- integra head gasket advice? new engine? and new trans?
- paint help
- COMPETITION CLUTCH flyhwheels ?
- Wth is this thing?...
- Brake pads rub against rotor...need some help
- Just bougth a 94 GS-R.. It has a nifty lil card that came w/it. A punch ticket.
- Which is the ecu fuse?
- whats more important
- bad idle
- Front Brake Problem
- ecu location in 1st gen integra.
- need some help/advice for Type R head on GSR block
- diagram?
- Auto GSR Tranny into Auto LS...What is needed?
- Help! my teg is sick
- TPS (Throttle Position Sensor)
- Energy Suspension
- DA SUSPENSION SETUP!!!!!!!!
- b18b1 into a 99 civic si
- Need help! Have vibration at even low speeds!
- vizage body kit. pics?
- tien springs.
- Removing a VAFC...
- will integra seats (dc) fit into (da)
- o2 hard wire???
- problems taking off gsr spoiler.
- throttle body `
- Need clutch help, don't know which one to choose
- TIRE questions for DC2's
- How long do DC2 LS or GSR Transmissions Last? Might Need a Tranny. Where to Buy?
- suspension advise????
- 95 Integra with over heating problems......HELP!!!!!!
- Changing rear discs...wheel bearings?
- my GSR got smoked by an LS today in the freeway.. weight factor??
- shifting problem. help!
- noob vtec question
- where do i put the feeler gauge?
- how to bypass the neutral safety switch. on clutch pedal
- Tranny Question...NEED HELP!
- TurBO LS
- what all do i need to do to install a carpet into my 95 integra?
- individual throttle bodies?
- Help with wires???
- Gs-r fat fives?
- What cluster fits in a DA?
- GSR Idles high when cold...???
- Cheap Type R conversions...
- iacv wtf tried everything
- Hi-Flo Cat...
- Lower JDM seat brackets/sliders
- ebay parts
- were can i find jdm headers for a good price
- DA Rear Brake Pad Problem (PBR ULT Ceramic)
- Whats a stock b17 vtec crossever at??? 5.5???
- gsr longblock for sale
- are all B-series headers the same?
- 2000 GSR crank flux sensor OBD2 ECU
- are hi-flo cats still legal??
- Crazy weird oil leak b18
- OBD1 P72 ECU Evap question
- Removing Headlights
- Question about the 96 LS ECU IS THAT A OBD1 OR OBD2 ??
- Question about a O2 SENSOR
- 91 integra suspension ???
- Need Help Reading A GSR Cyclinder Head?
- Removing disc brake rotors...?
- 95 LS Airbag Question
- Light dims and shine when using brakes
- Does anyone own a RS*R Exmag???????????????????????????
- tensioner problem
- doing ABS removal right now need a fast answer!!!!!!
- how much...
- Pictures of my teggy
- Help me decide...
- possible quarter mile times, need info
- jdm obd 1 gsr longblock into obd 2 integra
- QUESTION: Has anyone gotten a paint job at earl Shieb Pro 4?
- Crower are Crane???
- CRACKE SLEEVE IN GSR BLOCK!
- Looking for decent shop for clutch replacement in Illinois (NW suburbs)
- dash
- Is there a difference in 94-95 usdm dc2 fenders and 96-up fenders...????
- Body Kit For Sale
- Tacho
- Worn motor mounts causes vibration?
- Shifting From 1st to 2nd Isn't Smooth
- wats the best
- WTB: 98-01 USDM GSR Catback
- hid jdm headlights
- DC Squad
- 94-95 vs 96 and up..
- Check Engine Light went on after the Intake Removal ???
- I hope I dont have bent valves! please help!
- Somebody tried to steal my 2000 gsr.......hahahaha
- no bottom end
- what the possibility of bent valves on a 92 integra ls with broken timing belt?
- ZEX KIT on my Gsr...
- Tranny help
- What are my options for brake pads and rotors?
- stainless steel header
- How do u remove the Black bezel part from an Integra Cluster?
- Intrusment cluster bulb #'s?
- Crank pully that fits 87 integra...
- new rims check it out
- horn doesn't work
- Anybody running 215/45/17......
- need to repin my o2 sensor plug
- LS integra steering wheel
- Door Latch Sticks
- Car gets warm...car quits.
- !!!!95 GSR ingnition Problem!!!!!
- What throttle body is this?
- 92 integra starting problems...
- HKS high power exhaust???
- qestion about HKS high power catback system.
- b18c1 HELP!!!!
- HELPPPPPPPP
- I need B18C1(GSR) Vacuum diagram
- Timing on 92 Integra
- skunk2 trottle body. what cable bracket?
- carbon fiber rain proof wax or protection?
