View Full Version : Acura Integra
- Racing Sports Akimoto SRI VS AEM CAI
- cd player question
- lowering your car the right way?
- Broken into DC4 on New Years Eve...way to go!!!!!
- need some help! CD Deck and Lighter dont get any power!
- Anyone seen the last race movie?
- how do 94-97 signal lights work?
- Looking to get a type R lip.........Can you only paint certain materials?
- 98 la check engine code 67 HELP
- how to turn off/reset check engine light?
- 97' b18c1- Intake Rattle
- 95 gsr w/ 2000 gsr suspension issues, replacing blown agx's with stockers
- need LS (P75) or LS/VTEC basemap HELP!
- Question about headlight
- Starter Compatability???
- Anyone have any luck with ebay turn signals?
- 94-99 GSR Anti-Rattle Clip/ Retainer Clip Part #.
- oil leak. need pointers
- Buddy Club Spec 2
- Power steering pump and belt replacement instructions?
- DIY: $5 AMBER Cluster
- 97-01 Integra bumpers
- ()()()()(SOMETHING IS WRONG WITH MY CLUTCH!!!)()()()()
- a noob question
- Cooling fan will not turn on... help!
- Blox Cams
- LS-Vtec Throwing code 6 and 10 upon switch of ECU
- GSR on a LS
- a short throw for integra or prelude?
- 5K Rpm Idle, while rolling, untill complete stop?
- 94 Acura, no oil on dipstick, oil light.
- trunk and drivers side window
- Stickied fs/wnt
- Maintenance Required Light !?!
- Buying '95 GSR Soon Need Help
- BAR QUESTION !!! ON A2
- ls wing?
- Tachometer ON DA help!
- valve adjustment question
- Need a price check on a stock 96 GSR steering wheel please.
- which wire means which on driver's airbag?
- spoon header, jun 2 camshaft, skunk 2 valve spring/retainer
- acura
- 92 to 94 coil over swap?
- INTEGRA SPUTTERS
- dashboard compatibility?? please help
- 91 teg my caster is all out of wack
- no start, there is fuel and spark.
- Bolt pattern 1990 Integra
- 94-95 fender vs 96-01 fender
- just installed short shifter and poly shifter bushings hows it supose to feel?
- noob ? here
- b18 firing order?
- **Heater is not working on my (Dc4)**
- jdm hid retrofit?
- 93 integra overheating???
- tow hook help
- im a noob
- Check engine light
- noobs question? gsr head
- Top fuel power chamber intake
- Apexi WS2 rust?
- 1996 Acura Integra LS Indicator light turned on
- koni GCs on illuminas?
- 90 integra speedo cable
- Mystery Problem for 1990 Acura Integra.... Please Help
- Registration...
- Any good shops in Pensacola, Florida
- gsr IM
- 96 DC4 (LS bodystyle) with ITR coil springs to lower for smooth ride????????
- OEM Mudguards Question.
- B20 into a DA integra?
- Question seeking Answers
- WTF!!? Water in mah cylinderz :P
- smoked a ford crustang
- DA bumper gaps won't go away!
- h22a automatic into an integra
- HYDROLOCK GG
- carpet help!!!!!!!!
- Need Help Quick Question
- Carfax Account?
- bruised paint? not sure what to call it..need help!
- NEED HELP
- car wont stay in 4th gear
- JDM 4door front?
- turbo for my b18b1
- Integra Jerks when shifting Auto trans, revs up to 2k at start up
- i need a quote from this place...help
- how do i make my HID's brighter?
- Ls/vtec Can i still do it ???
- Pending obd2 codes? How do I clear a pending code? Inspection TOMORROW!
- side mirror replacement
- Problem, which axle? teg b16
- Fidanza flywheel torque specs?
- just got short shifter what are the two small washers for?
- wiring
- car dies out of nowhere
- 2000 teg surging and CEL on. Stops when I uplug and replug TPS and IAC motor wires...??
- b16a quetion
- DOES ANYONE KNOW IF A TINT VIOLATION GOES ON THE INSURANCE?????????????
- question about turbo trim. im confused
- HELP! Pain in the Ass
- rebuild title
- stupid newb question
- LS Turbo? or keep it stock?
- Speedometer 5 MPH off - What in the world is causing this
- Overheated on the Interstate (part identification needed) Thanks
- Who runs K-Sport Kontrol Pro on their DA???
- Headlight adjustment
- Tips for installing OEM Paper Gasket - Intake Manifold
- Hot Acuras?
- Where do you guys get your OEM honda oil filters?
- 99 LS Motor in 95 GSR (OBDI to OBDII) question
- HELP! siR-G foglight bulb
- trailing arm bushing homebrew remover?
