View Full Version : Acura Integra
- where can I get gsr main bearing caps?
- K20 in a DA?? Anyone seen one? Pics pls if so.
- quick main relay question
- 2 Inch Drop
- thinkin about selling my 95 gsr
- ABS light
- omni front control arms adjusting
- GC/koni or RSR exhaust ?
- 94-01 ABS
- Spark Plug Gapping
- Cosmo Racing short shifter, anyone have?
- Stolen Red boosted GSR with a jdm front end in Colorado Springs!!!
- Custom Exhaust shop in Dumfries/NoVa?
- 93 gsr
- Quick Question: Are all exhaust B-pipes and Axlebacks interchangeable ??
- Throttle cable or spring gettin stuck i think, help!!
- intermediate shaft question.
- turbo app.
- Need Tuning help
- Gs-R engine
- sentra se-r spec v?
- Clutch problems..... help please
- installin new clutch and light weight flywheel
- got a question about pricing
- 1995 integra overheats while stopped
- oil drain valve who has one
- LS engine revving too high
- Distributor
- Flywheel
- i LOVE my teg
- help !!! how to install the jdm DB8 type-r master power switch in my 95 4dr usdm integra?
- Integra 96 Speacial Edition rims
- lip
- hows this teg looking
- What kind of oil do you use for your GSR?
- cat length???
- got my new turbo!
- 2nd generation angled exhaust
- carsound magnaflow cat
- Well, 87 Integra smoking,
- throttle problem?
- prob with ls at 5500 rpms??
- AGX setting question?
- JDM Bumper
- sellin my GS-R
- Searched......Now 2 questions about JDM carpets and wannabees.
- Need Help! My 92 integra
- stock hp?
- Problem with my distributor HELP~!!!!!!!!!!
- rim repair??
- Edelbrock TB (need help ASAP)
- obd1 integra parts for sale
- want to trade my si hatch eg6 for integra
- help please
- Rod torque on a stock b18c1 bottom end
- These are my compression numers are they ok..?
- how much boost can it take
- Bogging problem.. strange one, too.
- JRSC questions...
- After installing my axles, when I shift into gear, the car doesn't drive...
- Shift Knob
- can i get some pics
- Spark Plug On A 98 Different from the 2000?
- 98 integra LS $8800 @ 78k miles mint condition... could i do better?
- 96-00 Civic and AEM ITR CAI?
- Type R cams
- Torque specs on fly wheel and clutch ?
- ANYBODY KNOWS THE SFECIFIC NAME OF THIS PART?
- increasing red line?
- So I changed my tranny oil and...
- starting issues
- Another DC2 GONE: Timeline of the Teg. 56k DEATH
- How many miles after gas light comes on?
- Dont wanna be a NOOB anymore
- To Turbo or not To Turbo, That Is the question
- LS Crank in GSR block rebuild
- flywheel question
- Can anyone help
- Installing JDM 92-93 Bumper/Bumper Support on 1990 DA Integra
- JUST CHANGE MY AXLES BUT STILL MAKING WIERD NOISE!!!!
- uncommon o2 sensor question
- Auto Teg tranny going crazy? NEED HELP!
- GSR 94-99 question
- new rear mount with b16
- lakewood or competition engineering traction bars?
- Spark plugs for GSr
- tire rubbing problem
- Sensor Fitting on 94 GSR Intake Manifold??
- 1990 DA...wingless or not?
- E-Brake tightness?
- take out a valve.
- amber bumper lights??
- post pics of your gsr (t) here
- Cam question
- Constant squealing noise
- Replaced pads and rotors and brakes squeaking/ squeeling
- DA Steering Wheel Replacement
- What Gsr Intake Manifold to get? Blox or Aebs
- jdm auto ecu
- install question
- hp handling of a b18c engine
- rubbing issue
- 94+ Integras: does the LS, the GS and GS-R really all get the same MPG?
- how do you guys tell which motor is which?
- Problem with Horn
- quick question.. simple yes/no answer.
- what do you think?new swap
- 96 integra for 3200! Should i buy???
- How good is a OEM JDM Type R header+CAT combo - Comparisons?
- 4-1 header
- Lsv question
- Car shaking and axle pops out
- 94 Gsr??
- how to roundup? (can't search)
- need radio serial number for acura integra LS 1996
- i know its the wrong room....
- ***Pics Request**** looking for some slammed 4 doors
- I have a 95 teg gsr. What is the cheepest way to lower it about 2 in.
- intermediate shaft strength
- n e body know how to make idle screw from vacuum line?
- problem.....
- car still pulling right after alignment
- can a type R head fit on a LS block?
