View Full Version : Acura Integra
- Failed emission test.
- 94' integra costs 10000CAN , worth?
- abs box by front pass. headlight ticks at startup? good or bad?.....
- searched: checked the wiring and no ign. wire to the radio? how to make one?
- halos?
- G2 integra vacuum hose questions oc714
- vtec cuts off????
- tranny vin question
- I think you guys will like this...56k not so much.
- gsr stock flywheel???
- How do you identify ITR springs? What the diff between OEM ITR & LS/GS/GSR?
- Quick question about new battery!!!
- fuel rails
- lost key?
- help picking axle
- I have an Idle problem, Should there be a vacuum hose here?
- signal light problems
- Which Throttle Cable for Power Throttle Body?
- yes another tps question, searched already!
- Deal of the month, my $800 buy
- Few pictures of my H22 DC2 new shoes. SSR SP1
- New to the Board with my JDM DC2.. reppin Toronto..
- exhaust leak
- both seat belts and alarm just stopped working 91 integra
- theft proof?
- Tranny swap question..92 Teg Auto > Manual.
- B18C1, Smoke on accell, but compression good... What could it be?
- NOT BLOWING ANY AIR AT ALL!
- Dizzy questions
- valve adjustments on a b16a
- The main question on a turbo build.
- Ls vtech
- KYB AGX Shocks or Tokico Illuminas?
- any difference?
- How to take out an alternator
- need help!!!! IM question
- TIMING NEEDED 13:1 LS-VTEC pump gas!!!!!!
- Type R Front Strut Bar
- Short VSS?
- flywheel
- GCs on DC4 messed up in the rear. Bad Install?
- What spark plugs to run in a 97 GSR?
- sound clip request RSR ExMag GT II for B18b
- i been wanting to buy at honda market!
- who is truely slammed and what is your setup?
- anyone know what kind of mirror this is?
- type r headers on integra ls
- Maintence chek up!
- May My Sycros Be BAD???
- Stolen Integra: Please be on the look out REWARD!!!
- How do u take off Coil-Over ??
- Steeting is loose on highway
- hi im new!
- Will a 92 civic ex distributor engine plug harness work on a obd1 gsr?
- Finally got my setup ready. Dc2 project
- COASTAL Honda Power steering fluid vs DEALER ship Honda Steerring fluid
- Side marker question
- 1995 acura integra front lip
- custom exhaust
- New At H-Tech,& Well Just Wanted To See What Yall Think Of My 90 DA
- reset timing??
- help!!!!
- Local swap
- how to wire an electric oil pressure gauge?
- SWAP HELP !!1 PLEASE
- CEL 43- Fuel Supply System...Help!
- Lower springs, which ones go front and which ones go in rear
- can't find motor mounts and bracket for 90 teg
- obd1 integra ecu pinouts
- bypassing crank position sensor
- removing p/s and a/c
- 89 scrx with 91 ls swap no power???
- da bogs around 4k
- Turn Signal Wiring Diagram?
- funny issue, car runs fine by beginning of day, crappy by the end.
- dented header....?!
- Help...
- headlight question
- HELP: electrical problems
- 1994 gsr stock for sale
- check oil light won't go off???
- brake problems and it's not the M/C help me out!
- XTD CLUTCH!!!!!! FTW
- blown oil rings maybe?!?!
- MAXIM WORKS exhaust manifold...
- Gear engaging help
- header question!!!!
- Why is the hood propped up like this and what does it do
- ecu pinouts
- new here
- So my DA decided to die on me while driving... wth?!
- wats ur guys ride height on ur teg
- Is there a Cabin filter for integra's?
- 88 integra will 91 LS motor drop in please help
- lightest rims
- Boostin the ls
- 97 or 98 headlights?
- Muffler GASKETS
- Hondata, PCV valve, and Evap Canister
- front wheel bearing
- how to remove glue on gauges?
- Sounds like a blown motor help me out!
- type R clock
- help finding a tranny rebuild kit for my gsr
- Will my fingernail fall off? or, Bleeder Screw 1, Me 0
- Bleeder Screw 1, Me 0 ... FTL
- Bleeder crew 1, Me 0. FTL
- HELP!!! Car running too rich?
- Anyone know how to replace bent valves?
- wheel locks
- wat tranny is better ????????
- think i can post this here too, my integra LS turbo build...
- HELP! I may have been scammed!!!!
- Is it possible to use a different dizzy plug for a gsr?
- DC header freakin suck
- NEED HELF FRONT TURN SIGNALS ARE NOT WORKING??????
- jr supercharger
- can someone possibly do me a quick favor?
- how high compression for stage 2 cams
- My new car... Any comments?
- Is it my main fuel relay causing problems? 95-gsr
- Greddy vs. DC
- Turbo question
- exhaust questions....what to do
- FUEL FILTER QUESTION??????
