- Compression problem.
- dc2 jdm itr conversion HELP ASAP
- motor swap
- What kind of heads would you get
- 03 si wheels on dc2
- pr3 pistons or p30 what is the difference they are going on a b18c motor need feedback
- Fix it or strip it
- edelbrock turbo kit for gsr!
- Help! Lighting Problems dim and bright
- my ls/vtec build
- OBD2 to OBD1
- ITR muffler question...
- Head bolt tread striped on my block WHAT TO DO???
- Pics of painted LS meshes?
- H22 in 94 Integra. Pulling tranny off?
- Blown fuse!
- GC/Koni Yellow for DC2
- Ignition switch Integra Civic?
- Cams on N/A ls
- car wont start...sometimes
- 94 integra shift linkage loose
- Help on car problem
- another tranny ?
- did amber gauge cluster and clock
- Need a diagram
- CEL PROBLEM
- da tranny problems
- show me your suspen setup...
- Replace synchros?
- Which clutch for my setup?
- How to Make Steel Wheels real shiny...
- Hello to all integra sedan owners
- brown integra
- junk???? take a look
- Best Cheap Header
- exhaust question
- Spring Rates
- power windows??
- Lower tie bar
- What are these wires for?
- Knocking while releasing clutch
- Where to go now?
- Looking for a shop in southern NJ
- whats differents with cheap intake and expensive intake?
- Rear suspention questions(90 GS Sedan)
- Speedo not working
- Integra DC2 rear lower control arm same for DB8??
- take me to your dealer.
- How to take off my left fender?
- Looking for a hot aftermarket horn!!! help me out!!!!
- need help with finding signal light bulb....!!!!
- Wheels and Catback
- pumped 87 into my 95 gsr!! what should i do
- what header are you running on your DA ??
- Fuel Pressure
- 90-93 Tegs: 4 Door Radiator (core) support the same as 2 door?
- im lookin for the 11 to 1 ratio in my ls/vtec
- car running rich
- Headers: SMSP * Hytech * Comptech * Toda
- anybody else have a problem with mugen ecu
- yO! I need sum help with my DA please...
- Perfect lanuch
- seat belts
- Shifting without clutch
- legit 94GSR b18c1 motor resleeved by JG has 84mm bore wiseco 84mm 8:5.1 eagle gsr rods
- b18b1...need help...
- some banging noise
- Price question?
- couldnt do an alignment?!?
- Shift Linkage
- keep burning up distributors HELP!!!!!!
- any pics of bbs wheels on integra please?
- 17x7.5 too big?
- integra problem
- compression check
- 1992 integra gsr for sale
- which rotors do you think is better?????? PLEASE HELP
- YS1 Transmission question
- KSPORT QUICK RELEASE - Any thoughts/opinions?
- RHD converision regisration question
- jdm front prices??
- WTB JDM Front end for DC2
- Another Newby
- hood hinges
- where can i buy a JDM front end conversion? ? ?
- Motor swap... which is the most reliable??
- STR manifold any good? going on a GSR
- how much can i get for my da?
- GSR vs B16A head bolt pattern
- s2k radio/DA integra?
- Integra gsr dohc cam vtec top out in second gear
- need help with starter
- gsr cluster in a 95 ls
- 91 integ
- ls compression
- experience only please
- Sup everyone....got another noob in the house!
- Cam installtion gone wrong?
- Let's see them cars!!!
- LS Compression Results
- 94 ls shifting grind
- password jdm??
- da axels in a dc? possible?
- ls/vtec help
- Things i should know?
- oil burning question
- Jdm fron bumper for a Usdm bumper
- greddy evo pix??
- knock sensor plug wire colors
- is it common for high mileage gsrs to burn oil?
- B0ost..or No boost..?
- Measuring Redline
- Wich Flywheel to Buy.....Hmmm....??????
- Brake Fluid for High Speed fun?
- Is it bad for a GSR temp not to be in the normal Temp?
- Whats the best way to Remove Rear window tint?
- JDM n00b driver signs..
- how cani post pictures of me car and stuff
- DA: Cheapest place to buy RS*R exhaust?
- Fluidyne or Koyo Radiators.....
- Broken bolt
- itr header to cat.. what flange do i need? help.. pics!!
- redline??
- Starter Upgrades
- PIC REQUEST DA GS-R'S
- leakdown test....