- skunk2 short shifter on DA???
- IS THIS EVERYTHING YOU NEED FOR THE CONVERSION (ls/vtec)
- ls rods and crank in a gsr block
- need some specs, please
- Need a chassis number of a integra GSR
- Looking for gsr block
- car dies after start up...HELP!
- master and slave cylinders
- click/clunk coming from tranny when depressing clutch pedal
- PIC REQUEST: 17" GRIDS/TE-37s ON AN INTEG (CLEAN ONES!)
- 93 Integra with 99 B18c Swap
- apexi vafcII wiring diagram?
- Has anyone Tried a MSD 2 Step on there tegs/TurboTegz?
- SKUNK2 pro coilovers? ANY GOOD?
- p 72 p72 ecu codes looking for a complete list
- Ls/ Vtec Baby
- air conditioniong compressors
- T1R Power 70 Exhaust System
- Brake work problem/question...! HELP!
- seats height problem...need info
- JRSC on my 91 Integra?
- Steering Column Clock wise
- STALL
- Im new so whats the deal here in HT
- which is faster
- Testing ABS yourself
- motor mounts
- car shakes
- anyone w/b16 heads on b18c1
- need help on a good shop
- Stock wing
- do regular integra's have this?
- AHHHHHHHHHH F'in Alarm driving me crazy.
- Broken turn signals
- Question about cost of headlamp
- Calling all 92-93 Integra's with a GSR or ITR swap
- Right Hand Drive Integra?
- LS/VTEC need help
- Taking off VSS ?
- any way to start car with out tranny?
- transmission problem? a few month ago my tranny just started shirting at around 4500
- RHD Conversion
- Window Visor Japanese installation instructions
- Compression Test #'s
- question for the jdm front guys!
- Setup
- new build car wont start
- 91 ls motor and 95
- Problems with password and username had to re register can anyone help
- Anybody near Pittsburgh,Pa
- Starter Replacement
- password: jdm 4-point rear...wtf is going on
- Some Asst Honda / Acura Parts for sale.....
- Hlp: Turbo Timer install
- skunk2 manifold 2nd coolant plugging
- JDM engines?? MPG
- da
- Check Engine
- 90 Integra Transmission Breakage
- oil pressure sending unit
- 6 Spd. transmission?
- suspension knocking noise?
- Euro ITR steering wheel
- Spark Plugs?
- Is the B18B non-interference?
- DA bumpers?
- Mobil 10w-30 into a Y80 LS tranny?
- dropping my 97 teg, how far should i go?
- 91 integra Tanny 5speed
- help me
- Seat belt problem
- skunks 2 control arm vs ingall ball joint
- 97 integra, light mods: revs a bit higher than normal when crusing in D
- What do I need to convert to obd1
- Has anyone used those radiator pellet things to stop a leak?
- skunk2 stage 1 cams for gsr.. stock manifold or skunk2 single runner??
- need 98+ headlights
- DA fitted seats in DC
- spoon sports header...
- motorvacum problems mannn!!!
- suggestions on cats. i would like to take out my cat an straight pipe it good or bad???
- which cam gears?
- Need Help from JDM Front guys!
- suspension advice....
- Might have a leak?
- How long of a test pipe?
- Car bogging in a left turn
- new here...
- ''PARTS FOR A 91 INTEGRA''
- Is it just me, or do passengers slam DC doors a lot?
- 2000 ls teg
- Where to start
- price for a 96 integra
- Exhaust Leak???
- Why did my car idle higher and seem faster when i had...
- NEW to HT heres some pics of my dc2
- 5-speed swap
- Help shaving car.
- '94-'01 teg suspension question
- Hard Starts...
- what is ECU chip do?
- Bought wrong cluster. the sir g
- need parts website
- Need help modifying Distributor Cap for Jacobs ICE Ignition - 90 DA
- is bleeding all four brakes neccessary?
- Gas Mileage For OBD1
- teaser...1 frontend shot
- Is the 98+ Integra oem lip kit still available
- ---Beyond Thunderdome---Teaser Shots of my D-series powered DA...
- super mesh rim
- Fitment Question about test pipes for DA models ??
- Da Side Marker location
- Wheel bearing? brakes? or what?
- car SMOKEING
- 91 4 door and 92 2 door rad support the same?
- Crusing RPM
- Websites Legit?
- 1st Gen Integra Questions -- Transmission interchange, cranks
- tires
- vtech or rebuild
- DA nightmare Part II
- OBD1 to OBD2
- car bogging
- ? about cam gears
- Can you legally smog a b18c engine in a 91 integra ls?
- vss leak, hoe do i fix?
- battery relocation problem
- question on going wingless
