View Full Version : Acura Integra
- Whats the best way to remove the shifter linkage spring pin(split pin)?????????
- oil pan bolt
- lsv or ls
- wont start think it has something to do with my distributor?
- Troubleshooting Misfire???
- si- vtec fogs
- Car painters and people with car painting experience.
- Weird Voltage while driving
- DA exhaust suggestions
- where is main relay locate in?
- Best replica OEM Type R front lip?
- tach. - which wire?
- Too good to be true??
- Question about a trade... Type R's for Buddy Club's
- Which car to buy?
- MY TEGGY WONT START!!! DISTRIBUTOR??? HELP PLEASE...
- OBX Twin loop
- 2000 gsr compression test... anyone
- 92 GSR F/s
- missing brake line on master cylinder
- Question About Injen Intake Fitment
- lightspeed dropsprings
- Looking For Vehicles To Feature In Online Magazine
- ((((FUSE DIAGRAM ))))
- hould stock head or ls
- Axle removal instructions.
- Starting troubles------1999 GSR turbo
- B17
- Help me ID this head.
- How to fix CODE 71 72
- gsr turbo
- B18b1 obd1 or b18b1 obd2 head gasket?
- LS/VTEC vs. GS-R
- gsr turbo build
- Bad Engine Block ??
- b18b stock rods
- b18a1 block with a b18b head...(HELP!!)
- Car troubles
- WOT % problem
- Turbo Or Supercharger??
- Junkyard motor an trans, what to look for?
- where can I get the main relay for 98teg GS2dr?
- part number?
- Any ls integras (da or dc) in the 14s?
- Need help, overheating!
- Lip & Sides identification
- b18a1 engine
- How many are tired of hearing this similiar post?
- Please someone help!!!!!!!!!!!!!!!!!!!!
- Sunroof....99 integra
- ITR rear calipers
- where to buy rota rim(only need 2)
- Having a problem with the starter, help me....lol
- polling for engines swap...
- EK and Integra rear motor mounts.
- DIY Link
- Sticky outer door handels*searched*
- Anyone know where to get a 94-01 Tegra bumper?
- After market itr parts
- DA clutch bleeder?
- how to install rear coil-overs
- do jdm engines have carfaxable vin numbers?
- Anyone have pics of an USDM ITR lip bought from an HT sponsor ?
- B20 Bottom End -> LS Head -> Turboed???
- What size / kind / type are SiR-G headlights?
- axle on or off?
- timing issues, need help!!!!
- abs accumulator pump
- Where to get IM gasket?
- 93 teggy seat rails?
- WTB: Azect SideSkirts for 98+ Integra 4 door
- no compression in all cyl. HELP!
- 90 tegy help
- OEM 2.25" truck muffler on a full exhaust setup...interesting results
- tein s springs
- Type R oil pump?
- gsr tranny leak
- GSR Intermediate Shaft / Half Shaft used in H22A ?
- Stolen Integra
- Shifting from 1st to 2nd
- Timing Belt Question
- Spacers for HX's?
- way to test functionality of a solenoid?
- 90-93 Pillar Triple Gauge Holder?
- Turn signal lights ratteling???
- HELP!!!
- Comptech ITR lip
- i need motor mounts ASAP
- Spindle Question.
- Cat length of USDM header with JDM exhaust.
- Header/Cat/Exhaust Fitment
- how to install suspension technique sway/tie bar combo?
- On a hondata s200, where do i conect the interface box to the ecu and what colors go where?
- Integra OEM parts.
- How much tranny oil do i put in?
- Got the Teg tuned!
- Which rims look better on DC2 Gsr Blades or SI rims
- Loose battery terminal connectors - can I replace them?
- B20 and B18 valve same size?
- header way close to the ground!
- ABS HELP!!!!
- HELP!?!? Installed DC Leather In a DA now the BEEP FROM HELL!!!!
- confused.........
- Dirty Intake Manifold
- smoke from my headers?
- QUESTION PLEASE HELP!!
- wire tuck
- PLEASE HELP!! QUESTION: STAGE 2 AXLES
- 85mm pistons
- 97 gsr airbag
- How To: Integra aftermarket steering wheel with functional horn
- b18a1 conversion
- my enigne after being replaced after parts stolen
- valve lash adjustment
- all motor b16
- my 92 gsr doesnt start?
- Suspension and Wheel set up
- searched cant find an answer
- emission question
- engine diagram
- my car is making a weird noise
- Next gen integra???
- velocity stack on comptech icebox
- weird idle problem
- are both gen. 3 4dr and 3dr midpipes the same length?
