View Full Version : Acura Integra
- How important is braking in a new clutch?
- Mugen Side skirts
- GSR Guys Please Chime In
- Catalytic Converter
- 94-95 Integra - Front Sway Bar pics please..
- JDM power folding mirror!???? where to find them??? integra!
- want to buy a JDM RHD integra type R where can i purchase one ?? and get shipped?
- anyone have JDM headlights for a 93 LS?
- maitnence light
- AEM CAI Questions
- KONI/Eibach question need help!!!
- Header torque down ?
- Clutch adjustment
- sway bar ?
- How much abuse can the gsr handle?
- PLEASE HELP! b18b valve cover
- Someone help me out please
- Aoexi N1
- Whats the differences between 1990-93 teggies
- Where to find Jun Stuff?
- Need help deciding on selling my Integra.
- rear quarter glass??
- HELP: I have a loose driver side, side view mirror
- 90k tune up
- jun flywheel
- Is this a Type R Part Only?
- Dyno
- Rebuilding my GSR, looking for suggestions
- what size bolts?
- cusco rear strut bar
- What is best short shifter?
- rebuild mods?
- b18b header on a b17a head?
- Misc. clips and grommets
- Newbie here
- anyone interested in a cross bar brace like this?
- Skunk2 intake mani & AEM CAI on a GSR?
- 94-94 gsr rims...pic request
- 5w-30 vs. 10w-30
- Newbie with some Exhaust Questions
- ITR cat vs LS cat, size shape difference?
- Will Rear outside door handles bolt on into the front?
- JDM ITR cams in a USDM B18C1
- 90-93 Integra lights question
- Car is having starting problems. Starter??
- piaa xtreme bulbs
- Is this a good NA setup? What should I expect?
- Additional horn question
- hoods
- ls v-tec
- damage from overfilled engine oil?
- DIY icebox is in! yay!
- I will MOVE all Carfax posts.
- FOR all you JDM HId headlight owners!!! please help!
- Does anyone know where to powercoat something gunmetal in So.cali
- Nov 16 - Acuras at E-Town Raceway
- t-belt question
- integra LS motor power
- Shift Knobs - Personal Preference or Design Important?
- Should I aim my lights lower now with HID??
- do you use aditives
- ZEX nitrous
- swap ?
- replacing the catalytic converter
- Help, something is wrong with my car, anyone have this problem before?
- 97 integra GSR complete airbags
- What do you all want to buy?
- custom headlights
- My GSR is fuxored up!!! HELP
- Integra's rule. Why? Ckeck it out.
- Harnesses w/o seats and a cage?
- Holding an event to cruise the Angeles Crest!!
- I need boost NOW!!!!!!!!
- I want some help yo, and some ideas
- Valvesprings and retainers... ITR or Crower??
- Has anyone ever converted their headlights
- water pump spec....
- JDM ITR Tranny in GSR
- Dirty fuel lines?
- Integras.....what do i need to convert LHD to RHD? can it be done?
- 3.2 rl motor into an integra?
- retrofitting projectors headlights
- can this be done? put a 2.5" collector onto a USDM header?
- stock spring installments - HELP!
- civic radiator in a DC2?
- Integra On Ebay
- $19.99 for a Honda Oil Filter!!!!!!!
- 92-95 civic ex steelie fit on gsr???
- anyone plead innnocent on a ref ticket?
- 5-lug conversion on a GSR
- where is the coolant drain bolt on the engine block?
- TyPe R = Type Racing Or Type Reduce Weight??? Just Want To Make It Clear
- need to find a ls moter for sell!
- most torque you have ever seen out of a B18C1...
- Should i go super charger or tubo for ls?
- EG axleback on DC2?
- Tire Question.......
- Sunoco 94 Octane Gas
- abs wheel sensor
- JDM Integras in Conroe, TX ?
- How hard is it to take the headlights off of a 94-01 Integra?
- Greddy SP, doh
- lsvtec vs gsr
- springs
- Does VTEC engage when going reverse?
- osakajdmmotors.com
- teg trannys
- Newly Turbo'd LS what to expect??
- are the new tenzo's SR-5s light?
- Does any one else have a saggy rear bumper???????
- 94-97 fogs for 98+
- thermal exhaust?
- help...trouble shifting gears
- Painting Side of Rotor?
- where to buy true RHD JDM integra type R?????
- Tanabe Super Down Precedeo
- engine shakes, vibrates i need to know
- Prelude SH vs. Integra GS-R
- type r wing w/ LED
- DIY obd2 --> obd1 conversion harness???
- replacing radiator core support...?
- My wheel/tire combo...
- VAFC/SAFC Question
- 1986-1989 Integra
- Bridgestone Turanza ER30?
- Which clutch master/slave cylender fluid do I use?
- roll a S2000 club....am i the only member?
- header wrap?
