View Full Version : Acura Integra
- a/c receiver pipe c
- Freshly pulled B18B1 should I disassemble or sell as is?
- Side Mirrior
- Oil in radiator but not in block/head
- GSR FUEL PROBLEM!
- removingf struts without removing wheel?
- GSR B18C1 Bogging Issues
- OBD1 B18C1 w/ITR TB & SK2 IM: Need help w/coolant and PCV
- gsr head gasket
- Where to find OEM rear bumper filler grills
- dead miss problem on #1 cylinder please help!
- Cracked Radiator going over speed bump
- integra ac, Quick question
- gsr built for turbo..how much is it worth
- Ek fogs on 98 spec integra? (pic's inside)
- How much is K20 swap total cost? B or K series
- broken clutch springs
- Would a del sol axel back fit an integra?
- freshCROOKS's whatever goes BUILD THREAD
- Opinions on diamond racing rims with 2" drop?
- Swap Questions...
- bad idle, running EXTREMELY rich
- Need help finding HID size
- motor lifts up and down!!
- car is stuttering
- CTR rear sway bar vs ITR
- Cat converter fitment question 94-95 GSR
- P28 ECU problems
- Wiring problems, hope someone can help!
- cam plug Qs,and valve cover gasket identify/replace.
- idle issues
- 2000 integra cranks but won't start. P1298 CEL Code
- Jrsc ls pulley question..?
- safe to drive whiled the rear brake lines are plugged?
- intermit cel o2 sensor low voltage
- 94-97 integra front lip
- 91 LS1.8L No spark/rpms on tach PLEASE HELP!!
- 91 integra weird fuel pump???
- 1995 GS-R fuel & brake hard line removal
- GSR Supercharger help
- Wiring through firewall 97 Gs
- Tucking issues 16x7 205/45
- Gsr smog ref'd in a crx help
- 95 integra ls
- New to HT,Problems with integra..
- Neede help with 94-97 fog light install
- Fuel Gauge problem...Please Help
- B16 Turbo or B18c5 w/89mm crank all motor?
- Immobilizer question YET UNASKED!!
- Gsr no power to fuel pump can i run a switch to it
- 95 Acura Integra Build !!!!
- What would be a good accent color?
- What cluster is this?
- need some help on purchasing this DC2
- 91 Integra Overheating Issue.
- 98 gsr doing some test now no start
- Wtb 99 oo 01 integra front bumper
- b18b1 serial number
- k20 DC2 Drag Car build thread
- Car wont start need help! asap
- jdm itr exlxe back vs usdm itr axle back
- diffrence in radiator/
- 92 integra with rusty water.
- WHO MAKES THE BEST JUMPER HARNESS?
- 90 GS Clutch interlock switch removal
- car only runs with spark plugs backwards
- Some questions about window molding/trim
- auto shift bezel?
- bad running if not at all b16a. ready to get it done!
- missn bad ilde b16a
- Is this (B18B1) Head and Block any good?(pics)
- 1997 integra swap
- integra sedan trim options q's
- I keep failing inspection and it's getting worse each time
- b series cable trans lever issue.
- FS: Authentic Spoon N1 Exhaust for DC2 Integra Type R
- installing one peice head lights
- b16 head tap for lsv?
- 95 Integra Idle Problem
- HIDS, and the integra headlight system light output
- what engine harness is compatible with b18b1
- 1996 integra (need help)
- Washington HT members is your car Famous?
- Swapped LS Shell With Vtec Swap-vtec not working
- NRG Quick Release + Short Hub + Lock
- Clunking noise from under hood.
- CANT Figure Out Problem On Integra 92?
- spacers to make end links vertical with aftermrkt lcas??
- CEL 43 Help!
- Worn front end do I need after market camber kit?
- 92 Integra wont start! Very weirdo problemo...
- gsr tranny problem
- gsr swap in ef with real high idle
- 90 DA, liquid gasket question
- short shifter install replacement parts
- b16a timing. need help asap
- obd1 harness ??
- DA Integra
- Numbers
- Transmission rebuild
- RSX Key Blank cut to my car locks
- 98 acura integra hids
- What y'all think?
- Has anyone actually tried a trunk-mount bike rack?
- integra gsr turbo build
- Car dies on me
- need info on honda fuel pressure regulators
- Cable Transmission question
- Cant really find an answer for my gsr
- Can't find answer anywhere!!
- Throwing CEL, which sensor?
- putting skunk2 on my gsr need help pls
- Broken hose in engine bay.
- Integra ls/v Help
- ebay turbo piping?
- LS Vtec Question
- Blue smoke ONLY after coasting??
- gsr intake/ls head/ls aftermarket intake manfold identification
- Coolant fan only wants to work when ac is on
- Building the LS
- Radiator fan question
- fuel pump not turning on right away
- O2 sensor question
- AC install help
- Idle to low after reaching head gasket
- newly rebuilt engine zero compression in 4th cylinder!
- Injectors question!
