View Full Version : Acura Integra
- ZC in an Integra...HELP!!....
- turbo b18b?
- CTR N1 pulley, JDM FD & pistons, etc in stock
- Any special tricks for lining up the LCA bolt holes (tie bar install)
- Will a GS exhuast fit a GSR
- questions about taking car to dyno?????
- New custom exhaust...
- Your engine temp
- Will my check light go on if I get a test pipe
- B18C5 oil pan on B18B1
- how do you take out g3 seats
- Weird Electrical Problem??
- Had a starting problem at first now its gone!
- getting cams....will it mess up my car?
- ls/vtec
- what is a b-pipe?
- OBD-2 Distributer on OBD-1 Harness??
- NOS...
- AEM Fuel Filter Element
- 94 gsr 4th to 3rd problems -4dr
- burning oil smell..grrrr..!?!?
- carb manafold
- whats wrong with my friends integra??
- best head package for ls turbo!
- Differences In Sedan Taillights/Rear Bumper?
- Can anybody tell me what this is or where it goes?
- Please I need some info about a swap!!!!!!!!
- Did anybody seen History channel @10pm EST
- anyone got pics of their car with the 5 zigen fireball
- help w/ b&m fuel pres. reg. install
- looking for an SIR-G lip
- Type R Pistons in GSR
- JDM H22A in a '97 Integra...need advice on how much to sell it for.
- Apex'i WS FS cheap! better jump quick!
- how to mod the blinker?
- low fluids will do what
- ****connecting to battery help****
- Heat shield
- Solid rear mount?
- Dead Battery or Bad Starter
- ***wiring in glove compartment anyone know?***
- 97 GS-R p62 ecu pinouts
- JG Edelbrock vs Skunk 2 intake manifold for gsr
- Car is hard to put in gear
- How to take off ps/alternator/last belt for B20??
- antenna stuck up!!!
- Fenderwell Trim on 1994-2001 Integras - Rust Problems?
- Testpipe help
- Picture Post
- Spring bolt things that bolt together stock manifold to cat.
- seat swap
- My Door Open Light Will Not go Off What's Wrong????????
- Firestone Firehawk SS20 Tires.....any good?
- For those of you with DC Sports exhausts...
- What in the world are these things used for ???!
- Header gain question
- walbro fuel pump ??
- Integra GS-R Options (All Years)
- stock cd player removal, possible input to stereo?
- Who here has ever run open header?
- anyone have a turbo in their 90-93 teg..?
- Problem starting my car
- 215/45/17s or 215/40/17s? I don't know which one to get
- tips on changing head gasket
- solid urathane mounts....
- gsr ecu question?????
- Is this an ITR intake cam?
- help i need pics of dc stainless steel headers after use..
- cel problems
- Need emergency help! Transmission problem?
- Ran my 1st Quarter Mile Today
- rear racing seats
- **lowering springs**
- Need list of street legal parts
- Seriosly considering an Integra
- Radiator leaking....what NEW radiator do you guys recommend?
- I NEED exhaust, some one fill me in
- post your cats!! which ones do you guys prefer??
- How much torque (m-kg) for the wheel nuts?
- Spoon Rear Strut Tower Bar
- once again... oil filters...
- Are all B-series plug wires the same?
- GB: JE pistons $500 shipped
- Nakayama Exhaust
- ?'s on the B16 compared to the B18
- Too much oil bad?
- Is a jdm itr tranny in an LS overkill?
- gsr swap technique same as the one on c-speed done on a LS?
- What can i use to plug an o2 bung?
- Parking Brake Light Comes On 1st-4th gear!
- Nighthawks going Turbo!
- handyman.. please help me with this removal
- Seattle area peeps...
- Will stock air filter fit in comptech ice-box?
- H&R race springs
- Lifetime Alignment
- How reliable is LS V-tech?
- Will 96 ls cat work for a 95? (o2 sensor wise)
- To Spray or Not to Spray Part3
- Anyone got pics of Eibach Pro kit???
- Will a 4 door Integra front bumper fit on my 2 door?
- B18A Engine Questions - Blown Something or Other
- Confused about ...KYB AGX and HR Sports
- Gas Mileage Question????
- what must this mean?
- Building my frankenstein....need help with vafc settings
- Will an AEM CAI from an ITR fit an LS?
- My Dyno Please tell me what you think and please help me out
- Bulbs for JDM one-piece headlights
- any gains itr stock header on LS?
- is there any B16A1 and B16A2 on DA integra clip?
- Best Ignition >>>> ?
- Skunk2 Rear sway bar...
- Can I spray?
- Air Conditioning Help!!!
- AEM intake question (Not sure if what I'm lookin at is an AEM)
- Oldschool or alphanumeric?
- squeky
- B18B1 Auto Ls Motor
- are ceramic header lighter???
- I got some pics of this hottie I met. *warning nekkid!*
- JDM 4-1 Dounut Gasket Q's????
- Cam maintenance
- Anyone ever use Type r ecu on a Gsr 98 with skunk2 manifold???
