View Full Version : Acura Integra
- which axxis brake pads?
- exhaust options
- common hand tools
- ECU model list wanted
- oil leaking?
- Just installed my short ram...
- Buying Stock Brake Pads and Rotors
- looking to build a B17 turbo
- I already bought this font lip, and im wondering....
- wat short ram intake is the best?
- What Short Ram Intake Should I Get and Why?
- Tranny ?
- 93 INTEGRA GSR HEADER
- how long are these trial memberships?
- ceramic or SS headers which is best..
- 3 bar map sensors?
- Bogging and Stalling
- Thru a rod
- request :: anyone got a dc2 on some rota grids
- HELP!! My engine Blew
- pressure plate replacement
- What color to paint?
- Cleaning of A/C on Integra
- Greddy Turbo in Swapped 90 LS
- skunk 2 coilover help
- exhaust opinions
- Hubs for teg? Help!
- change to maunal
- HELP!!!!! lighting problem
- Bad CV joints or wheel bearings?
- Jackson Racing Map Controller need info??
- popping from the air box
- volk te37 on teg
- Cutting valve cover?
- valve adjustment specs on skunk2 stage 2 cams?
- Hood Pin ???'s
- where Tha Rs integs at??
- Removing the sunroof off of an Integra.
- GSR Paint Choice
- Z10 traction bar and supension install..getting ready for new motor..Latest upgrades!!!
- Tein S tech Springs stock shocks will they blow?
- My 91 Teg
- slight ticking after valve adjustment
- up and down, up and down idle problem.....
- obd2b to obd1 problem, need help!
- How good is this kit?
- question when checking timing with timing gun......
- torque steer?
- mugen thermostat/ fan switch + koyo radiator. anyone running this set up?
- 4x100 hub and bearing / 4x113.4 hub interchangability USDM parts
- CEL 22, dead battery?
- ACCELERATION VIBRATION
- CEL 8. how to fix???
- High Idle problem after head gasket replaced....please help! :-)
- integra fuel injector and ecu question
- Fujitsubo exhaust question
- Ignition Coil Test
- LS TURBO
- Did a compression test on my 90 LS today. I have just a few questions.
- gsr paint
- turbo ls
- Failed smog...some advice on what I need to check/replace?
- New Parts, Awesome Photography!
- gsr tranny hard to shift on 1st,2nd gear....
- How to pull stereo out?
- mugen front bumper
- where can i find lower torque mounts besides jimfabs
- vtec problem with new computer
- GSR Fuse box digram anyone? would be appreciated....i did search. got red x's
- JDM ITR 4-1 header with 2.5 collector VS DC 4-1 header ?
- Overheating Issues help!?!
- shaving rear lip
- check engine light/knock sensor
- can i use eagle rods with ctr pistons??
- 2000 CRV Radiator fit on 94+ integra?
- Stolen and found
- Get a free GReddy Exhaust (new list of cars)
- skunk2 throttle body on DA
- State ref smog
- should i turbo or ls/vtec
- bfg drag radials
- ECU Code
- walbro fuel pump
- smoke when i hit vtec.
- White Smoke Question
- MAINTANENCE REQUIRED??????????????
- foglights
- apexi gt spec exhaust
- vibrant exhaust?
- LS throttle body gasket on GSR manifold
- Need a new starter?
- Rear Left Tire Humming?? Know Why???
- Im Overheating
- resistor box wiring
- WTF?!?! Gas pedal broke??
- Exhaust Upgrades vs. Suspension Upgrades
- Temperature Gauge Issues
- [Pittsburgh,PA] Parting out 92 DA GS
- anyone run jimfab torque mounts on thir integra
- best dc headers fo gs
- 92 GSR ?
- Rate: JDMshit header
- intake mani help
- starting problem
- Red LEDs in Taillamps. Do yours work in direct daylight?
- DA lips? which one?
- FS: Right Hand Drive DC2 center shift boot console!!!asking $40
- FS:DC2 HIDs retrofits 10000K.
- Civic SI cd player 99-00 in a 96 integra. Wireing help
- CF lip for 90-91 DA integra......
- H22A Integra? ANyone done it? Ups and down? Any pics???
- 00 civic SI cluster fit 94 LS ???
- Water coming in from A/C.....
- banging gears
- Most stock looking adjustable fuel pressure regulator
- LS B18B1 Cam Gear
- 4 door cat back will 2 door fit if so with what modifications?
- idle problem when ac is on
- brake pros please help me out!
- Need Advice: Removing Dent
- ATTENTION ALL DC2'S....Please post pics of your Tein S Tech drop....
- Where does this come from?
- Help Please
- cruise control removal
- Changing Cam Gears...
- Any good Daily Driver Springs to go with Koni Sport?
- Motor Swap into 92 DA.....What do I need??
- jdm front??