- Video of my crusing my Integra
- sanded down old faded lights and threw clear on them how do they look?
- Rear wiper plug
- Megan Header...Any Experience?
- 2.0 vtec turbo da9
- Exhaust????
- which fittings do I need for my catch can setup?
- is this worth it ?
- alternator problems
- CATBACK
- quick help.
- the plug for codes help???cant find it
- oem head gaskets
- Fuel Issue
- Where can i get my hands on a DA or a DC rolling chassis?
- turn signals wont stay in place
- spark plugs
- GOOD SHOPS IN SAN ANTONIO!!!
- gauge cluster help!!!
- DA with OBD2 ITR Swap.. NEED HELP PLEASE!
- my DA dies when ever i put the clutch in....
- need some help??
- abs?
- D.A problem
- bad gas mileage with 70mm skunk2 throttle body - HELP!!!
- another idle thread...
- 4 door integra build
- ecu code
- JDM XSi in DA
- Car wants to die with people in car
- body shop work? estimate?
- Bosal performance exhaust
- 94-01 axles fit 90-93 integra
- yes another exhaust question.
- JDM front w/ hid retain a/c?
- DC Sports 4-1 Header hits oil pan
- b18b1 water pump timing belt tensioner on b18a1
- HELP PLEASE!!!! HEATER??????
- i was wondering how much my rims are going for.
- 2nd gen service manual?
- b17
- btw... What u guys think about the HKS hi power exhaust on a Ls motor? im kinda new... trying to get
- How much will it cost to paint a Type R spoiler and Lip?
- b18b into 98 gsr, got cel code 54
- what steering wheel is this?
- Universal mufflers
- Test pipe
- kteller rear subframe bar
- rotors
- automatic to manual on 91 integra
- aftermarket motor mounts for da
- JDM B16A into integra LS help!
- What exhaust will pass smog??
- how much should i sell my GSR for??
- CEL 14
- head gasket question?? 81.5??
- locking lug nuts
- car suddenly stop need help!!
- Can Oil Pressure Switch do damage?
- Wilwood brakes from a civic on Integra?
- tein tophats`
- Need help identifying plug
- gsr into 93 da
- ABS light came on, help?
- da throwing code need help
- oil light on
- Help on rebuilding my b18c1
- Need ADVISE please!!!!!
- Car wont start need guru help
- Cut wires under my dash and what I believe is a security system...
- How much should I sell my GSR for
- Need help finding shifter bushings.
- Oil 'Disappering' ??
- Turbo LS
- help me!!!!!!! p72-1
- GSR and H22 HELP!
- steering rack is humming, can anything be done besides replacing the rack?
- intake...
- throttle body q!!
- Ebay Headers...
- h22 b20
- Original Decals
- NEED help Dash info
- door panel inserts question
- Does the stock CD player have any extra inputs?
- antenna won't go up
- 4dr exhaust question
- Alright... So I've read ALLLL about headers... but now what?
- Power Window Issue
- trouble passing inspection.....
- 93 acura integra blower resistor
- 94 engine
- b20b started boggin out at low speeds
- Anyone ever try 80w low beams? any harness issues?
- type r internals in ls block
- tranny parts question
- clucth scrape?
- Ls vtec integral with type-r pistons???
- How much would it cost for a complete spoon spec dc o.O
- manual steering?
- mugen
- Help me identify this part!
- GSR vs ITR crank. what is the difference if any?
- Running Lights/Dashlight fuse keeps breaking
- Axles??? ABS or non-ABS
- Removed/Reinstalled Distributor from working car, now won't start
- 91 integra pass. window placement??
- EG steering wheel in 92 integra?
- Got rear-ended last night.
- What cai / sri for Edelbrock Victor X / Performer X on a GSR B18C1?
- BUILD THREAD: For Mfoehrkolb
- Prelude Steering Wheel on DC2?
- b16 auto trans
- Looking for an Automatic B series transmission for an b20 swap...
- Since everyone else has one...
- temp gauge?
- Anyone know where to get those defrost button bulbs cheap?
- 93Ls Vs 94 GS-R
- New O2 sensor = check engine light
- fender bender, need some insurance advice
- 91 Integra Looped PS Rack question
- How to make more HP on a first gen????
- 1989 Integra Alternator EASY REMOVAL DISCOVERED!!!!!
- How to NOT be Ghetto
- Some sort of Water Leak on Passenger side? Need Help
- Well this just sucks
- Buddy Club Spec 2? Owners, give me your opinion
- HID headlights
- Valve stem/guide seals -- color of spring?
- gauge cluster problem????
- how to torque pulley bolt?
- driver side lower motor mount thread pattern??..
- obd1 dizzy b16 head ls vtec
- been sitting for a while
