View Full Version : Acura Integra
- in need of an ETM please!
- The fastest and easiest way to remove tint...
- J Series DC Build 56k*no
- Lightened flywheel torque spec question
- SRP 10 5:1 pistons can i turbo this
- Thoughts and/or Opinions on Megan Racing DB/DC Chassis Components
- clutch conversion
- integra build *warning lots of pics
- DA integra header???????
- DIY: Installing EK coilovers on your 94-01 Integra
- P73 problems
- RSX Lug Thread Size
- Will a VTEC distributor fit on an LS motor? OBD2.
- LED wiring question. Help?
- interior leak
- b20 vs b16
- powerchamber whale penis installation questions
- skunk2 lowering spring questions
- eagle crank for gsr good or no
- dimming lights
- fuel pressure sensor? obd2?
- itr pistons..can i go turbo????
- skunk 2 lowering springs questions!
- Heater/Fan not working
- noob question #2 ???????????????????????
- new brakes ... some problems
- Help with 90 Integra Idle
- DC4 Coilovers: Koni Yellow w/ Ground Controls Sleeves or other?
- b16b camshafts
- Front License Plate Ticket Help
- da mirrors
- vtec wiring question 92ls w/ a b17 swap
- best tires for negative camber?????
- Timing Belt Whining
- LS VTEC Oil Pumps
- DC springs fit on DA?
- rsr ex-mag sounds like N1 style
- The BEST transmission setup (gearing wise)
- Fender Liner question...
- Tanabe Sustec Pro S-0C Type-II Suspension Kit 90-93 Integra 2dr
- wheel beaing fused to spindle?
- Vtec
- Sensitive Brakes In Rain
- Throttle Body Question
- brake conversion '00 gsr
- HELP on ITR spoiler install
- How to clean USDM ITR carpets please
- wierd vibration?
- Best axles to buy for Integra 90-93
- Acura Integra turbo blow off valve not working right
- gsr leather seats
- Catback Exhaust questions
- fuel pump
- K-Series Swap
- 90 da transmission ?
- Need brakes soon on my DA, what to do?
- quick questions....
- integra wiper question
- GSR exhaust systems dont fit an LS?
- aftermarket fuel rail for integra
- Need help fast.. Dont know if this is a tranny issue!
- Gauge problem
- Will Cruise, PS, AC from EK coupe fit 00 GSR?
- wheel segestions please?
- Need Some Help With My Frank Set Up
- clutch change
- exhaust question muffler shop or catback?
- 91 integra biuld ls vtec
- TPS Issue
- Clutch problems...
- b18b is idleing at 3k steady. any ideas on the issue?
- can lsvtec pass the smog?
- B16a2
- Type R spoiler ?
- Dome light wiring?
- Tripping automatic seats.
- Bogging help
- Newb Question
- Will these wheels clear these wilwood bbk?
- B20V with GSR TRanny any good
- Junkyard Pricing?
- New guy
- Proper way to refill power steering fluid?
- a couple of dash questions
- B20b vs rsx type s
- exhaust cam on intake side?
- headgasket leak? solenoid failure? HELP please!!
- need some part numbers for tranny parts
- New car...evap leak
- HELP Pulsing Idle. GSR
- 90-91 prelude b20a into a 91 da
- what colour is this
- open, non-tapered differential bearings
- ARC MAGIC WINGS on a USDM FRONT?
- Rotors
- noob question???????????????????????
- DA Seatbelt Problem..
- DA wont rev past 3.5k
- Jdm Clock
- axle problems
- Gsr tranny noise help
- Apexi NOIR exhaust system qustion
- clutch fork question
- Post your suspension mods.
- Just got my DC2
- 1995 integra LS to b20 SWAP
- ok im going h22 .. need help fast
- Driver seat-belt problem on '91 sedan.
- stock GSR rims specs?
- Skunk2 IM Question (Searched)
- How do u feel about maaco
- 94 integra speed sensor
- nice quality quiet muffler????
- Need help identifying electrical plug
- Best Oil
- Antifreeze Container and Engine Temperature gauge
- Radiator fans are dead, anyone used the Mishimoto fan shrouds yet?