- JDM GSR Specs?
- OBD 1 vtec/ wiring diagram
- my vents smell like piss/mold!!!!! WTF?!?!!?!?
- nitrous or turbo on stock ls
- Can someone run a CARFAX
- oil pumps, interchangable?
- 94 Teg- Shifting to reverse causes a big "jump".
- Question on USDM ITR Header....
- Car won't start. Just makes a click noise, and good voltage w/ battery
- Would eg rotors fit on a da6?
- I drive alot on the highway and my gsrs ride sucks after an hour what do i do?
- Any bolt on Cat-backs for Turbo??
- 89 teg-the sway bar is rubbing against the driveshaft!!!
- Is My Fuel Pump Out?
- Lowering
- did a timming belt and h20 pump change and now losing oil........
- repairing DA JDM one piece headlight
- b16DA pops at a steady rpm?? WTF
- exhaust sytem install??
- B20 Intake Manifold on LS Head????
- obd2 or what?
- Vibrant Header Install
- obd2 intake manifold on a obd1 head
- front passenger ball joint on gsr
- Got my turbo kit n flywheel !
- skunk2 coilover
- abs light on mild brake jiggle
- how can i put a hydro tranny into a DA?
- tranny info
- Filter Question
- only two cylinders are working in my 92 integra LS
- If you are sporting ROTA WHEELS post pics here...waiting on mine...looking for pics..
- Leaking Distributor O-ring?
- Stolen and stripped....don't let this happen to you!
- i need some help here plz
- how much you think my 2000 gsr shell is worth?
- crane cam review for LS ?
- 95 integra gsr start problem
- i need a good camber kit for 90 integra
- Is this OEM?
- valve adjustiment questions.....
- Can a ITR intake manifold work on a 98 B18C1
- Help:Weird Brake Problem with Integra
- Burning Rubber Smell?
- cruise control button
- 1996 Acura 4door..front bumper body kit conversion question......
- cable LS have short gears than hydro LS tranny?
- to drain fuel??
- 96 spec itr suspension on a DA?
- LS vetch question
- European Taillights
- 98 Integra conversion question
- need help with engine harness for obd1 gsr
- GSR clutch question...
- GSR and i have no low end power
- dyno'ed the ls today.....
- A clutch problem w/ staging at the line which way do need to adjust it?
- best place to find gsr shortblock
- condensor fan keeps blowing the fuse!
- 1/4 miles for 92-93 Integra GSR's
- stock p28 into stock gsr
- My bby
- I screwed up big time: NEED HELP!!!
- performance parts
- Worn out alternator?
- pr4 ecu-p75 ecu
- car won't rev over 6500 rpm n no vtec? help
- Question about maintenance for a loooong drive
- Price for stock rebuild on B18B?
- 90-93 Integra Rotors
- wiring diagram for obd 0 pr4 ecu
- code 6 on a DA HELP
- Parking Brake
- Good Brake Setup?
- DA vs DC
- Tranny Cooler
- questions about skunk2 IM + hondata IM gasket for a GSR
- Quick Question
- No Cooling Fan = Overheating????
- keep getting CEL code p 0420.....HELP!!!
- Tranny Ques.?
- stuid questions but i was wondering about cylinder order...........
- 10 newton meters sounds like a small amount for cam cover bolts
- Pimp my ride - 4dr 95 GSR
- F/S Link to my 94 DC2 GSR
- CR-VTEC in a 94 integra!!!
- Need help!
- da check engine light (code 6)
- :(....death to gsr
- GSR tranny on LS worthit
- Intergra Number one again .......
- integra front bumper
- neeed help with fuel pressure
- 95 Integra GSR, which test pipe length?
- Bye bye Gs-R...=(
- searched. Q about dizzy conversion obdII to obdI
- Turbo'd Teg w/ No room for A/C lines. Help!
- Gsr question (random)
- Finally Got my Car Back
- Interested in buying a DA
- bad news bears: headgasket problem
- stripped screws
- OBX Racing header
- white smoke on muffler
- How much will stock exhaust hurt this setup?
- i search but no luck, help with wire
- car shut off while making a turn
- Rear strut question
- Fluidyne Fan Install
- does cam gears & shafts make a difference?
- >>>Finally got my OEM kit on 2001 NHB GSR INSIDE<<<<
- help, power steering on 95 dc2 leaks real bad!!!
- help, power steering on dc2 leaks real bad!!!
- Integra Brake Line Lengths (SS and Stock)
- The best Upgrade i've done in awhile lol!!!
- 92 Integra... is it worth $6000???
- Full valvetrain safe revlimit??
- Bleeding brakes in 94 Teg???
- Turbo'd Teg, No room for A/C???
- obd2 to obd1 conversion question... searched
- integra idle/map probs
- Monza Pacesetter exhaust ?
