View Full Version : Acura Integra
- JDM Fog Light Wiring Problem!
- help da9 products
- O2 sensor interchange... what Honda part #
- ls tranny shift at high rpm
- gsr to type r tranny worth it??????
- motor swaps
- LOOKING FOR LS TRANNY & AXLES
- 91 integra idle fluctuations!!
- LS to a GSR, really worth it?
- clutch willl not engage to put it gear
- K&N RU-2820 or RU-3130 for stock airbox?
- code P505
- Question on JDM DC Sports header w/ 2.6" Collector...
- b16 swaped; no brackets for the clutch cable on the VC!
- MIL????
- passenger side mirror moves horizontally but not vertically
- Over Oiled
- *HELP* OIL IN SPARK PLUG AREA~!!
- grease on header?
- Can you tune Skunk2 or any other cams with a VAFC????
- Out of all the Integras--Which one is the best?(no Type R)
- STUCK CLUTCH PEDAL
- 5spd parts ?
- is it bad to rev a high mileage integ?
- anyone selling Tokico, AGX, Koni 90-93 ??
- b18a or b16?
- rewire or repin 99 tail lights?
- Running on 20w/50 oil in a Teg......Whats the worst???
- no vin on engine?
- JDM SIDEMARKERS
- Can I put Xenon Super White Bulbs In My Car
- integra brake caliper question
- hydro to cable possible?
- Fuse Box diagram for a 95 Teg...
- gsr timing belt
- This is why you don't let your car sit
- Cam Gear Advancement help.
- Best Site For USDM Type R Lip?
- JDm headlight conversion
- QUICK QUESTION: PLEASE HELP!!!
- weight of stock integra hood vs carbon fiber hood
- looking for advice from current integra owners.
- i finally got computer so now im here...finally
- kinda confused
- Integra GS-R vs LS/GS/whatever
- Easy Street....
- will uk jdm headlights fit a usdm car?
- Good cams to use with JRSC??
- question about type of integra
- Another Tranny Issue
- Team!!
- where to get front nose metal trim piece?
- keyless entry won't unlock but will lock when armed.
- ebay intake
- Type R spolier swapped on DC2 possible?
- which clutch to buy????
- trans swap ?
- 90-93 2.5" Exhaust
- QUICK FIX: Condensation in rear tail light..
- steering wheel hubs and spacers. need help!
- difference between 94 gsr oil pump and 01 gsr oil pump?
- shift light on cluster
- First time at the track.
- window roll up?
- What would you do? Help me pick
- Reputable store/shop to buy new axles and bearings? 94-01 LS non-ABS
- 2dr vs 4dr weight.
- My Turbo Integra Photoshoot! Orange Turbo GSR and Auto LS
- which exhaust header is better........4-2 or 4-2-1
- ECU Wiring Diagram
- Ebrake/Thumping/Pulling Problems
- PasswordJDM.com J's style
- weight of a stock GSR flywheel
- B18 series B20 series Question!
- Replace Timing Belt/Master Clutch Cylinder Leaking?
- Help, Check engine light !
- Golden eagle Main girdle
- Callin any DB owner. Just a quick confirmation needed.
- Have the fastest N/A LS??? Post your times here!
- whats up with all the smoke?
- B A N G!
- Megan Racing Cat-Back Exhaust
- Freak GSR Motor
- 2nd Bumper bulb???
- GSR Cam to valve clearance
- How much could i sell my teg for??
- VTEC engagement point advice
- 90 da auto
- anyone know any good places to smog in the san diego area?
- Weird Clutch?
- anyone have a extra valvecover grommet i could have?
- cant hear vtec any longer
- Valvetrain for Toda Spec Bs
- vtec head please help..
- What's the most gas you have put in at once?
- Parking lights not coming on and right turn signal blinking to fast, relay?
- Catback interchangability?
- will 96 gsrOBD2 TB with TPS and MAP work on 94 OBD1 ls motor
- Got an offer on used Crower Stage 1 App for $80, what you think
- Plate hole covers
- DA: Spec for pressing TA bushings in.
- Good springs with little bounce... searched & can't fiund straight answer
- ITR 5 Lug conversion prob. - takin off knuckle from axle
- 2001 gsr to 1994 gsr dashboard
- b16 xsi
- DynoJet Research............
- simple pr4 ecu question
- 98 front conversion on a 94 Integra
- plasti-guageing bearings With engine in car?
- how to adjust clutch pedal, and also some days car wont start
- vafc2 install G3 gsr HELP!!!!!
- Car won't start
- Temp. knob broken on 90 Teg climate control
- Energy bush for which part?
- 2nd cable on accelerater pedal??
- most common integra parts to have on hand?
- GSRstarter
- Dc2 k20
- LS question
- aftermarket gauges
- Short shifter problems after new exhaust install.