- lsvtec wiseco or cp pistons???
- ARP head stud install, one stud not level
- Head on, TDC? Oil control orifice?
- how can i get rid of grease on longblock?
- Can I remove the plastic behind the cam gears?
- how to identify b series motors?
- Cannot quite remove rear speakers, 3rd Gen 2D
- Car died driving, Won't Start Now!
- Bought my first car, 1997 Honda Integra - SiR II
- 00 Civic Si/GSR swap stalls when idling or switching gears
- 99 gsr exhaust ?
- oil light on, new pump, nagano ITR swap
- 96 acura integtra alternator issue?
- '90 GS, need junkyard parts
- Number on rod?
- 96 gsr cam caps, cam journals order...
- walboro fuel pump
- Starter issue
- LS teg died while driving...
- Buying cars from the USA
- Having some idle issues with my DA!
- 95 integra Smog help needed in So cal..
- ITR front wiring issue
- Cool site i came across
- Fan wont shut off?
- Tokico Front Strut Assembly 2005JDM Integra type S
- Injector fitment problem
- Decent price for used Eibach Sportlines??
- Viper 5501 install 1994 gsr
- help!!!!
- 94-95 vs 96-01 Integra Gs-R Water pump Difference.
- Ls-v piston question
- Bog/missfire problem
- rough idle/ blinking CEL. tryed some things HELP!!!
- b18c GS-R vs b18c Type-R
- brake pedal super hard after changing MC
- Clock Problems
- Decent fitment 94-97 Integra fog light
- 1995 integra Driver Side Noise WONT GO AWAY
- Idle issues since i put on turbo
- Davidb's 98 Gsr
- My FBP Dc2
- GSR Weak when warm, vtec not working
- So my car was stolen and recovered. ??
- Possible bad B18C1 block?
- 2000 GSR Major Knocking Noise!
- HElP! gsr idle issues
- My brother got his dash re-wraped
- check engine light o2 sensor low voltage
- HELP Acura Integra 92 Start Up Problem?
- a/c compressor
- BOSCH O2 SENSOR QUESTION!?
- Spark plugs looking worse going from 1 (ok) to 4 (kinda bad)
- Running on 2 cyl. lsvtec
- Replaced Battery and Nothing Works
- USDM INTERIOR QUESTION
- Start the car and turbo timer starts counting down
- obd1 to obd2 question
- oil leak ? an high idle
- Motorola map sensor 2.5 bar stock map housing
- Radiator
- HELP ME FIND HER - OLD GSR NEED TO FIND - DVP GSR '00 - RHODE ISLAND
- anyone here around the missiouri area
- 93 Honda Integra...DIY tips
- 99 teg gsr swapping b20/vtec questions???
- 2STEP WHILE DRIVING?
- GSR Short Block / Edelbrock Cams / cam gears
- Type R cams on Stock GSR
- 220whp from Jdm type r
- over heating
- Grinding Noise Low Fuel
- Cant find my emmisions plug, 96 rs
- B18A1 Block Questions
- 94 integra OBD1 automatic Crank position sensor?
- Blown cat question.
- b20 nitrous limitations
- 1995 ITR conversion (Video)
- weird cel code
- integra takes soooooo long to start
- Vtec distributor
- TENZO Type-M Version 2 rims on 1990 integra
- B16 valve cover issue
- whistle in throtle
- Will DC2 exhaust work on DB8?
- Instrument Cluster, Radio, & Windows Not Working?
- Tach Freaking out
- need help with stock integra radio code
- Where to get B17 rods?
- y80/s80 bad syncs...Rebuild advice?
- Is a 4 door gsr engine harness different from a 2 door
- b18b1 97 teg non v tec n/a build advice
- 1996 integra db7 problems?
- Non-socketed P72 ecu?
- injector/resistor box problems and issues
- erratic idle at constant rpm's?? jdm GSR
- car is in "limp mode"
- burning smell
- water in my head
- charcoal canister question
- Assistance needed; somebody with a pin layout.
- got my 1st integra today
- Can't decide to keep rare VBM color or go with a white paintjob...
- Advice needed; Very Rough Idle & No Rev
- Second opinion on this buy!!
- Clutch cover help
- lean on deceleration normal?
- Aftermarket Muffler that resembles OEM?? Need help
- Gsr weird noise no power
- i need HELP!!! :/
- Throw out bearing
- After market parts web sites?
- headlight and radio problem on 95 db8
- I parked the car and I couldn't get the key out, then...
- LS rods on gsr crank?
- attempting a shave and tuck..but i have question..
- Car wont start seriously need some help!
- how to remove a stripped sparkplug from a ls.motor??? (pics inside)
- ITR Front conversion on a DC2 Help!!
- GSR HELP :(
- spun bearing will it damage crank?
- need BIG HELP, removing & replacing all brake and fuel lines (5 total) going to rear
- price for b18a1 and cable trans?
- 92 Integra GSR Under Dash Harness