- my 92' teggy gsr
- DA One Piece Headlight question...anyone have these black ones? (Searched)
- oh great..
- JDM ITR HID install
- What year purge control solenoid and model is this? *PIC* HELP please
- 98 Integra GSR MODS
- new to HT guy w a da
- Car won't go in gear
- need help with an ecu
- HI IM NEW TO HT
- JDM Headlight Foglight question.
- DC2 removing power steering
- Integra LS SE info
- wont start after head gasket replacement
- recommend me some brake pads
- Cruise control doesn't work. Need help
- Please help me identify this sound.
- water leak
- Headlight collects water, and is REALLY nasty inside
- how to cover pcv hole on 97+ integra valve covers???
- 100W H3s
- DIY: Shaved license plate holes
- 94 b20 vtec TURBO, help!!!!!!!!!!!!
- cam question
- LSVTEC running rich.
- cleaning inside of your headlight
- need helpppp 96 ls
- Integra wouldn't start!!
- axle question
- Help valve cover broke broken in half
- acura integra '94 RS starting problems
- Rubber Window Track
- Hondata ????
- Roof Rack question...?
- >>>>>HELLO from MONTREAL CANADA....<<<<<<
- Do I need this valve for the line on IM vaccum to the PCV?
- Looking For Welding Shop
- Power Steering Removal
- e-break light
- Removing/installing rear motor mount
- header differences
- soft clutch pedal
- rear valence fit
- k20
- ecu pin out
- will a 98 gsr muffler fit in a 00 gsr?
- NEW TO THE AREA...ALEXANDRIA,VA/DC ANYONE HERE
- j's racing exhaust
- Towing Capacity of a DA
- Down pipe for T3 gsr
- Setting the Idle
- header trade?
- 95 gsr vs ef civic w/b16?
- Ticking in my engine!
- resurface flywheel or no? flywheel looks great
- Airbag? obd2a/ ob2b?
- pic rqst -red integra w/ jdm front and on work s1 wheels
- Rack Guide Adjustment
- city lgihts
- Can I loop the pvc box lines?
- weight reduction
- Can you run an integra without its charcoal canister
- Will a skunk2 pro series intake manifold fit in my 94 integra with a h22a1 engine swap
- how to paint rims
- WESWES NEW usERR....HAleRRR FOR a dOLLeRRR
- check out my intake
- another new guy
- What gauge cluster is this?
- 1990 DA Fog Light install?
- Question about installing motor torque mounts (ES Inserts)
- g3 front bumper(dumb question)
- abs??
- your 2 cents
- b20vtech E-MAIL ME MAN!!!! B20B B20Z
- ROAD TRIP PREPARE
- where do i put oil in my lsd
- flashing oil light 92gsr
- J's Racing carbon fiber intake compatible with strut bars?
- ITR 5 lug conversion
- Can all the experts please help me???
- Steering Problems?????
- cam for my 91
- My new city lights and HID's
- LS timing belt cover on a GSR?
- I just got some mud flaps
- Anyone have any luck with Ebay headlights on the DC body style?
- WTF is wrong with my car?
- tire size?
- Changing Dash lights
- stock air box system for 93 integra
- Trying to locate and purchase a CDM ITR cluster
- Da shocks!!
- integra problems HELP
- How to Install a windshield on 96 Integra?
- RECARO or BRIDE
- da speed sensor cable
- CF Hood!!!Maintenance???
- idling whistle noise?
- 98+ OEM Foglights install
- hey guys im back.. alot better pics of the HIDizzals. nonretro fit*
- Need More Speed
- In Need of B18a1 and B18b1 torque specs!
- 87 shift rod ???
- fuel pressure gauge
- Engine back together, won't start, fouled plugs, oily smoke from TB.. Help?
- moving to Seattle
- 95 integra le special edition; throttle jammed/can't close
- RC injector install question
- Hood release problem
- can i put a h22 in a 92 integra
- Field SFC/Vtec w/ B.C. Spec IV cams & B.C. cam gears (p1) in da GSR.. How do I!?
- Single Cam in a GSR? Look Inside
- 99 integra Fuse panel diagram
- car in day time
- 1991 Acura Integra help!!
- ecu codes again, not fixed
- Integra excorcism? Door ajar emulation?
- ***BOLO*** STOLEN S2000 05 SILVER
- brake question
- Boiling Coolant? Need some help. (DA)
- Small weird problem
- Coolant smell but NO visible leaks, no idea where its coming from?