- Climate control removal
- asr and beaks question
- h22 in first gen integra
- Question about Syncromesh
- Clutch Cable problem in '88 Integra
- GSR Sputtering and Dropping RPMs
- car doesnt reconigize its in park
- p28 computer
- daily driving a teg with no cat and o2 censor in socal?
- ctr cams in gsr
- No vtec
- USDM pistons in a LS block
- OBD 1 to OBD 2 JDM Cluster HELP!!!
- Skunk2 megapower comfortable for a DD?
- good deal or no?
- Help: Cel 17 vss
- Help. Is this engine knock? VIDEO
- safe to drive with blown motor mount?
- parasitic power drain
- how much power gain would i get drom fuel rail and intake manifold
- Will ABS Master Cylinder Fit A Non ABS?
- JDM GSR Spark Plugs & Oil Filter
- jdm front light harness
- i am on a roll of questions today, oil pan question!
- ls/vtec stops while turning crank
- new teg question
- injector size help
- i want to do
- Need Picture of B18b with JDM 4-1 Header
- tach issues
- Megan Lower control arms/ Lower strut bar
- nitrous ?
- newbie alert.
- make my exhaust quiter?
- Is this obd1 or obd2
- Help!
- 1 exhaust for 4dr ls?
- Radiator Fan Issues....please help
- problems with 91 integra taillights
- Integra tail light question
- Traction Bar
- evap purge valve where can i purchase?
- erz performance
- Radiator Question
- 95 Integra LS quit running HELP!!!!!!
- jdm itr clock and climate control
- my ls-v build
- cel?
- deep dish rims?
- a/c compressor problem help
- Help: Slow turnover, funny idle, Boosted GSR
- Rotary Engine/ Transmission
- Mounting the JDM vin plate
- Help with my car starting
- asking for help b18b ob boost
- what other honda exhaust will fit my db8 integra
- hondata s100
- can anyone confirm this diy bar?
- Spark Plug Replacement DIY with pictures?
- Clutch Freeplay Adjustment
- boosting my b18b.
- Power Steering Fluid
- what kind of ecu is this??
- need some expertise
- tranny problem. . .
- Problem with blinkers
- My cluster stopped working.
- grounding
- hydro to cable tranny?
- does anyone on here own this teggy now?
- brake pad installation problem
- skunk 2 magnetic drain plugs question
- GS/RS/LS Door Side Molding, PLZ HLP!!!
- Just got my HID Kit hooked up!
- need help installing DC side markers
- Is There A Difference?????
- low clutch fluid
- i need help ! damn speedometer
- Noise coming from brake pedal
- Muffler advice
- Integra not firing
- Need header/exhaust for my 94'GSR ASAP!
- extremely tough to shift transmission
- Quick release safety button
- Build Thread: Road to a 10 Second Pass! (Alex From El Paso, TX)
- gsr question
- Just did a 98+ Conversion on my 97 and I have a question..
- Transaxle???
- Help 91 Teg not starting
- npr ctr pistons (ebay)
- My trunk doesn't stay up - Help
- DC2 top fuel bars
- oil leaks??
- '94 RS? Issues
- DC2 wing differences
- i have a question! cold air intake
- Second hand 94 Integra gas problem
- Apexi Ws2 Exhuast who has it?
- SOO glad my car paged me....
- Floor mats
- PCV Valve
- Distributor shaft play
- distributor questions/swap/help
- My intro~:d
- want to boost a ls
- Weird valve tap issue
- Usdm itr seat covers replicas?
- anybody ever deal with raceinspired.com
- Help !!!!!!!!
- Need help!!!!!!!!!!!!!!!!!!!!!!!
- Gsr Tuning Opinions
- GSR SWAP INTO DA TEG ?'s!
- Coolant Reservoirs
- Non-Detergent Oil question
- Ticking engine, no rod knock
- what do i need for a h22A swap into a 96 integra ls engine trany wat else?
- b and d trannys
- throttle stays open
- valve springs
- Torq Specs anybody?? (HELP)
- (HELP) ITR cams in my GSR ??
- Gas Questionsssss . . .
- clutch pedal leaking!
- Tranny Questions?
- Farewell To All!
- good deal or bad deal
- cold-air intake question!?
- need new springs!!
- Looking for the hytech replica nitrate header
- fuel rail question
- Advice about Integra purchase (was: I need some help)
