View Full Version : Acura Integra
- engine management parts
- B18C1 obd2/1 differences
- I am new and looking for some advice
- map sensor problems!!
- Clutch Master Cylinder wont drain
- J1 transmission
- re-tuned with hondata200 - boost
- bleeder valve
- skunk2 manifold
- 90k tune up
- b18c1 and b18b waterpumps
- Parts Price
- Ignition Problem
- buying 99 gsr...what you think this price
- Bouncy / Jearky clutch engagement and / or throttle
- S15 1 Pieces
- fuel pump on stock car?
- STOLEN INTEGRA 7/22/2005 IN THE SUN VALLEY/NORTH HOLLYWOOD AREA(SO CAL)
- 1990 LS Check Engine and S3 Blinking car will not start... Help Please
- I need advice and tips. Here are all the upgrades I'm going to do, and I need to know if they're ok
- carsound catalytic converter
- What year should I get?
- tranny problem
- what is the difference on gsr seats?
- 90 Integra Gs..the beginning
- o2 plug/wire problem!
- Hey Guys new here from Gulf Shores, Alabama
- NJ/NY/DE/PA Integra Meet 7/31/05 (yes i know this is not necessarily posted in the correct forum)
- Little amateur bondo work...
- 91 teg, clutch pedal hit the floor!!???
- Turn signal lights help!!!
- PIC REQUEST: integra DA w/ blades, fat 5's, Si's or rota's!!!!
- Getting DMH exhaust cutout... should i go 3" or 2.5"? setup inside, TIA!
- TOKICO HP??
- valve adjustment tool.
- Check engine light question? Yes I read the faq! Where is teh conector at? above the ecu?
- purchasing autos online.....is it safe? Need suggestions...
- HOw to test ICM????
- HEAD SWAP
- Recaro Speed Seats
- Quick OBDII Integra Question
- my radio doesnt work when i turn on my lights
- who owns the red hatchback in nova... thats a girl
- how low do black widow side skirts hang??
- fixin the speedo needle
- wat kind of skirt is this??
- Tranny problem. sy1 non LSD
- car is bogging/studdering after...
- LS was jacked at school yesterday
- HELP: need to remove a few things from a GSR
- Insurance cost on GSR
- Clutch which one...exedy or cc??
- did a charging system test today
- F/S 1998 gsr cw white,jdm front,5 lug,12pt roll cage
- need 1gen Integra website asap
- hondata s300?
- Limits of Synchromesh
- Noob Need Help!!!Electrical...wires......
- About to swap engines in an LS...
- cant get my b18 to run
- jasma
- del sol seats on DA integ
- ADVICE NEEDED
- anyone know...
- Vibration during acceleration, diff bearing is shot.
- o2 sensor??!?
- 00 GSR Cluster in 95 LS Teg
- axelback for a DA
- Keep my teg Alive!
- Good spark plugs for an NA 95 SE?
- GAUGE CLUSTER?
- OEM Optional Sideskirts
- grinding scraping noise "after" braking hard
- uberdata or crome info?
- ac line busted
- getting a new muffler with piping.
- exhaust sound
- Double-Clutching?
- itr conversion $$$
- H&R sport springs and alignment ???
- Are the 88-91 Si and HF harness the same as obdo 90 integra?.
- I have a 91 B18a that's OBD1. Does it have 92-93 cams?
- Catz HID bulbs WHERE TO FIND THEM?
- exhaust questions
- 90 acura integra under drive pulley alternator pulley
- skunk2coilovers
- Damaged rear spindle - replace?
- clutch break-in
- Starting problem... plz help
- Toda B's strike again: My SECOND shreaded Timing Belt...
- DA trailing arms... 4 door -- 2 door... same ?
- performance problems
- way to go thieves.
- Any boosted B20 owners ..how much boost you running and hows ih hold up?
- moroso oil pan question
- got my first car 96 GSR
- AC button switch-- Where to buy one for a 96
- special edition (power locks) doors on an LS (no power locks)??
- Newbie here, with car problems...88 integra.
- Price question
- shift linkage removal
- seized rear brake
- chassis stifness
- Car wont start. Help !!!!!!!
- can a 4 door dash fit in a 2 door?
- b20/vtec question
- difference in exhausts
- integra seats
- B18A1 valve cover on B18B1
- Do you need to unhook the IACV when setting TPS? (b18c)
- hi honda tech people
- difference between the gsr rod bearings and ls rod bearings
- slim fan install help
- ignition switch?
- What is the best header for me???
- Selling a 92GSR in the near future.
- Integras that went 5lug, how did your braking feel? did you change your Master Cylinder?
- help i have a tranny problem....please help
- Went to the track last nite!!
- What Does Rebuild The Engine Include?
- new style radiator
- Clutch problems maybe???? HELP!!!!!!!!!!!!!
- Is there a way to connect a 2.5” Header collector to a stock CAT?
- Car puttered then died....
- BLOX intake mani carb legal?