- shocks for 2.5", 3.0" inch drop
- Honda N1 CTR Pulley Belt Size for B18C
- Need Help: Back seat wont go down,lever broke;advice needed
- whats your fastest time with LS vtec and what did you have in it???
- 94 ls 160-175 whp goal
- :::::::::Advice on Exhaust pipe size 2.25inch vs 2.5inch::::::::
- what next?
- Teg Problem
- oil pressure?
- will type r injectors fit on my ls?
- gsr engine
- steering wheel shakes while in braking progess...?
- Code 43, running rich, I'm stumped... long post, sorry
- integra leather with the A emblem on the seat
- Monroe's?
- difference between the type r front end and other integras
- exhuast
- i need imediate help
- DA Rear Bumpers
- ls to gsr helpppppp!!!!!!!!
- Whining noise when shifting 2nd, 3rd, 4th or just accelerating????
- Ignition Problem
- AEM V1 intake
- 90 93 teg auto to 5 spd
- Looking for integra 98+ rear lights
- Suspension Problems. . .
- ARP main studs
- 98 LS Header, 95 GSR B Pipe, 98 LS Muffler - What cats work?
- DA6 RHD Clips
- DA squad.... lend me your opinions
- b16 in DA teg: VTEC aint working Help
- Overheating with sustained High RPM
- ls v-tec?
- BUmper GSR 94+ jdm
- Totaled my Teg
- civic type r pistons in ls vtec
- Fixed my problem another pops up...?!?! help techs..
- JDMsh!t 4-1 header question
- Cleaning Engine Question
- shot rack & pinion?
- installing starter lil help needed i did seach!! please help me out
- 09-93 integra headlights
- Beginner, wanna rebuild b16a
- Stolen Hondas/acuras
- wiring for evap purge control solenoid
- Questions on window/lexan in cf hatch for teg
- 91 LS spark plug gap size
- dash wont come off
- WTF!! I just spun my GSR like a RWD...
- IDLE thread...
- NEED Help
- I need to add a/c!!!!
- LS VTEC Problem
- 95 Integ LS/VTEC Turbo needs help....
- anyone running a side exit for the track?
- Integra GSR door side moldings
- another axle problem
- Mugen Mf10's what offset to choose +43mm or +50mm???
- Headers
- LS VTEC set ups
- are vtec speedometers different than non vtec speedometers?
- blox intake manifold question
- DA carbon fiber lip
- Picture request.
- Calling all upstate NY G3 owners!
- Help:Noise at 3500 in every gear
- Raced a stock lude the other day, taking a poll on next mod.
- b18a into what?
- Just bought 1998 GSR, what would you suggest I first upgrade?
- why is my car thumping?
- good tires for decent price?
- B16A B16A2
- b18c1 obd1 JDM into 89 integra.. SEARCHED... some questions!
- b18 vs k20
- integ and civic question
- 98 integra won't rev past 5k... sometimes
- how can you put on ITR lower tie bar on DC2 integra? is it possible? installing itr Truck Bar possib
- wheel hop?
- Del Sol Aux lights.
- 96 integra RS hatch (cig charger and radio not working)
- Speedometer Fluctuating?
- tokicos from a 91 integra work on a 97 civic?
- Mounting Half Rad..
- 2001 GSR sedan $12k
- need trans
- TEIN drop?
- Length of stock 98 GSR cat???
- is the ITR front sway bar the same as stock front sway bars on DC2's?
- WHO BIG DO I DRILL A HOLE 4 LS VTEC???
- is there anyway you can install a itr lower tie bar and trunk bar on a 94+ Ls integ?
- For Sale 90-93 Integra Wiring Harness, Alternator, Distributor, Head, Intake Manifold
- where could i get a gsr b18c1 short block
- Alligment
- JDM civic type r camshafts vs. USDM gsr camshafts???
- Motor Oil
- new to these forums
- New Quaker State Q Motor Oil....
- Crank pulley
- '98-'01 Body Conversion
- Alarm and Parking lights...
- Anyone have Apexi N1 soundclips?
- Anyone have a carfax account and want to make money?
- WTB: gsr block
- will s2k oil filter fit and work with my 91 LS???
- looking for a itr rear sway bar for sale ???
- Ok... is this fuel mileage and gallons right or is something wrong??
- question
- pretty sure the clutch went tonight
- Squealing Noise
- tight spot need help!!!
- WHAT to get, civic type r or integra type r lip for my teggy
- 90 Integra RS
- turbo Ls tech?
- How should I clean my air filter?
- Death to all Vandals!
- 90 LS integra - whats the weight of this car?
- newbie here
- Turn my motor off and a scrapping sound?
- :::::Need Advice About 5w-30 Motor Oil:::::
- ignition switch getting sticky, what to do?
- 4 door rear seats.
- whats the price
- blades on da?
- Oil in Spark plug Chambers???? and HID Retro question...
- LS engine build -up questions
- hp's gains ?????
- JDM ITR Bottle neck
- ls vtec wiring
- quarter panel glass got shot!
