View Full Version : Acura Integra
- Valve needs tightening? Should i even attempt?
- 91 integra - name of sensor right below distributor and distributor cap ? car won't turn over.
- ecu codes???
- hooking up vtec?
- 1998 GS-R engine bay pics.. Need advice on how bad oil leak is.
- 3re gen integra gurus.. needs some help with interior panels difference
- What does the Oil Orifice do???
- why dont i have this on my GSR???
- Da integra temperature problem
- Do i need a new clutch? or a new tranny?
- what kind of primer would you guys recomend?
- JDM front fender liners
- Locked Out
- Integra 16in Rota slipstreams
- ABS light
- s2k oil filter
- Ebay clutch what do you think
- Florida: 99 JRSC Integra Gsr for Sale CLEAN!!!
- cable not so sure need some help
- just got a paint job, and 2 days later it rains HARD.. now what do i do?
- no spark
- OBD2a GSR... no vtec? or just quiet vtec?
- changing o2 sensor
- integra duckbill wing?
- driverside window stutters when opening..
- 94-95 Teg Auto Tranny issue wtf?
- Trans leak
- is it better to NOT have oil squirters.????
- Considering purchase of a high mileage'r
- Another What Should I Do Thread
- Are oem gsr cam gears supposed to say PR3???
- best turbo set up for 94 ls ?
- JDM ITR cat or aftermarket high flow cat?
- will i need a camber kit.
- stripped header bolt
- tachometer ????
- Exedy Clutch
- Question.......and need help ASAP!!
- what kind of muffler?
- how to check timing ~ ??
- Daily Driver Project
- 93 integra swap problem
- defining the heads?
- What are some good Headlight Bulbs for the integra??
- HKS HI POWER!
- HIDs help - Connection bad?
- sleeve coilovers
- Tein S tech springs on a 94-01 Integra
- exhaust hanging...
- Suggestions on Tranny for DA w/95GSR motor
- what is it worth?
- ebay motor mounts
- Question about parting out a 94 gsr
- ???crower stage 1 or 2's cams b18a???
- what is the stock fuel pressue for gsr....
- B20B Headers?
- Anyone know any good sites where you can find good deals on JDM front end conversions thanks
- aeromotive fuel pump
- # of quarts on 93 Integra LS
- Best 205/45-WR16s
- 94-01 INTEGRA HELP
- Alarm...
- coil overs/springs?
- LS auto tranny strength??
- piston difference??? p73 and PR3...
- Shawn at Church Automotive tuning in So Cal
- LSD in a GSR tranny...
- DA struts
- Juss did oil change and no OIL in FILTER? WTF?!
- what motor is the b18b?
- cel on/off on its own...
- How do i rotate to TDC with camshafts off
- I need pictures of how the IACV is hooked up on a 1st gen. b16
- Planning to build a "Converted" RHD DC with K20a3 swap... legal issues before i go through with it..
- Quick question (searched)
- weight of 2000 DB8
- Oil pressure switch plug, OBD1 LS harness, wire color?
- removing ABS?????????
- mugen sidesteps for da
- AUTO >> STICK conversion
- timing issues
- Cheap turbo kits?
- Burning oil
- Where can I budy a JDM metal front end for my DC2?
- is it worth it?
- need help setting timing on an ls motor
- wierd clicking noise after i turn off my car? never heard it before till now..
- Oil problems
- tailight wont turn off help!
- Just put in a new clutch set and still my problem persists, help!
- bulldog Deluxe 500 Remote Starter
- DC2 ANtenna PLUG.. do u PAINT it or leave it BLACK on a white CAR?
- HELP 94 teg cluster no lights?????
- suspension help?
- Write Up: Need a timing blet/tensioner/water pump for b18c1.. thanks
- 94-01 integra rear hatch visor?????......
- gsr idles funny, need help
- 97 dc2 rear assembly??? help please
- whats the differences ?
- turn signal problem
- whats this????
- HOW MUCH BOOST?
- Comes out of v-tec in 2nd?
- Performance Diff. 4-1 and 4-2-1 Headers
- 65:1 A/F Ratio!!!
- what i need for turbo??
- Suspension Question????
- help with rims!!!
- Need DA Integra INFO
- Driver side axle and water pump.. fixxer upper
- Waddup H-T?
- buyin a civic wanted to sell teg 92 GS-R BONE STOCK was wonderin what its worth?
- dc2 with h22 swap
- on the road again!!
- Starting issues
- gsr turbo stock?
- Freezes in Gear?
- Clutch Opinions -
- sway bar
- a lil DA help....
- Sedan vs Coupe
- hello everybody
- 94 RS with big problems
- What kind of exhaust are you guys using???
- Help!!!! Timing Belt
- BBK Intake manifold question...
- TUNING B18B ALL MOTOR, NEED ADVICE!!!!!!@$@^%&
- AEM Fuel Rail?