- ECU questions
- were to get this headlights at?????
- hot integra
- H.I.D. mounting?
- need help with ecu....
- GSR AXLES/BELTS
- intake manifold
- what is this???
- i got rims..wanna know what tires you guys think i should get
- need pics. DAs
- lowering my DA question
- post da9 sedan pics
- bulbs?
- coolant lines under throttlebody.. TRIED SEARCH.
- Updated pics of my DC
- Xenon DA
- JDM ITR front end? where is the cheapest place to buy one?
- How to get a deeper tone exhaust sound?
- Changing Fog Light Bulb ? How To On DA?
- yo i got a 1998 gs integra any advice on wat i should do to it?
- teg losing power to the fuel pump
- WHat oil pan for ls/vtec setup?
- searched. whats the speed limiter set at on a 95 gs-r?
- HELP Can't remove Rear Wheel Hub Assembly On GSR
- 1/8 mile time
- Going LS-V. Which ECU to use???
- Integra GSR Headliner, I just sold....
- red dc2 gauges.
- Need Help Configuring Angel Eyes
- black smoke
- weak cabin air flow
- B&M Short Shifter GSR Rattle Box !!
- JDM DC5 integra emblem on USDM integra
- Do 94-97 front fenders fit 98+ ??
- Bought an engine stand but dont have bolts for engine
- Bent rim ?
- s3 light blinking?
- Check Engine Light?
- Sway bars..rear strut bars..
- Stainless Steel ExMag
- help with changing tach... to usdm or jdm itr
- Dash harness for 96 (OBD2) Integra
- b18a in 94 shell
- New Here...
- hey all im new to handa tec
- Bumper Paint remover
- are DA & DC A/C compressors swappable?
- clutch master cylinder replacement?
- Restoration vs Motor /w Less Mileage when turboing???
- Werid Teg Problem
- Don't hate y'all, but, speaker size question...
- How to change REAR Speakers on 94+ INTEGRA?
- Where to buy throttle plate?
- Mothers Mag polish vs Old Yellow Headlights.. Check out the difference.
- Clutch: specified for tranny or engine.
- keep the gsr tranny or go with...?
- Motor Mounts Aftermarket
- VSS Problem
- Which of these is the "Main Relay" on a 92 Teg?
- type-r brake conversion?
- Is my new clutch already gone?
- Well dream 1 is dead time to start number 2
- header
- mugen
- gsr vavle cover
- GS-R motor now whats next
- oil pump pickup gasket
- Spring inside OBD-I distributor launches across garage; is now MIA
- 9006 in DA JDM headlights?
- REPLACE PIPPING FOr exhaust or keep it stock
- Idle problem with my integra JDM Type R engine...
- b16 head or gsr head
- Cam Seal/Cam Plug Removal
- has anyone run a tanabe super hyper medallion? pics pls
- Hissing/Grinding/ Vibrating noise at 3700-4000 RPM please help~
- k20a jdm base model
- How much to fix this frame damage?
- Upside down A
- 15X7 and 15X8 +27mm offset work on 94+ Integra?
- Need Verification of Integra Models.
- help with my Ls v-tech
- what webs site can i buy crower 404 for a good price
- Switching To Synthetic Oil 124K Mile GSR ?
- b20 v-tec
- will nsx steering wheel fit?
- WIll a OBD1 Fuel pump fit in a 90-91 Integra?
- check engine light
- ac components interchangable in DC?
- throttle body
- Manual Tranny fluid change
- main relay problem
- ECU harness diagram for integra
- I got my Teggy
- What do you guys do first when braking?
- dent on DC header
- buddy club spec 3 cam question
- DC2 Elite Meet Cincinnati, OH Sept 23
- integra turbo
- TB on a 90 DA?
- My tranny is gone in my 96 gsr.please help!!!!
- Another "my VTEC wont work" thread
- Mud Guards?
- what is the amount of coolant needed for aluminum koyo (showa) radiator 94-01?
- How much does a stock 95 GSR flywheel weigh?
- Amsoil MTF in an LSD tranny?
- timing off 1/2 degree...ok to drive on?
- San Antonio Racers & Friends
- 98+ iNtegra front conversion help!!!!
- JDM Front end conversion kit?
- help: eibach prokit problem
- Engine Pull
- CEL Help: 00' DC4 with B18C5 code 91
- Adjust fuel pressure regulator
- Gsr motor specs
- rotter
- ls/vtec question
- Anyone have a pic of a 2DR CatBack on a 4DR LS Integra
- How do you replace the oil pan on a GSR?
- question about k20 swap
- question about bolt patterns
- Diagnostic codes P0170,P0172
- Oil Pan Help!!
- fuel system to rich
- 96 Integra No Blinker Lights
