View Full Version : Acura Integra
- del sol seats into a G3 easily?
- Response to a ? about push button ignition
- Ls camshafts/gears
- Problems w/ Mugen exhaust
- Where to get P73 Pistons and Rings....soon, can't wait for the 1-2 month back order
- Performance A/C?
- HELP!! my car won't start
- Best Speed Shop in NYC Area?
- Stuff........help please?
- Tranny swap
- Hello everyone
- tucking 18's
- Zex Nitrous System on a GSR
- Hatch Rattle!?!?!?
- help! paint starting to fade! what should i do?
- Need help with ac motor
- FI or ALL MOTOR? have $4,500 to spend help!
- On and off squeal coming from engine. Mysterious source...
- Short Shifters???
- My car seems to be reaching the redline a LOT lately... is this safe?
- where can i get info on aebs,hitech......
- What should I get?
- Can't decide..please helps...
- NEW RS-X info!!!
- Will an OBDII ecu just "pop right in" in exchange for my old one, or do i need a harness?
- Dood, came back from Sears Pt. didnt run, but saw a lot of Disappointing times
- Quick! Alternatives for Honda High temp Urea Grease
- torque wrench
- Exhaust q
- A FRIEND JUST GOT AN RSX-S WHATS 0-60 & 1/4 TIMES SUPOSE TO BE LIKE?
- Any heard or have the E-RAM Electric Supercharger
- Can I rev to 8 grand all day with CTR cams and stock valvetrain?
- What kind of power could I see with this setup?
- missing dowel in b16 head for ls/vtech, options
- which ignition should i get for my gs-r
- KYB boots and bumpers?
- teg pics - finally..... big'uns too!
- How to measure GAS MILEAGE
- Spark Plug Torque Spec please for G3 GSR
- $4800 to spend, turbo? supercharger? help...
- Suspension Problem (please help)
- Crankshaft pulley bolt removal
- Teg brake failure
- Where can i get RS*R exhausts for my 96 integra ls? anyone know
- OT: Cleaning glass....
- 60K maintenance on GSR
- Illinois people, here's some interesting reading
- Are these gearing combinations possible?
- Is the dealership the only place to buy bumpstops?
- Quick question, Chassis code?
- need info on Dinan Stage II chip and others
- HELP!!! Losing oil fast...
- ARP head studs...
- Paint or Powdercoat??
- Clear Corners...easy to install?
- Help with a problem after some mods please!!
- Rear wiper removal
- gutted cat???
- ITR o CTR cams
- Can someone help me out a Qauife lsd
- Winow problems???
- Stock fuel pressure on a 95 GSR?
- How long will I extend a cat-back exhaust for a 2dr to fit a 4dr?
- How to drain oil
- Where can I get OEM Acura Body Panels?
- ECU Differences
- Whats up with DC Sports Headers JDM Type R?
- ITR trunk brace
- test pipe or exhaust cutout?!?!?
- air breather question....
- can someone help me locate the PCV valve?
- timing belt replacement...
- CF hood
- CV Boot
- getting S2 intake manifold, what about ECU?
- door pannel reinstall!!!!!
- 96 GSR 4-Sale 56000 Miles Selling ASAP
- JDM Front-End conversion...Sheet metal or Fiberglass?
- Who here is running spoon cams - currently
- ITR rear swaybar bushings fit LS/RS front swaybar ?
- INFO on horsepower gains on ctr intake cam on 95gsr
- VX 13 inch wheel fit on a integra 3rd gen???
- RAM CLUTCHES.......good/bad?
- difference??? header question
- Motort mount inserts
- how to make my 94 gsr faster>? please help
- Bringing my car to the mechanic - What should I replace?
- HELP: Is there supposed to be a small hole in the Comptech Icebox?
- cluster bezel?
- ARGH! Rattle coming from dash (left of steering wheel)
- Flywheel questions
- MASS DYNO DAY CONFIRMATION!!!
- planning on these mods...comments/suggestions?
- I want an ITR exhaust on my GSR... new springs/shocks... header... everything
- good auto shops in seattle?
- comptech vs. greddy
- Honda ponders return to in-house tuner parts
- Clunking in right rear after ITR Bar on Stock LS (not tearout!!)
- PROBLEM!! LOSING 10MPG after installing AEM CAI
- Red gen3, JDM front, white guh drivin, Bay Area 101
- Choosing coilovers
- ACT 6puck disk with stock pressure pate?
- valves?
- LS with Si tranny?
- Random thoughs from my RSX testdrive
- AT to Manual conversion - help!!
- Crower CRO-62405 "Race Only" Camshafts
- making ls faster
- Brakes! Rotors, pads, calipers, oh my!
- torque converter
- Tech Q: My car has an electrical problem, MAP sensor, car won't idle HELP!
- RSX dealer invoice?
- LSD (limited slip diff) is it worth it?
- Anyone have an Antenna Mast
- machine shot in NJ/NY area?????
- Jet-Hot coating for header: Any first-hand experiences with this process?
- speedbleeder size for clutch fluid bleeding?
- Dyno runs
- Where to get black lug nuts.....for cheap
- Toda Spec B owners...what are ur cam gear and vafc settings
- brake/caliper/rotor problem
- Looking for STOCK ITR b-pipe
- Koni Coilovers?
- purchasing a cf hood directly from fiberimages
- just purchased a 92 gsr...