- What Injectors 4 me?
- anyone from white city oregon?? or area?
- Looking for ino for 4-door GSR's.
- Can you adjust the vafc while driving
- Intermittent starting probs, please diagnose
- blue smoke??
- easy headers question..help me out
- To Spray or Not to Spray Part2
- Anyone got pics of Integra with SKunk2 Exhaust?
- rear window defogger works only sometimes....whats wrong??
- Need help quick!!! Buying a 94 4d Ls, messed up suspension?? And Master cylinder??
- How do u know when a clutch is going bad?
- Best intake for a GS-R??
- accelerate hard, car pulls left, right
- BIG! Rear brake problem need help immediately
- Skimatics for ecu of 94 acura integra GS-R Wanted badly!!!!!!!!
- What should I expect?
- Chicago Cruise Night at Strats/X-Treme Graphics. Wednesday, 9/18
- how to remove sound deadning material
- 98+ bumper
- Integra Dash
- Integra LS compared to a Civic si ?
- Need a favor in Socal...need OEM GSR intake for smog...
- check engine light on after installing CAI
- performance intake...?
- B16A or B18C
- What to pull from wrecked GS-R?
- Too many miles for mods???
- OT: How much is the OEM Integra Deck worth?
- jrsc detonation
- j's racing intake
- LS tranny problems... help anyone?
- 94 GS-R 180,000 whats the first thing i should do
- Hankook Ventus HRII H405 tires
- 45 vs 40 series on 16 inch rims
- the s14 silvia conversion for a 3rd gen Integra
- GSR's w I/H/E, How many miles per tank are you getting?
- radiator...
- Fuel Capacity on a 2001 GSR
- Who can do Valve Train here in Midwest?
- Burning oil...turbo questions...
- difference between 94-96 GSR, and 97-00?
- easiest way to remove axle from hub?
- IPS Fall Specials
- Fuse Diagram
- Are the floor mats for a civic and Integra the same???
- Airmass High Flow catalytic converter, i can get it for $100
- For those who have had bent valves replaced - advise please
- Anyone want to trade JE pistons .4.Crower C
- Spring Rates on Standard Ground Control kits
- 9005 Conversion
- Q's on rear sway barz
- Engine ?
- KYB GR2's...good or bad??
- ITR catback on GSR???
- Apexi V-AFC is it worth it getting one?
- car shakes please help!
- What throttle body to get?
- what is the difference between 1995/6 and 1999/00 GsR-Door Panels?
- WTF? 200 miles to tha tank.....
- What are the Best Motor Mounts!!!???
- integra type r cam gears
- H/C/E questions?
- does a K&N air filter really work or is it crap
- anyone ever get stuff from this website??
- anyone has pictures of an intake (AEM, Injen) on a 92-93 GSR?
- Intake Manifold
- Will an ITR brake master cylinder fit on a 95 GSR?
- how bad is an exhaust leak?
- battery question
- need help with pillar bar
- Passing Emissions with Race Porting???
- 700 bucks, but what to buy?
- Horns Cont....
- (Bad) Joke of the Day
- still need help w/ radiator =/
- What color is your Master Power window Switch? HELP!!!!!!!!!!!!!!
- mod to change signal speed and coordination
- fixin up a 4 door gsr
- an LS should not be beating an Si stock
- B&M Edge Shifter
- Skunk mani?
- 205/50/15 tires ?
- Air Intake for GS-R
- Thinking about getting a gs-r. Need help.
- how are kamakazie headers?
- when was the v-tec introduced on the tegs???
- Leaking water in rear hatch
- Apexi N1 rubbing bumper?
- Windshield Wiper Problem
- anyone got tips?
- N E 1 use Sylvania 9006ST headlight bulb?
- what mods should I do to my 92 gs-r
- What to make?
- What is this tube for?
- installing headers and exhaust?
- integra for sale, $600 obo, in atlanta
- HELP car won't start (it's not the relay)
- Removing rear seats on a 2nd gen
- clunking from rear sway bar
- 16" Rota subzeros w/ H&R Sport and Koni Yellows....
- H22 in 92 CX?????
- Removing ball joint, did I screw something up ?
- 94 Integra RS weight
- skunk2 lower tie bar install...
- Need HELP ASAP!!! Type-R Exhuast???
- JDM 4-1 Header being too big for N/A
- integra parts
- Where to get head gasket replaced in So Cal?
- is anyone doing that koni yellow buy?
- header for JRSC...
- traveling to Asia.. where to go for car accessories?
- Will 2001 integra wheels fit on a 95 integra
- Integra Type-R Cams in a 2001 GS-R?
- car will not turn off.?.?
- Tell me what you think about these dyno settings with my vafc...
- helms $
- Oil + Battery light....
- B&M fuel regulator or AEM fuel regulator which one is better? is there a diff?
- Where to Buy JDM front end??
- Q: Cam question
- Who makes Black Plug Wires
- Gonna try to install my coilovers on my integra
- how to read in engine light
- HELP! Code 54!!
- fs msd distributor cap and distributor