- can u cnage how hard amd fast an atomatic shifts
- Glovebox Mounting for VAFC and Guages
- Bridgestone Potenza Re950's or Dunlop SP sport A2
- Bottom End Differences?
- cheap carbon fiber hood and a JDM lip??
- Whats better Cross Drilled or Slotted Rotors???????
- Extra wide tires on 95 5 spoke alloy GSR rims
- cut car off and wont start back
- One last T&T for us Ohio guys. Come!!
- Removal of All Heat Shields
- do lighter rims make a big diffrence
- horn, wtf ?!?
- Yanking the Rear Seat, Teg style
- Rainy Season.....
- Website to buy Toda Spec B cams for integra.
- 1991 integra old tinting
- Question about Ground Controls and Perch wrench
- 2nd gen Tegs
- header question
- Wheels?
- trouble starting
- 94-97 oem fogs lights
- NGK Iridium IX Spark Plugs --- part number fo GSR (b18c1)
- car wont start anymore!
- feels a bit weird
- what tranny are you using for your b20 swap?
- ls/vtec or ls/turbo:need to know asap
- which headers for LS?
- Help, car shuddering/shaking/vibrating
- Anybody heard of Topspeed?
- Koni Yellow Online Dealers
- Boost ready Block Swap - Columbus, OH
- I did a search and still have a question about ITR springs on GSR
- Integra JDM Front
- what do you consider stock..??
- Spoiler Plugs
- how to install A pillar pod
- Best 205/40/16 tire for around 70 bucks?
- What should i do about an exhaust system
- Do 98+ Corners fit the 94-97 Bumpers?
- fuel pressure regulator
- Any 2nd Gen Integras with motor swaps in here?
- any alternatives to replacing the o2 sensor ?
- got a question on ls-vtec
- What Size Inlet Needed
- How Hard to Install a Car-Sound Cat?
- would this work.. switching out dcsports catback and keeping the piping but replacing axle back with
- how much oil loss is considered normal?
- IS this a good setup?
- Putting in new front brake pads...
- ARGHHH i messed up!!!
- Anyone with tanabe racing medallion and silencer!
- mods to run nos in a gsr
- HELP!!! How to remove brake disk retainer screw without stripping??!
- fried my bulb harness
- squeking noise in steering wheel
- NeW sHiT: AEM V2 Cold Air Intake...
- What Two Bolts Are Used Tto Change Tranny Fluid On Integra
- Heat Shield after Header Replacement
- zzzzzzzzzzzzzz.........
- hondata tuners in CT???
- How much would a JDM conversion cost?
- All you JDM-lovin' '94-'01 Integra owners (L.A. area especially)...check out what I found for you...
- Finally i replaced my O2 sensor!!!!
- carbon fiber rear hatch?
- what honda parts needed for Skunk2 manifold install?
- VIN Questions ...
- HELP! Idle problem..
- Cutting AEM CAI? Where is the best place on the pipe to cut?
- JDM conversion installation...
- :::Need an idea on mugen rims:::
- ITR Front lips
- Exedy Clutch Questions
- b-series engine question?
- Which Is Better 4-2-1 or 4-1
- Catalytic Converters
- need to change small 4 lug to large 4 lug for wheels
- Buying a turbo... need help.......
- hit bump in road BAD now car shakes
- ITR Pistons/valve/shaft?
- HELP! 89 won't start
- What Kind of Spoiler Is This?
- Rubbing??? 205/50/15?
- Fuel pump/Rail/Injector questions
- engine problems
- B18C1...good lightweight flywheel
- need help with front end, bodyshop in socal
- How much do you think this is worth?
- Anyone with a RHD Integra?
- p73 odbII ecu wiring into a 97 LS...
- Axle seal install.....
- any good shop in Houston?
- b18c head pics - need help.
- need help with suspension please!!!
- clutch pedal stays on floor for a little bit
- Anybody with stock Type R Springs?
- anything I should do to my motor before the swap
- P28 ECU ?
- Battery Terminal
- LS to GSR door panels?
- Want to get my car painted
- hydrolocked....what should i do now?
- Apexi N1...opinions
- Integra Oil Analysis?
- how much does a 94 LS sedan weigh? 2600??
- anyone buy there engine from osaka???
- 14" civic steelies on GSR
- anyone with tokico springs in there teg??
- tanabe super hyper medallion
- URGENT!! Timing Belt Install Crisis
- Anyone notice a difference in handling after lowering there car?
- Clutch Pedal Help
- Pics and info my Brakes, Suspension, and Stock CAI
- Suspesion
- Where do u guys set ur timing???
- exhaust/header question?
- Quick question: 00 GSR ecu works in 99 GSR??
- Why is the front of my car so high?
- Will 01 gsr Comptech i/h/e fit on to 95 gsr, if not why not???
- suspension removal???
- Burning oil?
- did these rims come on GSR and LS or just LS?