- Realigning headlights
- Problems!! Water leaking from passenger dash..
- Wiring problems
- Posting about someone's RSX running a 14.7
- Type R Cams
- adjustable springs & shocks on GSR
- Will 92-00Civic Skunk2 coilovers fir 3rd gen Integra shocks?
- APEXI N1 exhaust forGS-R ??????????
- advance timing?
- Crower 63403
- Squeek from the clutch..
- Pumps not working??? help!!!
- Strut Caps
- What is the best way to compare cars in terms of who would win in a race....HP? Torque? HP/LBS ratio
- 2 piece 11" bolt on rotors finally ready...12" kit in the final design stages...
- Stocker shocks are in rosebud mode !
- Need advice guys!!!?!??!?!?!?!?!?!?!?!?!??!?!
- Wisconsin...where can I go to rebuild my motor?
- Are these worth it?!
- will type r intake amnifold fit a 95 gsr?
- Attn. All GSR Greddy Kit owners. Need help asap
- Fuel Press Regulator for LS?
- Properly torqueing the valve cover..
- new to the board...need advice!
- Eibach sportline question?
- Worth buying a 94-95 GSR with over 100K?
- JDM B18c1???
- tire Problem, is this a big problem?
- 4-door Integra owners.....what exhaust do you have on your Teg? is Greddy SP the only choice?
- What Kind of Horesepoer Do you Get from AEM Pulleys?
- Integra troubles.. please HELP!
- can't remove the K&N filter, please advise..
- why is battery light on?
- What is the correct way to reset the ECU for 94 Integra.
- Need help understanding Helms manual (urgent)
- Really rough idle, please help
- 3g integra trunk lid width
- new pads less dust?
- My first impression of the RSX-S
- Honda Oil Filter
- McGaurd Wheel Locks
- Help me figure out this noise
- how 2 make LS faster? *auto*
- C's short shifter installed
- Cam Gear and Ignition Timing Settings
- Went to the track tonight
- Can I switch to a manual steering rack?
- HELP 02 Sensor problem
- QM times faster or slower? changing tires to 205-50-15
- BEST RSX-S Review Yet!
- AGX n Sportlines rides kinda rough ...???
- Steering Feels "Notchy"
- Broken radiator fan
- Does RSX seats fit in an Integra?
- What is the difference between three-piece and one-piece wheels in terms of performance?
- Car and Driver RSX review - 0-60 in 6.1, qtr in 14.8
- Ram-Air intake helpful?
- Attn all people w/ aftermarket ignition
- MASS DYNO DAY?????
- Please help to clearfy this: Greddy carry Evo for 4-door gsr? Greddy or 5 Zigen ?
- Front Beam (Bumper)
- OT: Are there any reputable import tuner shops in Atlanta, Georgia?
- Whats next for my LS?
- Waht do you guys think of this set-up?
- g2 gsr
- Race Tires
- Secondary Intake Runners
- few questions, need a little info
- where to buy icebox?
- Can you guys help me out here?
- My climate control is stuck in the heat position and im roasting, help!
- I need some advice....
- Does anyone with the B18b have a USDM/JDM type r header?
- Help me with brake install!!
- '95 GSR - Engine vibration at 3500-4000rpm
- spring rates for H&R sports and race, anyone?
- check out the Integra Type R forum it has pics of a wrecked RSX type S on it
- HEADERS????? Which one is best for JRSC integra? someone help me
- Anyone with a body kit and lowered help me out
- Alternative to Hondabond?
- Transmission Swap inquire...
- Lowering questions
- Air Flow theory?
- Where's the 12 V ignition wire?
- So... where do I start? [Integra LS performance mods]
- Neuspeed SofSports vs. H&R OE Sport Springs
- How do you remove the distributor rotor?!
- need help with wheels...
- What to do with $300?
- Need help quickly....stupid question
- Tech Question: Would a 255 LPH fuel pump really be necessary for my N/A mods? Opinions needed
- Do you need to jump the service connector?
- Rear Wiper Removal Solution
- Camber
- Differences between R and GSR master cylinder?
- Steering wheel alignment.
- what shocks are good????????
- ANYBODY HAVE THE CLUTCHMASTERS FLYWHEEL??????
- air conditioner help!!!!!!!!
- Ferrea Valves
- Good combination for lowering: Nuespeed sport springs and KYB shocks?
- Someone with an integra helms manual...
- Is there a difference between a type r flywheel and a gsr flywheel?
- Very newbie question: What is the ignitor?
- Anybody know any place to get JDM front-end?!?
- Let's make the pact now!! no more moderator comp. post's
- How do I know what offset wheels to get?
- sparco seats....need help
- Finally Drove GG today! Anyone got a KAAZ LSD? VTEC4GS?
- Is my clutch going? Please help me.
- NA setup with NOS?
- Jerking in First and Engagement into 2nd
- I WOULD LIKE TO GIVE THE MODS A ROUND OF APPLAUSE
- MSD6A/L & OBD-II
- nitrous on auto teg
- RS*R springs for integra
- type r limites slip
- is the axle back part of the exahsut 94-99 integra the same for 4 dr and 2 dr?
- shift knob
- We need help choosing Exhaust and Headers for our project car
- AEM Cam gears
- GREAT!! just got a speeding ticket... got 1 ???
- Dangit, acura.com already removed Integra from their site
- what are "dead coils" on springs?
- Side mouldings