- Does anyone offer pig tails/plug and play harness's for JDM HID balasts?
- crank pulley
- Steering or front suspension problem
- should be an easy question for u guys
- Just wondering
- THEY JACKED MY GT3'S!!!!!!!!!!!
- Got my first car-- 99 Integra LS
- Paint Code
- my ls_v setup
- Stock radiator on a integra gsr...?
- need help with radiator and water pump
- This just came out like two days ago... idk if anyone say it
- LOOK!!!! finally got pics up of my DA, tell me what you think guys!!!
- Brake Job
- Anyone make a side and top post battery that fits 98 teg?
- Having Problems with my DA
- New to Honda Tech
- brake caliper bracket interchange?
- how important is it to upgrade the retainers ?
- battery reloaction quick ? <<SEARCHED>>
- motor mount vibration
- How do I improve clutch engagement?
- I have a question about stock retainers.
- can someone check this picture of a head gasket and tell me if it look good or blown.
- cam gears
- is it the abs???
- had to post this fool
- hondata ? need info
- 92 gsr chipped?
- Ground Control w/ Tokico Illumina
- 01 gsr 4 door header same length as JDM ITR 2.5?
- another prob with the integra...
- LS Pistons In a B16A1 for turbo application
- need help replacing timing belt for 93 teg ls
- fuel cutoff question yeah ive done tons of searching just a stupid question
- Axle snap/lower armbar bent help,prices to fix??
- center cap ?
- INTEGRAS ARE #1 !!!!!!
- WTT: 2nd gen integra *Bay Area*
- Just did compression test
- how to become a da squad member
- fiber glass
- why is vtec louder???
- no power
- front bumper question
- which duplicolor = taffeta white
- prelude rims
- Radiator fitcheck for GSR w/ JDM 4-1 header
- Front bumper & head light
- charging system going bad?
- brake pedal is very loose. goes all the way to the ground after stepping on it for a while
- Cant test battery while running..HELP very confusing!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- question on cam question??
- I never got to share my car here :*(... 56k beware (long story)
- CEL 43 on '91 integra
- BRIDE Zeta II what rails will fit other than Bride (FO type) ? ? ? pls help
- Help fixing rust.
- 4x100 or 4x114??
- What do I need to put on new cat-back?
- valve clearance specs.
- CAN ANY ONE IN HERE TELL ME WHAT BULBS ARE IN THE A/C CONTROLS
- whats a better header 4-2-1 or 4-1
- anyone! please post pics: integra DA 2 door w/ any rota's!!!!!!
- rebuilding a b18a1
- need help guys. sy1 tranny dismantle
- usdm type r seats.
- going to look at a gsr tonite... any tips on what to look for?
- flywheel/clutch question
- Stock GSR shift knob
- rocker arm questions.....91' acura integra......valve clearance
- Integra woes....
- Wheel Hop
- pic request : integra 4dr jdm raingaurds
- where to buy used itr suspension?
- CEL with my B18 non vtec integra
- stock b16 bore size?
- custom exhaust
- Requesting pics of a 2000 GSR sedan on Sprint springs and other springs as well
- 02 sensor
- Most stollen car in 2004 = 1999 Acura Integra...
- New Exhaust and New Lip
- Shift solenoid
- Looping power steering line
- Will stock GSR TB fit AEBS IM?
- WHAT ELSE WILL I NEED TO COMPLETE A TURBO SET UP FOR MY GSR
- Whats lighter?
- turbo gsr
- 1996 Integra SIRG Guage Cluster Question ??
- Help
- Acura Integra tops most stolen list!!
- JDM Front
- JDM MUSTANG
- All motor or forced induction 1995 GS-R
- overheating...need help!!
- Almost ready to dyno - check my mod plan for holes
- DA JDM corner light question
- Which Honda Timing Belt Fits?
- 68mm throttle body
- CAR not starting...LOOK HERE and Help if you can. TIA
- what??? ecu????
- Rear wheel bearing owning me
- could i have a aftermarket clutch?
- LS VTECH
- nissan murano HIDs in a GSR?
- What are the 3 block sensors on the back of a B16 first gen
- Timing Belt Problem....
- headlights
- Randomly INSANE good gas mi, but lean:(
- looking for someone with valve adjustment experiance.........on 91' integra
- looking for link for online service manual for 91' acura integra
- My 92 DA wont start! Help PLEASE!!!! I changed the starter and nothing!!! HELP
- integra with 16
- How does a uca mount to a 99 gsr chassis
- Type-R LSD?
- time to boost the Ls
- Why you dont let your friends drive your car. :Help:
- What's the deal with FMIC?
- Getting behind the firewall
- power steering removal
- Did a compression test on the GSR today
- is ELD in fuse box on '92 DA GS-Rs?????
- Endyn Roller Wave pistons
- Need help finding fenders for JDM front end Integ (CF or metal fenders only)
- Tanabe USA is looking for a so cal Integra ( DA )
- fuel pressure problem
