View Full Version : Acura Integra
- timing belt help?
- Check engine light
- Fuel Pump Help
- Need a quick response about air filter!!
- check engine light
- are DA and DC2 rear shocks the same?
- need ideas on cooling system problem
- Question about OEM replica ITR lip.
- Coolant leak: Water Tube moves from Side-to Side???
- 1-1.5" drop
- o2 sensor wires toast.
- No motor mount?!
- What cams to choose?
- 93 LS, poor gas mileage and bogging at low RPM- running rich?
- NEED HELP WITH DOOR PANEL REMOVAL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Greddy Evo2 Axle back
- will a '94 integra ls alternator work on a '00 integra ls?
- Where to buy OEM Plastic retainers?
- Door handle security upgrade??
- Spark, Fuel, no start plz someone help......
- B20b into 94 LS
- 90-93 Intgera Honda embelms
- vtec problem
- Idle RPM surges. Up and down. Help?
- Where can I buy just 2 pistons?
- What lights are suppose to come on before ignition?
- Apexi Noir Exhaust System
- need help on pistons fast. please respond
- b16 swapped Integra - please chime in!
- question about ft. lbs torque on head bolts
- sohc in my dc?
- looking to get some drilled and slotted rotors
- DA-9 bad acceleration problem
- DA in the works.
- Brand of Products for Tune Up
- question about 94-00 integra oil pans
- thinking about getting this...need to know if its worth it
- Coolant leak?
- s2000 wiring
- Transmission problem?
- b-16 wheels or blades?
- 94 integra
- 96 4 door ls automatic
- What if use 87 gas on any car running a b18c1
- Clutch Slave Cylnder HELP!!!!
- 93 integra ls special edition
- t-stat stuck open?
- Integra JDM clip
- need help quick!!!!!!!!!!!!!!!!!!!!!
- 91 integra b18c1 swap
- Asr rear subframe brace
- p61 ecu or p72 ecu help.help!!!!!!!!!!!!!!!!!!!
- Sticky throttle cable
- Odd overheating problem?
- when to replace timing belt
- is it the rack and pinion?
- Removing A/C...is there any GOOD way to do it??
- type r head question
- Which ECU do I need?
- b18b in 91 integra havin install problems
- changing from obd0 to obd1
- i have a question about removing the back seat
- blox rear lower control arms
- what would you do...?
- Need help with hoses on B18 Swap into 1991 Civic DX
- HELP!!! Car won't start!
- i have no idea what is wrong with my ls
- Anyone have a closeup pic of a GSR exhaust cam?
- 99 integ conditioning issue
- p61 ecu. Ok for jdm b18c?
- b18c1 build
- Need Help Deciding On 94 integra
- Installing side markers....
- New Member here - Thinking about an Integra
- 97 LS RACING SHOCKS AND SPRINGS IN A 99 LS
- Milano Red or Ruby Red Pearl (Car is Milano Red Now) GIMMIE YOUR OPINIONS!
- ion headlights
- 0bd1 starting problems NO SPARK
- i made a boo boo
- Blower Resistors
- Some problems with my DAs Climate Control/Heater
- HOW do i get the pink out of my tailights?
- A/C Compressor
- high flow cat / test pipe advice? fitting?
- Found DB2 - Excellent shape Stock - Red - Lodaded - 248000 miles worth $3200 ???
- integra 95 gsr cluster problem
- hello! i need help
- integra 94 ls
- Help throttle plate got stuck on dc2
- Need Help: 92 DA Won't Start!!
- ls auto on a gsr
- Help me end this argument please??
- Car won't crank
- How to take off steering wheel
- How can I prevent oil from spilling out the filter while changing oil?? !
- airbag block off tray
- Which led's on SUPER BRIGHT LED's for cluster?
- Tail Lights Problem
- A race last night on 76/222 on the way home from NJ.
- MSD on integra LS VTEC?????
- Car WONT START!!
- p28 vtec to b series how to
- Rough Starting..
- side mirror
- JDM ITR Ballast Dead - Options
- B18c none V-Tec? Please help everyone!!!
- Timing advance for Boost?
- Engine Troubles
- b17 vs b16a
- turbo GS-r?! Need some help from you brilliant h-t guys
- Gas question.
- Where to buy FITV Fast Idle Thermo Valve cant find a store that has it.
- RHD integra questions
- cat converter bolts
- problems with my 90 teg ls
- O2 Sensor confusion bonanza!
- cv half axel shafts for a stock da6 integra?
- alternator seems to have died, replacement? (DA)
- b20b in a DA
- better springs for street
- DA driver looking to get off of trial member ^^
- 97 GSR radio problem
- having problems with my 90 teg ls
- Timing belt tensioner
- DC squad member
- DA Integra?