- ANYONE EVER TURBO THE AUTO 94-01 INTEGRA?
- What Valve Covers will fit a Ls Head?
- whistling sound?
- sunroof question (search down)
- problem after work was done....
- Strange Buzzing noise. Cat converter? (search not working)
- Where are all the turbo'D DA integra videos?
- 96 LS distributor is broken..wat year will the distributor will work n fit for it?
- Problem...Driver side lower than passenger side....
- tokico shocks
- Sway bar question
- Should I trade my 5 lug for a 4 lug w/ a Wilwood Brake kit?
- How are everyone's Integra's so heavy?
- Have a problem....
- can someone tell me what is happening?
- post your lcd screen (non motorized)
- 95 gsr 2.5" exhausts
- exhaust headers
- exhaust resonator question
- Gs-r with LS crank
- gsr block with cracked sleeve
- lca pros and cons
- 94 integra im buyin...worth it????
- keyless entry?
- Clutches: 8 Puck vs 6 Puck - Miba vs Kevlar - Sprung vs Unsprung... opinions?
- different models
- 1998 Integra GsR Sedan Exhuast questions... Search is down
- this is dumb...how to bleed coolant?
- quickie question....which side of the axle would wear out faster????????????
- head bolts
- ONE PIECE HEADLAMPS?
- Lower ball joint spinning?
- nee you help on purchasing a car!
- XTD clutch
- Coilovers
- exhaust setup question.
- torque specs help
- skunk2 intake manifold...overheating...headache...
- What Reinforcement kit 2 use with ITR Swaybar?
- My new LS
- E-manage base map
- dont know which fuel regulator to get
- does timing tension pully bolt auto tightn the pully or do i have to manual tightn pully by hand? pi
- indivia test pipe?
- MY BABY WAS SIDESWIPED TODAY
- lock just springs back....
- Where is the ECU fuse?
- exhausts
- turbo b18b1 gas
- does main crank pulley need to come off to get to timing tension pulley on b18
- Turn Signal Issues
- ls/vtec
- jdm front c/f hood or no?
- Hondata
- Throttle sticking on my boosted ls
- Turbo GSR?
- maintenance required light WEIRD
- Water leak into the drivers side
- Car started burning Oil
- which bushing makes biggest difference ?
- turbo gasoline
- DB1 f/s or trade
- intake suction even louder!
- Please help--corner light fitment issue??
- gsr or si
- what i parts i need for valve adjustment and tools for lowering car?
- Subaru steering wheel in an Interga?
- Ls engine---> Gsr swap?
- ITR headers on a GSR question.
- First pics of my DA
- Rebuilding Front Susp. Is this kit ok? NTK ASAP
- maintance required light
- Integra factory alarm trouble
- headgasket question
- Idling Question
- FS: 1994 GSR / 42k miles NY
- bad piston rings?
- anyone make hood damper/hood lift support for DAs?
- smoke coming from motor
- b18c1 ignitor into a b16a2 dizzy.
- TYPE R?
- Fuel management
- Alternator belt sqealing after changing T-belt? LS T-belt same as GSR?
- paint job?
- my new DC2!
- need help please
- ECU QUESTION? FOR ALL MOTOR.
- The Sunday Honda Tech Story (Redline MTL Impressions)
- Jumping rpm's??
- GAB any good??
- type r lip
- axle bind
- Maint. Reqd. Light
- what is the voltage on a knock sensor.
- ATTENTION THIEVES:
- help: integra auto - manual - how do wire the reverse light?
- clutch pedal wiring hareness? what is it called? need help asap, auto - manual conversion
- Cusco Roll Cage in a GSR? Searched, no help.
- check out better pics of my car
- Let me know what u think
- should i get this lip???
- jdm car boy
- Horn Problem. Please help
- WHat the smallest rim that will fit on a 1995 GSR?
- JDM LS motor question
- Coil on 91 Acura Integra
- pics on ur bio
- DA trouble codes
- how do u find out the year of a motor?
- Overheating Problem (need help)
- Question about a gsr swap
- Miles Per Tank 94-01 Poll, How far do you get on a tank of gas?
- Brake Light Illuminates Randomly
- fuel problem
- 2000 Prelude cat on 96 Integra???
- quick help pls
- Stop/Horn(20A) Fuse keep blowing
- AEM EMS?
- ITR Rear section on DB7
- Neuspeed sports
- skunk 2 intake manifold
- Leaky passenger floor
- Gauge lights, plate lights, parking lights fuse keeps blowing...
- My new project.... G2 integra w/ b16
- power door locks
- auto-5spd swap how to and how hard?
- My distributorking.com distributor grenaded on me today...
