View Full Version : Acura Integra
- STOLEN GSR in La Jolla San Diego
- power loss around 2500
- gsr idle problems/ vtec not crossing over HELP!
- ignition timing issue????
- Is my 90 DA dying?
- do i need a camber kit?
- please help!!!!
- 92 GSR with 92 LS trans swap, motor power problems, HELP!!!!
- 94 integra with poor handling? What to do?
- about to buy 96 ls auto
- 2k budget
- Moisture leak in headlight... randomly happens, randomly doesnt... Any ideas?
- overheating problem
- car won start.
- OEM Half Mast antenna switch help!
- need help with axles for h23 swap
- big vtec problem
- ABS light reset on 99 GSR
- oil pump
- V Maxx Suspension
- 92 gs-r
- stillin motor mounts
- type R cams
- help!!!!!!! ls on gsr
- finally a DA carbon fiber roof
- 92 Civic susp/brakes on 90 Teg?
- if i cut off the tip
- need feedback on KYB GR-2's
- Belt squeal?
- Headlight and Turn Signal Help!
- Knock Sensor/Retard Timing
- Instrument cluster won't light up on 98 Integra
- 00 gsr type r swap
- Timing gear question
- b17 info
- Covering holes and side moldings
- LS Motor Tranny ?`
- 99 gsr ideling problems
- overheat with top hose hot and lower hose cold !
- 91 ls, raw fuel smell... need help quick!!!
- wire tuck
- DIY wheel painting, my 2 day project
- Yellow Fogs
- clutch problems
- CAR SMOKINGG HELP!! =[
- SPEEDO TROUBLE
- gsr or ls/v
- Are these craptastic rotars?
- DC2 Inner Tie Rod Removal
- Smog failed... HELP
- 92 Integra with B18B1, what crank pulley?
- Gauge cluster / instrument lights not working
- ls/Gsr swap
- need VC studs
- my tranny is leaking fluid
- New motor?
- Masking tape wont come off
- FINALLY!!!!!
- tb and im
- 91 DA very weird situation
- B16A2 engine leaking bad
- Common Mods That Are Really Bad Ideas
- Temperature switch stuck!
- Piston Rings - Sealed Power or Beck\Arnley - 91 LS
- New noise in my 99 GS
- wheelspin??
- 2nd gen and 3rd gen Teg alternator the same?
- torque sequences and specs for replacing head gasket
- OBD II Dizzy GSR >> Need Help ASAP!!!
- gs-r head
- 93 teg shuts down randomly, problems starting
- Quick Help for a Friend!
- I need help with troubleshooting please??
- What Size Bolt?!?
- need advice
- DC4 Auto to Manual swap
- scs on p72 ecu
- plugs got wet... now rough idle
- Anyone with JDM power folding mirrors? simple question....
- What hardware is needed for OEM ITR lip installation?
- Is there an auto ls jdm ecu?
- Head gasket leak & upper rad. hose blown?
- NEED HELP! idle problem when i turn on a/c
- OBD2 or OBD! on 96 Teggy
- Water in car?!?.... help
- Speedometer/Speed Sensor 0-140 MPH.. REPLACED.. NOW WONT WORK AT ALL
- OBD2 Cars - Without FITV or Fast Idle Thermo Valve - How does it function
- what part is this?
- ls/vtec
- need help picking a clutch
- asr brace endlinks
- Body kit front & rear bumper & side skirts
- GRound Control Issues!! Please help FOZEN!
- ABS light on and off
- 94 Integra LS wont start when warm or parked in sun, fuel pump doesn't turn on
- what should i do b16 or gsr
- Charcoal Canister Problem
- B20 JRSC Thinner headgasket
- N/A vs Boost
- CLUTCH PROBLEM ON 93 INTEG DA
- Sensor Broken
- radio wont keep code
- i sold my other car and i dont know what motor to get a b20 or a h23
- Koni Coil overs
- Cruise Control not working
- unusual idle
- Help: Code 91 still~ after new Honda Gas cap installed
- Will a radiator out of a 97 JDM conversion fit on my 97 integra?
- what size steelie comes on the da
- tps help.. gsr
- G1TEG.ORG
- Idle air control valve - Should rough idle happen only at cold start or at ALL the time?
- '00 LS Randomly died, but came back to life...
- Integra Rear undermount bumper spoiler
- finally went ls vtec.
- 94 GSR water leak only when parked on slope, passenger side.
- loss of major power help comfirm
- different feel in power?
- no start on my 94 need help bad!
- vtec problem
- vtec problem
- what does the final gear do?
- Would a Main Relay cause my car to die?
- battery light?
- Problems on a B18c1 oil leak
- Buying a turbo GSR? how much would you pay?
- 15" drag rims ?
- question about camshafts
- Integra exhaust mod
- Clutch pedal is creaking
- Power antenna not going down...