- noob HAHAH.. sorry..
- Air Breathers Legal?
- maintenance required light
- 2 questions about timing belt...
- 98-01 front bumper on a 94. Do i need to change the fenders?
- difference betwee real and fake itr lip?
- Pictures of this rear lip?
- How many db2 gsr's did Acura produce?
- Map Sensor Problem
- Vacum leak ?
- normal for white smoke on start up/cold night ?
- jdm conversion on a 2door(dc2)
- Running to rich or lean?
- resistor box
- 1990 acura integra fixed
- losing oil. could it be PCV not hooked up?
- what is this style intake called?
- b18c into 1992 ls integra
- Rebuild or new?
- Stock 00 GsR Turbo Build Suggestions
- which tires.. 911111111
- Window help
- obd0 injectors?
- obd1 obd2?
- Import Tuner project car needs STOCK suspension...
- Project CARMA: 1994 Integra LS build up. Again. :P
- Radio Codes
- Tow hook fitment with front mount intercooler?
- quick question.. type r piston in stock ls. will it work..
- ECU CODE: 45System Too Rich or Too Lean
- hey
- Axxis Ultimates or Metal Masters for DD.
- What Should I do next to my dc2
- timing??????
- Ls/Vtec Build
- Is it bad to have your intake filter straight on the throttle body?
- getting 16 MPG intown with my gsr... HELP!!!
- Electronics Problem?
- Need Tech Help On Buying Car
- DjBurns 98 GSR Project (Lots Of Pics)
- LS Integra help
- ep3 wheels
- Mildew smell
- DC2 swaps
- my $300 piece, the new project car.
- rear tire
- dash problems
- high beam light stays on please help me???
- Am I going to need a camber kit or alignment? Or both?
- trans problem
- 1990 ls/vtec ecu question
- what is this and what does it do? GSR question
- how to flush clush ?
- knock sensor question
- HELP!!! need windsheild wipers and they wont work properly, quick help
- gsr intake manifold question
- need help with seat belt
- ways to get car to heat up faster
- weird howling sound while going in reverse
- will 98-01 clear corner lights fit on a 94-97?
- Is this the correct ECU?
- i need help
- MAYBE ALIGNMENT?
- Gen 2 integra rear bumper help!
- Another Stolen Teg in San Diego
- throttle body, throttle pulley problem
- PIC(power in control) suspension
- stage 3 clutch
- Bypass Starter
- itr pipe
- need help: IACV and FITV wiring for obd1 B20 w/LS intake manifold
- continuity
- master cylinder
- Firewall Plug for Wiper?
- SET SNOW TIRES AND RIMS+ SUMMER TIRES AND RIMS
- is it my trailing arm????
- car idling 92 integra
- My 1990 integra stops running whell driving then you turn it off and back on and it starts please he
- where is the harness plug for the hatch on a 90 GS ???
- CA smog ?? B16a in Integra
- Check Engine Light question!!
- Fuel Questions
- Are passwordjdm type r lips authentic or just replicas?
- calling all DA OWNERS!!!! speed sensor problem
- shifter play
- Just bought a GSR, having cooling system issues
- GSR 450 DSM injectors question
- wheel fell off
- what to do?
- HELP: check engine o2 sensor
- removing the stock side skirts off my 97
- da help
- GSR 98 HELPPPPP!!!! Vtec oil pressure switch
- Are nippon pistons any good?
- GSR BOGS REALLY BAD!!
- Swapping My Integra into a civic....in a way
- K-Series Questions...
- Really need help please
- temp sensor
- Shoud I go hydro? or stay with cable?
- OBD2 to OBD1 distributor pinouts???
- dc-da motor mounts
- How can you tell what kind of transmission?
- DC2 integra subframe and front LCA's the same as 1994 honda civic EX coupe?
- Internal help
- 92 integra problem
- Maxbore throttlebody. NOT SATISFIED!!!
- skunk2 proS vs. omni/illuminas
- Hood Proping AKA Using washers to raise hood in back venting hot air out
- anybody with coilover sleeves 4 sale?
- anyone ever used the blacked out halo lights?
- OBD2 engine harness in an OBD1 chassis?
- exhaust question
- 4 door integra
- manual tranny issue, need advice
- piece of sh** clock!! removal problem
- Trunk Liner
- 98 front on 95? Do I need fenders?
- Can a bad positive wire connection cause charging problems?
- Will a LS automatic, Smog with a GSR swap, STick....
- head light not working
- head bolt patter
- What is this? and where do the hoses go?
- Can I paint my stock side skirts on my teg?
