View Full Version : Acura Integra
- golden eagle LSvtec conversion kit DIY?
- '98 LS into a '93 -- motor mount questions
- Type R lip
- 90-93 ls tranny
- hondata prices????
- Mobil Oil
- Proper puck break in ?
- question about obd2 header emmisions???
- Timing Belt/Water Pump
- Toms Performance Sport Brake Pads?
- Car wont urn over
- clicking/clunking when taking off and shifting into second
- 94-97 Rear lips?
- carbon fiber hood
- Comptech Rear Sway Bar Tie Bar Combo?
- Integra Climate Control Disassemble?
- frame diagrams/images: 86-ish integra GS 2-door
- Smoked parking lights for an 01 Integra??
- shifter grinds?
- MY DA IS ON ITS LAST LEG
- turbo kit for my GS-R
- integra door panals.
- Throwing a Weird Code!!! :*(
- Rear Wheel Drive teg
- What do u call it???
- Really werid problem
- mis shift mayhem
- 190+/- Miles per Tank on my DA!!! Help!!!
- Gs-r Header on a ls motor
- B18b or B18a intake manifold which one is better
- how long does it take to swap a tranny in a teg?
- Problem with left turn signal??? and brake light
- tail light/ brake light harness question.
- Where to get motormounts
- I think my spring is damaged :(
- safe bore-out stock gsr is ?
- Turn Signal Lights
- GSR 4dr vs 2dr
- Faster for Twisties
- Brake Pads
- ESPELIR EXHUAST any need help with these plz
- skunk2 intake manifold (gsr)
- this question is to those who have ever rebuilt a b18c1
- vtech problem!!!!
- gsr muffler
- Ways to Determine Tranny's?? HELP
- 01 Teg question
- Timing Belt Problem
- Engine Face Plates?
- What kind of Injectors?
- RSX type S seats!
- Rattling Crazy!
- AC question?
- fuel cutoff switch link seen here last week or so
- what is this on the back of the LS block?
- 1992 DA ....offset question?
- *LOOK* Identify these Integra rims!
- ? about rims
- GSR intake manifold swap. need Help!
- lower Balljoints
- WHAT ARE THE DIFFERENT COMBINATIONS OF BLOCKS AND HEADS THAT CAN BE CONNECTED TOGETHER, TO CREATE A
- VTEC question
- 4dr or 2dr wich one handles better?
- RSX Steering Wheel
- help on b18a1?
- compression reading b18a1?
- Difference between P72 and P75 a/c bracket
- parting out 94LS 2dr 5sp tan cloth interior black
- Nut and bolt specs............
- Ive got a strange fuel problem, need help please.......
- Skunk2 Lower Strut bar question
- Engine Check Light
- NEED HELP ASAP PLEASE SOMEONE
- 4 Door GSR Question
- All b series engine parts interchangeable?
- Those running a p72 w/ skunk2 intake manifold
- Anybody runnin on KYBs made for civics?
- Toda Cams?
- What is this vacuum source for? And is this for the cars water heater(motor being dropped in)
- 4 point harness on a DA????
- questions about 5 lug conversion
- Removing dash-- Will it cause problems?
- hybrid gsr...no vtec...need help to figure out why
- 17" wheels sucks!
- ????KONI YELLOW COILOVERS????
- ITR Lip
- Throttle cable help!
- ls to gsr
- Few Questions?
- gsr head
- Apex'i RSM Meter /w G Sensor Users
- ebrake question...probably retarded
- JIC Magic coilovers.... Anybody have them?
- 94-01 ABS Unit
- GSR Gas Mileage??
- are there 2 diff. valve covers for the LS ??
- Ideas for my 97 stock integra
- car makes odd humming noise, and goes with the rhythm of blinkers, windshield wipers, etc. - help
- RPM does not work anymore?
- how can I tell if I still have the SRS sensor in my front bumper?
- question about bleeding brakes (at modulator?) for 94 GSR
- Any Pics of K20s in DA chassis Integras?
- clutch chatter/vibration
- Im looking for a trade!!!!!!
- p72 question
- NEVER thought i would see this
- 94 gsr gauge cluster problem
- radio question
- Anybody Retrofit HID's to factory headlamps?
- Exhaust request
- Endyne Pistons 12.1 with Toda B cams clearence
- Need price quote on Integra Type R intake manifold
- bad gas? bogging problem
- need answer about suspension quick! 94-01 springs on a 91??
- ????SUPERCHARGERS?????
- front end question
- AXXIS brake pads suck!!!
- what power steering bracket to use for my 97 integra w/ b20 motor
- Need a little help...
- Bogging/Hesitation issue, at idle and at more than 1/2 throttle! help!
- awd integra
- vtec in reverse?