- ek rear struts on my teg
- How to repair my door panels?
- Integra skunk2 intake manifold problem
- Bad Fuel Pump?
- jdm gauge cluster question
- Consequences of driving car with bad LMA
- swapping OBD2 H22 into OBD2 integra
- b16 check engine light
- Just purchased a DA, maybe you guys can help me out.
- Will these tires fit?
- water dripping/leaking down from inside near driver and pass. feet area....
- Lca/shock bolt
- removing abs
- Calling all DA with ABS Owners...Help Needed!!!
- H4h bulbs in 98-01 headlights
- FRESH STEELIES WITH BRAND NEW TIRES!!!!!!!!!!!! 195/60/14
- Can Someone Help Me? Turbo Troubles.. What to get?
- my car is knocking.. NEED HELP
- B16 header on stock 95 LS in a teg
- Carbon Fiber Bumper
- DA9 dash question
- where can i get my teg smogged?
- header on da
- what is the difference between a DA and DB1
- Flat Black Exhaust?
- rear suspension problem?
- CELs- 1509, 1003, 0118, and 1298. Please Help.
- looking for a 94, 4 door gsr
- help valve tick
- Stuck power Antenna
- 96 LS Died while on Interstate???
- type r supercharger on a b16 head?
- VAFC2 MANUAL TO A OBD-0 INTEGRA?
- Which header to get?
- Rear Hub Assembly : passenger side
- Is this true about new cluthes?
- My 95 rs.
- Cel 16 Fuel Injector
- vaccum hose diagram?
- oilpan leakageeee
- Dizzy, Ignitor, ECU, Main Relay, Fuel Pump- No Start issues.
- Speedometer Not Working..
- Wanna Double Check - LS vs GSR Rotars
- Super AUTOBAC in southern cali
- 1998-2001 Integra sedan interior colors, HELP!!!
- radio code retrieval thread honda/acura answers are here....search friendly
- valve clearance gsr
- Rear window wiper block off plate
- specs?
- fog lights
- clutch suggestions...
- Radio Code
- cooling system problem - I don't get it
- Car trys to start but wont turn over
- Intake manifold for a GSR
- Fan won't turn on, never overheats, Fan will turn on with AC - help?
- passenger rear lower control arm from 90 ef the same as passenger rear lower control arm from 90 int
- Help with Drivetrain Compatibility and Comparing
- Another Idle Thread HELP PLEASE!!
- DOES ANYONE KNOW WHERE THIS WIRE COME OFF FROM?????
- I NEED HELP WITH MY 90 ACURA INTEGRA!!
- Anyone have a j's racing 60rs exhaust?????
- 94 integra FITV o-ring
- VTEC hesitating problem? help!
- Integra gas/idle problem!
- Starting Issue
- engine restore?does it work?
- H.I.D.'s
- 98 integra b18b1 non vtech
- white 98 integra rs Black strip
- new cams, won't start
- 93 integra 5speed conversion.HELP!
- whats rong with my da?
- Offset specialists I have a question
- WILL SOMEBODY PLEASE HELP
- vtec air/fuel question?
- Engine idle problems.....(video inside)
- i need help.anyone got a fidanza short shifter?i need pics
- What size to go? Confused
- more help on this dang car
- Another Teg soiled.....
- rear spoiler removal
- tein h tech and s tech springs, pics...i searched for 2 horus.
- what's with this fear of buying modded cars?
- Even more problems with the teg....
- 1993 DA Rear Lip?
- making cf cargo cover?
- p72-oa1 ecu??????
- Comparison questions 1991 integra
- WHICH ECU DO I USE??
- 16 or 17 rims??
- OBD2 Scan
- 92-95 Civic SI (Non-ABS) Front brake pads fit a DA calipers?
- Fuse keeps blowing
- Starting Problem
- Anyone have any experience w/the amber corner sold on ebay?
- B18A1 Block with P73 PISTONS? WHAT U THINK ABOUT THAT?
- How can i hook up a vafc2 in my 91 integra without vtec..
- Sidemarkers!!! Finally!!!
- question about vtec controller
- intake
- ALL FOUR CYLINDERS MISFIRING?????? HELP!!!!
- suspension question !! need quick answer please
- Best bang for your buck???
- Need help. Exhaust problem
- cluster question?
- factory remote for 98 integra ls
- !!!@!@#@..HELP!!!!!! just hooked up turbo timer to 97 teg!!!@#$!@#$
- will a 95 accord front end fit on a 94 integra ?
- gsr integra question
- yonaka radiator 1994/2001
- gsr fuel pressure regulator
- skunk2 pro series for a modded gsr?
- Oil in my spark plugs
- stock gsr manifold help
- Buying a gsr tomo? Good/bad deal.
- Front Clip Question
- intermediate shaft rebuild?
- broken bolt problems
