View Full Version : Acura Integra
- P54 ECU - Difference between auto & m/t version?
- bad ect sensors?
- Spark plug ?
- Q: How to check from what state my Integra is from ?
- Need help with my 1990 acura integra rs
- 96 Acura integra takes a while to start
- 1991 Acura integera da9
- jdm b18b swap questions
- please help p0171,p0133 and p0170
- DC2 rear hatch wont shut right anymore
- OE Style catalytic converter (experienced opinions wanted)
- Hello and thanks for having me
- B20/VTEC D Mod Race car(1970 Fiat)
- My 2001 b20v project
- need some help with my 90 da9
- Help white smoke ! 1990 da9
- 1996 Acura Integra LS misfires on cylinder 1 and 3
- How to install LED Headlights?
- Jdm Obd2a b18c1 in obd1 dc2
- 2k TEg Random Misfire?
- No Spark after rebuild
- These used K-sports worth it or should I buy new?
- Does a 2001 acura integra ls have a fitv?
- 91 integra starting issues
- Help regarding engine harness plug
- need a new ac compressor which cars interchangeable?
- Help - Driver's window gets stuck in the upward position...
- Test fit new wheels=blown front struts?
- 2001 Acura Integra LS idle issue
- Removed spoiler and need a 3rd brake light
- Whats it worth? 1990 Integra LS
- B series sputtering
- 95 GSR B18C dizzy help
- Looking for active forum member to test/review new products
- Looking for A/C Harness Plug
- Can someone look at these before I purchase?(sort of long)
- car randomly locks
- Car won't start after sitting for 9 months
- LCA wont come out! Need SERIOUS help!
- Tires for 1991 Integra GS Hatchback
- Boosted GSR coolant issues
- 92 integra rs break problems please help
- Need help with what type of head gasket I may need plz...!!!
- Cold start problem HELP
- b18b oil leak. Will is pass smog in CA?
- Would like opinions on the value of my car.
- My first B18B. Any ideas on why it won't stay running?
- Trouble shooting a no start
- Help needed again, No start issue.
- removing sunroof
- Motor die after VTEC
- Real or fake?
- Hose routing for coolant, quick help please!
- Need help with my 93 Integra b18a
- Serious issue with 95 integra
- 01 Integra GSR Crankshaft Position Sensor
- Front caliper sticking
- Need help fast please
- 91 radius rod / strut rod aftermarket struggles
- 96 integra rough start up
- Da9 h2b help!
- 95 acura integra antenna
- Tail light assembly
- Exhaust swap question
- 91 integra jdm b16a help
- 1995 LS issues
- My 1996 GSR ongoing build thread
- Ghost's LS project
- DA 93 INTEGRA LS FAILED CA SMOG YEAH!
- Interior compatibility
- Need help with my 95 gsr
- Your Integra... if you would have to do it all over again
- B16 cable trans into 91 db1
- Wiring Help Offered
- 95 Acura Integra
- Stock 95 GS-R value?
- ITR ICM issue
- integra engine vibration
- Integra Type R Spoiler Fitment
- 2000 GSR MAP Sensor Reading Backwards
- GSR Heater controls Non A/C
- 94 integra LS sedan build
- High idle and backfire
- Does '00 Integra GS comes with remote?
- manual to auto
- Transmission issues?
- OBD2 LS/Vtec Help.
- ITR Replica Spoiler (those with experience please chime in)
- Where to find Harmonic Balancer?
- High idle problem (not surging)
- A/C Compressor Oil Leak Diagnosis
- Help VTEC pins arent locking
- D16a1 axles
- 1990 Integra GS ABS problem
- A little confused
- Help taking out axle nut
- Lsvtec sometimes starts. Sometimes shuts off at idle
- 3rd gen integra.. Car clicks but doesn't start
- 98 Integra Cruise Control not working
- Recaro Seats in dc2
- Fluid leaking from LS Manual Transmission Drain plug
- B20b,S1 Clutch
- CODE 16 !! PLEASE HELP 1996 INTEGRA GSR
- pcv rubber gromment part number?
- Prelude yellow fog capsules in DA JDM one-pieces?
- Milled B18C1/B20V Build Help
- Speedometer not working
- 95 GSR/B18C starting issue-need help!
- 94 RS not running fixed, possibly
- 1999 integra b20 into ef hatch
- Did a b18b1 swap and now fuel pressurizes but starter won't crank
- My 98 RS got totalled, swap drivetrain into...?
- My car beeps when I hit my brake!
- Cluster Issue
- Need help with a rattling sound
- Startup Delay
- How to reset driver side auto window
- under dash wire harness replacement, da/db obd1
- Keep binding my axles. Unsure why
- code 43 need a little help!
- Where to get/install seat belts for 1990 integra?
- What Sensors/Ignition Components Need to be Changed for AEM EMS?
- My 1998 VTi-R (GSR) pics and engine build questions
- 1997 Integra RS electrical problem
- CG Transmission Rebuild Questions
- Mishimoto Dual Fans and Shroud
- My '91 Teg won't start...have done research
- 99B16a2 into a 95 gsr
- pls help 1996 honda civic with a gsr motor tried everything and still runs horribly.