- dont eg spoon mirrors fir dc2???? curious
- what kind of camber kit???
- WTB: Stock integra muffler in SO CAL !!!
- ECU HELP!!
- gas gauge dont light up
- '99 GSR I/IM/H/E dyno...
- Need some teg insight
- ground control
- integra shell
- clutch engaged high..help! thanks
- 1994 Integra LS Parts
- b18b and b18c1 parts interchangable?
- Integra slim window visors
- Constant check engine light
- socal (sgv) rims person
- man freakin leaking oil again!!!
- Tokico or Tein basics or the combo style?
- 94-97 integra 4dr rear lip!
- Centerforce DFX Clutches
- GSR Block LS Crank - Oil Squirters?
- rims for my integra
- GSR Question?
- Thieves caught.... (just thought I'd throw caught story)
- Acura & Honda OEM Part Number Websites!!!!!!!
- Possible to fix exhaust header?
- Car Squeaks when going slow
- 00 ITR exhaust on 96 LS
- How Do I Mount My Front Plate Like....
- How do i make this look clean, like bling bling ??
- Latest Info on K20 into DA Chassis?
- Sqeaking!!!
- Seat question?
- EG suspension
- What intake manifold is this?????HELP
- GSR stock shifter?
- what is biggest turbo?
- intake route to bumper
- distributorless ignition
- making corner lenses steal proof
- lowering springs
- Theives make me wake up....
- Newbie here again!
- NEED YOUR HELP. My cars dying....dont know why...
- DCsports tie bar on DB8!
- buzz sound in engine bay.
- greddy evo exhaust question??
- Racing Axels? worth it...............
- WANTED INTEGRA 2DOOR OEM SIDE SKIRT ASAP
- Need help with Head Rebuild
- which intake pipe for use with JG edelbrock maifold? itr? ls?
- I’m so exited, hip hip hooray!!!!
- will it pass smog?
- 90-93 integ headlights
- rebuild
- which b18c/b18b parts interchangeable?
- sup HONDA-tech.com ppl hey i finally got my honda mtf nice
- VAC leak vs. Code 9 ???
- Gauges
- in need of a b16 with or without lsd
- Smallest Rim on DA
- will ls part fit gsr
- Low RPM problem
- Newb Question... B16 header onto GSR engine.
- people need to ask there self why they come to this web sight?
- Need help with AUTO Teg
- Engine Misfire
- need advice from a veteran
- NSX Brakes on a 4x100 Integra
- Which Iceman intake
- ???KYB AGX 1994-2000 GSR shocks same as 2001 GSR???
- Just wondering. Retrofit question?
- ABScode 48, WTF? Can anyone help with a shop manual?
- 1 front Integra coil spring needed
- Help!!! weird poping sound comming from my suspension/axel/cv boot i dont know?
- San Diego help a brotha out v2.0 :p
- Can anyone guesstimate what this car would run in the quarter?
- GSR Question
- 98-01 Front End Conversion
- Volks CE28N 10 Spoke
- Integra LS tranny worth?
- Timing Belt Q
- 94 gsr speed sensor same as 95?
- vtec question
- car won't start...
- Steering Wheel Question
- 93 teg interior help?
- Here's my setup so far!!!!!!!!
- OEM ITR ITR headlight Question!!!!
- How much would it cost to fix this? Rear quarter panel / suspension damage, please see
- Yes or No, ebay o2 Sensor
- itb
- A/C idle pulley - all same for B??
- Need help with 98 teg AUTOMATIC
- so my axle is shot already... but it might be linked to my clutch?
- new member, be nice tell me what you think
- ABS Fuse
- Acura Engine Codes
- Engine / Transmission bolts
- JDM ITR cluster question
- Can someone help a bro out (O2 sensor)
- Odd rear suspension type
- good shops in austin, tx
- Need Help with my Coilovers
- what kind seats are good for tall person.
- Interior
- Key gets stuck in ignition...help
- Who does JDM Conversions in the NC/VA Area?
- Timing Belt Tensioner
- obd1 head on an obd2 motor
- will this fit
- is it my axles?or WAaahhhhhhhhhhhhhhhhhhhhhHT!
- S2k cluster into an DC integra
- Noisy Azenus
- 94-97 and 98-2001 integra body.....please gurus help
- Motor swaps
- Want to lose the Tan uglyness But nervous about removing the Dashboard, Please help
- Quick question
- da's and dc's track times!!!!!!
- DH camshafts??
- engine swap fast!
- MOMO hub
- 94-97 JDM Si VTEC fog light fitment with front lip
- Adding power locks and Cold air intake question
- tranny identification
- new to forums, integ gurus..(POST HERE!!!)
- House of Kolor books
- major problem with door lock!
- tranny diagnosis.