- new here!
- I'm a Veteran Noob
- Hood pins or not??
- 2 dr to 4 dr taillights
- Need help with headlight!!!!!!
- exhuast help....for integra
- speedo jumping
- painting wheel?
- how did you use the stealthmode drainline?
- questions about integra front lights going out?
- will Civic seatbelts work in Integra?
- carbon fiber
- Is my cluster broken?
- How do i join the DA SQUAD??
- Sleeper Exhaust
- Integra LS/RS w/ Turbo Kit
- amber gauage cluster 92 DA
- engine temperature
- Idle Problem
- Exhaust Question?
- 92 EG \ K20A2 Swap - STOLEN!!!!!!!!!
- 94 integra 4 door help please !!!
- Integra Tire Sizes
- jdm oil filter?
- coilovers
- front bumper
- Towing clip in rear bumper
- Ecu problems
- my hazard lights don't work.
- kakimoto exhaust
- HID retrofit questions
- change a intake on automatic
- k24/k20 sawp
- Eagle talon turbo... Good or bad for a stock DA?
- O2 Sensor Wire Diagram???
- jdm ITR headlights
- i need help on wich exhaust i want
- super mesh rim on integra!!!! look!!!!!comment!!!!!
- tranny help
- skunk2 cams?
- Stage 1, 2, or 3 clutch??
- eBay Parts
- Tried reseting SRS light...No go
- 6 puck clutch owners....
- Are all first gen crank pulleys the same? and what about ZC?
- White Smoke outta engine bay
- LS
- noob
- Opinions for my build
- ??Input Shaft bearing or Throwout Bearing??
- e-brake
- Header heat shield removal - I searched
- can you paint this....
- 97+gsr worth in bay area?
- 1990 DA need tips
- anyone from missouri
- abs light
- Swapping tranny fluid?
- do i have to go to honda for this litttle part?
- Reliable street clutch for 95 GSR
- Random Clean Car Pix
- Emission/SRS light?
- Anyone running 215/40/16 tires?
- police rader
- Axels gone bad? someone please help
- how long does the b18 automatic last
- Using Civic steering knuckles on an Integra?
- tsudo headers wut u guys think
- 96 gsr help! ! !
- DIY: JDM Visor install
- Clicking noise coming from drivers side.
- LS/VTEC vs. B18C1???
- GSR front bumper on a LS????
- how do I get rid of my gap hood between bumper?
- B18B, wanting to upgrade valvetrain
- short shifter advice..
- What kinda shocks should she get?
- RACE GAS
- why is my stearing wheel shacking
- suspension help
- can anybody help me?
- question about emblems
- Misfire at 3k RPM and hard starting
- Need help!
- Need help identifying (ID'ing) tranny *PICS*
- Comptech vs. JDMSh!t replica ITR lip?
- How do I put on a Jdm integra front end?
- for sale complete b18b1 ls motor 76, 230 miles
- wtb:stock air intake and box w or w.o filter
- Appropriate Throttle Body Size?
- My cars incredible transformation
- Blinker bulbs?
- CODE #1 O2 Sensor CEL ???
- will a b20b head non vtec Fit on my b18 non-vtec engine ??
- just wondering if you could
- suspension time
- need help wiring itr jdm power foldin mirrors
- Guess this will be my new home from now on
- Does anyone know how much this will cost (quick accident damage cost)?
- Edelbrock Vs. Skunk 2
- what model integra did these wheels come off of???
- gsr cat converter????????
- Patch Panels
- Radiator quest.
- Koyo Rad-OEM fan shroud fitment
- How much are these parts worth?
- location and testing of coolant temp sensor and MAP sensor on 90 Teg?
- Chamber Help.
- _____which rods should i use for my setup???_____
- A/C in a boosted DA
- evo nine seats
- TDC sensor, need help!!
- type r wing ????
- Are GSR Power steering pulleys the same as b18a, b18b, b16?
- which steering wheel to get with nrg quick release
- integra head gasket advice? new engine? and new trans?
- paint help
- COMPETITION CLUTCH flyhwheels ?
- Wth is this thing?...
- Brake pads rub against rotor...need some help
- Just bougth a 94 GS-R.. It has a nifty lil card that came w/it. A punch ticket.
- Which is the ecu fuse?
- whats more important
- bad idle