- O2 sensor missing?
- Need measurement for Spare wheel tub
- DA B18A1 coolant bleeding screw?
- English Racing's 187MPH..1000HP DC2
- A few issues maybe the community could help with.
- Screeching noise from driver side after shifting
- 5 Lug question
- Issue with new-to-me car
- 91 DA hatch plastic flange behind bumper
- Alternator installation issues
- OBD1 Code 14 Car been down for months need to work please!
- DA B18A1 thermostat housing sealant?
- HELP good spot to tap b18b1 Valve cover?
- Where are the mugen guys at?
- 2001 Integra gsr head gasket bore 81mm vs 81.5
- Fire wall plugs
- FIXED uncommon problem '91 Integra LS - crank but no start
- Integra intermediate shaft
- Speedometer doesn't work
- Driver side mount bolt size
- Looking to build a DA Integra
- 98 integra. Clicking noise
- 92 integra GS turns over, no spark
- How to value/sell a 1995 GSR
- 94 Integra starts but starter sparks little fire
- 97 integra /mechanical advice
- 96' integra 1.8L cranking but will not start
- Will a B20 swap pass smog
- 97 integra GS
- obd1 or 2?
- Just Score A 92 Integra GS-R What Should I DO?
- Transmission Noises
- No start
- 95 GSR Timing help
- Ipg parts reviews?
- 5 speed swap speedometer help
- Volk LE37 value (used)
- 95' integra gsr wont start
- Water spraying out of motor?
- Question about ignition coil
- 97 integra b20 swapped cooling problem
- 1991 acura integra wiring diagram
- AC help 92 Acura Integra.
- 1997 Integra misfire loss of power issues
- b20 Swap
- What to look for when buying
- Acura integra wont START but cranks slightly
- Need pinout for dash harness connectors
- First Integra Build
- My 1997 rs Integra green just got hit
- Help with engine "hesitation"
- 92 integra 3dr auto front pipe bosal 740-723 discontinued
- 97 Integra rs 5mt 40/40 valve help
- Help with ABS Code 1-8
- Need help with really worn and stripped 23mm 12 point bolts on flywheel
- GSR swapped into a '73 mini cooper....NEED ELECTRICAL HELP
- Best in-car antenna?
- Got a 95 GSR sedan in need of new tires
- honda dc1
- HELP! 1996 honda civic running bad when warmed up please help
- Re-doing the spare tire compartment. What gauge metal should I use?
- skunk2 pro+1 camshaft degree help!!!!!
- Weird popping problem in front end Not CV joints
- B18b1 Pcv valve problem
- ECU/Short Problem
- Trying to pull an oil cooler return hose from a junker
- Type r sway bar issue
- 92 Integra Ignition Problem
- Ecu options for a 1993 DA with a B18a1 (manual)
- 1991 Acura integra Cable clutch issues
- fresh LSV build wont start!
- Help with diff problem!!!!
- Skunk2 Pro Series Intake Manifold and Throttle Body
- Perfomance Fuel Pump On Stock Engine?
- Ecu ls/vtec automatic?
- Turbo Integra overheating?
- Car lagging
- DC2 RPM stopped working but ECU sees RPM
- getting a junkyard motor NEED ADVICE
- DA A/C Wiring Diagram
- fuel pump not priming......moisture in ECU??
- '98 GSR trouble starting, I've replaced battery and main relay--Video
- Best racing setup for ecu
- revd high and now doesn't start.
- drivers window issue
- Pulling the cams.
- Anyone on here have a PWJDM radiator??
- Which VTEC part do I need?
- 98 teg with 01 teg b18b1 everything
- P1259 with engine off
- Helicoil / TimeSert Quetion
- Project KillRTeg unveiled
- (Sedan/DB) Will a non-2001 front door windows fit in a 2001?
- 94 sedan At -Mt ????
- integra 94 4 door problem transmission shift at-mt
- jdm P30 ECU into my 1998 integra RS
- Papa needs a new clutch
- Another DB7 Build thread... slow...
- Integra head
- Help Identifying Integra mudflaps
- Teggy?
- Internal engine oil leak? jdm gsr
- HELP! NO SPARK NO FUEL!!!
- JDM Integra good cable issues
- Help, dropped valve in cynlinder 2 when changing valve seals
- 92 Integra AC compressor clutch relay
- Cams for B18c1
- Seat belt problem
- Ls/v in automatic
- Intermittant misfire and valve tap episode
- B20 integra help me please
- Timing not lined up to TDC mark?
- Help! b18b1 civic blowing smoke/won't rev past 4.5k
- My baby needs your help. 96 LS
- My Integra sent me to the ER
- 1997 skunk2 intake manifold and TB installation
- Identify my b18c?
- 99 Teg Dome Light Issue
- High beam wiring for JDM conversion
- DIY: Trunk Electronic Motor Replacement