- Transmission problems
- Hole in charcol canister?
- blown headgasket?
- CA-san jose-$ 30 to anyone that wants to replace my clutch cable.have parts. thanks
- EG HATCH OR DA TEG??? DIDNT KNO WHERE TO POST
- Mugen Kit for a DA??? From JDMCARBOY
- lowering my da
- Plates stuck on car? Help on best technique to remove w/o stripping
- Window wont go down :-(
- 97 Gsr wont pass CA smog
- Help buildin 96 gs-r b18c1
- VTEC not opening up..
- BBK Intake Manifold is it any good...
- how to install window visors
- INTEGRA TYPE R HELICAL LSD DC2
- b18b
- db8 window visor
- Adjust Fuel Pressure for nitrous?
- 94 Automatic Transmission Clunky
- whats the wheel horsepower of a stock USDM GSR??
- Illuminas with Skunk2s, any issues?
- How do you stop the car from running rich?
- Need you guys oppinion
- help.. wont start
- DA lsvtec almost done need advice!!!
- Grill on 92 Teg stock bumper....?
- Lets see some pictures of 2 inch drop and 2 and half inch drop with 17s
- Upper A arm creak??
- brake master cylinder.
- A/c removal
- [[ DA sunroof / moonroof ??? ]]
- short shifter on DA
- intake for gsr
- part number
- Dyno in New Jersey and philadelphia
- car bogs out???????
- Question about Motor Mounts for a DC2
- Skunk2 intake manifold TECH Question!!!!!
- quick valve lash ??
- 93 integra fule filter!!!!!
- ALT FUSE KEEPS BLOWING
- electrical short problem.
- integra pretty much done.
- $2,000 for a 94 Integra RS with a maintanance light on?
- Quick Dizzy question, will GSR dizzy work on a B20?
- Immobilizer???
- 4dr exhaust?
- shifter hitting exhaust
- 92 gsr
- San Diego groups
- Problem on my DA..think u know anything about it
- Here's one for all of you Toyota guys...
- stall?
- Opinions on Dropzone Shocks?
- Radio Code
- Anybody with a bodymods want to sell their old parts?
- Sage brush pearl?
- just finshed installin first turbo kit
- so i lowerd my car with some springs!
- WHY IS MY CAR RUNNING LIKE SHIT?
- how to u post pic!! of my car
- Clicking noise when turning but brand new axles & cvjoints
- CAR IS SMOKING AFTER WARM UP.
- compresion test on a stock gsr
- Can DC2 tail lights be opened up?? (Taking the lense cover off)
- can you guys help me with the value of an item???
- New here....just bought a 99 Teg Need Opinions on Tint
- I need someone to help me with my 90 Integra's idle/rpm problem
- interchangeable CV joint (axle driving shaft)
- db8 window visor pix please!
- oem honda oil filters?????
- Fuel Injector service
- DA coilovers on a DC ?
- wtf timing belt wont go on
- abs situation
- Check engine light slowing car down.
- Bad ideling on my 1993 integra
- New to the Integra Owners Club!!!!!
- What to go with in my 1993 Integra .. Gsr or H22
- hey wut is obd2
- where can u buy keepers???
- COLOR CLARIFICATION - Blueish purple integra
- What does "checking PDH" mean??
- SEARCHED!!! Sir-G Fog light switch install
- type r and gsr crankshaft difference??
- head stud question
- 94 integra gsr idle air control valve interchangable with ex/dx/lx/ls?
- Temp gauge doesnt work help!!
- Any difference between DA GSR exhaust and DA non-GSR exhaust?
- 96'spec ITR 4x114 conversion on a DC2 GSR.....what brake rotors can I use with this conversion?
- LS/VTEC
- rotor suggestion
- I seem to be running a bit rich on my stock 98 GSR, anything I can do?
- Head removal/Install Instruction (Alldata)
- Engine problem
- 94-01 integra seats in a DA
- window switches...
- Starting problems?
- Will this be a problem?
- Rear Motor Mount Question
- hid kit questions
- 96 Integra LS Alarm Chirp
- anyone have pics of apexi gt spec exhaust on an integra
- GSR with jdm b16a just bought the car
- Blox LCA - Longer or shorter or same size as stock? Anyone have them installed?
- i need fuel injectors
- b&m shifter factory bend? bushing part#?
- bad fuel injectors
- Stiff Heat/Cold Control Slider...
- Need opinion on whether i should keep my system or not...
- idle speed adjustments
- throttle body
- suspension or direction issue?
- Will ASR subframe kit fit on ITR Lower control arm
- Having some clearance issue with pwr half size radiator
- maintence light
- My ABS light is on...
- new to the group
- obd1 dash into obd0 car
- legend brake swap???
- Relocating 94-97 ABS modulator to install JDM ITR HID headlights...
- Bronze GT3 Rota Trade For GT3 Rota
