatch on 94-97 integra
- Right direction to pinouts please KEIHIN ECU
- Emergency hazard switch
- 2001 GSR Fuel tank Replacement and parts
- Reliable 350-400hp built motor
- B18 Coil On Plug S300V No Start
- Need suggestions on camshafts
- 1999 Acura Integra sedan automatic/ bad charging system
- Potential cam/lifter issue
- B18a1 skunk2 intake
- 96 integra no start, grounded starter power
- 1999 Acura integra
- B16a2 knock on idle
